[geos-commits] [SCM] GEOS branch main updated. 5ab1b4bba604f770ae1b2acec502a74169227c7f
git at osgeo.org
git at osgeo.org
Thu Aug 22 12:45:14 PDT 2024
the project "GEOS".
The branch, main has been updated
via 5ab1b4bba604f770ae1b2acec502a74169227c7f (commit)
from eaf900515cd7b7058e7be6ecd94108d08f0a411b (commit)
revisions in full, below.
commit 5ab1b4bba604f770ae1b2acec502a74169227c7f
Author: Even Rouault <even.rouault at spatialys.com>
Date: Thu Aug 22 21:44:45 2024 +0200
include/geos/geomgraph: remove useless virtual qualifiers, add final and improve a bit const safety (#1140)
* Add -Wsuggest-override for gcc, and add missing override qualifiers
* include/geos/geomgraph: remove useless virtual qualifiers, add final and improve a bit const safety
The removal of the useless virtual qualifiers is safe since the addition
of -Wsuggest-override in a previous commit makes sure that all
overloaded methods (of methods that ware marked as 'virtual') are marked
as 'override', which in turns ensures that all base methods that are overriden
are marked as 'virtual'.
(This doesn't change the status quo if a method was overloaded, but the
base class lacked a 'virtual' and the overloaded method lacked a
'override'...)
Said otherwise, the dangerous situation would be a
class A { virtual void foo(); };
class B: public A { virtual void foo(); };
where we would erroneously remove the virtual qualifier.
But given -Wsuggest-override, the above code would have been corrected
to
class B: public A { virtual void foo() override; };
And thus if we erroneously remove the virtual qualifier from A::foo() the
compiler will error out.
This results in a small reduction in the size of libgeos.so (5954240 to 5946336),
suggesting that de-virtualizations are done.
diff --git a/include/geos/geomgraph/DirectedEdge.h b/include/geos/geomgraph/DirectedEdge.h
index 13c09632d..ab88f6234 100644
--- a/include/geos/geomgraph/DirectedEdge.h
+++ b/include/geos/geomgraph/DirectedEdge.h
@@ -39,7 +39,7 @@ namespace geos {
namespace geomgraph { // geos.geomgraph
/// A directed EdgeEnd
-class GEOS_DLL DirectedEdge: public EdgeEnd {
+class GEOS_DLL DirectedEdge final: public EdgeEnd {
public:
diff --git a/include/geos/geomgraph/Edge.h b/include/geos/geomgraph/Edge.h
index 100ae71e7..52a9f57bc 100644
--- a/include/geos/geomgraph/Edge.h
+++ b/include/geos/geomgraph/Edge.h
@@ -60,7 +60,7 @@ namespace geos {
/** The edge component of a geometry graph */
-class GEOS_DLL Edge: public GraphComponent {
+class GEOS_DLL Edge final: public GraphComponent {
using GraphComponent::updateIM;
private:
@@ -102,27 +102,27 @@ public:
~Edge() override;
- virtual size_t
+ size_t
getNumPoints() const
return pts->getSize();
- virtual const geom::CoordinateSequence*
+ const geom::CoordinateSequence*
getCoordinates() const
testInvariant();
return pts.get();
- virtual const geom::Coordinate&
+ const geom::Coordinate&
getCoordinate(std::size_t i) const
testInvariant();
return pts->getAt(i);
getCoordinate() const
testInvariant();
@@ -130,8 +130,8 @@ public:
- virtual Depth&
- getDepth()
+ const Depth&
+ getDepth() const
testInvariant();
return depth;
@@ -142,41 +142,48 @@ public:
* @return the change in depth as the edge is crossed from R to L
- virtual int
+ int
getDepthDelta() const
testInvariant();
return depthDelta;
- virtual void
+ void
setDepthDelta(int newDepthDelta)
depthDelta = newDepthDelta;
testInvariant();
- virtual size_t
+ size_t
getMaximumSegmentIndex() const
testInvariant();
return getNumPoints() - 1;
- virtual EdgeIntersectionList&
+ EdgeIntersectionList&
getEdgeIntersectionList()
testInvariant();
return eiList;
+ const EdgeIntersectionList&
+ getEdgeIntersectionList() const
+ testInvariant();
+ return eiList;
/// \brief
/// Return this Edge's index::MonotoneChainEdge,
/// ownership is retained by this object.
