[geos-commits] [SCM] GEOS branch main updated. 654ad34cf7381500acc545d2bc8e4317026cefdd
Thu Aug 22 15:14:06 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  654ad34cf7381500acc545d2bc8e4317026cefdd (commit)
      from  937cf5f58d6071b1ca163ed2ce55488c1f95c57e (commit)
revisions in full, below.
commit 654ad34cf7381500acc545d2bc8e4317026cefdd
Author: Oreille <33065839+Oreilles at users.noreply.github.com>
Date:   Fri Aug 23 00:13:39 2024 +0200
    FIX: 3D coordinates handling of GeoJSON MultiLineString (#1151)
diff --git a/src/io/GeoJSONReader.cpp b/src/io/GeoJSONReader.cpp
index fe53b63c7..0f0817e32 100644
--- a/src/io/GeoJSONReader.cpp
+++ b/src/io/GeoJSONReader.cpp
@@ -317,7 +317,7 @@ std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(
         coordinates->reserve(coords.size());
         for (const auto& coord : coords) {
             const geom::Coordinate& c = readCoordinate(coord);
-            coordinates->add(geom::Coordinate{c.x, c.y});
+            coordinates->add(c);
         lines.push_back(geometryFactory.createLineString(std::move(coordinates)));
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index 2a8e7c030..c5ff39db8 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -596,4 +596,28 @@ void object::test<38>
     ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 3u);
+// Read a GeoJSON MultiLineString with three dimensions
+template<>
+template<>
+void object::test<39>
+    std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[[[30,10,1],[40,40,2],[20,40,4],[10,20,8],[30,10,16]]]}" };
+    GeomPtr geom(geojsonreader.read(geojson));
+    ensure_equals(geom->toText(), "MULTILINESTRING Z ((30 10 1, 40 40 2, 20 40 4, 10 20 8, 30 10 16))");
+    ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 3u);
+// Read a GeoJSON MultiLineString with mixed dimensions
+template<>
+template<>
+void object::test<40>
+    std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[[[30,10],[40,40,2],[20,40],[10,20,8],[30,10]]]}" };
+    ensure_equals(geom->toText(), "MULTILINESTRING Z ((30 10 NaN, 40 40 2, 20 40 NaN, 10 20 8, 30 10 NaN))");
Summary of changes:
 src/io/GeoJSONReader.cpp            |  2 +-
 tests/unit/io/GeoJSONReaderTest.cpp | 24 ++++++++++++++++++++++++
 2 files changed, 25 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
