[geos-commits] [SCM] GEOS branch main updated. 37f7600b591d40d1afd5035d3f40f1a19bc85cc2
git at osgeo.org
git at osgeo.org
Thu Jun 13 09:32:32 PDT 2024
the project "GEOS".
The branch, main has been updated
via 37f7600b591d40d1afd5035d3f40f1a19bc85cc2 (commit)
from 72c76d060606e511e50c24dacf533a6f28c7f69e (commit)
revisions in full, below.
commit 37f7600b591d40d1afd5035d3f40f1a19bc85cc2
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Jun 13 09:32:06 2024 -0700
Improve GEOSTopologyPreserveSimplifyStableTest logging
diff --git a/benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp b/benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp
index a73906989..406d5d1ec 100644
--- a/benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp
+++ b/benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp
@@ -38,6 +38,15 @@ GEOSGeometry* readGeom(std::string& fname) {
return geom;
+void write(GEOSGeometry* g)
+ GEOSWKTWriter* writer = GEOSWKTWriter_create();
+ char* wkt = GEOSWKTWriter_write(writer, g);
+ GEOSWKTWriter_destroy(writer);
+ std::cout << wkt << std::endl;
+ GEOSFree(wkt);
//---------- Run test ---------------
void run(std::string& fname, int nRuns, double tolerance)
@@ -57,8 +66,8 @@ void run(std::string& fname, int nRuns, double tolerance)
//std::cout << "Run " << i << std::endl;
if (! isEqualExact || ! isDiffEmpty) {
nErrors++;
- std::cout << "simplified results are not identical" << std::endl;
- std::cout << diff << std::endl;
+ std::cout << "Run " << i << " - simplified results not identical: equals=" << isEqualExact << ", empty=" << isDiffEmpty << std::endl;
+ write(diff);
GEOSGeom_destroy(simp1);
Summary of changes:
benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp | 13 +++++++++++--
1 file changed, 11 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
