[geos-commits] [SCM] GEOS branch main updated. 152e6f7cd1a17aa565ae3c44c6a42310e8496845
Wed May 22 21:17:22 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  152e6f7cd1a17aa565ae3c44c6a42310e8496845 (commit)
      from  147616518549be54b318b3987a6ca329bac9781e (commit)
revisions in full, below.
commit 152e6f7cd1a17aa565ae3c44c6a42310e8496845
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed May 22 21:17:04 2024 -0700
    Add GeosOp options --select and --selectNot (#1100)
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index f5fa28b91..37085bf29 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -1082,6 +1082,18 @@ Result::isGeometry() {
     return typeCode == typeGeometry;
+bool
+Result::isBool() {
+    return typeCode == typeBool;
+bool
+Result::toBool() {
+    if (typeCode == typeBool)
+        return valBool;
+    return false;
 bool
 Result::isGeometryList() {
     return typeCode == typeGeomList;
diff --git a/util/geosop/GeometryOp.h b/util/geosop/GeometryOp.h
index 1dad1016a..9ffc7f853 100644
--- a/util/geosop/GeometryOp.h
+++ b/util/geosop/GeometryOp.h
@@ -46,6 +46,9 @@ public:
     static std::string code(int typeCode);
+    bool isBool();
+    bool toBool();
     bool isGeometry();
     bool isGeometryList();
     std::string metadata();
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 4e50cdc7d..5774d7a77 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -89,6 +89,8 @@ int main(int argc, char** argv) {
         ("p,precision", "Set number of decimal places in output coordinates", cxxopts::value<int>( cmdArgs.precision ) )
         ("q,quiet", "Disable result output", cxxopts::value<bool>( cmdArgs.isQuiet ) )
         ("r,repeat", "Repeat operation N times", cxxopts::value<int>( cmdArgs.repeatNum ) )
+        ("select", "Select geometries where op result is true", cxxopts::value<bool>( cmdArgs.isSelect ) )
+        ("selectNot", "Select geometries where op result is false", cxxopts::value<bool>( cmdArgs.isSelectNot ) )
         ("t,time", "Print execution time", cxxopts::value<bool>( cmdArgs.isShowTime ) )
         ("v,verbose", "Verbose output", cxxopts::value<bool>( cmdArgs.isVerbose )->default_value("false"))
         ("h,help", "Print help")
@@ -439,8 +441,7 @@ void GeosOp::executeUnary(GeometryOp * op, OpArguments& opArgs) {
     for (unsigned i = 0; i < geomA.size(); i++) {
         vertexCount += geomA[i]->getNumPoints();
         Result* result = executeOpRepeat(op, i, geomA[i], 0, nullptr, opArgs);
-        output(result);
+        output(result, geomA[i].get());
         delete result;
@@ -452,7 +453,7 @@ void GeosOp::executeBinary(GeometryOp * op, OpArguments& opArgs) {
             vertexCount += geomB[ib]->getNumPoints();
             Result* result = executeOpRepeat(op, ia, geomA[ia], ib, geomB[ib], opArgs);
-            output(result);
+            output(result, geomA[ia].get());
             delete result;
@@ -512,7 +513,7 @@ Result* GeosOp::executeOp(GeometryOp * op,
     return result;
-void GeosOp::output(Result* result) {
+void GeosOp::output(Result* result, Geometry* geom) {
     //---- print result if format specified
     if (args.isQuiet)
         return;
@@ -528,6 +529,18 @@ void GeosOp::output(Result* result) {
     else if (result->isGeometryList() ) {
         outputGeometryList( result->valGeomList );
+    else if (result->isBool() ) {
+        if (args.isSelect || args.isSelectNot) {
+            bool isSelected = (args.isSelect && result->toBool())
+                    || (args.isSelectNot && ! result->toBool());
+            if (isSelected) {
+                outputGeometry( geom );
+        else {
+            std::cout << result->toString() << std::endl;
     else {
         // output as text/WKT
diff --git a/util/geosop/GeosOp.h b/util/geosop/GeosOp.h
index 3fe373700..3bfd16cb1 100644
--- a/util/geosop/GeosOp.h
+++ b/util/geosop/GeosOp.h
@@ -50,6 +50,8 @@ public:
     int offsetA = -1;
     bool isCollect = true;
     bool isExplode = false;
+    bool isSelect = false;
+    bool isSelectNot = false;
     std::string srcB;
@@ -91,7 +93,7 @@ private:
         unsigned int indexA, const  std::unique_ptr<Geometry>& geomA,
         unsigned int indexB, const  std::unique_ptr<Geometry>& geomB,
         OpArguments& opArgs);
-    void output(Result* result);
+    void output(Result* result, Geometry* geom);
     void outputExplode(std::unique_ptr<Geometry>& geom);
     void outputGeometry( const Geometry* geom);
     void outputGeometryList(std::vector<std::unique_ptr<const Geometry>> & val);
Summary of changes:
 util/geosop/GeometryOp.cpp | 12 ++++++++++++
 util/geosop/GeometryOp.h   |  3 +++
 util/geosop/GeosOp.cpp     | 21 +++++++++++++++++----
 util/geosop/GeosOp.h       |  4 +++-
 4 files changed, 35 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
