[geos-commits] [SCM] GEOS branch main updated. 76d0e8f344efbad4b41bafced76f3f8e48573ccb
git at osgeo.org
git at osgeo.org
Tue Jun 11 06:07:42 PDT 2024
the project "GEOS".
The branch, main has been updated
via 76d0e8f344efbad4b41bafced76f3f8e48573ccb (commit)
from d0d3d5a0bf9c5a3f3bcb4da64ae53fef0f7d64e2 (commit)
revisions in full, below.
commit 76d0e8f344efbad4b41bafced76f3f8e48573ccb
Author: Dan Baston <dbaston at gmail.com>
Date: Tue Jun 11 09:07:13 2024 -0400
WKBWriter: Support curved geometry types (#1104)
diff --git a/include/geos/io/WKBConstants.h b/include/geos/io/WKBConstants.h
index 51d9615f4..438574841 100644
--- a/include/geos/io/WKBConstants.h
+++ b/include/geos/io/WKBConstants.h
@@ -37,7 +37,12 @@ namespace WKBConstants {
wkbMultiPoint = 4,
wkbMultiLineString = 5,
wkbMultiPolygon = 6,
- wkbGeometryCollection = 7
+ wkbGeometryCollection = 7,
+ wkbCircularString = 8,
+ wkbCompoundCurve = 9,
+ wkbCurvePolygon = 10,
+ wkbMultiCurve = 11,
+ wkbMultiSurface = 12,
enum wkbFlavour {
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index 0910f52f5..90b2fbc67 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -33,6 +33,8 @@ namespace geos {
namespace geom {
class CoordinateSequence;
+class CompoundCurve;
+class CurvePolygon;
class Geometry;
class GeometryCollection;
class Point;
@@ -43,6 +45,7 @@ class MultiPoint;
class MultiLineString;
class MultiPolygon;
class PrecisionModel;
+class SimpleCurve;
} // namespace geom
} // namespace geos
@@ -194,6 +197,8 @@ public:
void writeHEX(const geom::Geometry& g, std::ostream& os);
// throws IOException, ParseException
+ static int getWkbType(const geom::Geometry&);
private:
// 2, 3, or 4
@@ -215,13 +220,17 @@ private:
void writePointEmpty(const geom::Point& p);
- void writeLineString(const geom::LineString& ls);
+ void writeSimpleCurve(const geom::SimpleCurve& ls);
+ void writeCompoundCurve(const geom::CompoundCurve& curve);
void writePolygon(const geom::Polygon& p);
- void writeGeometryCollection(const geom::GeometryCollection& c, int wkbtype);
+ void writeCurvePolygon(const geom::CurvePolygon& p);
+ void writeGeometryCollection(const geom::GeometryCollection& gc);
void writeCoordinateSequence(const geom::CoordinateSequence& cs, bool sized);
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index 0e622b0d4..f7c83d38d 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -22,6 +22,8 @@
#include <geos/io/CheckOrdinatesFilter.h>
#include <geos/util/IllegalArgumentException.h>
#include <geos/geom/Coordinate.h>
+#include <geos/geom/CompoundCurve.h>
+#include <geos/geom/CurvePolygon.h>
#include <geos/geom/Point.h>
#include <geos/geom/LinearRing.h>
#include <geos/geom/LineString.h>
@@ -99,8 +101,6 @@ WKBWriter::writeHEX(const Geometry& g, std::ostream& os)
void
WKBWriter::write(const Geometry& g, std::ostream& os)
- util::ensureNoCurvedComponents(g);
OrdinateSet inputOrdinates = OrdinateSet::createXY();
inputOrdinates.setM(g.hasM());
inputOrdinates.setZ(g.hasZ());
@@ -108,36 +108,21 @@ WKBWriter::write(const Geometry& g, std::ostream& os)
outStream = &os;
