[geos-commits] [SCM] GEOS branch main-relate-ng updated. 2c9887a0df473f999f8d8fb89e56077d25bf7d50
Wed Jul 3 13:18:19 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
       via  2c9887a0df473f999f8d8fb89e56077d25bf7d50 (commit)
      from  3c040699dca4eb10c711c09f279cc93235528a4e (commit)
revisions in full, below.
commit 2c9887a0df473f999f8d8fb89e56077d25bf7d50
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 3 13:14:41 2024 -0700
    Add LinearBoundaryTest and fix LinearBoundary cardinality counter
diff --git a/include/geos/operation/relateng/LineStringExtracter.h b/include/geos/operation/relateng/LineStringExtracter.h
new file mode 100644
index 000000000..fc7298f88
--- /dev/null
+++ b/include/geos/operation/relateng/LineStringExtracter.h
@@ -0,0 +1,77 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (c) 2024 Martin Davis
+ * Copyright (C) 2024 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <geos/geom/GeometryFilter.h>
+#include <geos/export.h>
+#include <memory>
+#include <vector>
+// Forward declarations
+namespace geos {
+namespace geom {
+    class LineString;
+    class Geometry;
+using geos::geom::LineString;
+using geos::geom::Geometry;
+using geos::geom::GeometryFilter;
+namespace geos {      // geos.
+namespace operation { // geos.operation
+namespace relateng {  // geos.operation.relateng
+class GEOS_DLL LineStringExtracter : public GeometryFilter {
+private:
+    std::vector<const LineString*>& comps;
+public:
+    LineStringExtracter(std::vector<const LineString*>& p_comps)
+        : comps(p_comps)
+    void filter_ro(const geom::Geometry* geom) override;
+    static void getLines(const Geometry* geom, std::vector<const LineString*>& lines);
+    static std::vector<const LineString*> getLines(const Geometry* geom);
+    * Extracts the {@link LineString} elements from a single {@link Geometry}
+    * and returns them as either a {@link LineString} or {@link MultiLineString}.
+    * @param geom the geometry from which to extract
+    * @return a linear geometry
+    // static std::unique_ptr<Geometry> getGeometry(const Geometry* geom);
+} // namespace geos.operation.relateng
diff --git a/src/operation/relateng/LineStringExtracter.cpp b/src/operation/relateng/LineStringExtracter.cpp
index 000000000..b1c229cba
--- /dev/null
+++ b/src/operation/relateng/LineStringExtracter.cpp
@@ -0,0 +1,87 @@
+#include <geos/operation/relateng/LineStringExtracter.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/LineString.h>
+#include <geos/constants.h>
+#include <sstream>
+using geos::geom::GeometryFactory;
+/* public static */
+void
+LineStringExtracter::getLines(const Geometry* geom, std::vector<const LineString*>& lines)
+    if (geom->getGeometryTypeId() == geom::GEOS_LINESTRING) {
+        lines.push_back(static_cast<const LineString*>(geom));
+    else if (geom->isCollection()) {
+        LineStringExtracter lse(lines);
+        geom->apply_ro(&lse);
+    // skip non-LineString elemental geometries
+    return;
+std::vector<const LineString*>
+LineStringExtracter::getLines(const Geometry* geom)
+    std::vector<const LineString*> lines;
+    getLines(geom, lines);
+    return lines;
+// std::unique_ptr<Geometry>
+// LineStringExtracter::getGeometry(const Geometry* geom)
+//     std::vector<const LineString*> lines;
+//     getLines(geom, lines);
+//     return geom->getFactory()->buildGeometry(lines);
+/* public */
+void
+LineStringExtracter::filter_ro(const Geometry* geom)
+        comps.push_back(static_cast<const LineString*>(geom));
+} // namespace geos.operation.overlayng
diff --git a/src/operation/relateng/LinearBoundary.cpp b/src/operation/relateng/LinearBoundary.cpp
index 84caee1c1..5b4dfbae7 100644
--- a/src/operation/relateng/LinearBoundary.cpp
+++ b/src/operation/relateng/LinearBoundary.cpp
@@ -100,9 +100,10 @@ LinearBoundary::addEndpoint(const CoordinateXY *p, Coordinate::ConstIntMap& vert
     if (it != vertexDegree.end()) {
         dim = it->second;
-    dim++;
-    std::pair<const CoordinateXY*, int> entry(p, dim);
-    vertexDegree.insert(entry);
+    // dim++;
+    // std::pair<const CoordinateXY*, int> entry(p, dim);
+    // vertexDegree.insert(entry);
+    vertexDegree[p] = dim + 1;
diff --git a/tests/unit/operation/relateng/LinearBoundaryTest.cpp b/tests/unit/operation/relateng/LinearBoundaryTest.cpp
index 000000000..620c3bcb9
--- /dev/null
+++ b/tests/unit/operation/relateng/LinearBoundaryTest.cpp
@@ -0,0 +1,147 @@
+// Test Suite for geos::operation::relateng::LinearBoundary class.