- virtual index::MonotoneChainEdge* getMonotoneChainEdge();
+ index::MonotoneChainEdge* getMonotoneChainEdge();
- virtual bool
+ bool
isClosed() const
testInvariant();
@@ -187,11 +194,11 @@ public:
* An Edge is collapsed if it is an Area edge and it consists of
* two segments which are equal and opposite (eg a zero-width V).
- virtual bool isCollapsed() const;
+ bool isCollapsed() const;
- virtual Edge* getCollapsedEdge();
+ Edge* getCollapsedEdge();
- virtual void
+ void
setIsolated(bool newIsIsolated)
isIsolatedVar = newIsIsolated;
@@ -209,7 +216,7 @@ public:
* Adds EdgeIntersections for one or both
* intersections found for a segment of an edge to the edge intersection list.
- virtual void addIntersections(algorithm::LineIntersector* li, std::size_t segmentIndex,
+ void addIntersections(algorithm::LineIntersector* li, std::size_t segmentIndex,
std::size_t geomIndex);
/// Add an EdgeIntersection for intersection intIndex.
@@ -217,7 +224,7 @@ public:
/// An intersection that falls exactly on a vertex of the edge is normalized
/// to use the higher of the two possible segmentIndexes
- virtual void addIntersection(algorithm::LineIntersector* li, std::size_t segmentIndex,
+ void addIntersection(algorithm::LineIntersector* li, std::size_t segmentIndex,
std::size_t geomIndex, std::size_t intIndex);
/// Update the IM with the contribution for this component.
@@ -233,11 +240,11 @@ public:
/// return true if the coordinate sequences of the Edges are identical
- virtual bool isPointwiseEqual(const Edge* e) const;
+ bool isPointwiseEqual(const Edge* e) const;
- virtual std::string print() const;
+ std::string print() const;
- virtual std::string printReverse() const;
+ std::string printReverse() const;
* equals is defined to be:
@@ -246,16 +253,16 @@ public:
* <b>iff</b>
* the coordinates of e1 are the same or the reverse of the coordinates in e2
- virtual bool equals(const Edge& e) const;
+ bool equals(const Edge& e) const;
- virtual bool
+ bool
equals(const Edge* e) const
assert(e);
return equals(*e);
- virtual const geom::Envelope* getEnvelope();
+ const geom::Envelope* getEnvelope();
diff --git a/include/geos/geomgraph/EdgeEnd.h b/include/geos/geomgraph/EdgeEnd.h
index f497d94e3..86ac11a87 100644
--- a/include/geos/geomgraph/EdgeEnd.h
+++ b/include/geos/geomgraph/EdgeEnd.h
@@ -51,7 +51,7 @@ namespace geomgraph { // geos.geomgraph
* "a has a greater angle with the x-axis than b".
* This ordering is used to sort EdgeEnds around a node.
-class GEOS_DLL EdgeEnd {
+class GEOS_DLL EdgeEnd /* non-final */ {
public:
@@ -101,7 +101,7 @@ public:
return label;
- virtual geom::Coordinate& getCoordinate() {
+ geom::Coordinate& getCoordinate() {
return p0;
@@ -111,19 +111,19 @@ public:
return p0;
- virtual geom::Coordinate& getDirectedCoordinate();
+ geom::Coordinate& getDirectedCoordinate();
- virtual int getQuadrant();
+ int getQuadrant();
- virtual double getDx();
+ double getDx();
- virtual double getDy();
+ double getDy();
- virtual void setNode(Node* newNode);
+ void setNode(Node* newNode);
- virtual Node* getNode();
+ Node* getNode();
- virtual int compareTo(const EdgeEnd* e) const;
+ int compareTo(const EdgeEnd* e) const;
* Implements the total order relation:
@@ -141,7 +141,7 @@ public:
* computeOrientation function can be used to decide
* the relative orientation of the vectors.
