[geos-commits] [SCM] GEOS branch 3.12 updated. ce2dea56d803aef971e1e77bf5482292f33cde1e
git at osgeo.org
git at osgeo.org
Mon Mar 18 17:06:13 PDT 2024
the project "GEOS".
The branch, 3.12 has been updated
via ce2dea56d803aef971e1e77bf5482292f33cde1e (commit)
from 57df1921de666cd1a1d540811f321a00d0de85b9 (commit)
revisions in full, below.
commit ce2dea56d803aef971e1e77bf5482292f33cde1e
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Mar 18 17:03:47 2024 -0700
Fix buffer Inverted Ring Removal check (#1056)
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 714c123d9..ea1e0a788 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -250,13 +250,18 @@ public:
/// @param ret will be set to the midpoint of the segment
- void midPoint(Coordinate& ret) const
+ CoordinateXY midPoint() const
- ret = Coordinate(
- (p0.x + p1.x) / 2,
- (p0.y + p1.y) / 2);
+ return midPoint(p0, p1);
+ static CoordinateXY midPoint(const CoordinateXY& pt0, const CoordinateXY& pt1)
+ return CoordinateXY(
+ (pt0.x + pt1.x) / 2,
+ (pt0.y + pt1.y) / 2);
/// Computes the distance between this line segment and another one.
double distance(const LineSegment& ls) const
diff --git a/include/geos/operation/buffer/BufferCurveSetBuilder.h b/include/geos/operation/buffer/BufferCurveSetBuilder.h
index 2c0ddc061..e731840bf 100644
--- a/include/geos/operation/buffer/BufferCurveSetBuilder.h
+++ b/include/geos/operation/buffer/BufferCurveSetBuilder.h
@@ -169,14 +169,19 @@ private:
const geom::CoordinateSequence* curvePts);
- * Computes the maximum distance out of a set of points to a linestring.
- * @param pts the points
- * @param line the linestring vertices
- * @return the maximum distance
+ * Tests if there are points on the raw offset curve which may
+ * lie on the final buffer curve
+ * (i.e. they are (approximately) at the buffer distance from the input ring).
+ * For efficiency this only tests a limited set of points on the curve.
+ * @param inputRing
+ * @param distance
+ * @param curveRing
+ * @return true if the curve contains points lying at the required buffer distance
- static double maxDistance(
- const geom::CoordinateSequence* pts, const geom::CoordinateSequence* line);
+ static bool hasPointOnBuffer(
+ const CoordinateSequence* inputRing, double dist,
+ const CoordinateSequence* curveRing);
* The ringCoord is assumed to contain no repeated points.
diff --git a/src/operation/buffer/BufferCurveSetBuilder.cpp b/src/operation/buffer/BufferCurveSetBuilder.cpp
index 239b28a8d..61a5b8132 100644
--- a/src/operation/buffer/BufferCurveSetBuilder.cpp
+++ b/src/operation/buffer/BufferCurveSetBuilder.cpp
@@ -38,10 +38,12 @@
#include <geos/geomgraph/Label.h>
#include <geos/noding/NodedSegmentString.h>
#include <geos/util.h>
+#include <geos/io/WKTWriter.h>
#include <algorithm> // for min
#include <cmath>
#include <cassert>
+#include <iomanip>
#include <memory>
#include <vector>
#include <typeinfo>
@@ -357,56 +359,67 @@ BufferCurveSetBuilder::addRingSide(const CoordinateSequence* coord,
/* private static*/
bool
BufferCurveSetBuilder::isRingCurveInverted(
- const CoordinateSequence* inputPts, double dist,
- const CoordinateSequence* curvePts)
if (dist == 0.0) return false;
* Only proper rings can invert.
- if (inputPts->size() <= 3) return false;
+ if (inputRing->size() <= 3) return false;
* Heuristic based on low chance that a ring with many vertices will invert.
* This low limit ensures this test is fairly efficient.
- if (inputPts->size() >= MAX_INVERTED_RING_SIZE) return false;
+ if (inputRing->size() >= MAX_INVERTED_RING_SIZE) return false;
* An inverted curve has no more points than the input ring.
* This also eliminates concave inputs (which will produce fillet arcs)
- if (curvePts->size() > INVERTED_CURVE_VERTEX_FACTOR * inputPts->size()) return false;
+ if (curveRing->size() > INVERTED_CURVE_VERTEX_FACTOR * inputRing->size()) return false;
- * Check if the curve vertices are all closer to the input ring
- * than the buffer distance.
- * If so, the curve is NOT a valid buffer curve.
+ * If curve contains points which are on the buffer,
+ * it is not inverted and can be included in the raw curves.