- if (const Point* x = dynamic_cast<const Point*>(&g)) {
- return writePoint(*x);
+ switch(g.getGeometryTypeId()) {
+ case GEOS_POINT: writePoint(static_cast<const Point&>(g)); break;
+ case GEOS_LINESTRING:
+ case GEOS_LINEARRING:
+ case GEOS_CIRCULARSTRING: writeSimpleCurve(static_cast<const SimpleCurve&>(g)); break;
+ case GEOS_COMPOUNDCURVE: writeCompoundCurve(static_cast<const CompoundCurve&>(g)); break;
+ case GEOS_POLYGON: writePolygon(static_cast<const Polygon&>(g)); break;
+ case GEOS_CURVEPOLYGON: writeCurvePolygon(static_cast<const CurvePolygon&>(g)); break;
+ case GEOS_MULTIPOINT:
+ case GEOS_MULTILINESTRING:
+ case GEOS_MULTIPOLYGON:
+ case GEOS_MULTICURVE:
+ case GEOS_MULTISURFACE:
+ case GEOS_GEOMETRYCOLLECTION: writeGeometryCollection(static_cast<const GeometryCollection&>(g)); break;
- if (const LineString* x = dynamic_cast<const LineString*>(&g)) {
- return writeLineString(*x);
- if (const Polygon* x = dynamic_cast<const Polygon*>(&g)) {
- return writePolygon(*x);
- if (const MultiPoint* x = dynamic_cast<const MultiPoint*>(&g)) {
- return writeGeometryCollection(*x, WKBConstants::wkbMultiPoint);
- if (const MultiLineString* x = dynamic_cast<const MultiLineString*>(&g)) {
- return writeGeometryCollection(*x, WKBConstants::wkbMultiLineString);
- if (const MultiPolygon* x = dynamic_cast<const MultiPolygon*>(&g)) {
- return writeGeometryCollection(*x, WKBConstants::wkbMultiPolygon);
- if (const GeometryCollection* x =
- dynamic_cast<const GeometryCollection*>(&g)) {
- return writeGeometryCollection(*x, WKBConstants::wkbGeometryCollection);
- assert(0); // Unknown Geometry type
void
@@ -172,11 +157,11 @@ WKBWriter::writePoint(const Point& g)
void
-WKBWriter::writeLineString(const LineString& g)
+WKBWriter::writeSimpleCurve(const SimpleCurve& g)
writeByteOrder();
- writeGeometryType(WKBConstants::wkbLineString, g.getSRID());
+ writeGeometryType(getWkbType(g), g.getSRID());
writeSRID(g.getSRID());
const CoordinateSequence* cs = g.getCoordinatesRO();
@@ -184,12 +169,33 @@ WKBWriter::writeLineString(const LineString& g)
writeCoordinateSequence(*cs, true);
+void
+WKBWriter::writeCompoundCurve(const CompoundCurve& g)
+ writeByteOrder();
+ writeSRID(g.getSRID());
+ writeInt(static_cast<int>(g.getNumCurves()));
+ auto orig_includeSRID = includeSRID;
+ includeSRID = false;
+ for (std::size_t i = 0; i < g.getNumCurves(); i++) {
+ const SimpleCurve& section = *g.getCurveN(i);
+ writeSimpleCurve(section);
+ includeSRID = orig_includeSRID;
void
WKBWriter::writePolygon(const Polygon& g)
writeByteOrder();
- writeGeometryType(WKBConstants::wkbPolygon, g.getSRID());
if (g.isEmpty()) {
@@ -219,12 +225,42 @@ WKBWriter::writePolygon(const Polygon& g)
void
-WKBWriter::writeGeometryCollection(const GeometryCollection& g,
- int wkbtype)
+WKBWriter::writeCurvePolygon(const CurvePolygon& g)
+ // Why not combine this with writePolygon?
+ // A CurvePolygon differs from a Polygon in that its rings
+ // can one of three different types. Therefore, the type
+ // information is written for each ring, unlike a Polygon.