- virtual int compareDirection(const EdgeEnd* e) const;
+ int compareDirection(const EdgeEnd* e) const;
virtual void computeLabel(const algorithm::BoundaryNodeRule& bnr);
@@ -155,7 +155,7 @@ protected:
EdgeEnd(Edge* newEdge);
- virtual void init(const geom::Coordinate& newP0,
+ void init(const geom::Coordinate& newP0,
const geom::Coordinate& newP1);
private:
diff --git a/include/geos/geomgraph/EdgeEndStar.h b/include/geos/geomgraph/EdgeEndStar.h
index 40b20ad31..b249b60d5 100644
--- a/include/geos/geomgraph/EdgeEndStar.h
+++ b/include/geos/geomgraph/EdgeEndStar.h
@@ -60,7 +60,7 @@ namespace geomgraph { // geos.geomgraph
* @version 1.4
-class GEOS_DLL EdgeEndStar {
+class GEOS_DLL EdgeEndStar /* non-final */ {
public:
typedef std::set<EdgeEnd*, EdgeEndLT> container;
@@ -86,46 +86,46 @@ public:
* a Coordinate owned by the specific EdgeEnd happening
* to be the first in the star (ordered CCW)
- virtual geom::Coordinate& getCoordinate();
+ geom::Coordinate& getCoordinate();
const geom::Coordinate& getCoordinate() const;
- virtual std::size_t getDegree();
+ std::size_t getDegree();
- virtual iterator begin();
+ iterator begin();
- virtual iterator end();
+ iterator end();
- virtual reverse_iterator rbegin();
+ reverse_iterator rbegin();
- virtual reverse_iterator rend();
+ reverse_iterator rend();
- virtual const_iterator
+ const_iterator
begin() const
return edgeMap.begin();
+ const_iterator
end() const
return edgeMap.end();
- virtual container& getEdges();
+ container& getEdges();
- virtual EdgeEnd* getNextCW(EdgeEnd* ee);
+ EdgeEnd* getNextCW(EdgeEnd* ee);
virtual void computeLabelling(const std::vector<std::unique_ptr<GeometryGraph>>&geomGraph);
// throw(TopologyException *);
- virtual bool isAreaLabelsConsistent(const GeometryGraph& geomGraph);
+ bool isAreaLabelsConsistent(const GeometryGraph& geomGraph);
- virtual void propagateSideLabels(uint32_t geomIndex);
+ void propagateSideLabels(uint32_t geomIndex);
//virtual int findIndex(EdgeEnd *eSearch);
- virtual iterator find(EdgeEnd* eSearch);
+ iterator find(EdgeEnd* eSearch);
@@ -140,7 +140,7 @@ protected:
/** \brief
* Insert an EdgeEnd into the map.
- virtual void
+ void
insertEdgeEnd(EdgeEnd* e)
edgeMap.insert(e);
@@ -148,7 +148,7 @@ protected:
private:
- virtual geom::Location getLocation(uint32_t geomIndex,
+ geom::Location getLocation(uint32_t geomIndex,
const geom::Coordinate&p,
const std::vector<std::unique_ptr<GeometryGraph>>&geom);
@@ -158,9 +158,9 @@ private:
std::array<geom::Location, 2> ptInAreaLocation;
- virtual void computeEdgeEndLabels(const algorithm::BoundaryNodeRule&);
+ void computeEdgeEndLabels(const algorithm::BoundaryNodeRule&);
- virtual bool checkAreaLabelsConsistent(uint32_t geomIndex);
+ bool checkAreaLabelsConsistent(uint32_t geomIndex);
diff --git a/include/geos/geomgraph/EdgeIntersection.h b/include/geos/geomgraph/EdgeIntersection.h
index 7e43c910a..6a65131cf 100644
--- a/include/geos/geomgraph/EdgeIntersection.h
+++ b/include/geos/geomgraph/EdgeIntersection.h
@@ -39,7 +39,7 @@ namespace geomgraph { // geos.geomgraph
* The intersection point must be precise.