- double distTol = NEARNESS_FACTOR * fabs(dist);
- double maxDist = maxDistance(curvePts, inputPts);
- bool isCurveTooClose = maxDist < distTol;
- return isCurveTooClose;
+ if (hasPointOnBuffer(inputRing, dist, curveRing))
+ return false;
+ //-- curve is inverted, so discard it
+ return true;
+//std::cout << std::setprecision(10) << io::WKTWriter::toLineString(*curveRing) << std::endl;
+//std::cout << "isRingCurveInverted: " << isCurveTooClose << " maxDist = " << maxDist << std::endl;
-/* private static */
-double
-BufferCurveSetBuilder::maxDistance(const CoordinateSequence* pts, const CoordinateSequence* line) {
- double maxDistance = 0;
- for (std::size_t i = 0; i < pts->size(); i++) {
- const Coordinate& p = pts->getAt(i);
- double dist = Distance::pointToSegmentString(p, line);
- if (dist > maxDistance) {
- maxDistance = dist;
+/* private static*/
+bool
+BufferCurveSetBuilder::hasPointOnBuffer(
+ double distTol = NEARNESS_FACTOR * fabs(dist);
+ for (std::size_t i = 0; i < curveRing->size(); i++) {
+ const CoordinateXY& v = curveRing->getAt(i);
+ //-- check curve vertices
+ double distVertex = Distance::pointToSegmentString(v, inputRing);
+ if (distVertex > distTol) {
+ return true;
+ //-- check curve segment midpoints
+ std::size_t iNext = (i < curveRing->size() - 1) ? i + 1 : 0;
+ const CoordinateXY& vnext = curveRing->getAt(iNext);
+ CoordinateXY midPt = LineSegment::midPoint(v, vnext);
+ double distMid = Distance::pointToSegmentString(midPt, inputRing);
+ if (distMid > distTol) {
+ return true;
- return maxDistance;
+ return false;
/*private*/
diff --git a/tests/unit/geom/LineSegmentTest.cpp b/tests/unit/geom/LineSegmentTest.cpp
index 31bb2dc7c..71cb7892d 100644
--- a/tests/unit/geom/LineSegmentTest.cpp
+++ b/tests/unit/geom/LineSegmentTest.cpp
@@ -11,6 +11,10 @@
// std
#include <iostream>
+using geos::geom::Coordinate;
+using geos::geom::CoordinateXY;
+using geos::geom::LineSegment;
namespace tut {
// Test Group
@@ -18,9 +22,6 @@ namespace tut {
struct test_lineseg_data {
- typedef geos::geom::Coordinate Coordinate;
- typedef geos::geom::LineSegment LineSegment;
geos::geom::Coordinate ph1;
geos::geom::Coordinate ph2;
geos::geom::Coordinate pv1;
@@ -119,6 +120,17 @@ struct test_lineseg_data {
ensure_equals("checkDistancePerpendicularOriented", expected, dist, 0.000001);
+ void checkMidPoint(
+ double x0, double y0,
+ double x1, double y1,
+ double px, double py)
+ LineSegment seg(x0, y0, x1, y1);
+ Coordinate expected(px, py);
+ Coordinate actual = Coordinate(seg.midPoint());
+ ensure_equals_xy(actual, expected);
test_lineseg_data()
: ph1(0, 2), ph2(10, 2), pv1(0, 0), pv2(0, 10), h1(ph1, ph2), v1(pv1, pv2)
@@ -331,6 +343,16 @@ void object::test<13>()
checkDistancePerpendicularOriented(1,1, 1,1, 1,2, 1);
+// test midpoint
+template<>
+template<>
+void object::test<14>()
+ //-- right of line
+ checkMidPoint(1,1, 1,3, 1,2);
+ checkMidPoint(1,1, 1,1, 1,1);
+ checkMidPoint(1,1, 5,5, 3,3);
} // namespace tut
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 4d4c693d9..ba347799f 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -43,6 +43,22 @@ struct test_bufferop_data {
ensure_equals(default_quadrant_segments, int(8));
+ void checkBufferEmpty(const std::string& wkt, double dist, bool isEmpty)
+ std::unique_ptr<Geometry> geom = wktreader.read(wkt);
+ std::unique_ptr<Geometry> actual = geom->buffer(dist);
+ ensure_equals(actual->isEmpty(), isEmpty);
+ void checkBuffer(const std::string& wkt, double dist, double tolerance, const std::string& wktExpected)
+ std::unique_ptr<Geometry> expected = wktreader.read(wktExpected);
+ ensure_equals_geometry(expected.get(), actual.get(), tolerance);
private:
// noncopyable
test_bufferop_data(test_bufferop_data const& other) = delete;
@@ -465,37 +481,33 @@ void object::test<15>
ensure_equals_geometry(gresult.get(), gexpected.get());
-// Test for #1101 - Non-empty negative buffer of 4-pt convex polygon
