[geos-commits] [SCM] GEOS branch 3.12 updated. 16c92dbb20de08fa0be7ae8d10d69fcef63236ef
Mon Jun 17 11:09:40 PDT 2024
the project "GEOS".
The branch, 3.12 has been updated
       via  16c92dbb20de08fa0be7ae8d10d69fcef63236ef (commit)
       via  24d01ae23e9a3a6be73b3a783f4e589ca159afcf (commit)
       via  ae8fbb46c0cc5c6f9e727b9604b5705c2cdad960 (commit)
       via  c077f176d1ccb907998843134ea2e8757a7f19ac (commit)
       via  44f17e15b677d3c6d073ba637aa7bff67f229dcb (commit)
      from  c5532795d12bb23057db6c3d5a5f2e1dae09526c (commit)
revisions in full, below.
commit 16c92dbb20de08fa0be7ae8d10d69fcef63236ef
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Jun 17 14:06:25 2024 -0400
    NEWS updates
diff --git a/NEWS.md b/NEWS.md
index 4c1f30928..8d7d65e39 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -3,6 +3,10 @@
 - Fixes:
   - TopologyPreservingSimplifier: fix to remove ring endpoints safely (GH-1110, Martin Davis)
+  - Centroid: Fix crash on polygons with empty holes (GH-1075, Dan Baston)
+  - MinimumClearance: Fix crash on NaN inputs (GH-1082, Dan Baston)
+  - GEOSLineSubstring: Fix crash on NaN length fractions (GH-1088, Dan Baston)
+  - GEOSRelatePatternMatch: Fix crash on invalid DE-9IM pattern (GH-1089, Dan Baston)
 ## Changes in 3.12.2
 2024-06-05
commit 24d01ae23e9a3a6be73b3a783f4e589ca159afcf
Date:   Tue Apr 30 18:37:19 2024 -0400
    IntersectionMatrix: Ignore patterns longer than 9 characters
    Fixes https://github.com/libgeos/geos/issues/1084
diff --git a/src/geom/IntersectionMatrix.cpp b/src/geom/IntersectionMatrix.cpp
index 82acfcf4e..f7ace8a9e 100644
--- a/src/geom/IntersectionMatrix.cpp
+++ b/src/geom/IntersectionMatrix.cpp
@@ -144,7 +144,7 @@ IntersectionMatrix::set(Location row, Location col, int dimensionValue)
 void
 IntersectionMatrix::set(const std::string& dimensionSymbols)
-    auto limit = dimensionSymbols.length();
+    auto limit = std::min(dimensionSymbols.length(), static_cast<std::size_t>(9));
     for(std::size_t i = 0; i < limit; i++) {
         auto row = i / firstDim;
diff --git a/tests/unit/capi/GEOSRelatePatternMatchTest.cpp b/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
index c5f34a40b..b60ab1e18 100644
--- a/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
+++ b/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
@@ -78,5 +78,18 @@ void object::test<5>
     ensure_equals(ret, char(0));
+// invalid DE-9IM argument
+// https://github.com/libgeos/geos/issues/1084
+template<>
+template<>
+void object::test<6>
+    const char* mat = "0000000000";
+    ensure_equals(strlen(mat), 10u); // not a valid DE-9IM!
+    GEOSRelatePatternMatch(mat,  "111111111");
 } // namespace tut
commit ae8fbb46c0cc5c6f9e727b9604b5705c2cdad960
Date:   Tue Apr 30 17:43:35 2024 -0400
    GEOSLineSubstring: Avoid crash with NaN length fraction
    Fixes https://github.com/libgeos/geos/issues/1077
diff --git a/src/linearref/LengthIndexedLine.cpp b/src/linearref/LengthIndexedLine.cpp
index 012a9dc43..5522eb32c 100644
--- a/src/linearref/LengthIndexedLine.cpp
+++ b/src/linearref/LengthIndexedLine.cpp
@@ -57,6 +57,13 @@ LengthIndexedLine::extractPoint(double index, double offsetDistance) const
 std::unique_ptr<Geometry>
 LengthIndexedLine::extractLine(double startIndex, double endIndex) const
+    if (std::isnan(startIndex)) {
+        throw util::IllegalArgumentException("startIndex is NaN");
+    if (std::isnan(endIndex)) {
+        throw util::IllegalArgumentException("endIndex is NaN");
     const LocationIndexedLine lil(linearGeom);
     const double startIndex2 = clampIndex(startIndex);
     const double endIndex2 = clampIndex(endIndex);
diff --git a/tests/unit/capi/GEOSInterpolateTest.cpp b/tests/unit/capi/GEOSInterpolateTest.cpp
index 3b5a49f60..44992617f 100644
--- a/tests/unit/capi/GEOSInterpolateTest.cpp
+++ b/tests/unit/capi/GEOSInterpolateTest.cpp
@@ -72,4 +72,14 @@ void object::test<4>
     ensure_geometry_equals(result_, expected_);
+// ensure NaN argument does not crash
+template<>
+template<>
+void object::test<5>
