[geos-commits] [SCM] GEOS branch main updated. ef8f6d974f4d4e8fed1b7f3263edb633da5c98fb
Tue Dec 10 15:51:28 PST 2024
the project "GEOS".
The branch, main has been updated
       via  ef8f6d974f4d4e8fed1b7f3263edb633da5c98fb (commit)
      from  dd0fdc59b9fd9aa7d0bc4eda9c16ff968e91815a (commit)
revisions in full, below.
commit ef8f6d974f4d4e8fed1b7f3263edb633da5c98fb
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Dec 10 15:50:59 2024 -0800
    Add geosOp bufferJoin and offsetCurveJoin
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index d55d7b88f..1e2dbf52b 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -303,6 +303,26 @@ std::vector<GeometryOpCreator> opRegistry {
         return new Result( geom->buffer( d, quadrantSegments ) );
+{"bufferJoin", [](std::string name) { return GeometryOp::create(name,
+    catConst,
+    "compute the buffer of geometry by a distance, with join >0 = QS, 0 = Bevel, <0 = Mitre limit",
+    [](const std::unique_ptr<Geometry>& geom, double d, int join) {
+        geos::operation::buffer::BufferParameters param;
+        if (join > 0) {
+            param.setQuadrantSegments( join );
+            param.setJoinStyle(geos::operation::buffer::BufferParameters::JOIN_ROUND);
+        else if (join == 0) {
+            param.setJoinStyle(geos::operation::buffer::BufferParameters::JOIN_BEVEL);
+        else if (join < 0) {
+            param.setJoinStyle(geos::operation::buffer::BufferParameters::JOIN_MITRE);
+            param.setMitreLimit( -join );
+        std::unique_ptr<Geometry> g3 = geos::operation::buffer::BufferOp::bufferOp(geom.get(), d, param);
+        return new Result( g3.release() );
 {"offsetCurve", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute the offset curve of geometry by a distance",
@@ -312,6 +332,27 @@ std::vector<GeometryOpCreator> opRegistry {
+{"offsetCurveJoin", [](std::string name) { return GeometryOp::create(name,
+    catConst,
+    "compute the offset curve of geometry by a distance, with join >0 = QS, 0 = Bevel, <0 = Mitre limit",
+        int quadSegs = 0;
+        geos::operation::buffer::BufferParameters::JoinStyle joinStyle = geos::operation::buffer::BufferParameters::JOIN_ROUND;
+        double miterLimit = 0;
+        if (join > 0) {
+            quadSegs = join;
+            joinStyle = geos::operation::buffer::BufferParameters::JOIN_BEVEL;
+            joinStyle = geos::operation::buffer::BufferParameters::JOIN_MITRE;
+            miterLimit = -join;
+        std::unique_ptr<Geometry> g3 = geos::operation::buffer::OffsetCurve::getCurve(*geom, d, quadSegs, joinStyle, miterLimit);
 {"OLDoffsetCurve", [](std::string name) { return GeometryOp::create(name,
     catConst,
Summary of changes:
 util/geosop/GeometryOp.cpp | 41 +++++++++++++++++++++++++++++++++++++++++
 1 file changed, 41 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
