[geos-commits] [SCM] GEOS branch main updated. 0296a92919e54257adcd2bc6faa9a83de768b252
Thu Aug 22 09:00:10 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  0296a92919e54257adcd2bc6faa9a83de768b252 (commit)
      from  e8028977055522fd103d06d75e1e2940ae52bfc3 (commit)
revisions in full, below.
commit 0296a92919e54257adcd2bc6faa9a83de768b252
Author: Oreille <33065839+Oreilles at users.noreply.github.com>
Date:   Thu Aug 22 17:59:39 2024 +0200
    Add 3D supports to GeoJSON reader and writer (#1150)
diff --git a/include/geos/io/GeoJSONWriter.h b/include/geos/io/GeoJSONWriter.h
index 8bb7e663b..002a6f501 100644
--- a/include/geos/io/GeoJSONWriter.h
+++ b/include/geos/io/GeoJSONWriter.h
@@ -74,11 +74,33 @@ public:
     std::string write(const GeoJSONFeatureCollection& features);
+     * \brief
+     * Returns the output dimension used by the
+     * <code>GeoJSONWriter</code>.
+    int
+    getOutputDimension() const
+        return defaultOutputDimension;
+     * Sets the output dimension used by the <code>GeoJSONWriter</code>.
+     * @param newOutputDimension Supported values are 2 or 3.
+     *        Default since GEOS 3.12 is 3.
+     *        Note that 3 indicates up to 3 dimensions will be
+     *        written but 2D GeoJSON is still produced for 2D geometries.
+    void setOutputDimension(uint8_t newOutputDimension);
 private:
+    uint8_t defaultOutputDimension = 3;
-    std::pair<double, double> convertCoordinate(const geom::CoordinateXY* c);
+    std::vector<double> convertCoordinate(const geom::Coordinate* c);
-    std::vector<std::pair<double, double>> convertCoordinateSequence(const geom::CoordinateSequence* c);
+    std::vector<std::vector<double>> convertCoordinateSequence(const geom::CoordinateSequence* c);
     void encode(const geom::Geometry* g, GeoJSONType type, geos_nlohmann::ordered_json& j);
diff --git a/src/io/GeoJSONReader.cpp b/src/io/GeoJSONReader.cpp
index 9daa5ac15..fe53b63c7 100644
--- a/src/io/GeoJSONReader.cpp
+++ b/src/io/GeoJSONReader.cpp
@@ -210,13 +210,16 @@ geom::Coordinate GeoJSONReader::readCoordinate(
     const std::vector<double>& coords) const
     if (coords.size() == 1) {
-        throw  ParseException("Expected two coordinates found one");
+        throw  ParseException("Expected two or three coordinates found one");
-    else if (coords.size() > 2) {
-        throw  ParseException("Expected two coordinates found more than two");
+    else if (coords.size() == 2) {
+        return geom::Coordinate { coords[0], coords[1] };
+    else if (coords.size() == 3) {
+        return geom::Coordinate { coords[0], coords[1], coords[2] };
     else {
-        return geom::Coordinate {coords[0], coords[1]};
+        throw  ParseException("Expected two or three coordinates found more than three");
@@ -225,7 +228,7 @@ std::unique_ptr<geom::Point> GeoJSONReader::readPoint(
     const auto& coords = j.at("coordinates").get<std::vector<double>>();
     else if (coords.size() < 2) {
         return geometryFactory.createPoint(2);
@@ -240,7 +243,8 @@ std::unique_ptr<geom::LineString> GeoJSONReader::readLineString(
     const geos_nlohmann::json& j) const
     const auto& coords = j.at("coordinates").get<std::vector<std::vector<double>>>();
-    auto coordinates = detail::make_unique<CoordinateSequence>(0u, 2u);
+    bool has_z = std::any_of(coords.begin(), coords.end(), [](auto v) { return v.size() > 2; });
+    auto coordinates = detail::make_unique<CoordinateSequence>(0u, has_z, false);
     coordinates->reserve(coords.size());
     for (const auto& coord : coords) {
         const geom::Coordinate& c = readCoordinate(coord);
@@ -263,7 +267,8 @@ std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(
     std::vector<std::unique_ptr<geom::LinearRing>> rings;
