[geos-commits] [SCM] GEOS branch main-relate-ng updated. 80d4b85012032f4891d710ef43f1dfd30baceb11
git at osgeo.org
git at osgeo.org
Thu Aug 1 16:26:02 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
via 80d4b85012032f4891d710ef43f1dfd30baceb11 (commit)
from aefc338ce9b60c6cff52b2bb7b2cb3a17cc31dde (commit)
revisions in full, below.
commit 80d4b85012032f4891d710ef43f1dfd30baceb11
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Aug 1 16:25:33 2024 -0700
Change to using dimA param names
diff --git a/include/geos/operation/relateng/RelatePredicate.h b/include/geos/operation/relateng/RelatePredicate.h
index 00e6926bd..4fc972d85 100644
--- a/include/geos/operation/relateng/RelatePredicate.h
+++ b/include/geos/operation/relateng/RelatePredicate.h
@@ -190,9 +190,9 @@ class ContainsPredicate : public IMPredicate {
return isSourceA == RelateGeometry::GEOM_B;
- void init(int dA, int dB) override {
- IMPredicate::init(dA, dB);
- require(isDimsCompatibleWithCovers(dA, dB));
+ void init(int dimA, int dimB) override {
+ IMPredicate::init(dimA, dimB);
+ require(isDimsCompatibleWithCovers(dimA, dimB));
void init(const Envelope& envA, const Envelope& envB) override {
@@ -230,7 +230,7 @@ static std::unique_ptr<IMPredicate> contains();
* the points in the boundary of a geometry B, within(B, A) = false
* (As a concrete example, take A to be a LineString which lies in the boundary of a Polygon B.)
* For a predicate with similar behavior but avoiding
- * this subtle limitation, see coveredBy().
+ * this subtle limitation, see coveredimBy().
* @return the predicate instance
@@ -251,9 +251,9 @@ class WithinPredicate : public IMPredicate {
return isSourceA == RelateGeometry::GEOM_A;
- require(isDimsCompatibleWithCovers(dB, dA));
+ require(isDimsCompatibleWithCovers(dimB, dimA));
@@ -287,8 +287,8 @@ static std::unique_ptr<IMPredicate> within();
* * [***T**FF*]
* * [****T*FF*]
- * coveredBy(b, a) = true
- * (covers is the converse of coveredBy())
+ * coveredimBy(b, a) = true
+ * (covers is the converse of coveredimBy())
* If either geometry is empty, the value of this predicate is false.
@@ -302,7 +302,7 @@ static std::unique_ptr<IMPredicate> within();
- * @see #coveredBy()
+ * @see #coveredimBy()
class CoversPredicate : public IMPredicate {
@@ -319,9 +319,9 @@ class CoversPredicate : public IMPredicate {
@@ -345,7 +345,7 @@ static std::unique_ptr<IMPredicate> covers();
* Creates a predicate to determine whether a geometry is covered
* by another geometry.
-* The coveredBy predicate has the following equivalent definitions:
+* The coveredimBy predicate has the following equivalent definitions:
* Every point of this geometry is a point of the other geometry.
* The DE-9IM Intersection Matrix for the two geometries matches
@@ -357,7 +357,7 @@ static std::unique_ptr<IMPredicate> covers();
* [**F*TF***]
* covers(B, A) = true
-* (coveredBy is the converse of covers())
+* (coveredimBy is the converse of covers())
@@ -383,9 +383,9 @@ class CoveredByPredicate : public IMPredicate {
@@ -434,11 +434,11 @@ class CrossesPredicate : public IMPredicate {
return std::string("crosses");
bool isBothPointsOrAreas =
- (dA == Dimension::P && dB == Dimension::P) ||
- (dA == Dimension::A && dB == Dimension::A);
+ (dimA == Dimension::P && dimB == Dimension::P) ||
+ (dimA == Dimension::A && dimB == Dimension::A);
require(!isBothPointsOrAreas);
@@ -490,9 +490,9 @@ class EqualsTopoPredicate : public IMPredicate {
return std::string("equals");
- require(dA == dB);
+ require(dimA == dimB);
@@ -543,9 +543,9 @@ class OverlapsPredicate : public IMPredicate {
return std::string("overlaps");
bool isDetermined() const override {
@@ -602,9 +602,9 @@ class TouchesPredicate : public IMPredicate {
return std::string("touches");
- bool isBothPoints = (dA == 0 && dB == 0);
+ bool isBothPoints = (dimA == 0 && dimB == 0);
require(! isBothPoints);
Summary of changes:
include/geos/operation/relateng/RelatePredicate.h | 62 +++++++++++------------
1 file changed, 31 insertions(+), 31 deletions(-)
hooks/post-receive
More information about the geos-commits