-class GEOS_DLL EdgeIntersection {
+class GEOS_DLL EdgeIntersection final {
public:
// the point of intersection
diff --git a/include/geos/geomgraph/EdgeIntersectionList.h b/include/geos/geomgraph/EdgeIntersectionList.h
index 428bbd490..7c8bdba89 100644
--- a/include/geos/geomgraph/EdgeIntersectionList.h
+++ b/include/geos/geomgraph/EdgeIntersectionList.h
@@ -54,7 +54,7 @@ namespace geomgraph { // geos.geomgraph
* Implements splitting an edge with intersections
* into multiple resultant edges.
-class GEOS_DLL EdgeIntersectionList {
+class GEOS_DLL EdgeIntersectionList final {
public:
// Instead of storing edge intersections in a set, as JTS does, we store them
// in a vector and then sort the vector if needed before iterating among the
diff --git a/include/geos/geomgraph/EdgeList.h b/include/geos/geomgraph/EdgeList.h
index 01e6675eb..56fd225c6 100644
--- a/include/geos/geomgraph/EdgeList.h
+++ b/include/geos/geomgraph/EdgeList.h
@@ -52,7 +52,7 @@ namespace geomgraph { // geos.geomgraph
* It supports locating edges
* that are pointwise equals to a target edge.
-class GEOS_DLL EdgeList {
+class GEOS_DLL EdgeList final {
private:
@@ -85,7 +85,7 @@ public:
ocaMap()
- virtual ~EdgeList() = default;
+ ~EdgeList() = default;
* Insert an edge unless it is already in the list
diff --git a/include/geos/geomgraph/EdgeNodingValidator.h b/include/geos/geomgraph/EdgeNodingValidator.h
index 287bf678a..6f844d1e0 100644
--- a/include/geos/geomgraph/EdgeNodingValidator.h
+++ b/include/geos/geomgraph/EdgeNodingValidator.h
* Throws an appropriate exception if an noding error is found.
-class GEOS_DLL EdgeNodingValidator {
+class GEOS_DLL EdgeNodingValidator final {
private:
std::vector<noding::SegmentString*>& toSegmentStrings(std::vector<Edge*>& edges);
diff --git a/include/geos/geomgraph/EdgeRing.h b/include/geos/geomgraph/EdgeRing.h
index 00f5d9a25..257453c81 100644
--- a/include/geos/geomgraph/EdgeRing.h
+++ b/include/geos/geomgraph/EdgeRing.h
@@ -54,7 +54,7 @@ namespace geos {
/** EdgeRing */
-class GEOS_DLL EdgeRing {
+class GEOS_DLL EdgeRing /* non-final */ {
public:
friend std::ostream& operator<< (std::ostream& os, const EdgeRing& er);
diff --git a/include/geos/geomgraph/GeometryGraph.h b/include/geos/geomgraph/GeometryGraph.h
index 322bb3fc8..78976cd68 100644
--- a/include/geos/geomgraph/GeometryGraph.h
+++ b/include/geos/geomgraph/GeometryGraph.h
@@ -68,7 +68,7 @@ namespace geomgraph { // geos.geomgraph
/** \brief
* A GeometryGraph is a graph that models a given Geometry.
-class GEOS_DLL GeometryGraph: public PlanarGraph {
+class GEOS_DLL GeometryGraph final: public PlanarGraph {
using PlanarGraph::add;
using PlanarGraph::findEdge;
diff --git a/include/geos/geomgraph/GraphComponent.h b/include/geos/geomgraph/GraphComponent.h
index 44ba7b71a..2ad8058fd 100644
--- a/include/geos/geomgraph/GraphComponent.h
+++ b/include/geos/geomgraph/GraphComponent.h
@@ -42,7 +42,7 @@ namespace geomgraph { // geos.geomgraph
* Each GraphComponent can carry a Label.
