[geos-commits] [SCM] GEOS branch main-relate-ng updated. 70c036e84ba2d1f5116b838127932bd4f597f1c3
Mon Aug 12 12:07:35 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
       via  70c036e84ba2d1f5116b838127932bd4f597f1c3 (commit)
      from  b3a3490336b917576d8f14538d680d7ec24dadc0 (commit)
revisions in full, below.
commit 70c036e84ba2d1f5116b838127932bd4f597f1c3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Aug 12 12:07:02 2024 -0700
    Add prepared relate, c++ and capi bindings.
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 98025b7a9..ab889455c 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1603,6 +1603,18 @@ extern "C" {
         return GEOSPreparedWithin_r(handle, pg1, g2);
+    char *
+    GEOSPreparedRelate(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+        return GEOSPreparedRelate_r(handle, pg1, g2);
+    char
+    GEOSPreparedRelatePattern(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2, const char* pat)
+        return GEOSPreparedRelatePattern_r(handle, pg1, g2, pat);
     CoordinateSequence*
     GEOSPreparedNearestPoints(const geos::geom::prep::PreparedGeometry* g1, const Geometry* g2)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 124d26524..7eebb1896 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1281,6 +1281,19 @@ extern char GEOS_DLL GEOSPreparedWithin_r(
     const GEOSPreparedGeometry* pg1,
     const GEOSGeometry* g2);
+/** \see GEOSPreparedRelate */
+extern char GEOS_DLL * GEOSPreparedRelate_r(
+    GEOSContextHandle_t handle,
+    const GEOSPreparedGeometry* pg1,
+    const GEOSGeometry* g2);
+/** \see GEOSPreparedRelatePattern */
+extern char GEOS_DLL GEOSPreparedRelatePattern_r(
+    const GEOSGeometry* g2,
+    const char* im);
 /** \see GEOSPreparedNearestPoints */
 extern GEOSCoordSequence GEOS_DLL *GEOSPreparedNearestPoints_r(
@@ -5188,6 +5201,44 @@ extern char GEOS_DLL GEOSPreparedWithin(
+* Use a \ref GEOSPreparedGeometry do a high performance
+* calculation of the DE9IM relationship between the
+* prepared and provided geometry, and compare that
+* relationship to the provided DE9IM, returning
+* true if the patterns are consistent and false otherwise.
+* \param pg1 The prepared geometry
+* \param g2 The geometry to test
+* \param pat The DE9IM pattern to test
+* \returns 1 on true, 0 on false, 2 on exception
+* \see GEOSPrepare
+* \see GEOSRelate
+* \see GEOSPreparedRelatePattern
+* \since 3.13
+extern char GEOS_DLL * GEOSPreparedRelate(
+* prepared and provided geometry.
+* \returns The DE9IM relate pattern string
+* \see GEOSPrepare
+* \see GEOSRelatePattern
+* \since 3.13
+extern char GEOS_DLL GEOSPreparedRelatePattern(
+    const char* pat);
 * calculation to find the nearest points between the
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index d16cd0b55..64aaf8e3e 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3750,6 +3750,24 @@ extern "C" {
+    char *
+    GEOSPreparedRelate_r(GEOSContextHandle_t extHandle,
+                         const geos::geom::prep::PreparedGeometry* pg, const Geometry* g)
+        return execute(extHandle, [&]() -> char * {
+            return gstrdup(pg->relate(g));
+    char
+    GEOSPreparedRelatePattern_r(GEOSContextHandle_t extHandle,
+                         const geos::geom::prep::PreparedGeometry* pg, const Geometry* g, const char* pat)
+        return execute(extHandle, 2, [&]() {
+            return pg->relate(g, std::string(pat));
     CoordinateSequence*
     GEOSPreparedNearestPoints_r(GEOSContextHandle_t extHandle,
diff --git a/include/geos/geom/prep/BasicPreparedGeometry.h b/include/geos/geom/prep/BasicPreparedGeometry.h
index 4653aa15f..dcd9fe3a6 100644
--- a/include/geos/geom/prep/BasicPreparedGeometry.h
+++ b/include/geos/geom/prep/BasicPreparedGeometry.h
@@ -179,6 +179,16 @@ public:
     bool within(const geom::Geometry* g) const override;
+     * Default implementation.