+ writeByteOrder();
+ if (g.isEmpty()) {
+ writeInt(0);
+ return;
+ std::size_t nholes = g.getNumInteriorRing();
+ writeInt(static_cast<int>(nholes + 1));
+ const Curve* ring = g.getExteriorRing();
+ write(*ring, *outStream);
+ for(std::size_t i = 0; i < nholes; i++) {
+ ring = g.getInteriorRingN(i);
+void
+WKBWriter::writeGeometryCollection(const GeometryCollection& g)
writeByteOrder();
- writeGeometryType(wkbtype, g.getSRID());
auto ngeoms = g.getNumGeometries();
@@ -381,6 +417,28 @@ WKBWriter::getOutputOrdinates(OrdinateSet ordinates)
return newOrdinates;
+int
+WKBWriter::getWkbType(const Geometry& g) {
+ case GEOS_POINT: return WKBConstants::wkbPoint;
+ case GEOS_LINEARRING: return WKBConstants::wkbLineString;
+ case GEOS_CIRCULARSTRING: return WKBConstants::wkbCircularString;
+ case GEOS_COMPOUNDCURVE: return WKBConstants::wkbCompoundCurve;
+ case GEOS_POLYGON: return WKBConstants::wkbPolygon;
+ case GEOS_CURVEPOLYGON: return WKBConstants::wkbCurvePolygon;
+ case GEOS_MULTIPOINT: return WKBConstants::wkbMultiPoint;
+ case GEOS_MULTILINESTRING: return WKBConstants::wkbMultiLineString;
+ case GEOS_MULTICURVE: return WKBConstants::wkbMultiCurve;
+ case GEOS_MULTIPOLYGON: return WKBConstants::wkbMultiPolygon;
+ case GEOS_MULTISURFACE: return WKBConstants::wkbMultiSurface;
+ case GEOS_GEOMETRYCOLLECTION: return WKBConstants::wkbGeometryCollection;
+ // Avoid -Wreturn-type warning
+ throw util::IllegalArgumentException("Invalid geometry type.");
} // namespace geos.io
} // namespace geos
diff --git a/tests/unit/capi/GEOSWKBWriterTest.cpp b/tests/unit/capi/GEOSWKBWriterTest.cpp
index 1bb95c808..2f3e041d6 100644
--- a/tests/unit/capi/GEOSWKBWriterTest.cpp
+++ b/tests/unit/capi/GEOSWKBWriterTest.cpp
@@ -186,18 +186,5 @@ void object::test<9>()
ensure_equals(hexstr, "010100008000000000000008400000000000002040000000000000F03F");
-template<>
-template<>
-void object::test<10>
- input_ = fromWKT("CIRCULARSTRING (0 0, 1 1, 2 0)");
- ensure(input_);
- std::size_t hex_size = 0;
- buf_ = GEOSWKBWriter_writeHEX(wkbwriter_, input_, &hex_size);
- ensure("curved geometry not supported", buf_ == nullptr);
} // namespace tut
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index eb4cf3102..ff31b7f0e 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
@@ -45,6 +45,22 @@ struct test_wkbwriter_data {
wkbreader(*gf)
+ void checkHexOutput(const std::string& wkt, const std::string& hex) {
+ std::stringstream out;
+ auto geom = wktreader.read(wkt);
+ wkbwriter.writeHEX(*geom, out);
+ ensure_equals(wkt, out.str(), hex );
+ void checkHexOutputWithSRID(const std::string& wkt, int srid, const std::string& hex) {
+ geom->setSRID(srid);
+ wkbwriter.setIncludeSRID(true);
typedef test_group<test_wkbwriter_data> group;
@@ -375,5 +391,91 @@ void object::test<12>
"010200004002000000000000000000F03F00000000000000400000000000000840000000000000104000000000000014400000000000001840");
+// CircularString
+template<>
+template<>
+void object::test<13>
+ checkHexOutput("CIRCULARSTRING EMPTY",
+ "010800000000000000");
+ checkHexOutput("CIRCULARSTRING (1 3, 2 4, 3 1)",
+ "010800000003000000000000000000F03F0000000000000840000000000000004000000000000010400000000000000840000000000000F03F");
+// CompoundCurve
+template<>
+template<>
+void object::test<14>
+ checkHexOutput("COMPOUNDCURVE EMPTY",
+ "010900000000000000");
+ checkHexOutput("COMPOUNDCURVE (CIRCULARSTRING (1 3, 2 4, 3 1), (3 1, 0 0))",
