[geos-commits] [SCM] GEOS branch main-relate-ng updated. 5746c2afa30767843421ae661df5b45b6403f8f9
git at osgeo.org
git at osgeo.org
Thu Aug 8 12:49:34 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
via 5746c2afa30767843421ae661df5b45b6403f8f9 (commit)
from 8aae1cf6c1f3edc0076edb6fcba14f7dff898f22 (commit)
revisions in full, below.
commit 5746c2afa30767843421ae661df5b45b6403f8f9
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Aug 8 12:49:15 2024 -0700
Add touches to TopoPredicatePerfTest
diff --git a/benchmarks/geom/TopologyPredicatePerfTest.cpp b/benchmarks/geom/TopologyPredicatePerfTest.cpp
index 4af663769..571bcbc70 100644
--- a/benchmarks/geom/TopologyPredicatePerfTest.cpp
+++ b/benchmarks/geom/TopologyPredicatePerfTest.cpp
@@ -1,7 +1,7 @@
- * Performance tests for spatial predicates
+ * Performance tests for topological predicates
- * Usage: perf_prepared_polygon_intersects [ intersects | contains ]
+ * Usage: perf_topo_predicate [ intersects | contains ]
#include <geos/geom/util/SineStarFactory.h>
@@ -25,7 +25,9 @@ std::size_t NUM_LINES_PTS = 100;
#define INTERSECTS 0
#define CONTAINS 1
#define COVERS 2
+#define TOUCHES 3
+std::string op{"intersects"};
int predicateOp = INTERSECTS;
int testRelateOpIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
@@ -55,6 +57,15 @@ int testRelateOpCovers(const Geometry& g, const std::vector<std::unique_ptr<Geom
return count;
+int testRelateOpTouches(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ for (const auto& geom : geoms) {
+ auto im = g.relate(geom.get());
+ count += im->isTouches(g.getDimension(), geom.get()->getDimension());
+ return count;
int testGeometryIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
@@ -79,6 +90,14 @@ int testGeometryCovers(const Geometry& g, const std::vector<std::unique_ptr<Geom
return count;
+int testGeometryTouches(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ count += g.touches(geom.get());
+ return count;
int testPrepGeomIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
auto prep = prep::PreparedGeometryFactory::prepare(&g);
@@ -133,10 +152,19 @@ int testRelateNGPreparedCovers(const Geometry& g, const std::vector<std::unique_
return count;
+int testRelateNGPreparedTouches(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ auto prep = geos::operation::relateng::RelateNG::prepare(&g);
+ for (const auto& line : geoms) {
+ count += prep->evaluate(line.get(), *geos::operation::relateng::RelatePredicate::touches());
+ return count;
template<typename F>
double test(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms, const std::string& method, F&& fun, double baseTime)
- geos::util::Profile sw("PreparedPolygonIntersects");
+ geos::util::Profile sw("TopologuyPredicatePerf");
sw.start();
int count = 0;
@@ -153,8 +181,9 @@ double test(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geo
<< count << "," << geoms[0]->getGeometryType() << ","
<< geoms[0]->getNumPoints() << ","
<< method << ","
- << tot << ","
- << timesFaster
+ << tot << ",";
+ std::cout << std::fixed << std::setprecision(1);
+ std::cout << timesFaster
<< std::endl;
return tot;
@@ -177,22 +206,28 @@ void test(int dim, std::size_t npts) {
double baseTime;
switch (predicateOp) {
case INTERSECTS:
- baseTime = test(*target, geoms, "RelateOp intersects", testRelateOpIntersects, 0);
- test(*target, geoms, "Geometry::intersects", testGeometryIntersects, baseTime);
- test(*target, geoms, "PreparedGeom", testPrepGeomIntersects, baseTime);
- test(*target, geoms, "RelateNGPrepared", testRelateNGPreparedIntersects, baseTime);
+ baseTime = test(*target, geoms, "RelateOp-intersects", testRelateOpIntersects, 0);
+ test(*target, geoms, "Geometry-intersects", testGeometryIntersects, baseTime);
+ test(*target, geoms, "PreparedGeom-intersects", testPrepGeomIntersects, baseTime);
+ test(*target, geoms, "RelateNGPrepared-intersects", testRelateNGPreparedIntersects, baseTime);
break;
case CONTAINS:
- baseTime = test(*target, geoms, "RelateOp contains", testRelateOpIntersects, 0);
- test(*target, geoms, "Geometry::contains", testGeometryIntersects, baseTime);
- test(*target, geoms, "PreparedGeom contains", testPrepGeomContains, baseTime);
- test(*target, geoms, "RelateNGPrepared contains", testRelateNGPreparedContains, baseTime);
+ baseTime = test(*target, geoms, "RelateOp-contains", testRelateOpIntersects, 0);
+ test(*target, geoms, "Geometry-contains", testGeometryIntersects, baseTime);
+ test(*target, geoms, "PreparedGeom-contains", testPrepGeomContains, baseTime);
+ test(*target, geoms, "RelateNGPrepared-contains", testRelateNGPreparedContains, baseTime);
break;
case COVERS:
- baseTime = test(*target, geoms, "RelateOp covers", testRelateOpCovers, 0);
- test(*target, geoms, "Geometry::covers", testGeometryCovers, baseTime);
- test(*target, geoms, "PreparedGeom covers", testPrepGeomCovers, baseTime);
- test(*target, geoms, "RelateNGPrepared covers", testRelateNGPreparedCovers, baseTime);
+ baseTime = test(*target, geoms, "RelateOp-covers", testRelateOpCovers, 0);
+ test(*target, geoms, "Geometry-covers", testGeometryCovers, baseTime);
+ test(*target, geoms, "PreparedGeom-covers", testPrepGeomCovers, baseTime);
+ test(*target, geoms, "RelateNGPrepared-covers", testRelateNGPreparedCovers, baseTime);
+ break;
+ case TOUCHES:
+ baseTime = test(*target, geoms, "RelateOp-touches", testRelateOpTouches, 0);
+ test(*target, geoms, "Geometry-touches", testGeometryTouches, baseTime);
+ test(*target, geoms, "RelateNGPrepared-touches", testRelateNGPreparedTouches, baseTime);
+ break;
@@ -209,15 +244,19 @@ void testAll(int dim)
int main(int argc, char** argv) {
- predicateOp = INTERSECTS;
+ op = "intersects";
if (argc >= 2) {
- std::string op{argv[1]};
- if (op == "contains") {
- predicateOp = CONTAINS;
- else if (op == "covers") {
- predicateOp = COVERS;
+ op = argv[1];
+ predicateOp = INTERSECTS;
+ if (op == "contains") {
+ predicateOp = CONTAINS;
+ else if (op == "covers") {
+ predicateOp = COVERS;
+ else if (op == "touches") {
+ predicateOp = TOUCHES;
std::cout << "target_points,num_tests,num_hits,test_type,pts_in_test,method,time,factor" << std::endl;
Summary of changes:
benchmarks/geom/TopologyPredicatePerfTest.cpp | 89 +++++++++++++++++++--------
1 file changed, 64 insertions(+), 25 deletions(-)
hooks/post-receive
More information about the geos-commits