+    std::string relate(const geom::Geometry* g) const override;
+    bool relate(const geom::Geometry* g, const std::string& pat) const override;
diff --git a/include/geos/geom/prep/PreparedGeometry.h b/include/geos/geom/prep/PreparedGeometry.h
index d0cf2379b..736950223 100644
--- a/include/geos/geom/prep/PreparedGeometry.h
+++ b/include/geos/geom/prep/PreparedGeometry.h
@@ -227,6 +227,28 @@ public:
     virtual bool isWithinDistance(const geom::Geometry* geom, double dist) const = 0;
+    /** \brief
+     * Compares the prepared geometry to the given geometry
+     * and returns the DE9IM intersection matrix as a string.
+     * @param geom the Geometry to test the
+     * @return the DE9IM matrix
+    virtual std::string relate(const geom::Geometry* g) const = 0;
+    /** \brief
+     * and the provided DE9IM pattern, and returns true if the
+     * pattern is consistent with the relationship between the
+     * prepared and provided geometries.
+     * @param geom the Geometry to test the distance to
+     * @param pat the DE9IM pattern
+     * @return true if the patterns are consistent
+    virtual bool relate(const geom::Geometry* g, const std::string& pat) const = 0;
diff --git a/include/geos/operation/relateng/RelateNG.h b/include/geos/operation/relateng/RelateNG.h
index ad9f3608e..f9b0e92b7 100644
--- a/include/geos/operation/relateng/RelateNG.h
+++ b/include/geos/operation/relateng/RelateNG.h
@@ -271,8 +271,8 @@ public:
     bool covers(const Geometry* a);
     bool coveredBy(const Geometry* a);
     bool equalsTopo(const Geometry* a);
-    bool relate(const Geometry* a, const std::string& imPattern);
+    bool relate(const Geometry* a, const std::string& pat);
+    std::string relate(const Geometry* a);
diff --git a/src/geom/prep/BasicPreparedGeometry.cpp b/src/geom/prep/BasicPreparedGeometry.cpp
index 1c7df4322..9dac0b965 100644
--- a/src/geom/prep/BasicPreparedGeometry.cpp
+++ b/src/geom/prep/BasicPreparedGeometry.cpp
@@ -149,6 +149,19 @@ BasicPreparedGeometry::within(const geom::Geometry* g) const
     return getRelateNG()->within(g);
+bool
+BasicPreparedGeometry::relate(const geom::Geometry* g, const std::string& pat) const
+    return getRelateNG()->relate(g, pat);
+std::string
+BasicPreparedGeometry::relate(const geom::Geometry* g) const
+    return getRelateNG()->relate(g);
 std::unique_ptr<geom::CoordinateSequence>
 BasicPreparedGeometry::nearestPoints(const geom::Geometry* g) const
diff --git a/src/operation/relateng/RelateNG.cpp b/src/operation/relateng/RelateNG.cpp
index b550b711b..f09a96504 100644
--- a/src/operation/relateng/RelateNG.cpp
+++ b/src/operation/relateng/RelateNG.cpp
@@ -268,6 +268,14 @@ RelateNG::relate(const Geometry* a, const std::string& imPattern)
     return evaluate(a, imPattern);
+/* public */
+std::string
+RelateNG::relate(const Geometry* a)
+    RelateNG rng(a, false);
+    return rng.evaluate(a)->toString();
 /* public static */
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index 56d852ccc..94da91cbb 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -451,7 +451,36 @@ void object::test<16>()
     ensure(geom1_);
     prepGeom1_ = GEOSPrepare(geom1_);
