[geos-commits] [SCM] GEOS branch main updated. 29b8f8e55bcce33992d64d9e1231dbb833268034
git at osgeo.org
git at osgeo.org
Wed Jun 28 18:57:19 PDT 2023
the project "GEOS".
The branch, main has been updated
via 29b8f8e55bcce33992d64d9e1231dbb833268034 (commit)
from 702973e45a2e29d6808e5fd0bc282485739b5d7d (commit)
revisions in full, below.
commit 29b8f8e55bcce33992d64d9e1231dbb833268034
Author: Regina Obe <lr at pcorp.us>
Date: Wed Jun 28 21:52:23 2023 -0400
Hopefully fixes gitlab make distcheck
- take out /.*build.*/
- add back /.*build-.*/
diff --git a/CMakeLists.txt b/CMakeLists.txt
index e0a09e56f..c64f5a375 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -168,13 +168,13 @@ message(STATUS "GEOS: Archives output: ${CMAKE_LIBRARY_OUTPUT_DIRECTORY}")
# -D CMAKE_CXX_COMPILER=/opt/local/bin/clang-mp-15++ \
# -D CMAKE_BUILD_TYPE=ASAN
-# To suppress reporting on leaks in MacOS itself (yes, really),
-# add a suppression file to your build directory.
+# To suppress reporting on leaks in MacOS itself (yes, really),
+# add a suppression file to your build directory.
# echo leak:realizeClassWithoutSwift >> lsan.supp
# Now run the program with env vars set to turn on leak checking and suppression.
# MallocNanoZone=0 \
# ASAN_OPTIONS=detect_leaks=1 \
# LSAN_OPTIONS=suppressions=lsan.supp \
@@ -457,7 +457,8 @@ if(PROJECT_IS_TOP_LEVEL)
set(CPACK_VERBATIM_VARIABLES TRUE)
set(CPACK_SOURCE_IGNORE_FILES
/\\..* # any file/directory starting with .
- /.*build.*/
+ /.*build-.*/
+ #/.*build.*/ #taken out because breaks gitlab make distcheck
/autogen\\.sh
/autom4te\\.cache
/bin/
Summary of changes:
CMakeLists.txt | 9 +++++----
1 file changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
