[geos-commits] [SCM] GEOS branch main updated. 54177f2da3d9b8f2903b1a6ed5f7837fda68aabc
git at osgeo.org
git at osgeo.org
Tue Jun 27 11:29:21 PDT 2023
the project "GEOS".
The branch, main has been updated
via 54177f2da3d9b8f2903b1a6ed5f7837fda68aabc (commit)
from 95b160126e8d7173cdc424999495c75953c093c1 (commit)
revisions in full, below.
commit 54177f2da3d9b8f2903b1a6ed5f7837fda68aabc
Author: Max Gabrielsson <max at gabrielsson.com>
Date: Tue Jun 27 20:28:59 2023 +0200
Expose geos ryu fork (#919)
Makes ryu number formatting accessible to c clients.
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 04e6c4fd3..d1f820d19 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1443,6 +1443,11 @@ extern "C" {
GEOSWKBWriter_setIncludeSRID_r(handle, writer, newIncludeSRID);
+ int
+ GEOS_printDouble(double d, unsigned int precision, char *result) {
+ return WKTWriter::writeTrimmedNumber(d, precision, result);
/* GeoJSON Reader */
GeoJSONReader*
GEOSGeoJSONReader_create()
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 210fd014e..781ff7c13 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1898,6 +1898,19 @@ extern void GEOS_DLL GEOSWKTWriter_setOld3D_r(
GEOSWKTWriter *writer,
int useOld3D);
+/** Print the shortest representation of a double using fixed notation.
+ * Only works for numbers smaller than 1e17 (absolute value).
+ * \param d The number to format.
+ * \param precision The desired precision. (max digits after decimal point)
+ * \param result The buffer to write the result to.
+ * \return the length of the written string.
+extern int GEOS_DLL GEOS_printDouble(
+ double d,
+ unsigned int precision,
+ char *result
/* ========== WKB Reader ========== */
/** \see GEOSWKBReader_create */
diff --git a/include/geos/io/WKTWriter.h b/include/geos/io/WKTWriter.h
index 09f6184ef..a37973a87 100644
--- a/include/geos/io/WKTWriter.h
+++ b/include/geos/io/WKTWriter.h
@@ -195,6 +195,9 @@ public:
void setOutputDimension(uint8_t newOutputDimension);
+ static std::string writeNumber(double d, bool trim, uint32_t precision);
+ static int writeTrimmedNumber(double d, uint32_t precision, char* buf);
protected:
int decimalPlaces;
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 77d4b20dc..def315a44 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -404,18 +404,21 @@ WKTWriter::appendSequenceText(const CoordinateSequence& seq,
-/* protected */
-std::string
-WKTWriter::writeNumber(double d) const
+int
+WKTWriter::writeTrimmedNumber(double d, uint32_t precision, char* buf)
- uint32_t precision = decimalPlaces >= 0 ? static_cast<std::uint32_t>(decimalPlaces) : 0;
+ return geos_d2sfixed_buffered_n(d, precision, buf);
+std::string
+WKTWriter::writeNumber(double d, bool trim, uint32_t precision) {
* For a "trimmed" result, with no trailing zeros we use
* the ryu library.
if (trim) {
char buf[128];
- int len = geos_d2sfixed_buffered_n(d, precision, buf);
+ int len = writeTrimmedNumber(d, precision, buf);
buf[len] = '\0';
std::string s(buf);
return s;
@@ -433,6 +436,14 @@ WKTWriter::writeNumber(double d) const
+/* protected */
+std::string
+WKTWriter::writeNumber(double d) const
+ uint32_t precision = decimalPlaces >= 0 ? static_cast<std::uint32_t>(decimalPlaces) : 0;
+ return writeNumber(d, trim, precision);
void
WKTWriter::appendLineStringText(const LineString& lineString, OrdinateSet outputOrdinates, int p_level,
bool doIndent, Writer& writer) const
Summary of changes:
capi/geos_c.cpp | 5 +++++
capi/geos_c.h.in | 13 +++++++++++++
include/geos/io/WKTWriter.h | 3 +++
src/io/WKTWriter.cpp | 21 ++++++++++++++++-----
4 files changed, 37 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