+// Test for https://trac.osgeo.org/geos/ticket/1101 - Non-empty negative buffer of 4-pt convex polygon
template<>
template<>
void object::test<16>
std::string wkt0("POLYGON ((666360.09 429614.71, 666344.4 429597.12, 666358.47 429584.52, 666374.5 429602.33, 666360.09 429614.71))");
- GeomPtr g0(wktreader.read(wkt0));
- ensure_not( GeomPtr(g0->buffer( -9 ))->isEmpty() );
- ensure( GeomPtr(g0->buffer( -10 ))->isEmpty() );
- ensure( GeomPtr(g0->buffer( -15 ))->isEmpty() );
- ensure( GeomPtr(g0->buffer( -18 ))->isEmpty() );
+ checkBufferEmpty(wkt0, -9, false);
+ checkBufferEmpty(wkt0, -10, true);
+ checkBufferEmpty(wkt0, -15, true);
+ checkBufferEmpty(wkt0, -18, true);
-// Test for #1101 - Non-empty negative buffer of 5-pt convex polygon
+// Test for https://trac.osgeo.org/geos/ticket/1101 - Non-empty negative buffer of 5-pt convex polygon
template<>
template<>
void object::test<17>
std::string wkt0("POLYGON ((6 20, 16 20, 21 9, 9 0, 0 10, 6 20))");
- ensure_not( GeomPtr(g0->buffer( -8 ))->isEmpty() );
- ensure( GeomPtr(g0->buffer( -8.6 ))->isEmpty() );
- ensure( GeomPtr(g0->buffer( -9.6 ))->isEmpty() );
- ensure( GeomPtr(g0->buffer( -11 ))->isEmpty() );
+ checkBufferEmpty(wkt0, -8, false);
+ checkBufferEmpty(wkt0, -8.6, true);
+ checkBufferEmpty(wkt0, -9.6, true);
+ checkBufferEmpty(wkt0, -11, true);
-// Test for #1101 - Buffer of Polygon with hole with hole eroded
+// Test for https://trac.osgeo.org/geos/ticket/1101 - Buffer of Polygon with hole with hole eroded
template<>
template<>
void object::test<18>
@@ -517,7 +529,7 @@ void object::test<18>
ensure( 0 == dynamic_cast<const geos::geom::Polygon*>(result2.get())->getNumInteriorRing() );
template<>
template<>
void object::test<19>
@@ -539,9 +551,6 @@ template<>
void object::test<20>
- using geos::operation::buffer::BufferOp;
- using geos::operation::buffer::BufferParameters;
std::string wkt0("LINESTRING (-20 0, 0 20, 20 0, 0 -20, -20 0)");
@@ -592,4 +601,34 @@ void object::test<22>
ensure_equals(result->getArea(), 200);
+// Checks a bug in the inverted-ring-removal heuristic.
+// See https://github.com/libgeos/geos/issues/984
+template<>
+template<>
+void object::test<24>
+ std::string wkt("MULTIPOLYGON (((833454.7163917861 6312507.405413097, 833455.3726665961 6312510.208920742, 833456.301153878 6312514.207390314, 833492.2432584754 6312537.770332065, 833493.0901320165 6312536.098774815, 833502.6580673696 6312517.561360772, 833503.9404352929 6312515.0542803425, 833454.7163917861 6312507.405413097)))");
+ checkBuffer(wkt, -3.8, 0.1,
+ "POLYGON ((833490.79 6312532.27, 833498.15 6312518, 833459.97 6312512.07, 833490.79 6312532.27))");
+ checkBuffer(wkt, -7, 0.1,
+ "POLYGON ((833489.57 6312527.65, 833493.27 6312520.48, 833474.09 6312517.5, 833489.57 6312527.65))");
+template<>
+template<>
+void object::test<23>
+ std::string wkt("POLYGON ((182719.04521570954238996 224897.14115349075291306, 182807.02887436276068911 224880.64421749324537814, 182808.47314301913138479 224877.25002362736267969, 182718.38701137207681313 224740.00115247094072402, 182711.82697281913715415 224742.08599378637154587, 182717.1393717635946814 224895.61432328051887453, 182719.04521570954238996 224897.14115349075291306))");
+ checkBuffer(wkt, -5, 0.1,
+ "POLYGON ((182722 224891.5, 182802 224876.5, 182717 224747, 182722 224891.5))");
+ checkBuffer(wkt, -30, 0.1,
+ "POLYGON ((182745.98 224861.57, 182760.51 224858.84, 182745.07 224835.33, 182745.98 224861.57))");
} // namespace tut
Summary of changes:
include/geos/geom/LineSegment.h | 13 ++--
.../geos/operation/buffer/BufferCurveSetBuilder.h | 19 ++++--
src/operation/buffer/BufferCurveSetBuilder.cpp | 71 ++++++++++++--------
tests/unit/geom/LineSegmentTest.cpp | 28 +++++++-
tests/unit/operation/buffer/BufferOpTest.cpp | 77 ++++++++++++++++------
5 files changed, 146 insertions(+), 62 deletions(-)
hooks/post-receive
More information about the geos-commits
