[geos-commits] [SCM] GEOS branch main updated. 975fa0008472416c4690b2ff1e7d843342c5fb92
git at osgeo.org
git at osgeo.org
Thu May 23 20:22:10 PDT 2024
the project "GEOS".
The branch, main has been updated
via 975fa0008472416c4690b2ff1e7d843342c5fb92 (commit)
from a7529ec07fd9e2a93e4b42d281bbcc8929eb6aea (commit)
revisions in full, below.
commit 975fa0008472416c4690b2ff1e7d843342c5fb92
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu May 23 20:21:49 2024 -0700
Improve Envelope doc
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 784e79d61..823a0dc04 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -48,7 +48,8 @@ class Coordinate;
* It is often used to represent the bounding box of a Geometry,
* e.g. the minimum and maximum x and y values of the Coordinates.
- * Note that Envelopes support infinite or half-infinite regions, by using
+ * Envelopes allow null values, which are represented with NaN values for ordinates.
+ * Envelopes support infinite or half-infinite regions, by using
* the values of `Double_POSITIVE_INFINITY` and `Double_NEGATIVE_INFINITY`.
* When Envelope objects are created or initialized, the supplies extent
@@ -301,8 +302,8 @@ public:
/** \brief
- * Returns the Envelope maximum y-value. `min y > max y` indicates
- * that this is a null Envelope.
+ * Returns the Envelope maximum y-value.
+ * Null envelopes do not have maximum values.
double getMaxY() const
@@ -311,8 +312,8 @@ public:
/** \brief
- * Returns the Envelope maximum x-value. `min x > max x` indicates
+ * Returns the Envelope maximum x-value.
double getMaxX() const
@@ -321,8 +322,8 @@ public:
/** \brief
- * Returns the Envelope minimum y-value. `min y > max y` indicates
+ * Returns the Envelope minimum y-value.
double getMinY() const
@@ -331,8 +332,8 @@ public:
/** \brief
- * Returns the Envelope minimum x-value. `min x > max x` indicates
+ * Returns the Envelope minimum x-value.
double getMinX() const
@@ -371,7 +372,7 @@ public:
* @param result the envelope representing the intersection of
* the envelopes (this will be the null envelope
* if either argument is null, or they do not intersect)
- * @return false if not intersection is found
+ * @return false if no intersection is found
bool intersection(const Envelope& env, Envelope& result) const;
Summary of changes:
include/geos/geom/Envelope.h | 21 +++++++++++----------
1 file changed, 11 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