-class GEOS_DLL GraphComponent {
+class GEOS_DLL GraphComponent /* non-final */ {
public:
GraphComponent();
@@ -69,39 +69,39 @@ public:
label = newLabel;
- virtual void
+ void
setInResult(bool p_isInResult)
isInResultVar = p_isInResult;
- virtual bool
+ bool
isInResult() const
return isInResultVar;
- virtual void setCovered(bool isCovered);
- virtual bool
+ void setCovered(bool isCovered);
+ bool
isCovered() const
return isCoveredVar;
- virtual bool
+ bool
isCoveredSet() const
return isCoveredSetVar;
- virtual bool
+ bool
isVisited() const
return isVisitedVar;
- virtual void
+ void
setVisited(bool p_isVisited)
isVisitedVar = p_isVisited;
virtual bool isIsolated() const = 0;
- virtual void updateIM(geom::IntersectionMatrix& im);
+ void updateIM(geom::IntersectionMatrix& im);
protected:
Label label;
virtual void computeIM(geom::IntersectionMatrix& im) = 0;
diff --git a/include/geos/geomgraph/Label.h b/include/geos/geomgraph/Label.h
index 025e454ab..773b822ad 100644
--- a/include/geos/geomgraph/Label.h
+++ b/include/geos/geomgraph/Label.h
* with specific geometries.
-class GEOS_DLL Label {
+class GEOS_DLL Label final {
public:
diff --git a/include/geos/geomgraph/Node.h b/include/geos/geomgraph/Node.h
index 72991be0c..3f63f6426 100644
--- a/include/geos/geomgraph/Node.h
+++ b/include/geos/geomgraph/Node.h
@@ -56,7 +56,7 @@ namespace geos {
/** \brief The node component of a geometry graph. */
-class GEOS_DLL Node: public GraphComponent {
+class GEOS_DLL Node /* non-final */: public GraphComponent {
using GraphComponent::setLabel;
public:
@@ -67,18 +67,18 @@ public:
~Node() override;
- virtual const geom::Coordinate& getCoordinate() const;
+ const geom::Coordinate& getCoordinate() const;
- virtual EdgeEndStar* getEdges();
+ EdgeEndStar* getEdges();
bool isIsolated() const override;
/** \brief
* Add the edge to the list of edges at this node
- virtual void add(EdgeEnd* e);
+ void add(EdgeEnd* e);
- virtual void mergeLabel(const Node& n);
+ void mergeLabel(const Node& n);
/** \brief
* To merge labels for two nodes,
@@ -87,15 +87,15 @@ public:
* The location for the corresponding node LabelElement is set
* to the result, as long as the location is non-null.
- virtual void mergeLabel(const Label& label2);
+ void mergeLabel(const Label& label2);
- virtual void setLabel(uint8_t argIndex, geom::Location onLocation);
+ void setLabel(uint8_t argIndex, geom::Location onLocation);
/** \brief
* Updates the label of a node to BOUNDARY,
* obeying the mod-2 boundaryDetermination rule.
- virtual void setLabelBoundary(uint8_t argIndex);
+ void setLabelBoundary(uint8_t argIndex);
* The location for a given eltIndex for a node will be one
@@ -105,13 +105,13 @@ public:
* in the boundary.
* The merged location is the maximum of the two input values.
