[geos-commits] [SCM] GEOS branch main updated. 7fc5059b95621660a0496bc5ccdd3391d3daf7dd
git at osgeo.org
git at osgeo.org
Fri Nov 1 12:10:14 PDT 2024
the project "GEOS".
The branch, main has been updated
via 7fc5059b95621660a0496bc5ccdd3391d3daf7dd (commit)
from c972dd8f3c9d12b8f3c9b18349d91f43655d29e9 (commit)
revisions in full, below.
commit 7fc5059b95621660a0496bc5ccdd3391d3daf7dd
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 1 11:49:56 2024 -0700
reorganize headers
diff --git a/include/geos/operation/overlayng/EdgeMerger.h b/include/geos/operation/overlayng/EdgeMerger.h
index c02eda706..d1c7c9cc0 100644
--- a/include/geos/operation/overlayng/EdgeMerger.h
+++ b/include/geos/operation/overlayng/EdgeMerger.h
@@ -14,11 +14,7 @@
#pragma once
-#include <geos/operation/overlayng/OverlayLabel.h>
-#include <geos/operation/overlayng/EdgeKey.h>
-#include <geos/operation/overlayng/Edge.h>
#include <geos/export.h>
#include <vector>
#include <map>
@@ -31,7 +27,6 @@ class Coordinate;
namespace operation {
namespace overlayng {
class Edge;
-class EdgeKey;
diff --git a/include/geos/operation/overlayng/EdgeNodingBuilder.h b/include/geos/operation/overlayng/EdgeNodingBuilder.h
index 9066bff2f..f84657150 100644
--- a/include/geos/operation/overlayng/EdgeNodingBuilder.h
+++ b/include/geos/operation/overlayng/EdgeNodingBuilder.h
@@ -40,8 +40,6 @@
#include <memory>
#include <deque>
-using namespace geos::geom;
-using namespace geos::noding;
namespace geos { // geos.
@@ -57,7 +55,7 @@ namespace overlayng { // geos.operation.overlayng
* - Extracts input edges, and attaches topological information
* - if clipping is enabled, handles clipping or limiting input geometry
* - chooses a {@link noding::Noder} based on provided precision model, unless a custom one is supplied
- * - calls the chosen Noder, with precision model
+ * - calls the chosen noding::Noder, with precision model
* - removes any fully collapsed noded edges
* - builds {@link Edge}s and merges them
@@ -73,8 +71,8 @@ private:
// Members
const PrecisionModel* pm;
- std::unique_ptr<std::vector<SegmentString*>> inputEdges;
- Noder* customNoder;
+ std::unique_ptr<std::vector<noding::SegmentString*>> inputEdges;
+ noding::Noder* customNoder;
std::array<bool, 2> hasEdges;
const Envelope* clipEnv;
std::unique_ptr<RingClipper> clipper;
@@ -82,9 +80,9 @@ private:
// For use in createFloatingPrecisionNoder()
algorithm::LineIntersector lineInt;
- IntersectionAdder intAdder;
- std::unique_ptr<Noder> internalNoder;
- std::unique_ptr<Noder> spareInternalNoder;
+ noding::IntersectionAdder intAdder;
+ std::unique_ptr<noding::Noder> internalNoder;
+ std::unique_ptr<noding::Noder> spareInternalNoder;
// EdgeSourceInfo*, Edge* owned by EdgeNodingBuilder, stored in deque
std::deque<EdgeSourceInfo> edgeSourceInfoQue;
std::deque<Edge> edgeQue;
@@ -99,9 +97,9 @@ private:
* - Floating precision: a conventional model (which may be non-robust).
* In this case, a validation step is applied to the output from the noder.
- Noder* getNoder();
- static std::unique_ptr<Noder> createFixedPrecisionNoder(const PrecisionModel* pm);
- std::unique_ptr<Noder> createFloatingPrecisionNoder(bool doValidation);
+ noding::Noder* getNoder();
+ static std::unique_ptr<noding::Noder> createFixedPrecisionNoder(const PrecisionModel* pm);
+ std::unique_ptr<noding::Noder> createFloatingPrecisionNoder(bool doValidation);
void addCollection(const GeometryCollection* gc, uint8_t geomIndex);
@@ -171,8 +169,8 @@ private:
* which is used to provide source topology info to the constructed Edges
* (and is then discarded).