+ "010900000002000000010800000003000000000000000000F03F0000000000000840000000000000004000000000000010400000000000000840000000000000F03F0102000000020000000000000000000840000000000000F03F00000000000000000000000000000000");
+// CurvePolygon
+template<>
+template<>
+void object::test<15>
+ checkHexOutput("CURVEPOLYGON EMPTY",
+ "010A00000000000000");
+ checkHexOutput("CURVEPOLYGON( COMPOUNDCURVE( CIRCULARSTRING(0 0,2 0, 2 1, 2 3, 4 3), (4 3, 4 5, 1 4, 0 0)), CIRCULARSTRING(1.7 1, 1.4 0.4, 1.6 0.4, 1.6 0.5, 1.7 1) )",
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
+// MultiCurve
+template<>
+template<>
+void object::test<16>
+ checkHexOutput("MULTICURVE EMPTY",
+ "010B00000000000000");
+ checkHexOutput("MULTICURVE( (0 0, 5 5), COMPOUNDCURVE( (-1 -1, 0 0), CIRCULARSTRING (0 0, 1 1, 2 0)), CIRCULARSTRING(4 0, 4 4, 8 4))",
+ "010B000000030000000102000000020000000000000000000000000000000000000000000000000014400000000000001440010900000002000000010200000002000000000000000000F0BF000000000000F0BF0000000000000000000000000000000001080000000300000000000000000000000000000000000000000000000000F03F000000000000F03F00000000000000400000000000000000010800000003000000000000000000104000000000000000000000000000001040000000000000104000000000000020400000000000001040" );
+// MultiSurface
+template<>
+template<>
+void object::test<17>
+ checkHexOutput("MULTISURFACE EMPTY",
+ "010C00000000000000");
+ checkHexOutput("MULTISURFACE( CURVEPOLYGON( CIRCULARSTRING( 0 0, 4 0, 4 4, 0 4, 0 0), (1 1, 3 3, 3 1, 1 1)), POLYGON ((10 10, 14 12, 11 10, 10 10), (11 11, 11.5 11, 11 11.5, 11 11)))",
+ "010C00000002000000010A000000020000000108000000050000000000000000000000000000000000000000000000000010400000000000000000000000000000104000000000000010400000000000000000000000000000104000000000000000000000000000000000010200000004000000000000000000F03F000000000000F03F000000000000084000000000000008400000000000000840000000000000F03F000000000000F03F000000000000F03F01030000000200000004000000000000000000244000000000000024400000000000002C40000000000000284000000000000026400000000000002440000000000000244000000000000024400400000000000000000026400000000000002640000000000000274000000000000026400000000000002640000000000000274000000000000026400000000000002640");
+// CompoundCurve with SRID
+template<>
+template<>
+void object::test<18>
+ checkHexOutputWithSRID("COMPOUNDCURVE (CIRCULARSTRING (1 3, 2 4, 3 1), (3 1, 0 0))", 5646,
+ "01090000200E16000002000000010800000003000000000000000000F03F0000000000000840000000000000004000000000000010400000000000000840000000000000F03F0102000000020000000000000000000840000000000000F03F00000000000000000000000000000000");
+// CurvePolygon with SRID
+template<>
+template<>
+void object::test<19>
+ checkHexOutputWithSRID("CURVEPOLYGON( COMPOUNDCURVE( CIRCULARSTRING(0 0,2 0, 2 1, 2 3, 4 3), (4 3, 4 5, 1 4, 0 0)), CIRCULARSTRING(1.7 1, 1.4 0.4, 1.6 0.4, 1.6 0.5, 1.7 1) )", 5646,
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
} // namespace tut
Summary of changes:
include/geos/io/WKBConstants.h | 7 +-
include/geos/io/WKBWriter.h | 13 +++-
src/io/WKBWriter.cpp | 132 ++++++++++++++++++++++++----------
tests/unit/capi/GEOSWKBWriterTest.cpp | 13 ----
tests/unit/io/WKBWriterTest.cpp | 102 ++++++++++++++++++++++++++
5 files changed, 214 insertions(+), 53 deletions(-)
hooks/post-receive
More information about the geos-commits