-    ensure("curved geometries not supported", prepGeom1_ == nullptr);
+    ensure("curved geometries not supporteds", prepGeom1_ == nullptr);
+template<>
+template<>
+void object::test<17>()
+    geom1_ = fromWKT("POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))");
+    geom2_ = fromWKT("POLYGON((0.5 0.5, 1.5 0.5, 1.5 1.5, 0.5 1.5, 0.5 0.5))");
+    ensure(geom1_);
+    ensure(geom2_);
+    prepGeom1_ = GEOSPrepare(geom1_);
+    ensure_equals("prepTouches1", GEOSPreparedTouches(prepGeom1_, geom2_), GEOSTouches(geom1_, geom2_));
+    ensure_equals("prepTouches2", GEOSPreparedTouches(prepGeom1_, geom2_), GEOSTouches(geom1_, geom2_));
+    ensure_equals("prepOverlaps1", GEOSPreparedOverlaps(prepGeom1_, geom2_), GEOSOverlaps(geom1_, geom2_));
+    ensure_equals("prepOverlaps2", GEOSPreparedOverlaps(prepGeom1_, geom2_), GEOSOverlaps(geom1_, geom2_));
+    ensure_equals("prepCrosses1", GEOSPreparedCrosses(prepGeom1_, geom2_), GEOSCrosses(geom1_, geom2_));
+    ensure_equals("prepCrosses2", GEOSPreparedCrosses(prepGeom1_, geom2_), GEOSCrosses(geom1_, geom2_));
+    ensure_equals("prepDisjoint1", GEOSPreparedDisjoint(prepGeom1_, geom2_), GEOSDisjoint(geom1_, geom2_));
+    ensure_equals("prepDisjoint2", GEOSPreparedDisjoint(prepGeom1_, geom2_), GEOSDisjoint(geom1_, geom2_));
+    char* r1 = GEOSPreparedRelate(prepGeom1_, geom2_);
+    char* r2 = GEOSRelate(geom1_, geom2_);
+    ensure_equals("prepRelate1", std::string(r1), std::string(r2));
+    GEOSFree(r1);
+    GEOSFree(r2);
 } // namespace tut
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 5f2d0cf04..2666d1479 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -23,6 +23,7 @@ namespace capitest {
         GEOSGeometry* result_ = nullptr;
         GEOSGeometry* expected_ = nullptr;
         char* wkt_ = nullptr;
+       char* str_ = nullptr;
         utility()
@@ -35,32 +36,19 @@ namespace capitest {
         ~utility()
-            if (wktw_)
-                GEOSWKTWriter_destroy(wktw_);
-            if (geom1_) {
-                GEOSGeom_destroy(geom1_);
-            if (geom2_) {
-                GEOSGeom_destroy(geom2_);
-            if (geom3_) {
-                GEOSGeom_destroy(geom3_);
-            if (input_) {
-                GEOSGeom_destroy(input_);
-            if (result_) {
-                GEOSGeom_destroy(result_);
-            if (expected_) {
-                GEOSGeom_destroy(expected_);
-            if (wkt_) {
-                GEOSFree(wkt_);
+            if (wktw_)     GEOSWKTWriter_destroy(wktw_);
+            if (geom1_)    GEOSGeom_destroy(geom1_);
+            if (geom2_)    GEOSGeom_destroy(geom2_);
+            if (geom3_)    GEOSGeom_destroy(geom3_);
+            if (input_)    GEOSGeom_destroy(input_);
+            if (result_)   GEOSGeom_destroy(result_);
+            if (expected_) GEOSGeom_destroy(expected_);
+            if (wkt_)      GEOSFree(wkt_);
+            if (str_)       GEOSFree(str_);
             finishGEOS();
         static void notice(GEOS_PRINTF_FORMAT const char* fmt, ...) GEOS_PRINTF_FORMAT_ATTR(1, 2)
             std::fprintf(stdout, "NOTICE: ");
diff --git a/tests/unit/geom/prep/PreparedGeometryTest.cpp b/tests/unit/geom/prep/PreparedGeometryTest.cpp
