[geos-commits] [SCM] GEOS branch main-relate-ng updated. 65803b8f139ffa4d4c36aa0811a3827d3fa3d280
git at osgeo.org
git at osgeo.org
Mon Jul 8 17:56:23 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
via 65803b8f139ffa4d4c36aa0811a3827d3fa3d280 (commit)
from 2c9887a0df473f999f8d8fb89e56077d25bf7d50 (commit)
revisions in full, below.
commit 65803b8f139ffa4d4c36aa0811a3827d3fa3d280
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Jul 3 16:28:13 2024 -0700
Fix PolygonNodeConverter sorting
diff --git a/src/operation/relateng/PolygonNodeConverter.cpp b/src/operation/relateng/PolygonNodeConverter.cpp
index 54c080956..e9b1e9c41 100644
--- a/src/operation/relateng/PolygonNodeConverter.cpp
+++ b/src/operation/relateng/PolygonNodeConverter.cpp
@@ -43,10 +43,11 @@ PolygonNodeConverter::convert(std::vector<const NodeSection*>& polySections)
const NodeSection* ns1,
const NodeSection* ns2)
- return PolygonNodeTopology::compareAngle(
+ int comp = PolygonNodeTopology::compareAngle(
ns1->nodePt(),
ns1->getVertex(0),
ns2->getVertex(0));
+ return comp < 0;
std::sort(polySections.begin(), polySections.end(), comparator);
diff --git a/tests/unit/operation/relateng/PolygonNodeConverterTest.cpp b/tests/unit/operation/relateng/PolygonNodeConverterTest.cpp
index 4a4899f70..6037df049 100644
--- a/tests/unit/operation/relateng/PolygonNodeConverterTest.cpp
+++ b/tests/unit/operation/relateng/PolygonNodeConverterTest.cpp
@@ -9,6 +9,7 @@
#include <geos/io/WKTWriter.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/Location.h>
+#include <geos/geom/Dimension.h>
#include <geos/operation/relateng/PolygonNodeConverter.h>
#include <geos/algorithm/PolygonNodeTopology.h>
@@ -30,67 +31,81 @@ namespace tut {
// Common data used by all tests
struct test_polygonnodeconverter_data {
- WKTReader r;
- // WKTWriter w;
+ NodeSection* sectionShell(double v0x, double v0y, double nx, double ny, double v1x, double v1y) {
+ return section(0, v0x, v0y, nx, ny, v1x, v1y);
- std::unique_ptr<CoordinateSequence>
- readPts(const std::string& wkt)
+ NodeSection* sectionHole(double v0x, double v0y, double nx, double ny, double v1x, double v1y) {
+ return section(1, v0x, v0y, nx, ny, v1x, v1y);
+ NodeSection* section(int ringId, double v0x, double v0y, double nx, double ny, double v1x, double v1y) {
+ return new NodeSection(true, Dimension::A, 1, ringId, nullptr, false,
+ new Coordinate(v0x, v0y), new Coordinate(nx, ny), new Coordinate(v1x, v1y));
+ std::vector<const NodeSection*>
+ toPtrVector(const std::vector<std::unique_ptr<NodeSection>>& input)
- std::unique_ptr<Geometry> line = r.read(wkt);
- return line->getCoordinates();
+ std::vector<const NodeSection*> vec;
+ for(std::size_t i = 0, n = input.size(); i < n; ++i) {
+ vec.emplace_back(input[i].get());
+ return vec;
+ bool checkSectionsEqual(std::vector<const NodeSection*>& ns1,
+ std::vector<const NodeSection*>& ns2) {
+ if (ns1.size() != ns2.size())
+ return false;
+ sort(ns1);
+ sort(ns2);
+ for (std::size_t i = 0; i < ns1.size(); i++) {
+ int comp = ns1[i]->compareTo(ns2[i]);
+ if (comp != 0)
+ return false;
+ return true;
+ void sort(std::vector<const NodeSection*>& ns) {
+ // Comparator lambda for sort support
+ auto comparator = [](
+ const NodeSection* a,
+ const NodeSection* b)
+ return a->compareTo(b) < 0;
+ std::sort(ns.begin(), ns.end(), comparator);
+ void
+ freeNodeSections(std::vector<const NodeSection*>& ns) {
+ for (std::size_t i = 0; i < ns.size(); i++) {
+ delete ns[i]->getVertex(0);
+ delete ns[i]->getVertex(1);
+ delete ns[i]->nodePt();
+ delete ns[i];
void
- checkCrossing(const std::string& wktA, const std::string& wktB)
+ checkConversion(std::vector<const NodeSection *>& input,
+ std::vector<const NodeSection *>& expected)
