[geos-commits] [SCM] GEOS branch main updated. fc0722fcc2cd925e0a4d445a93f630b5ea4c9f07
git at osgeo.org
git at osgeo.org
Wed Jun 19 18:08:06 PDT 2024
the project "GEOS".
The branch, main has been updated
via fc0722fcc2cd925e0a4d445a93f630b5ea4c9f07 (commit)
from 87e98b72ebfe3510a2c235ae8b23e64503f6adab (commit)
revisions in full, below.
commit fc0722fcc2cd925e0a4d445a93f630b5ea4c9f07
Author: Dan Baston <dbaston at gmail.com>
Date: Wed Jun 19 21:07:40 2024 -0400
GEOSConcaveHullOfPolygons: Avoid crash on zero-area input (#1076)
* GEOSConcaveHullOfPolygons: Avoid crash on zero-area input
Resolves https://github.com/libgeos/geos/issues/1071
diff --git a/src/algorithm/hull/ConcaveHullOfPolygons.cpp b/src/algorithm/hull/ConcaveHullOfPolygons.cpp
index d0ab8e426..6ed54fb0a 100644
--- a/src/algorithm/hull/ConcaveHullOfPolygons.cpp
+++ b/src/algorithm/hull/ConcaveHullOfPolygons.cpp
@@ -156,7 +156,7 @@ ConcaveHullOfPolygons::setTight(bool p_isTight)
std::unique_ptr<Geometry>
ConcaveHullOfPolygons::getHull()
- if (inputPolygons->isEmpty()) {
+ if (inputPolygons->isEmpty() || inputPolygons->getArea() == 0) {
return createEmptyHull();
buildHullTris();
diff --git a/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp b/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
index 57c6a0b9c..2cd039fb5 100644
--- a/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
+++ b/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
@@ -62,6 +62,15 @@ void object::test<3>()
result_ = GEOSConcaveHullOfPolygons(input_, 0.7, false, false);
ensure("curved geometry not supported", result_ == nullptr);
+template<>
+template<>
+void object::test<4>()
+ input_ = fromWKT("POLYGON((0 0, 0 0, 0 0))");
+ result_ = GEOSConcaveHullOfPolygons(input_, 0.7, false, false);
+ ensure(GEOSisEmpty(result_));
} // namespace tut
Summary of changes:
src/algorithm/hull/ConcaveHullOfPolygons.cpp | 2 +-
tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp | 9 +++++++++
2 files changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
