[geos-commits] [SCM] GEOS branch main updated. a32469b222c1f0bae5d9e596340a664127142446
git at osgeo.org
git at osgeo.org
Wed May 15 06:01:29 PDT 2024
the project "GEOS".
The branch, main has been updated
via a32469b222c1f0bae5d9e596340a664127142446 (commit)
from 7f429a927aa7638a2087a59f62a5f67fe1d094a2 (commit)
revisions in full, below.
commit a32469b222c1f0bae5d9e596340a664127142446
Author: Dan Baston <dbaston at gmail.com>
Date: Wed May 15 09:01:06 2024 -0400
GEOSLineSubstring: Avoid crash with NaN length fraction (#1088)
* GEOSLineSubstring: Avoid crash with NaN length fraction
Fixes https://github.com/libgeos/geos/issues/1077
* GEOSLineSubstring: Add test for non-linear input
diff --git a/src/linearref/LengthIndexedLine.cpp b/src/linearref/LengthIndexedLine.cpp
index 012a9dc43..5522eb32c 100644
--- a/src/linearref/LengthIndexedLine.cpp
+++ b/src/linearref/LengthIndexedLine.cpp
@@ -57,6 +57,13 @@ LengthIndexedLine::extractPoint(double index, double offsetDistance) const
std::unique_ptr<Geometry>
LengthIndexedLine::extractLine(double startIndex, double endIndex) const
+ if (std::isnan(startIndex)) {
+ throw util::IllegalArgumentException("startIndex is NaN");
+ if (std::isnan(endIndex)) {
+ throw util::IllegalArgumentException("endIndex is NaN");
const LocationIndexedLine lil(linearGeom);
const double startIndex2 = clampIndex(startIndex);
const double endIndex2 = clampIndex(endIndex);
diff --git a/tests/unit/capi/GEOSInterpolateTest.cpp b/tests/unit/capi/GEOSInterpolateTest.cpp
index 3b5a49f60..44992617f 100644
--- a/tests/unit/capi/GEOSInterpolateTest.cpp
+++ b/tests/unit/capi/GEOSInterpolateTest.cpp
@@ -72,4 +72,14 @@ void object::test<4>
ensure_geometry_equals(result_, expected_);
+// ensure NaN argument does not crash
+template<>
+template<>
+void object::test<5>
+ geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 1 1)");
+ result_ = GEOSInterpolate(geom1_, std::numeric_limits<double>::quiet_NaN());
} // namespace tut
diff --git a/tests/unit/capi/GEOSLineSubstringTest.cpp b/tests/unit/capi/GEOSLineSubstringTest.cpp
index 24078c085..df79b2659 100644
--- a/tests/unit/capi/GEOSLineSubstringTest.cpp
+++ b/tests/unit/capi/GEOSLineSubstringTest.cpp
@@ -131,5 +131,31 @@ void object::test<7>()
ensure("curved geometries not supported", result_ == nullptr);
+// NaN start fraction
+// https://github.com/libgeos/geos/issues/1077
+template<>
+template<>
+void object::test<8>
+ input_ = fromWKT("LINESTRING EMPTY");
+ double start = std::numeric_limits<double>::quiet_NaN();
+ double end = 0.1;
+ result_ = GEOSLineSubstring(input_, start, end);
+ ensure(result_ == nullptr);
+template<>
+template<>
+void object::test<9>
+ input_ = fromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
+ result_ = GEOSLineSubstring(input_, 0.2, 0.3);
} // namespace tut
Summary of changes:
src/linearref/LengthIndexedLine.cpp | 7 +++++++
tests/unit/capi/GEOSInterpolateTest.cpp | 10 ++++++++++
tests/unit/capi/GEOSLineSubstringTest.cpp | 26 ++++++++++++++++++++++++++
3 files changed, 43 insertions(+)
hooks/post-receive
More information about the geos-commits