     rings.reserve(polygonCoords.size());
     for (const auto& ring : polygonCoords) {
+        bool has_z = std::any_of(ring.begin(), ring.end(), [](auto v) { return v.size() > 2; });
         coordinates->reserve(ring.size());
         for (const auto& coord : ring) {
@@ -307,7 +312,8 @@ std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(
     std::vector<std::unique_ptr<geom::LineString>> lines;
     lines.reserve(listOfCoords.size());
     for (const auto& coords :  listOfCoords) {
-        auto coordinates = detail::make_unique<geom::CoordinateSequence>(0u, 2u);
+        auto coordinates = detail::make_unique<geom::CoordinateSequence>(0u, has_z, false);
diff --git a/src/io/GeoJSONWriter.cpp b/src/io/GeoJSONWriter.cpp
index 0fd4bc297..bf3826d49 100644
--- a/src/io/GeoJSONWriter.cpp
+++ b/src/io/GeoJSONWriter.cpp
@@ -29,6 +29,7 @@
 #include <ostream>
 #include <sstream>
 #include <cassert>
+#include <cmath>
 #include "geos/util.h"
@@ -40,6 +41,17 @@ using json = geos_nlohmann::ordered_json;
 namespace geos {
 namespace io { // geos.io
+/* public */
+void
+GeoJSONWriter::setOutputDimension(uint8_t dims)
+    if(dims < 2 || dims > 3) {
+        throw util::IllegalArgumentException("GeoJSON output dimension must be 2 or 3");
+    defaultOutputDimension = dims;
 std::string GeoJSONWriter::write(const geom::Geometry* geometry, GeoJSONType type)
     json j;
@@ -217,7 +229,8 @@ void GeoJSONWriter::encodePoint(const geom::Point* point, geos_nlohmann::ordered
     j["type"] = "Point";
     if (!point->isEmpty()) {
-        j["coordinates"] = convertCoordinate(point->getCoordinate());
+        auto as_coord = Coordinate { point->getX(), point->getY(), point->getZ()};
+        j["coordinates"] = convertCoordinate(&as_coord);
     else {
         j["coordinates"] = j.array();
@@ -233,7 +246,7 @@ void GeoJSONWriter::encodeLineString(const geom::LineString* line, geos_nlohmann
 void GeoJSONWriter::encodePolygon(const geom::Polygon* poly, geos_nlohmann::ordered_json& j)
     j["type"] = "Polygon";
-    std::vector<std::vector<std::pair<double, double>>> rings;
+    std::vector<std::vector<std::vector<double>>> rings;
     auto ring = poly->getExteriorRing();
     rings.reserve(poly->getNumInteriorRing()+1);
     rings.push_back(convertCoordinateSequence(ring->getCoordinates().get()));
@@ -252,7 +265,7 @@ void GeoJSONWriter::encodeMultiPoint(const geom::MultiPoint* multiPoint, geos_nl
 void GeoJSONWriter::encodeMultiLineString(const geom::MultiLineString* multiLineString, geos_nlohmann::ordered_json& j)
     j["type"] = "MultiLineString";
-    std::vector<std::vector<std::pair<double, double>>> lines;
+    std::vector<std::vector<std::vector<double>>> lines;
     lines.reserve(multiLineString->getNumGeometries());
     for (size_t i = 0; i < multiLineString->getNumGeometries(); i++) {
         lines.push_back(convertCoordinateSequence(multiLineString->getGeometryN(i)->getCoordinates().get()));
@@ -263,11 +276,11 @@ void GeoJSONWriter::encodeMultiLineString(const geom::MultiLineString* multiLine
 void GeoJSONWriter::encodeMultiPolygon(const geom::MultiPolygon* multiPolygon, geos_nlohmann::ordered_json& json)
     json["type"] = "MultiPolygon";
-    std::vector<std::vector<std::vector<std::pair<double, double>>>> polygons;
+    std::vector<std::vector<std::vector<std::vector<double>>>> polygons;
     polygons.reserve(multiPolygon->getNumGeometries());
     for (size_t i = 0; i < multiPolygon->getNumGeometries(); i++) {
         const Polygon* polygon = multiPolygon->getGeometryN(i);
         auto ring = polygon->getExteriorRing();
         rings.reserve(polygon->getNumInteriorRing() + 1);
@@ -291,15 +304,18 @@ void GeoJSONWriter::encodeGeometryCollection(const geom::GeometryCollection* g,
