[geos-commits] [SCM] GEOS branch main-relate-ng updated. 01c8fbc2b782f94e800e77805d72fa79ec672b7b
git at osgeo.org
git at osgeo.org
Thu Aug 8 07:57:07 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
via 01c8fbc2b782f94e800e77805d72fa79ec672b7b (commit)
from 43ac48e54737af05cedf380765ea5b68534464ce (commit)
revisions in full, below.
commit 01c8fbc2b782f94e800e77805d72fa79ec672b7b
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Aug 8 07:56:41 2024 -0700
Fix handling of LinearRings
diff --git a/include/geos/operation/relateng/DimensionLocation.h b/include/geos/operation/relateng/DimensionLocation.h
index e0e77b52b..6d3d87050 100644
--- a/include/geos/operation/relateng/DimensionLocation.h
+++ b/include/geos/operation/relateng/DimensionLocation.h
@@ -32,7 +32,7 @@ class GEOS_DLL DimensionLocation {
public:
enum DimensionLocationType {
- EXTERIOR = -3,
+ EXTERIOR = 2, // == Location.EXTERIOR
POINT_INTERIOR = 103,
LINE_INTERIOR = 110,
LINE_BOUNDARY = 111,
diff --git a/src/operation/relateng/RelateGeometry.cpp b/src/operation/relateng/RelateGeometry.cpp
index e07c3f602..6c5cb6c78 100644
--- a/src/operation/relateng/RelateGeometry.cpp
+++ b/src/operation/relateng/RelateGeometry.cpp
@@ -84,7 +84,7 @@ RelateGeometry::analyzeDimensions()
geomDim = Dimension::P;
return;
- if (typeId == GEOS_LINESTRING || typeId == GEOS_MULTILINESTRING) {
+ if (typeId == GEOS_LINESTRING || typeId == GEOS_LINEARRING || typeId == GEOS_MULTILINESTRING) {
hasLines = true;
geomDim = Dimension::L;
return;
@@ -105,7 +105,8 @@ RelateGeometry::analyzeDimensions()
hasPoints = true;
if (geomDim < Dimension::P) geomDim = Dimension::P;
- if (elem->getGeometryTypeId() == GEOS_LINESTRING) {
+ if (elem->getGeometryTypeId() == GEOS_LINESTRING ||
+ elem->getGeometryTypeId() == GEOS_LINEARRING) {
hasLines = true;
if (geomDim < Dimension::L) geomDim = Dimension::L;
@@ -124,7 +125,8 @@ RelateGeometry::isZeroLength(const Geometry* geom)
std::vector<const Geometry*> elems;
GeometryLister::list(geom, elems);
for (const Geometry* elem : elems) {
+ elem->getGeometryTypeId() == GEOS_LINEARRING ) {
if (! isZeroLength(static_cast<const LineString*>(elem))) {
return false;
@@ -408,7 +410,8 @@ RelateGeometry::extractSegmentStringsFromAtomic(bool isA,
return;
elementId++;
- if (p_geom->getGeometryTypeId() == GEOS_LINESTRING) {
+ if (p_geom->getGeometryTypeId() == GEOS_LINESTRING ||
+ p_geom->getGeometryTypeId() == GEOS_LINEARRING) {
const LineString* line = static_cast<const LineString*>(p_geom);
* Condition the input Coordinate sequence so that it has no repeated points.
diff --git a/src/operation/relateng/RelateNG.cpp b/src/operation/relateng/RelateNG.cpp
index 90eacd40e..681c58ee3 100644
--- a/src/operation/relateng/RelateNG.cpp
+++ b/src/operation/relateng/RelateNG.cpp
@@ -430,7 +430,8 @@ RelateNG::computeLineEnds(
if (elem->isEmpty())
continue;
//-- once an intersection with target exterior is recorded, skip further known-exterior points
if (hasExteriorIntersection
&& elem->getEnvelopeInternal()->disjoint(geomTarget.getEnvelope()))
diff --git a/src/operation/relateng/RelatePointLocator.cpp b/src/operation/relateng/RelatePointLocator.cpp
index aa29b374e..cca69d8ec 100644
--- a/src/operation/relateng/RelatePointLocator.cpp
+++ b/src/operation/relateng/RelatePointLocator.cpp
@@ -81,7 +81,8 @@ RelatePointLocator::extractElements(const Geometry* p_geom)
if (p_geom->getGeometryTypeId() == GEOS_POINT) {
addPoint(static_cast<const Point*>(p_geom));
- else if (p_geom->getGeometryTypeId() == GEOS_LINESTRING) {
+ else if (p_geom->getGeometryTypeId() == GEOS_LINESTRING ||
addLine(static_cast<const LineString*>(p_geom));
else if (p_geom->getGeometryTypeId() == GEOS_POLYGON ||
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 78dd304ea..af6ce0550 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -154,15 +154,23 @@ TopologyComputer::isExteriorCheckRequired(bool isA) const
return predicate.requireExteriorCheck(isA);
+char toSymbol(Location loc) {
+ switch (loc) {
+ case Location::NONE: return '-';
+ case Location::INTERIOR: return 'I';
+ case Location::BOUNDARY: return 'B';
+ case Location::EXTERIOR: return 'E';
/* private */
void
TopologyComputer::updateDim(Location locA, Location locB, int dimension)
+//std::cout << toSymbol(locA) << toSymbol(locB) << " <- " << dimension << std::endl;
predicate.updateDimension(locA, locB, dimension);
/* private */
void
TopologyComputer::updateDim(bool isAB, Location loc1, Location loc2, int dimension)
Summary of changes:
include/geos/operation/relateng/DimensionLocation.h | 2 +-
src/operation/relateng/RelateGeometry.cpp | 11 +++++++----
src/operation/relateng/RelateNG.cpp | 3 ++-
src/operation/relateng/RelatePointLocator.cpp | 3 ++-
src/operation/relateng/TopologyComputer.cpp | 10 +++++++++-
5 files changed, 21 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