- checkCrossing(wktA, wktB, true);
- void
- checkNonCrossing(const std::string& wktA, const std::string& wktB)
- checkCrossing(wktA, wktB, false);
- void
- checkCrossing(const std::string& wktA, const std::string& wktB, bool isExpected)
- auto a = readPts(wktA);
- auto b = readPts(wktB);
- // assert: a[1] = b[1]
- bool isCrossing = PolygonNodeTopology::isCrossing(
- &(a->getAt<CoordinateXY>(1)),
- &(a->getAt<CoordinateXY>(0)),
- &(a->getAt<CoordinateXY>(2)),
- &(b->getAt<CoordinateXY>(0)),
- &(b->getAt<CoordinateXY>(2)));
- ensure("checkCrossing", isCrossing == isExpected);
- void
- checkInterior(const std::string& wktA, const std::string& wktB)
- checkInteriorSegment(wktA, wktB, true);
- void
- checkExterior(const std::string& wktA, const std::string& wktB)
- checkInteriorSegment(wktA, wktB, false);
- void
- checkInteriorSegment(const std::string& wktA, const std::string& wktB, bool isExpected)
- bool isInterior = PolygonNodeTopology::isInteriorSegment(
- &(b->getAt<CoordinateXY>(1)));
- ensure("checkInteriorSegment", isInterior == isExpected);
+ auto actual = PolygonNodeConverter::convert( input );
+ auto actualPtr = toPtrVector(actual);
+ bool isEqual = checkSectionsEqual(actualPtr, expected);
+ freeNodeSections(input);
+ freeNodeSections(expected);
+ if (! isEqual) {
+ System.out.println("Expected:" + formatSections(expected));
+ System.out.println("Actual:" + formatSections(actual));
+ ensure("checkConversion", isEqual);
@@ -105,68 +120,94 @@ group test_polygonnodeconverter_group("geos::operation::relateng::PolygonNodeCon
-// testNonCrossing
+// testShells
template<>
template<>
void object::test<1> ()
- checkCrossing("LINESTRING (500 1000, 1000 1000, 1000 1500)",
- "LINESTRING (1000 500, 1000 1000, 500 1500)");
+ std::vector<const NodeSection *> input{
+ sectionShell( 1,1, 5,5, 9,9 ),
+ sectionShell( 8,9, 5,5, 6,9 ),
+ sectionShell( 4,9, 5,5, 2,9 )
+ std::vector<const NodeSection *> expected{
+ checkConversion(input, expected);
-// testNonCrossingQuadrant2
+// testShellAndHole
template<>
template<>
void object::test<2> ()
- checkNonCrossing("LINESTRING (500 1000, 1000 1000, 1000 1500)",
- "LINESTRING (300 1200, 1000 1000, 500 1500)");
+ sectionHole( 6,0, 5,5, 4,0 )
+ sectionShell( 1,1, 5,5, 4,0 ),
+ sectionShell( 6,0, 5,5, 9,9 )
-// testNonCrossingQuadrant4
+// testShellsAndHoles
template<>
template<>
void object::test<3> ()
- "LINESTRING (1000 500, 1000 1000, 1500 1000)");
+ sectionHole( 6,0, 5,5, 4,0 ),
+ sectionShell( 8,8, 5,5, 1,8 ),
+ sectionHole( 4,8, 5,5, 6,8 )
+ sectionShell( 6,0, 5,5, 9,9 ),
+ sectionShell( 4,8, 5,5, 1,8 ),
+ sectionShell( 8,8, 5,5, 6,8 )
-// testNonCrossingCollinear
-template<>
-template<>
-void object::test<4> ()
- checkNonCrossing("LINESTRING (3 1, 5 5, 9 9)",
- "LINESTRING (2 1, 5 5, 9 9)");
-// testNonCrossingBothCollinear
+// testShellAnd2Holes
template<>
template<>
void object::test<5> ()
- "LINESTRING (3 1, 5 5, 9 9)");
+ sectionHole( 7,0, 5,5, 6,0 ),
+ sectionHole( 4,0, 5,5, 3,0 )
+ sectionShell( 1,1, 5,5, 3,0 ),
+ sectionShell( 4,0, 5,5, 6,0 ),
+ sectionShell( 7,0, 5,5, 9,9 )
-// testInteriorSegment
+// testHoles
template<>
template<>
void object::test<6> ()
- checkInterior("LINESTRING (5 9, 5 5, 9 5)",
- "LINESTRING (5 5, 0 0)");
+ sectionShell( 7,0, 5,5, 3,0 )
-// testExteriorSegment
-template<>
-template<>
-void object::test<7> ()
- checkExterior("LINESTRING (5 9, 5 5, 9 5)",
- "LINESTRING (5 5, 9 9)");
} // namespace tut
Summary of changes:
src/operation/relateng/PolygonNodeConverter.cpp | 3 +-
.../relateng/PolygonNodeConverterTest.cpp | 201 +++++++++++++--------
2 files changed, 123 insertions(+), 81 deletions(-)
hooks/post-receive
More information about the geos-commits
