[geos-commits] [SCM] GEOS branch 3.11 updated. 98b53e76f2b0c9d691dfadcac71670af69daf435
git at osgeo.org
git at osgeo.org
Tue Jun 27 09:22:36 PDT 2023
the project "GEOS".
The branch, 3.11 has been updated
via 98b53e76f2b0c9d691dfadcac71670af69daf435 (commit)
from 462f5c969f31a7ed99c9a81c31cc26deea4b32f5 (commit)
revisions in full, below.
commit 98b53e76f2b0c9d691dfadcac71670af69daf435
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 27 09:22:13 2023 -0700
remove web from stable branch
diff --git a/web/content/specifications/geojson.md b/web/content/specifications/geojson.md
deleted file mode 100644
index fb3cee7de..000000000
--- a/web/content/specifications/geojson.md
+++ /dev/null
@@ -1,99 +0,0 @@
-title: "GeoJSON"
-date: 2021-10-04T14:18:42-07:00
-draft: false
-"GeoJSON" is a standard for structuring JSON when encoding geometry and features. By using GeoJSON, rather than some other arbitrary scheme for structuring JSON, you maximize the interoperability of your JSON output. There are dozens of tools and [websites](http://geojson.io) that happily consume and emit GeoJSON.
-The GeoJSON standard is formally maintained by the IETF as "[RFC 7946](https://datatracker.ietf.org/doc/html/rfc7946)".
-Unlike [WKB]({{< ref "wkb" >}}) and [WKT]({{< ref "wkt" >}}), GeoJSON does not restrict itself to just geometry representation. It also standardizes the transport of attribution. The three key levels of GeoJSON are:
-* [Geometry](https://datatracker.ietf.org/doc/html/rfc7946#section-3.1), representation of Points, LineStrings, Polygons, etc.
-* [Feature](https://datatracker.ietf.org/doc/html/rfc7946#section-3.2), representation of an object that has a "geometry" and an arbitrary set of other non-geometric "properties".
-* [FeatureCollection](https://datatracker.ietf.org/doc/html/rfc7946#section-3.3), representation of a list of Features.
-Since GEOS is almost 100% concerned with geometry operations, there is no GEOS abstraction to translate the non-geometric properties of GeoJSON Feature into, so handling of Feature properties is only available via the C++ [GeoJSON.h](https://github.com/libgeos/geos/blob/main/include/geos/io/GeoJSON.h) utilities.
-### Writing GeoJSON
-The GeoJSON writer, in both the C and C++ APIs, only supports writing out the Geometry portion of GeoJSON. So for writing features, the writer will end up embedded in some larger JSON emitter.
-```c
-/* Read a linestring */
-const char* linestring = "LINESTRING(0 0 1, 1 1 1, 2 1 2)";
-GEOSWKTReader* reader = GEOSWKTReader_create();
-GEOSGeom* geom = GEOSWKTReader_read(reader, linestring);
-/* Write it out as GeoJSON */
-GEOSGeoJSONWriter* writer = GEOSGeoJSONWriter_create();
-/* Generate the JSON, with an indentation of 2 */
-int indentation = 2;
-unsigned char* json = GEOSGeoJSONWriter_writeGeometry(writer, geom, indentation);
-/* do something ... */
-/* Free the WKB */
-GEOSFree(json);
-GEOSGeom_destroy(geom);
-GEOSGeoJSONWriter_destroy(writer);
-GEOSWKTReader_destroy(reader);
-### Reading GeoJSON
-The C++ GeoJSON reader does include the option to read full `Feature` and `FeatureCollection` objects, with a narrow API for reading the resulting objects.
-```c++
-#include <geos/io/GeoJSON.h> // GeoJSONFeatureCollection, etc
-#include <geos/io/GeoJSONReader.h>
-#include <geos/io/WKTWriter.h>
-#include <geos/geom/Geometry.h>
-using namespace geos::io;
-using namespace geos::geom;
-void main(void)
- // Read file into string
- std::ifstream ifs("geojson.json");
- std::string content((std::istreambuf_iterator<char>(ifs) ),
- (std::istreambuf_iterator<char>() ));
- // Parse GeoJSON string into GeoJSON objects
- GeoJSONReader reader;
- GeoJSONFeatureCollection fc = reader.readFeatures(content);
- // Prepare WKT writer
- WKTWriter writer;
- writer.setTrim(true);
- writer.setRoundingPrecision(2);
- // Print out the features
- for (auto& feature: fc) {
- // Read the geometry
- const Geometry* geom = feature.getGeometry();
- // Read the properties
- std::map<std::string, GeoJSONValue>& props = feature.getProperties();
- // Write all properties
- std::cout << "----------" << std::endl;
- for (const auto& prop : props) {
- std::cout << prop.first << ": " << prop.second << std::endl;
- // Write WKT feometry
- std::cout << "geometry: " << writer.write(geom) << std::endl;
Summary of changes:
web/content/specifications/geojson.md | 99 -----------------------------------
1 file changed, 99 deletions(-)
delete mode 100644 web/content/specifications/geojson.md
hooks/post-receive
More information about the geos-commits
