[geos-commits] [SCM] GEOS branch main-relate-ng updated. ebd1e124d7e3a95df872c6c1120f87310d269abe
git at osgeo.org
git at osgeo.org
Mon Jul 29 16:06:24 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
via ebd1e124d7e3a95df872c6c1120f87310d269abe (commit)
from 79881bbd235f26e9f1d0ff0a49cc893baeda7ced (commit)
revisions in full, below.
commit ebd1e124d7e3a95df872c6c1120f87310d269abe
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Jul 29 16:05:57 2024 -0700
Fix for GC
diff --git a/src/operation/relateng/RelateGeometry.cpp b/src/operation/relateng/RelateGeometry.cpp
index b2691ba4c..e07c3f602 100644
--- a/src/operation/relateng/RelateGeometry.cpp
+++ b/src/operation/relateng/RelateGeometry.cpp
@@ -346,6 +346,8 @@ RelateGeometry::getEffectivePoints()
//-- only return Points not covered by another element
std::vector<const Point*> ptList;
for (const Point* p : ptListAll) {
+ if (p->isEmpty())
+ continue;
int locDim = locateWithDim(p->getCoordinate());
if (DimensionLocation::dimension(locDim) == Dimension::P) {
ptList.push_back(p);
diff --git a/tests/unit/operation/relateng/RelateNGGCTest.cpp b/tests/unit/operation/relateng/RelateNGGCTest.cpp
index 0e0467222..5ca0bf8ff 100644
--- a/tests/unit/operation/relateng/RelateNGGCTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGGCTest.cpp
@@ -300,6 +300,15 @@ void object::test<21> ()
checkCoversCoveredBy(a, b, true);
+// https://trac.osgeo.org/geos/ticket/1110
+template<>
+template<>
+void object::test<22> ()
+ std::string a = "POLYGON ((3 7, 7 7, 7 3, 3 3, 3 7))";
+ std::string b = "GEOMETRYCOLLECTION (MULTIPOINT (EMPTY, (5 5)), LINESTRING (1 9, 4 9))";
+ checkIntersectsDisjoint(a, b, true);
Summary of changes:
src/operation/relateng/RelateGeometry.cpp | 2 ++
tests/unit/operation/relateng/RelateNGGCTest.cpp | 9 +++++++++
2 files changed, 11 insertions(+)
hooks/post-receive
More information about the geos-commits