+    geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 1 1)");
+    result_ = GEOSInterpolate(geom1_, std::numeric_limits<double>::quiet_NaN());
 } // namespace tut
diff --git a/tests/unit/capi/GEOSLineSubstringTest.cpp b/tests/unit/capi/GEOSLineSubstringTest.cpp
index c75930792..0b9ffaf09 100644
--- a/tests/unit/capi/GEOSLineSubstringTest.cpp
+++ b/tests/unit/capi/GEOSLineSubstringTest.cpp
@@ -120,5 +120,20 @@ void object::test<6>
+// NaN start fraction
+// https://github.com/libgeos/geos/issues/1077
+template<>
+template<>
+void object::test<8>
+    input_ = fromWKT("LINESTRING EMPTY");
+    double start = std::numeric_limits<double>::quiet_NaN();
+    double end = 0.1;
+    result_ = GEOSLineSubstring(input_, start, end);
+    ensure(result_ == nullptr);
 } // namespace tut
commit c077f176d1ccb907998843134ea2e8757a7f19ac
Date:   Sat Apr 20 17:53:03 2024 -0400
    MinimumClearance: Avoid crash on NaN inputs
    Resolves https://github.com/libgeos/geos/issues/1079
diff --git a/src/precision/MinimumClearance.cpp b/src/precision/MinimumClearance.cpp
index cc6b293d0..0a5e9e823 100644
--- a/src/precision/MinimumClearance.cpp
+++ b/src/precision/MinimumClearance.cpp
@@ -176,6 +176,10 @@ MinimumClearance::compute()
     MinClearanceDistance mcd;
     auto nearest = tree->nearestNeighbour(mcd);
+    if (nearest.first == nullptr || nearest.second == nullptr) {
+        throw util::GEOSException("Failed to find nearest items");
     minClearance = mcd.distance(nearest.first, nearest.second);
     const std::vector<Coordinate>* minClearancePtsVec = mcd.getCoordinates();
diff --git a/tests/unit/capi/GEOSMinimumClearanceTest.cpp b/tests/unit/capi/GEOSMinimumClearanceTest.cpp
index f683145da..e0c777afd 100644
--- a/tests/unit/capi/GEOSMinimumClearanceTest.cpp
+++ b/tests/unit/capi/GEOSMinimumClearanceTest.cpp
@@ -120,4 +120,14 @@ void object::test<5>
                   geos::DoubleInfinity);
+template<>
+template<>
+    input_ = GEOSGeom_createPointFromXY(std::numeric_limits<double>::quiet_NaN(), 1);
+    double d;
+    ensure_equals(GEOSMinimumClearance(input_, &d), 2);
 } // namespace tut
commit 44f17e15b677d3c6d073ba637aa7bff67f229dcb
Date:   Fri Apr 19 19:49:55 2024 -0400
    Centroid: Avoid crash with empty hole
    Resolves https://github.com/libgeos/geos/issues/1073
diff --git a/src/algorithm/Centroid.cpp b/src/algorithm/Centroid.cpp
index fa9355421..168a0996e 100644
--- a/src/algorithm/Centroid.cpp
+++ b/src/algorithm/Centroid.cpp
@@ -124,6 +124,10 @@ Centroid::addShell(const CoordinateSequence& pts)
 void
 Centroid::addHole(const CoordinateSequence& pts)
+    if (pts.isEmpty()) {
+        return;
     bool isPositiveArea = Orientation::isCCW(&pts);
     for(std::size_t i = 0, e = pts.size() - 1; i < e; ++i) {
         addTriangle(*areaBasePt, pts.getAt<CoordinateXY>(i), pts.getAt<CoordinateXY>(i + 1), isPositiveArea);
diff --git a/tests/unit/algorithm/CentroidTest.cpp b/tests/unit/algorithm/CentroidTest.cpp
index 40ec77b55..152d12dff 100644
--- a/tests/unit/algorithm/CentroidTest.cpp
+++ b/tests/unit/algorithm/CentroidTest.cpp
@@ -122,5 +122,11 @@ void object::test<5>() {
         "POLYGON EMPTY");
+template<>
+template<>
+void object::test<6>() {
+    checkCentroid("POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0), EMPTY)", 0.5, 0.5);
 } // namespace tut
Summary of changes:
 NEWS.md                                        |  4 ++++
 src/algorithm/Centroid.cpp                     |  4 ++++
 src/geom/IntersectionMatrix.cpp                |  2 +-
 src/linearref/LengthIndexedLine.cpp            |  7 +++++++
 src/precision/MinimumClearance.cpp             |  4 ++++
 tests/unit/algorithm/CentroidTest.cpp          |  6 ++++++
 tests/unit/capi/GEOSInterpolateTest.cpp        | 10 ++++++++++
 tests/unit/capi/GEOSLineSubstringTest.cpp      | 15 +++++++++++++++
 tests/unit/capi/GEOSMinimumClearanceTest.cpp   | 10 ++++++++++
 tests/unit/capi/GEOSRelatePatternMatchTest.cpp | 13 +++++++++++++
 10 files changed, 74 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
