[geos-commits] [SCM] GEOS branch main updated. 1821b67432de802ead6f0c655c93e74e03ffd267
Thu Aug 15 14:14:57 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  1821b67432de802ead6f0c655c93e74e03ffd267 (commit)
      from  e8e3e25549544cbaa672087bca765f190ec4d3b7 (commit)
revisions in full, below.
commit 1821b67432de802ead6f0c655c93e74e03ffd267
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Aug 15 14:14:21 2024 -0700
    Avoid overhead in zeroLenLine tests for non-line features. Some inlineing of trivial accessors.
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index cfb62aa80..ef251c3ee 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -87,7 +87,7 @@ public:
      * Uses an approach due to Jonathan Shewchuk, which is in the public domain.
-    static int orientationIndexFilter(
+    static inline int orientationIndexFilter(
         double pax, double pay,
         double pbx, double pby,
         double pcx, double pcy)
diff --git a/include/geos/operation/relateng/RelateGeometry.h b/include/geos/operation/relateng/RelateGeometry.h
index 3c071d056..e96a3b878 100644
--- a/include/geos/operation/relateng/RelateGeometry.h
+++ b/include/geos/operation/relateng/RelateGeometry.h
@@ -97,6 +97,13 @@ private:
     static bool isZeroLength(const LineString* line);
+    bool isZeroLengthLine(const Geometry* g) const {
+        // avoid expensive zero-length calculation if not linear
+        if (getDimension() != Dimension::L)
+            return false;
+        return isZeroLength(g);
     RelatePointLocator* getLocator();
     Coordinate::ConstXYSet createUniquePoints();
@@ -141,15 +148,30 @@ public:
     static std::string name(bool isA);
-    const Geometry* getGeometry() const;
+    const Geometry* getGeometry() const {
+        return geom;
-    bool isPrepared() const;
+    bool isPrepared() const {
+        return m_isPrepared;
-    const Envelope* getEnvelope() const;
+    const Envelope* getEnvelope() const {
+        return geomEnv;
-    int getDimension() const;
+    inline int getDimension() const {
+        return geomDim;
-    bool hasDimension(int dim) const;
+    bool hasDimension(int dim) const {
+        switch (dim) {
+            case Dimension::P: return hasPoints;
+            case Dimension::L: return hasLines;
+            case Dimension::A: return hasAreas;
+        return false;
     * Gets the actual non-empty dimension of the geometry.
diff --git a/include/geos/operation/relateng/RelateSegmentString.h b/include/geos/operation/relateng/RelateSegmentString.h
index 556ac4d37..f2e6caff4 100644
--- a/include/geos/operation/relateng/RelateSegmentString.h
+++ b/include/geos/operation/relateng/RelateSegmentString.h
@@ -123,11 +123,17 @@ public:
         bool isA, int elementId, int ringId,
         const Geometry* poly, const RelateGeometry* parent);
-    bool isA() const;
+    inline bool isA() const {
+        return m_isA;
-    const RelateGeometry* getGeometry() const;
+    inline const RelateGeometry* getGeometry() const {
+        return m_inputGeom;
-    const Geometry* getPolygonal() const;
+    inline const Geometry* getPolygonal() const {
+        return m_parentPolygonal;
     NodeSection* createNodeSection(std::size_t segIndex, const CoordinateXY intPt) const;
diff --git a/include/geos/operation/relateng/TopologyComputer.h b/include/geos/operation/relateng/TopologyComputer.h
index cad2a1bc3..00b204693 100644
--- a/include/geos/operation/relateng/TopologyComputer.h
+++ b/include/geos/operation/relateng/TopologyComputer.h
@@ -67,7 +67,9 @@ private:
     void initExteriorEmpty(bool geomNonEmpty);
-    RelateGeometry& getGeometry(bool isA) const;
+    inline RelateGeometry& getGeometry(bool isA) const {
+        return isA ? geomA : geomB;
     void updateDim(Location locA, Location locB, int dimension);
@@ -135,16 +137,16 @@ private:
 public:
-        TopologyComputer(
-            TopologyPredicate& p_predicate,
-            RelateGeometry& p_geomA,
-            RelateGeometry& p_geomB)
