[geos-commits] [SCM] GEOS branch main updated. 93e74e57d0e5be7026b87162c640fa866db661da
git at osgeo.org
git at osgeo.org
Fri May 24 10:43:42 PDT 2024
the project "GEOS".
The branch, main has been updated
via 93e74e57d0e5be7026b87162c640fa866db661da (commit)
from 6de25db755162d79e24474924ae05ee1c37aafb0 (commit)
revisions in full, below.
commit 93e74e57d0e5be7026b87162c640fa866db661da
Author: Sandro Santilli <strk at kbt.io>
Date: Fri May 24 19:43:15 2024 +0200
Add printf format attribute (#1097)
as suggested by -Wsuggest-attribute=format
Handle MinGW and MSVC printf format attributes
Co-authored-by: Mike Taves <mwtoews at gmail.com>
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 622838340..fb7f4ebd7 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -307,9 +307,9 @@ target_compile_definitions(geos_developer_cxx_flags
target_compile_options(geos_developer_cxx_flags
INTERFACE
- $<$<CXX_COMPILER_ID:MSVC>:-W4>
+ $<$<CXX_COMPILER_ID:MSVC>:-W4> # consider -analyze
$<$<OR:$<CXX_COMPILER_ID:GNU>,$<CXX_COMPILER_ID:Clang>,$<CXX_COMPILER_ID:AppleClang>>:-Werror -pedantic -Wall -Wextra -Wno-long-long -Wcast-align -Wconversion -Wsign-conversion -Wchar-subscripts -Wdouble-promotion -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wuninitialized -Wunused-parameter -fno-common>
- $<$<CXX_COMPILER_ID:GNU>:-fno-implicit-inline-templates -Wno-psabi>
+ $<$<CXX_COMPILER_ID:GNU>:-fno-implicit-inline-templates -Wno-psabi -Wsuggest-attribute=format>
$<$<OR:$<CXX_COMPILER_ID:Clang>,$<CXX_COMPILER_ID:AppleClang>>:-Wno-unknown-warning-option>
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 31d1feaef..5db388b24 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -102,7 +102,8 @@ typedef struct GEOSContextHandle_HS *GEOSContextHandle_t;
* \param fmt the message format template
-typedef void (*GEOSMessageHandler)(const char *fmt, ...);
+typedef void (*GEOSMessageHandler)(GEOS_PRINTF_FORMAT const char *fmt, ...)
+ GEOS_PRINTF_FORMAT_ATTR(1, 2);
* A GEOS message handler function.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 6efc5f2f5..2c18d8489 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -289,7 +289,7 @@ typedef struct GEOSContextHandle_HS {
void
- NOTICE_MESSAGE(const char *fmt, ...)
+ NOTICE_MESSAGE(GEOS_PRINTF_FORMAT const char *fmt, ...) GEOS_PRINTF_FORMAT_ATTR(2, 3)
if(nullptr == noticeMessageOld && nullptr == noticeMessageNew) {
return;
@@ -297,7 +297,14 @@ typedef struct GEOSContextHandle_HS {
va_list args;
va_start(args, fmt);
+ #ifdef __MINGW32__
+ #pragma GCC diagnostic push
+ #pragma GCC diagnostic ignored "-Wsuggest-attribute=format"
+ #endif
int result = vsnprintf(msgBuffer, sizeof(msgBuffer) - 1, fmt, args);
+ #pragma GCC diagnostic pop
+ #endif
va_end(args);
if(result > 0) {
@@ -311,7 +318,7 @@ typedef struct GEOSContextHandle_HS {
void
- ERROR_MESSAGE(const char *fmt, ...)
+ ERROR_MESSAGE(GEOS_PRINTF_FORMAT const char *fmt, ...) GEOS_PRINTF_FORMAT_ATTR(2, 3)
if(nullptr == errorMessageOld && nullptr == errorMessageNew) {
return;
@@ -319,7 +326,14 @@ typedef struct GEOSContextHandle_HS {
va_list args;
+ #endif
+ #endif
va_end(args);
if(result > 0) {
diff --git a/include/geos/export.h b/include/geos/export.h
index 997fb4c30..d1baff31d 100644
--- a/include/geos/export.h
+++ b/include/geos/export.h
@@ -31,3 +31,21 @@
#if defined(_MSC_VER)
# pragma warning(disable: 4251) // identifier : class type needs to have dll-interface to be used by clients of class type2
#endif
+ * Portability macros
+#ifdef _MSC_VER
+#include <sal.h>
+#define GEOS_PRINTF_FORMAT _Printf_format_string_
+#define GEOS_PRINTF_FORMAT_ATTR(format_param, dots_param) /**/
+#elif __GNUC__
+#define GEOS_PRINTF_FORMAT /**/
+#define GEOS_PRINTF_FORMAT_ATTR(format_param, dots_param) \
+ __attribute__((format(printf, format_param, dots_param)))
+#else
+#endif
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 3ceed08d6..5f2d0cf04 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -61,13 +61,20 @@ namespace capitest {
finishGEOS();
- static void notice(const char* fmt, ...)
+ static void notice(GEOS_PRINTF_FORMAT const char* fmt, ...) GEOS_PRINTF_FORMAT_ATTR(1, 2)
std::fprintf(stdout, "NOTICE: ");
va_list ap;
va_start(ap, fmt);
+ #endif
std::vfprintf(stdout, fmt, ap);
+ #endif
va_end(ap);
std::fprintf(stdout, "\n");
Summary of changes:
CMakeLists.txt | 4 ++--
capi/geos_c.h.in | 3 ++-
capi/geos_ts_c.cpp | 18 ++++++++++++++++--
include/geos/export.h | 18 ++++++++++++++++++
tests/unit/capi/capi_test_utils.h | 9 ++++++++-
5 files changed, 46 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
