[geos-commits] [SCM] GEOS branch main-relate-ng updated. b61bdcefa6abd2632ca68180b140b8aa36d4e99a
Tue Aug 6 11:50:25 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
       via  b61bdcefa6abd2632ca68180b140b8aa36d4e99a (commit)
      from  0983ab4027ce6e696d56bea89e8cdcea73315f99 (commit)
revisions in full, below.
commit b61bdcefa6abd2632ca68180b140b8aa36d4e99a
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Aug 6 11:50:06 2024 -0700
    Fix CSV header for PreparedPolygonIntersectsPerfTest
diff --git a/benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp b/benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp
index 04fa95c84..045e70e6a 100644
--- a/benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp
+++ b/benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp
@@ -111,7 +111,7 @@ void test (std::size_t npts) {
 int main() {
-    std::cout << "target_points,num_tests,num_hits,test_type,pts_in_test,method,time" << std::endl;
+    std::cout << "target_points,num_tests,num_hits,test_type,pts_in_test,method,time,factor" << std::endl;
     test(5);
     test(10);
     test(500);
Summary of changes:
 benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