-            : predicate(p_predicate)
-            , geomA(p_geomA)
-            , geomB(p_geomB)
-                initExteriorDims();
+    TopologyComputer(
+        TopologyPredicate& p_predicate,
+        RelateGeometry& p_geomA,
+        RelateGeometry& p_geomB)
+        : predicate(p_predicate)
+        , geomA(p_geomA)
+        , geomB(p_geomB)
+            initExteriorDims();
     int getDimension(bool isA) const;
diff --git a/src/operation/relateng/RelateGeometry.cpp b/src/operation/relateng/RelateGeometry.cpp
index 94536c16e..8a9620053 100644
--- a/src/operation/relateng/RelateGeometry.cpp
+++ b/src/operation/relateng/RelateGeometry.cpp
@@ -56,7 +56,7 @@ RelateGeometry::RelateGeometry(const Geometry* input, bool isPrepared, const Bou
     , geomEnv(input->getEnvelopeInternal())
     , boundaryNodeRule(bnRule)
     , geomDim(input->getDimension())
-    , isLineZeroLen(isZeroLength(input))
+    , isLineZeroLen(isZeroLengthLine(input))
     , isGeomEmpty(input->isEmpty())
     analyzeDimensions();
@@ -154,47 +154,6 @@ RelateGeometry::isZeroLength(const LineString* line) {
-/* public */
-const Geometry*
-RelateGeometry::getGeometry() const
-    return geom;
-/* public */
-bool
-RelateGeometry::isPrepared() const
-    return m_isPrepared;
-/* public */
-const Envelope*
-RelateGeometry::getEnvelope() const
-    return geomEnv;
-/* public */
-int
-RelateGeometry::getDimension() const
-    return geomDim;
-/* public */
-bool
-RelateGeometry::hasDimension(int dim) const
-    switch (dim) {
-        case Dimension::P: return hasPoints;
-        case Dimension::L: return hasLines;
-        case Dimension::A: return hasAreas;
-    return false;
 /* public */
 int
 RelateGeometry::getDimensionReal() const
@@ -210,6 +169,7 @@ RelateGeometry::getDimensionReal() const
     return Dimension::P;
 /* public */
 bool
 RelateGeometry::hasEdges() const
diff --git a/src/operation/relateng/RelateSegmentString.cpp b/src/operation/relateng/RelateSegmentString.cpp
index 5dfb5e716..41c0c4bbf 100644
--- a/src/operation/relateng/RelateSegmentString.cpp
+++ b/src/operation/relateng/RelateSegmentString.cpp
@@ -69,30 +69,6 @@ RelateSegmentString::createSegmentString(
-/* public */
-bool
-RelateSegmentString::isA() const
-    return m_isA;
-/* public */
-const RelateGeometry*
-RelateSegmentString::getGeometry() const
-    return m_inputGeom;
-/* public */
-const Geometry*
-RelateSegmentString::getPolygonal() const
-    return m_parentPolygonal;
 /* public */
 NodeSection*
 RelateSegmentString::createNodeSection(std::size_t segIndex, const CoordinateXY intPt) const
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 984073e46..6d6d11b16 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -111,11 +111,12 @@ TopologyComputer::initExteriorEmpty(bool geomNonEmpty)
-/* private */
-RelateGeometry&
-TopologyComputer::getGeometry(bool isA) const
+/* public */
+bool
+TopologyComputer::isAreaArea() const
-    return isA ? geomA : geomB;
+    return getDimension(RelateGeometry::GEOM_A) == Dimension::A
+        && getDimension(RelateGeometry::GEOM_B) == Dimension::A;
@@ -127,15 +128,6 @@ TopologyComputer::getDimension(bool isA) const
-/* public */
-bool
-TopologyComputer::isAreaArea() const
-    return getDimension(RelateGeometry::GEOM_A) == Dimension::A
-        && getDimension(RelateGeometry::GEOM_B) == Dimension::A;
 /* public */
 bool
 TopologyComputer::isSelfNodingRequired() const
Summary of changes:
 include/geos/algorithm/CGAlgorithmsDD.h            |  2 +-
 include/geos/operation/relateng/RelateGeometry.h   | 40 +++++++++++++++-----
 .../geos/operation/relateng/RelateSegmentString.h  | 12 ++++--
 include/geos/operation/relateng/TopologyComputer.h | 24 ++++++------
 src/operation/relateng/RelateGeometry.cpp          | 44 +---------------------
 src/operation/relateng/RelateSegmentString.cpp     | 24 ------------
 src/operation/relateng/TopologyComputer.cpp        | 18 +++------
 7 files changed, 61 insertions(+), 103 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