     j["geometries"] = geometryArray;
-std::pair<double, double> GeoJSONWriter::convertCoordinate(const CoordinateXY* c)
+std::vector<double> GeoJSONWriter::convertCoordinate(const Coordinate* c)
-    return std::make_pair(c->x, c->y);
+    if (std::isnan(c->z) || defaultOutputDimension == 2) {
+        return std::vector<double> { c->x, c->y };
+    return std::vector<double> { c->x, c->y, c->z };
-std::vector<std::pair<double, double>> GeoJSONWriter::convertCoordinateSequence(const CoordinateSequence*
+std::vector<std::vector<double>> GeoJSONWriter::convertCoordinateSequence(const CoordinateSequence*
                                     coordinateSequence)
-    std::vector<std::pair<double, double>> coordinates;
+    std::vector<std::vector<double>> coordinates;
     coordinates.reserve(coordinateSequence->size());
     for (size_t i = 0; i<coordinateSequence->size(); i++) {
         const geom::Coordinate& c = coordinateSequence->getAt(i);
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index bcbb9fead..2a8e7c030 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -336,7 +336,7 @@ void object::test<22>
         errorMessage = e.what();
     ensure(error == true);
-    ensure_equals(errorMessage, "ParseException: Expected two coordinates found one");
+    ensure_equals(errorMessage, "ParseException: Expected two or three coordinates found one");
 // Throw ParseException for bad GeoJSON
@@ -374,7 +374,7 @@ void object::test<24>
 // Throw error when geometry type is unsupported
@@ -412,7 +412,7 @@ void object::test<26>
 // Read a GeoJSON empty Polygon with empty shell and empty inner rings
@@ -446,7 +446,7 @@ void object::test<29>
     std::string errorMessage;
-    std::string geojson { "{\"type\":\"Point\",\"coordinates\":[1,2,3,4,5,6]}" };
+    std::string geojson { "{\"type\":\"Point\",\"coordinates\":[1,2,3,4]}" };
     bool error = false;
     try {
         GeomPtr geom(geojsonreader.read(geojson));
@@ -455,7 +455,7 @@ void object::test<29>
-    ensure_equals(errorMessage, "ParseException: Expected two coordinates found more than two");
+    ensure_equals(errorMessage, "ParseException: Expected two or three coordinates found more than three");
@@ -505,5 +505,95 @@ void object::test<31>
     ensure_equals(features.getFeatures()[8].getId(), "");
+// Read a point with all-null coordinates should fail
+template<>
+template<>
+void object::test<32>
+    std::string errorMessage;
+    std::string geojson { "{\"type\":\"Point\",\"coordinates\":[null,null]}" };
+    bool error = false;
+    try {
+        GeomPtr geom(geojsonreader.read(geojson));
+    } catch (geos::io::ParseException& e) {
+        error = true;
+        errorMessage = e.what();
+    ensure(error == true);
+    ensure_equals(errorMessage, "ParseException: Error parsing JSON: '[json.exception.type_error.302] type must be number, but is null'");
+// Read a GeoJSON Point with three dimensions
+template<>
+template<>
+void object::test<33>
+    std::string geojson { "{\"type\":\"Point\",\"coordinates\":[-117.0,33.0,10.0]}" };
+    ensure_equals("POINT Z (-117 33 10)", geom->toText());
+    ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 3u);
+// Read a GeoJSON MultiPoint with mixed dimensions
+template<>
+template<>
+void object::test<34>
+    std::string geojson { "{\"type\":\"MultiPoint\",\"coordinates\":[[-117.0,33.0,10.0],[-116.0,34.0]]}" };
+    ensure_equals("MULTIPOINT Z ((-117 33 10), (-116 34 NaN))", geom->toText());
+// Read a GeoJSON LineString with three dimensions
+template<>
+template<>
+void object::test<35>
+    std::string geojson { "{\"type\":\"LineString\",\"coordinates\":[[-117, 33, 2], [-116, 34, 4]]}" };
+    ensure_equals("LINESTRING Z (-117 33 2, -116 34 4)", geom->toText());
