[geos-commits] [SCM] GEOS branch main updated. 3db005a65baf5fb53a3d2078c30dd7d365115b5e
git at osgeo.org
git at osgeo.org
Wed Jun 26 14:09:18 PDT 2024
the project "GEOS".
The branch, main has been updated
via 3db005a65baf5fb53a3d2078c30dd7d365115b5e (commit)
from d84cf1aec56c9948f4f22dfbbbd331f61c32b132 (commit)
revisions in full, below.
commit 3db005a65baf5fb53a3d2078c30dd7d365115b5e
Author: Dan Baston <dbaston at gmail.com>
Date: Wed Jun 26 17:08:40 2024 -0400
LineIntersector: Fix invalid read on mixed-dimensionality inputs (#1115)
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index 958dbbf12..ebf676b10 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -589,8 +589,20 @@ private:
geom::CoordinateXYZM ptInt(Intersection::intersection(p1, p2, q1, q2));
if (ptInt.isNull()) {
- // FIXME need to cast to correct type in mixed-dimensionality case
- ptInt = static_cast<const C1&>(nearestEndpoint(p1, p2, q1, q2));
+ const geom::CoordinateXY& nearest = nearestEndpoint(p1, p2, q1, q2);
+#if __cplusplus >= 201703L
+ if constexpr (std::is_same<C1, C2>::value) {
+#else
+ if (std::is_same<C1, C2>::value) {
+#endif
+ ptInt = static_cast<const C1&>(nearest);
+ } else {
+ if (&nearest == static_cast<const geom::CoordinateXY*>(&p1) || &nearest == static_cast<const geom::CoordinateXY*>(&p2)) {
+ } else {
+ ptInt = static_cast<const C2&>(nearest);
return ptInt;
diff --git a/tests/unit/capi/GEOSIntersectionTest.cpp b/tests/unit/capi/GEOSIntersectionTest.cpp
index 2377c609f..c94b056a7 100644
--- a/tests/unit/capi/GEOSIntersectionTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionTest.cpp
@@ -157,5 +157,21 @@ void object::test<8>()
ensure("curved geometry not supported", result_ == nullptr);
+// https://github.com/libgeos/geos/issues/1074
+// Make sure no crash occurs when LineIntersector has mixed-dimensionality
+// inputs and substitutes a segment endpoint for intersection point
+template<>
+template<>
+void object::test<9>()
+ geom1_ = fromWKT("GEOMETRYCOLLECTION(POINT(0 0 59.083333333333336), POINT(1 1 59.083333333333336), LINESTRING(2 4 111 1, 2 223 22 2), POLYGON((42 -2.222222223222222e+155 111 1, 2 3 1 1, 2 4 111 NaN, 42 -2.222222223222222e+155 111 NaN)), POLYGON((2.2222222212222224e+149 4 111 1, 42 -2.222222222222222e+149 22 2, 2 4 111 1, 22 2222222222222223 22 NaN, 2.2222222212222224e+149 4 111 NaN)))");
+ geom2_ = fromWKT("LINESTRING (1.6409301755752343e+149 -5.298190649085575e+148, 1.6666666660752404e+149 -5.55555555396982e+148)");
+ result_ = GEOSIntersection(geom1_, geom2_);
+ ensure(result_ != nullptr);
+ ensure("HasZ", GEOSHasZ(result_));
+ ensure("HasM", GEOSHasM(result_));
} // namespace tut
Summary of changes:
include/geos/algorithm/LineIntersector.h | 16 ++++++++++++++--
tests/unit/capi/GEOSIntersectionTest.cpp | 16 ++++++++++++++++
2 files changed, 30 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
