[geos-commits] [SCM] GEOS branch main updated. 7791300797a36a326b27d7eb031ac4a600b90a07
git at osgeo.org
git at osgeo.org
Sat Jul 27 02:11:32 PDT 2024
the project "GEOS".
The branch, main has been updated
via 7791300797a36a326b27d7eb031ac4a600b90a07 (commit)
from b17470d44d875fe23ba682ebe7d63602911eb2c5 (commit)
revisions in full, below.
commit 7791300797a36a326b27d7eb031ac4a600b90a07
Author: Mike Taves <mwtoews at gmail.com>
Date: Sat Jul 27 21:11:14 2024 +1200
CI: re-add MSBuild as a separate job, use matrix for ninja builds (#1130)
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 73760cccc..1f3771583 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -350,57 +350,88 @@ jobs:
working-directory: ./build
run: ctest --output-on-failure
- windows-msvc:
- name: 'Windows (Visual Studio)'
- strategy:
- fail-fast: false
- matrix:
- ci:
- - build_type: Debug
- cxxstd: 14
- os: windows-2022
- vcdir: C:\Program Files\Microsoft Visual Studio\2022\Enterprise
- - build_type: Release
- cxxstd: 14
- os: windows-2019
- vcdir: C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise
- runs-on: ${{ matrix.ci.os }}
+ windows-msvc-msbuild:
+ name: Windows (MSVC MSBuild)
+ runs-on: windows-2022
steps:
- name: 'Check Out'
uses: actions/checkout at v4
- - name: 'Setup'
- run: choco install ccache ninja
+ # ccache not supported for this generator and/or Debug
+ - name: 'Build'
+ shell: cmd
+ run: |
+ md build
+ cd build
+ cmake --version
+ cmake ^
+ -G "Visual Studio 17 2022" ^
+ -D CMAKE_BUILD_TYPE=Debug ^
+ -D CMAKE_CXX_STANDARD=17 ^
+ -D BUILD_SHARED_LIBS=ON ^
+ IF %ERRORLEVEL% NEQ 0 exit /B 1
+ cmake --build . --config Debug -j 4 -- /p:CL_MPcount=4
+ - name: 'Test'
+ working-directory: build
+ run: ctest --output-on-failure -C Debug
+ windows-msvc-ninja:
+ name: Windows (MSVC Ninja)
+ strategy:
+ fail-fast: false
+ matrix:
+ ci:
+ - os: windows-2019
+ cxxstd: 14
+ arch: x86
+ - os: windows-2022
+ cxxstd: 20
+ arch: x64
+ runs-on: ${{ matrix.ci.os }}
+ steps:
+ - name: 'Check Out'
+ uses: actions/checkout at v4
- name: Retrieve build cache
uses: actions/cache/restore at v4
with:
path: .ccache
- key: windows-msvc-${{ matrix.ci.os}}-${{ matrix.ci.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
- restore-keys: windows-msvc-${{ matrix.ci.os}}-${{ matrix.ci.build_type}}
+ key: msvc-ninja-${{ matrix.ci.os }}-${{ matrix.ci.cxxstd }}-${{ matrix.ci.arch }}-${{ github.ref_name }}-${{ github.run_id }}
+ restore-keys: msvc-ninja-${{ matrix.ci.os }}-${{ matrix.ci.cxxstd }}-${{ matrix.ci.arch }}
+ - name: 'Setup'
+ run: choco install ccache ninja
+ - name: Activate MSVC
+ uses: ilammy/msvc-dev-cmd at v1
+ with:
+ arch: ${{ matrix.ci.arch }}
- name: 'Build'
env:
CCACHE_DIR: ${{ github.workspace }}\.ccache
shell: cmd
run: |
- call "${{ matrix.ci.vcdir }}\VC\Auxiliary\Build\vcvars64.bat"
md build
cd build
cmake --version
cmake ^
-G Ninja ^
- -D CMAKE_BUILD_TYPE=${{ matrix.ci.build_type }} ^
+ -D CMAKE_BUILD_TYPE=Release ^
-D CMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} ^
-D USE_CCACHE=ON ^
- IF %ERRORLEVEL% NEQ 0 exit
- cmake --build . --config ${{ matrix.ci.build_type }} -j 4
+ cmake --build . --config Release -j 4
ccache --show-stats --verbose
- name: Save build cache
@@ -411,7 +442,7 @@ jobs:
- name: 'Test'
- run: ctest --output-on-failure -C ${{ matrix.ci.build_type }}
+ run: ctest --output-on-failure -C Release
macos:
Summary of changes:
.github/workflows/ci.yml | 73 ++++++++++++++++++++++++++++++++++--------------
1 file changed, 52 insertions(+), 21 deletions(-)
hooks/post-receive
More information about the geos-commits