- virtual geom::Location computeMergedLocation(const Label& label2, uint8_t eltIndex);
+ geom::Location computeMergedLocation(const Label& label2, uint8_t eltIndex);
- virtual const std::vector<double>& getZ() const;
+ const std::vector<double>& getZ() const;
- virtual void addZ(double);
+ void addZ(double);
/** \brief
* Tests whether any incident edge is flagged as
@@ -124,7 +124,7 @@ public:
* @return <code>true</code> if any indicident edge in the in
* the result
- virtual bool isIncidentEdgeInResult() const;
+ bool isIncidentEdgeInResult() const;
protected:
diff --git a/include/geos/geomgraph/NodeFactory.h b/include/geos/geomgraph/NodeFactory.h
index 641de8bc7..fe577b610 100644
--- a/include/geos/geomgraph/NodeFactory.h
+++ b/include/geos/geomgraph/NodeFactory.h
@@ -35,7 +35,7 @@ class Node;
namespace geos {
-class GEOS_DLL NodeFactory {
+class GEOS_DLL NodeFactory /* non-final */ {
public:
virtual Node* createNode(const geom::Coordinate& coord) const;
static const NodeFactory& instance();
diff --git a/include/geos/geomgraph/NodeMap.h b/include/geos/geomgraph/NodeMap.h
index e30969a79..a3a769e11 100644
--- a/include/geos/geomgraph/NodeMap.h
+++ b/include/geos/geomgraph/NodeMap.h
@@ -47,7 +47,7 @@ class NodeFactory;
namespace geos {
-class GEOS_DLL NodeMap {
+class GEOS_DLL NodeMap final {
public:
typedef std::map<geom::Coordinate*, std::unique_ptr<Node>, geom::CoordinateLessThan> container;
@@ -65,8 +65,6 @@ public:
/// keep it alive for the whole NodeMap lifetime
NodeMap(const NodeFactory& newNodeFact);
- virtual ~NodeMap();
Node* addNode(const geom::Coordinate& coord);
Node* addNode(Node* n);
diff --git a/include/geos/geomgraph/PlanarGraph.h b/include/geos/geomgraph/PlanarGraph.h
index 8ba0c8c63..8684d3b7a 100644
--- a/include/geos/geomgraph/PlanarGraph.h
+++ b/include/geos/geomgraph/PlanarGraph.h
@@ -69,7 +69,7 @@ namespace geomgraph { // geos.geomgraph
* different graphs
-class GEOS_DLL PlanarGraph {
+class GEOS_DLL PlanarGraph /* non-final */ {
public:
/** \brief
@@ -105,36 +105,36 @@ public:
virtual ~PlanarGraph();
- virtual std::vector<Edge*>::iterator getEdgeIterator();
+ std::vector<Edge*>::iterator getEdgeIterator();
- virtual std::vector<EdgeEnd*>* getEdgeEnds();
+ std::vector<EdgeEnd*>* getEdgeEnds();
- virtual bool isBoundaryNode(uint8_t geomIndex, const geom::Coordinate& coord);
+ bool isBoundaryNode(uint8_t geomIndex, const geom::Coordinate& coord);
- virtual NodeMap::iterator getNodeIterator();
+ NodeMap::iterator getNodeIterator();
- virtual void getNodes(std::vector<Node*>&);
+ void getNodes(std::vector<Node*>&);
- virtual Node* addNode(Node* node);
+ Node* addNode(Node* node);
- virtual Node* addNode(const geom::Coordinate& coord);
+ Node* addNode(const geom::Coordinate& coord);
* @return the node if found; null otherwise
- virtual Node* find(geom::Coordinate& coord);
+ Node* find(geom::Coordinate& coord);
/** \brief
* Add a set of edges to the graph. For each edge two DirectedEdges
* will be created. DirectedEdges are NOT linked by this method.
- virtual void addEdges(const std::vector<Edge*>& edgesToAdd);
+ void addEdges(const std::vector<Edge*>& edgesToAdd);
- virtual void linkResultDirectedEdges();
+ void linkResultDirectedEdges();
- virtual void linkAllDirectedEdges();
+ void linkAllDirectedEdges();
/** \brief
* Returns the EdgeEnd which has edge e as its base edge
@@ -143,7 +143,7 @@ public:
* @return the edge, if found
* <code>null</code> if the edge was not found
- virtual EdgeEnd* findEdgeEnd(Edge* e);
+ EdgeEnd* findEdgeEnd(Edge* e);
/** \brief
* Returns the edge whose first two coordinates are p0 and p1
@@ -151,7 +151,7 @@ public:
- virtual Edge* findEdge(const geom::Coordinate& p0,
+ Edge* findEdge(const geom::Coordinate& p0,
const geom::Coordinate& p1);
/** \brief
@@ -161,12 +161,12 @@ public:
- virtual Edge* findEdgeInSameDirection(const geom::Coordinate& p0,
+ Edge* findEdgeInSameDirection(const geom::Coordinate& p0,
- virtual std::string printEdges();
+ std::string printEdges();
- virtual NodeMap* getNodeMap();
+ NodeMap* getNodeMap();
protected:
@@ -176,7 +176,7 @@ protected:
std::vector<EdgeEnd*>* edgeEndList;
- virtual void insertEdge(Edge* e);
+ void insertEdge(Edge* e);
private:
diff --git a/include/geos/operation/relate/RelateNode.h b/include/geos/operation/relate/RelateNode.h
index 5f7727dd1..047533d3f 100644
--- a/include/geos/operation/relate/RelateNode.h
+++ b/include/geos/operation/relate/RelateNode.h
@@ -42,7 +42,7 @@ namespace relate { // geos::operation::relate
* Represents a node in the topological graph used to compute spatial
* relationships.
