[geos-commits] [SCM] GEOS branch main-relate-ng updated. 5b160a0354e49e56d23acbc755a46a69dabdbe76
git at osgeo.org
git at osgeo.org
Wed Aug 7 08:38:53 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
via 5b160a0354e49e56d23acbc755a46a69dabdbe76 (commit)
from 9c8b1f05712a54979879a46107fa23c87d8facb9 (commit)
revisions in full, below.
commit 5b160a0354e49e56d23acbc755a46a69dabdbe76
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Aug 7 08:38:29 2024 -0700
Add contains option to perf test
diff --git a/benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp b/benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp
index f04583831..f66ee0d10 100644
--- a/benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp
+++ b/benchmarks/geom/PreparedPolygonIntersectsPerfTest.cpp
@@ -1,3 +1,9 @@
+ * Performance tests for spatial predicates
+ * Usage: perf_prepared_polygon_intersects [ intersects | contains ]
#include <geos/geom/util/SineStarFactory.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/profiler.h>
@@ -16,52 +22,83 @@ std::size_t MAX_ITER = 10;
std::size_t NUM_LINES = 10000;
std::size_t NUM_LINES_PTS = 100;
+#define INTERSECTS 0
+#define CONTAINS 1
-int testRelateOp(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& lines) {
+int predicateOp = INTERSECTS;
+int testRelateOpIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
- for (const auto& line : lines) {
- auto im = g.relate(line.get());
+ for (const auto& geom : geoms) {
+ auto im = g.relate(geom.get());
count += im->isIntersects();
return count;
-int testGeometryIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& lines) {
+int testRelateOpContains(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
- count += g.intersects(line.get());
+ count += im->isContains();
return count;
-int testGeometryContains(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& lines) {
+int testGeometryIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
- count += g.contains(line.get());
+ count += g.intersects(geom.get());
return count;
-int testPrepGeomCached(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& lines) {
+int testGeometryContains(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ count += g.contains(geom.get());
+ return count;
+int testPrepGeomIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
auto prep = prep::PreparedGeometryFactory::prepare(&g);
- count += prep->intersects(line.get());
+ count += prep->intersects(geom.get());
return count;
-int testRelateNGPreparedCached(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& lines) {
+int testPrepGeomContains(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ auto prep = prep::PreparedGeometryFactory::prepare(&g);
+ count += prep->contains(geom.get());
+ return count;
+int testRelateNGPreparedIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
auto prep = geos::operation::relateng::RelateNG::prepare(&g);
+ for (const auto& line : geoms) {
count += prep->evaluate(line.get(), *geos::operation::relateng::RelatePredicate::intersects());
return count;
+int testRelateNGPreparedContains(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ auto prep = geos::operation::relateng::RelateNG::prepare(&g);
+ count += prep->evaluate(line.get(), *geos::operation::relateng::RelatePredicate::contains());
+ return count;
template<typename F>
-double test(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms, const std::string& method, F&& fun, double base)
+double test(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms, const std::string& method, F&& fun, double baseTime)
geos::util::Profile sw("PreparedPolygonIntersects");
sw.start();
@@ -73,7 +110,7 @@ double test(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geo
sw.stop();
double tot = sw.getTot();
- double timesFaster = base == 0 ? 1 : base / tot;
+ double timesFaster = baseTime == 0 ? 1 : baseTime / tot;
std::cout << std::fixed << std::setprecision(0);
std::cout << g.getNumPoints() << ","
<< MAX_ITER * geoms.size() << ","
@@ -86,38 +123,60 @@ double test(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geo
return tot;
-void test (std::size_t npts) {
+void test(int dim, std::size_t npts) {
auto target = geos::benchmark::createSineStar({0, 0}, 100, npts);
- auto polygons = geos::benchmark::createPolygons(*target->getEnvelopeInternal(), NUM_LINES, 1.0, NUM_LINES_PTS);
- auto lines = geos::benchmark::createLines(*target->getEnvelopeInternal(), NUM_LINES, 1.0, NUM_LINES_PTS);
- auto points = geos::benchmark::createPoints(*target->getEnvelopeInternal(), NUM_LINES);
- double base;
- base = test(*target, polygons, "RelateOp", testRelateOp, 0);
- test(*target, polygons, "Geometry::intersects", testGeometryIntersects, base);
- test(*target, polygons, "PrepGeomCached", testPrepGeomCached, base);
- test(*target, polygons, "RelateNGPreparedCached", testRelateNGPreparedCached, base);
- base = test(*target, lines, "RelateOp", testRelateOp, 0);
- test(*target, lines, "Geometry::intersects", testGeometryIntersects, base);
- test(*target, lines, "PrepGeomCached", testPrepGeomCached, base);
- test(*target, lines, "RelateNGPreparedCached", testRelateNGPreparedCached, base);
- base = test(*target, points, "RelateOp", testRelateOp, 0);
- test(*target, points, "Geometry::intersects", testGeometryIntersects, base);
- test(*target, points, "PrepGeomCached", testPrepGeomCached, base);
- test(*target, points, "RelateNGPreparedCached", testRelateNGPreparedCached, base);
+ std::vector<std::unique_ptr<Geometry>> geoms;
+ switch (dim) {
+ case 0:
+ geoms = geos::benchmark::createPoints(*target->getEnvelopeInternal(), NUM_LINES);
+ break;
+ case 1:
+ geoms = geos::benchmark::createLines(*target->getEnvelopeInternal(), NUM_LINES, 1.0, NUM_LINES_PTS);
+ break;
+ case 2:
+ geoms = geos::benchmark::createPolygons(*target->getEnvelopeInternal(), NUM_LINES, 1.0, NUM_LINES_PTS);
+ break;
+ double baseTime;
+ switch (predicateOp) {
+ case INTERSECTS:
+ baseTime = test(*target, geoms, "RelateOp intersects", testRelateOpIntersects, 0);
+ test(*target, geoms, "Geometry::intersects", testGeometryIntersects, baseTime);
+ test(*target, geoms, "PreparedGeom", testPrepGeomIntersects, baseTime);
+ test(*target, geoms, "RelateNGPrepared", testRelateNGPreparedIntersects, baseTime);
+ break;
+ case CONTAINS:
+ baseTime = test(*target, geoms, "RelateOp contains", testRelateOpIntersects, 0);
+ test(*target, geoms, "Geometry::contains", testGeometryIntersects, baseTime);
+ test(*target, geoms, "PreparedGeom contains", testPrepGeomContains, baseTime);
+ test(*target, geoms, "RelateNGPrepared contains", testRelateNGPreparedContains, baseTime);
-int main() {
+void testAll(int dim)
+ test(dim, 5);
+ test(dim, 10);
+ test(dim, 500);
+ test(dim, 1000);
+ test(dim, 2000);
+ test(dim, 4000);
+ test(dim, 8000);
+ test(dim, 16000);
+int main(int argc, char** argv) {
+ predicateOp = INTERSECTS;
+ if (argc >= 2) {
+ std::string op{argv[1]};
+ if (op == "contains") {
+ predicateOp = CONTAINS;
std::cout << "target_points,num_tests,num_hits,test_type,pts_in_test,method,time,factor" << std::endl;
- test(5);
- test(10);
- test(500);
- test(1000);
- test(2000);
- test(4000);
- test(8000);
- test(16000);
+ testAll(0);
+ testAll(1);
+ testAll(2);
Summary of changes:
.../geom/PreparedPolygonIntersectsPerfTest.cpp | 149 ++++++++++++++-------
1 file changed, 104 insertions(+), 45 deletions(-)
hooks/post-receive
More information about the geos-commits