- std::vector<Edge*> node(std::vector<SegmentString*>* segStrings);
- std::vector<Edge*> createEdges(std::vector<SegmentString*>* segStrings);
+ std::vector<Edge*> node(std::vector<noding::SegmentString*>* segStrings);
+ std::vector<Edge*> createEdges(std::vector<noding::SegmentString*>* segStrings);
public:
@@ -182,9 +180,9 @@ public:
* If the noder is not provided, a suitable one will
* be used based on the supplied precision model.
- EdgeNodingBuilder(const PrecisionModel* p_pm, Noder* p_customNoder)
+ EdgeNodingBuilder(const PrecisionModel* p_pm, noding::Noder* p_customNoder)
: pm(p_pm)
- , inputEdges(new std::vector<SegmentString*>)
+ , inputEdges(new std::vector<noding::SegmentString*>)
, customNoder(p_customNoder)
, hasEdges{{false,false}}
, clipEnv(nullptr)
@@ -195,7 +193,7 @@ public:
~EdgeNodingBuilder()
- for (SegmentString* ss: *inputEdges) {
+ for (noding::SegmentString* ss: *inputEdges) {
delete ss;
@@ -203,7 +201,7 @@ public:
void setClipEnvelope(const Envelope* clipEnv);
// returns newly allocated vector and segmentstrings
- // std::vector<SegmentString*>* node();
+ // std::vector<noding::SegmentString*>* node();
* Reports whether there are noded edges
diff --git a/src/operation/overlayng/EdgeMerger.cpp b/src/operation/overlayng/EdgeMerger.cpp
index 205dcdb0e..5602213b4 100644
--- a/src/operation/overlayng/EdgeMerger.cpp
+++ b/src/operation/overlayng/EdgeMerger.cpp
@@ -17,7 +17,9 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateSequence.h>
#include <geos/util/Assert.h>
+#include <geos/operation/overlayng/EdgeKey.h>
+#include <geos/operation/overlayng/Edge.h>
+#include <geos/operation/overlayng/OverlayLabel.h>
namespace operation { // geos.operation
diff --git a/src/operation/overlayng/EdgeNodingBuilder.cpp b/src/operation/overlayng/EdgeNodingBuilder.cpp
index 74800020f..d617ca4f0 100644
--- a/src/operation/overlayng/EdgeNodingBuilder.cpp
+++ b/src/operation/overlayng/EdgeNodingBuilder.cpp
@@ -19,7 +19,6 @@
#include <geos/noding/ValidatingNoder.h>
#include <geos/noding/NodedSegmentString.h>
#include <geos/noding/MCIndexNoder.h>
-#include <geos/geom/Coordinate.h>
#include <geos/algorithm/Orientation.h>
#include <geos/noding/snapround/SnapRoundingNoder.h>
#include <geos/operation/overlayng/EdgeNodingBuilder.h>
@@ -28,13 +27,20 @@
#include <geos/operation/overlayng/OverlayUtil.h>
#include <geos/util.h>
-using geos::operation::valid::RepeatedPointRemover;
-using geos::noding::snapround::SnapRoundingNoder;
+using geos::operation::valid::RepeatedPointRemover;
+using geos::noding::snapround::SnapRoundingNoder;
+using geos::noding::Noder;
+using geos::noding::MCIndexNoder;
+using geos::noding::ValidatingNoder;
+using geos::noding::SegmentString;
+using geos::noding::NodedSegmentString;
/*private*/
Noder*
EdgeNodingBuilder::getNoder()
Summary of changes:
include/geos/operation/overlayng/EdgeMerger.h | 5 ----
.../geos/operation/overlayng/EdgeNodingBuilder.h | 32 ++++++++++------------
src/operation/overlayng/EdgeMerger.cpp | 4 ++-
src/operation/overlayng/EdgeNodingBuilder.cpp | 12 ++++++--
4 files changed, 27 insertions(+), 26 deletions(-)
hooks/post-receive
More information about the geos-commits