-class GEOS_DLL RelateNode: public geomgraph::Node {
+class GEOS_DLL RelateNode final: public geomgraph::Node {
public:
diff --git a/src/geomgraph/EdgeList.cpp b/src/geomgraph/EdgeList.cpp
index 41a6f55f6..d32f51930 100644
--- a/src/geomgraph/EdgeList.cpp
+++ b/src/geomgraph/EdgeList.cpp
@@ -140,7 +140,7 @@ operator<< (std::ostream& os, const EdgeList& el)
os << "EdgeList: " << std::endl;
for(std::size_t j = 0, s = el.edges.size(); j < s; ++j) {
- Edge* e = el.edges[j];
+ const Edge* e = el.edges[j];
os << " " << *e << std::endl;
return os;
diff --git a/src/geomgraph/NodeMap.cpp b/src/geomgraph/NodeMap.cpp
index 331fbaa98..3624cc83e 100644
--- a/src/geomgraph/NodeMap.cpp
+++ b/src/geomgraph/NodeMap.cpp
@@ -46,8 +46,6 @@ NodeMap::NodeMap(const NodeFactory& newNodeFact)
#endif
-NodeMap::~NodeMap() = default;
Node*
NodeMap::addNode(const Coordinate& coord)
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index 53f1bc627..90a18ed44 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -361,10 +361,10 @@ RelateComputer::computeIntersectionNodes(uint8_t argIndex)
void
RelateComputer::labelIntersectionNodes(uint8_t argIndex)
- std::vector<Edge*>* edges = arg[argIndex]->getEdges();
- for(Edge* e: *edges) {
+ const std::vector<Edge*>* edges = arg[argIndex]->getEdges();
+ for(const Edge* e: *edges) {
Location eLoc = e->getLabel().getLocation(argIndex);
- EdgeIntersectionList& eiL = e->getEdgeIntersectionList();
+ const EdgeIntersectionList& eiL = e->getEdgeIntersectionList();
for(const EdgeIntersection& ei : eiL) {
RelateNode* n = static_cast<RelateNode*>(nodes.find(ei.coord));
Summary of changes:
include/geos/geomgraph/DirectedEdge.h | 2 +-
include/geos/geomgraph/Edge.h | 55 +++++++++++++++------------
include/geos/geomgraph/EdgeEnd.h | 22 +++++------
include/geos/geomgraph/EdgeEndStar.h | 36 +++++++++---------
include/geos/geomgraph/EdgeIntersection.h | 2 +-
include/geos/geomgraph/EdgeIntersectionList.h | 2 +-
include/geos/geomgraph/EdgeList.h | 4 +-
include/geos/geomgraph/EdgeNodingValidator.h | 2 +-
include/geos/geomgraph/EdgeRing.h | 2 +-
include/geos/geomgraph/GeometryGraph.h | 2 +-
include/geos/geomgraph/GraphComponent.h | 18 ++++-----
include/geos/geomgraph/Label.h | 2 +-
include/geos/geomgraph/Node.h | 26 ++++++-------
include/geos/geomgraph/NodeFactory.h | 2 +-
include/geos/geomgraph/NodeMap.h | 4 +-
include/geos/geomgraph/PlanarGraph.h | 38 +++++++++---------
include/geos/operation/relate/RelateNode.h | 2 +-
src/geomgraph/EdgeList.cpp | 2 +-
src/geomgraph/NodeMap.cpp | 2 -
src/operation/relate/RelateComputer.cpp | 6 +--
20 files changed, 117 insertions(+), 114 deletions(-)
hooks/post-receive
More information about the geos-commits