+// Read a GeoJSON LineString with mixed dimensions
+template<>
+template<>
+void object::test<36>
+    std::string geojson { "{\"type\":\"LineString\",\"coordinates\":[[-117, 33], [-116, 34, 4]]}" };
+    ensure_equals("LINESTRING Z (-117 33 NaN, -116 34 4)", geom->toText());
+// Read a GeoJSON Polygon with three dimensions
+template<>
+template<>
+void object::test<37>
+    std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[[30,10,1],[40,40,2],[20,40,4],[10,20,8],[30,10,16]]]}" };
+    ensure_equals(geom->toText(), "POLYGON Z ((30 10 1, 40 40 2, 20 40 4, 10 20 8, 30 10 16))");
+// Read a GeoJSON Polygon with mixed dimensions
+template<>
+template<>
+void object::test<38>
+    std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[[30,10],[40,40,2],[20,40],[10,20,8],[30,10]]]}" };
+    ensure_equals(geom->toText(), "POLYGON Z ((30 10 NaN, 40 40 2, 20 40 NaN, 10 20 8, 30 10 NaN))");
diff --git a/tests/unit/io/GeoJSONWriterTest.cpp b/tests/unit/io/GeoJSONWriterTest.cpp
index 26a2d8520..53d6e609a 100644
--- a/tests/unit/io/GeoJSONWriterTest.cpp
+++ b/tests/unit/io/GeoJSONWriterTest.cpp
@@ -318,5 +318,106 @@ void object::test<20>
     ensure_equals(result, "{\"type\":\"Point\",\"coordinates\":[null,null]}");
+// Write a Point Z to GeoJSON
+template<>
+template<>
+void object::test<21>
+    GeomPtr geom(wktreader.read("POINT Z (-117 33 10)"));
+    std::string result = geojsonwriter.write(geom.get());
+    ensure_equals(result, "{\"type\":\"Point\",\"coordinates\":[-117.0,33.0,10.0]}");
+// Write a Point Z with NaN to GeoJSON
+template<>
+template<>
+void object::test<22>
+    GeomPtr geom(wktreader.read("POINT Z (-117 33 NaN)"));
+    ensure_equals(result, "{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}");
+// Write a Point M to GeoJSON ignores M
+template<>
+template<>
+void object::test<23>
+    GeomPtr geom(wktreader.read("POINT M (-117 33 10)"));
+// Write a Point ZM to GeoJSON ignores M
+template<>
+template<>
+void object::test<24>
+    GeomPtr geom(wktreader.read("POINT ZM (-117 33 10 2)"));
+// Write a LineString Z to GeoJSON
+template<>
+template<>
+void object::test<25>
+    GeomPtr geom(wktreader.read("LINESTRING Z (102 0 2, 103 1 4, 104 0 8, 105 1 16)"));
+    ensure_equals(result, "{\"type\":\"LineString\",\"coordinates\":[[102.0,0.0,2.0],[103.0,1.0,4.0],[104.0,0.0,8.0],[105.0,1.0,16.0]]}");
+// Write a LineString Z with some NaN Z to GeoJSON
+template<>
+template<>
+void object::test<26>
+    GeomPtr geom(wktreader.read("LINESTRING Z (102 0 2, 103 1 NaN, 104 0 8, 105 1 NaN)"));
+    ensure_equals(result, "{\"type\":\"LineString\",\"coordinates\":[[102.0,0.0,2.0],[103.0,1.0],[104.0,0.0,8.0],[105.0,1.0]]}");
+// Setting outputs dimensions to an invalid value should raise
+template<>
+template<>
+void object::test<27>
+    bool error;
+    for (auto dims: { uint8_t{1}, uint8_t{4} }) {
+        errorMessage = "";
+        error = false;
+        try {
+            geojsonwriter.setOutputDimension(dims);
+        } catch (geos::util::IllegalArgumentException& e) {
+            error = true;
+        ensure_equals(errorMessage, "IllegalArgumentException: GeoJSON output dimension must be 2 or 3");
+// GeoJSONWriter without output dimensions set to 2 ignores Z and M values
+template<>
+template<>
+void object::test<28>
+    geojsonwriter.setOutputDimension(2);
Summary of changes:
 include/geos/io/GeoJSONWriter.h     |  26 +++++++++-
 src/io/GeoJSONReader.cpp            |  22 +++++---
 src/io/GeoJSONWriter.cpp            |  34 ++++++++----
 tests/unit/io/GeoJSONReaderTest.cpp | 100 +++++++++++++++++++++++++++++++++--
 tests/unit/io/GeoJSONWriterTest.cpp | 101 ++++++++++++++++++++++++++++++++++++
 5 files changed, 259 insertions(+), 24 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
