[geos-commits] [SCM] GEOS branch main-relate-ng updated. 1ef8669c6de05af62be0bf99fd31530599739b37
git at osgeo.org
git at osgeo.org
Fri Aug 2 07:35:29 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
via 1ef8669c6de05af62be0bf99fd31530599739b37 (commit)
from 929c5f20e9e50f25bf63e86e7c88723479769560 (commit)
revisions in full, below.
commit 1ef8669c6de05af62be0bf99fd31530599739b37
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Aug 2 07:35:02 2024 -0700
Fix some unit test errors
diff --git a/src/operation/relateng/RelateNG.cpp b/src/operation/relateng/RelateNG.cpp
index 6b7a83f67..d4b8baea5 100644
--- a/src/operation/relateng/RelateNG.cpp
+++ b/src/operation/relateng/RelateNG.cpp
@@ -146,6 +146,9 @@ RelateNG::evaluate(const Geometry* b, TopologyPredicate& predicate)
return false;
+ util::ensureNoCurvedComponents(geomA.getGeometry());
+ util::ensureNoCurvedComponents(b);
RelateGeometry geomB(b, boundaryNodeRule);
if (geomA.isEmpty() && geomB.isEmpty()) {
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index 4ee90cea5..56d852ccc 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -406,6 +406,7 @@ void object::test<13>
// Verify no memory leak on exception (https://github.com/libgeos/geos/issues/505)
+// RelateNG does not throw for this case
template<>
template<>
void object::test<14>
@@ -419,7 +420,7 @@ void object::test<14>
ensure(nullptr != geom2_);
int ret = GEOSPreparedTouches(prepGeom1_, geom2_);
- ensure_equals(ret, 2);
+ ensure_equals(ret, 1);
// Test XY variants
diff --git a/tests/unit/capi/GEOSRelatePatternTest.cpp b/tests/unit/capi/GEOSRelatePatternTest.cpp
index 819e6ad79..cfd1bfe19 100644
--- a/tests/unit/capi/GEOSRelatePatternTest.cpp
+++ b/tests/unit/capi/GEOSRelatePatternTest.cpp
@@ -27,8 +27,8 @@ void object::test<1>()
geom3_ = GEOSBuffer(geom2_, 2, 8);
ensure(nullptr != geom3_);
- ensure_equals(1, GEOSRelatePattern(geom1_, geom3_, "0FFFFF212"));
- ensure_equals(1, GEOSRelatePattern(geom1_, geom3_, "*FF*FF212"));
+ ensure_equals(GEOSRelatePattern(geom1_, geom3_, "0FFFFF212"), 1);
+ ensure_equals(GEOSRelatePattern(geom1_, geom3_, "*FF*FF212"), 1);
template<>
@@ -57,13 +57,13 @@ void object::test<3>()
ensure(geom2_);
// pattern too long
- ensure_equals(2, GEOSRelatePattern(geom1_, geom2_, "0FFFFF2120000000000000000000"));
+ ensure_equals(GEOSRelatePattern(geom1_, geom2_, "0FFFFF2120000000000000000000"), 2);
// pattern too short
- ensure_equals(2, GEOSRelatePattern(geom1_, geom2_, "0F"));
+ ensure_equals(GEOSRelatePattern(geom1_, geom2_, "0F"), 2);
// pattern has invalid characters
- ensure_equals(0, GEOSRelatePattern(geom1_, geom2_, "123456789"));
+ ensure_equals(GEOSRelatePattern(geom1_, geom2_, "123456789"), 2);
} // namespace tut
Summary of changes:
src/operation/relateng/RelateNG.cpp | 3 +++
tests/unit/capi/GEOSPreparedGeometryTest.cpp | 3 ++-
tests/unit/capi/GEOSRelatePatternTest.cpp | 10 +++++-----
3 files changed, 10 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