index c1df1abac..3934af90c 100644
--- a/tests/unit/geom/prep/PreparedGeometryTest.cpp
+++ b/tests/unit/geom/prep/PreparedGeometryTest.cpp
@@ -99,4 +99,5 @@ void object::test<3>
     ensure( pg1->contains(g2.get()) );
 } // namespace tut
diff --git a/tests/unit/operation/relateng/RelateNGTest.h b/tests/unit/operation/relateng/RelateNGTest.h
index a5664825b..c81544a4f 100644
--- a/tests/unit/operation/relateng/RelateNGTest.h
+++ b/tests/unit/operation/relateng/RelateNGTest.h
@@ -35,14 +35,14 @@ struct test_relateng_support {
         auto prep_b = RelateNG::prepare(b.get());
         ensure_equals("equalsTopo", prep_a->equalsTopo(b.get()), a->equals(b.get()));
         ensure_equals("intersects", prep_a->intersects(b.get()), a->intersects(b.get()));
-        ensure_equals("disjoint", prep_a->disjoint(b.get()), a->disjoint(b.get()));
-        ensure_equals("covers", prep_a->covers(b.get()), a->covers(b.get()));
-        ensure_equals("coveredby", prep_a->coveredBy(b.get()), a->coveredBy(b.get()));
-        ensure_equals("within", prep_a->within(b.get()), a->within(b.get()));
-        ensure_equals("contains", prep_a->contains(b.get()), a->contains(b.get()));
-        ensure_equals("crosses", prep_a->crosses(b.get()), a->crosses(b.get()));
-        ensure_equals("touches", prep_a->touches(b.get()), a->touches(b.get()));
-        ensure_equals("relate", prep_a->relate(b.get()), a->relate(b.get())->toString());
+        ensure_equals("disjoint",   prep_a->disjoint(b.get()),   a->disjoint(b.get()));
+        ensure_equals("covers",     prep_a->covers(b.get()),     a->covers(b.get()));
+        ensure_equals("coveredby",  prep_a->coveredBy(b.get()),  a->coveredBy(b.get()));
+        ensure_equals("within",     prep_a->within(b.get()),     a->within(b.get()));
+        ensure_equals("contains",   prep_a->contains(b.get()),   a->contains(b.get()));
+        ensure_equals("crosses",    prep_a->crosses(b.get()),    a->crosses(b.get()));
+        ensure_equals("touches",    prep_a->touches(b.get()),    a->touches(b.get()));
+        ensure_equals("relate",     prep_a->relate(b.get()),     a->relate(b.get())->toString());
     void checkIntersectsDisjoint(const std::string& wkta, const std::string& wktb, bool expectedValue)
Summary of changes:
 capi/geos_c.cpp                                | 12 ++++++
 capi/geos_c.h.in                               | 51 ++++++++++++++++++++++++++
 capi/geos_ts_c.cpp                             | 18 +++++++++
 include/geos/geom/prep/BasicPreparedGeometry.h | 10 +++++
 include/geos/geom/prep/PreparedGeometry.h      | 22 +++++++++++
 include/geos/operation/relateng/RelateNG.h     |  4 +-
 src/geom/prep/BasicPreparedGeometry.cpp        | 13 +++++++
 src/operation/relateng/RelateNG.cpp            |  8 ++++
 tests/unit/capi/GEOSPreparedGeometryTest.cpp   | 31 +++++++++++++++-
 tests/unit/capi/capi_test_utils.h              | 34 ++++++-----------
 tests/unit/geom/prep/PreparedGeometryTest.cpp  |  1 +
 tests/unit/operation/relateng/RelateNGTest.h   | 16 ++++----
 12 files changed, 186 insertions(+), 34 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