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/algorithm/BoundaryNodeRule.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Location.h>
+#include <geos/io/WKTReader.h>
+//#include <geos/io/WKTWriter.h>
+#include <geos/operation/relateng/LinearBoundary.h>
+// std
+#include <memory>
+using namespace geos::geom;
+using namespace geos::operation::relateng;
+using geos::algorithm::BoundaryNodeRule;
+using geos::io::WKTReader;
+// using geos::io::WKTWriter;
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_linearboundary_data {
+    WKTReader r;
+    // WKTWriter w;
+    void
+    checkLinearBoundary(const std::string& wkt, const BoundaryNodeRule& bnr, const std::string& wktBdyExpected)
+        std::unique_ptr<Geometry> geom = r.read(wkt);
+        auto lines = extractLines(*geom);
+        LinearBoundary lb(lines, bnr);
+        bool hasBoundaryExpected = wktBdyExpected.length() == 0 ? false : true;
+        ensure_equals("hasBoundaryExpected == lb.hasBoundary", hasBoundaryExpected, lb.hasBoundary());
+        checkBoundaryPoints(lb, *geom, wktBdyExpected);
+    void
+    checkBoundaryPoints(LinearBoundary& lb, Geometry& geom, const std::string& wktBdyExpected)
+        std::set<CoordinateXY> bdySet;
+        extractPoints(wktBdyExpected, bdySet);
+        for (const CoordinateXY& p : bdySet) {
+            ensure("checkBoundaryPoints1", lb.isBoundary(&p));
+        auto allPts = geom.getCoordinates();
+        for (std::size_t i = 0; i < allPts->size(); i++) {
+            CoordinateXY p;
+            allPts->getAt(i, p);
+            if (bdySet.find(p) == bdySet.end()) { // p not in bdySet
+                ensure("checkBoundaryPoints2", !lb.isBoundary(&p));
+    void
+    extractPoints(const std::string& wkt, std::set<CoordinateXY>& ptSet)
+        if (wkt.length() == 0) return;
+        auto geom = r.read(wkt);
+        auto pts = geom->getCoordinates();
+        for (std::size_t i = 0; i < pts->size(); i++) {
+            CoordinateXY p;
+            pts->getAt(i, p);
+            ptSet.insert(p);
+        return;
+    extractLines(const Geometry& geom)
+        return LineStringExtracter::getLines(&geom);
+typedef test_group<test_linearboundary_data> group;
+typedef group::object object;
+group test_linearboundary_group("geos::operation::relateng::LinearBoundary");
+// Test Cases
+// testLineMod2
+template<>
+template<>
+void object::test<1> ()
+    checkLinearBoundary("LINESTRING (0 0, 9 9)",
+        BoundaryNodeRule::getBoundaryRuleMod2(),
+        "MULTIPOINT((0 0), (9 9))");
+// testLines2Mod2
+template<>
+template<>
+void object::test<2> ()
+    checkLinearBoundary("MULTILINESTRING ((0 0, 9 9), (9 9, 5 1))",
+        "MULTIPOINT((0 0), (5 1))");
+// testLines3Mod2
+template<>
+template<>
+void object::test<3> ()
+    checkLinearBoundary("MULTILINESTRING ((0 0, 9 9), (9 9, 5 1), (9 9, 1 5))",
+        "MULTIPOINT((0 0), (5 1), (1 5), (9 9))");
+// testLines3Monvalent
+template<>
+template<>
+void object::test<4> ()
+        BoundaryNodeRule::getBoundaryMonovalentEndPoint(),
+        "MULTIPOINT((0 0), (5 1), (1 5))");
+} // namespace tut
Summary of changes:
 .../geos/operation/relateng/LineStringExtracter.h  |  77 +++++++++++
 src/operation/relateng/LineStringExtracter.cpp     |  87 ++++++++++++
 src/operation/relateng/LinearBoundary.cpp          |   7 +-
 .../unit/operation/relateng/LinearBoundaryTest.cpp | 147 +++++++++++++++++++++
 4 files changed, 315 insertions(+), 3 deletions(-)
 create mode 100644 include/geos/operation/relateng/LineStringExtracter.h
 create mode 100644 src/operation/relateng/LineStringExtracter.cpp
 create mode 100644 tests/unit/operation/relateng/LinearBoundaryTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
