[geos-commits] [SCM] GEOS branch main updated. d7102075476d7034359ac80df9d6612e1e600359
Thu Nov 7 11:06:21 PST 2024
the project "GEOS".
The branch, main has been updated
       via  d7102075476d7034359ac80df9d6612e1e600359 (commit)
      from  f3edf738f78957ca9fd912764bddab04dbb02e6b (commit)
revisions in full, below.
commit d7102075476d7034359ac80df9d6612e1e600359
Author: kikitte <kikitte.lee at gmail.com>
Date:   Fri Nov 8 03:05:59 2024 +0800
    move using-declarations into class body to avoid polluting global (#1186)
    namespace
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index ef251c3ee..eb81e07c7 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -29,13 +29,12 @@ class CoordinateSequence;
-using namespace geos::math;
 namespace geos {
 namespace algorithm { // geos::algorithm
 /// Implements basic computational geometry algorithms using extended precision float-point arithmetic.
 class GEOS_DLL CGAlgorithmsDD {
+    using DD = geos::math::DD;
 public:
diff --git a/include/geos/algorithm/MinimumAreaRectangle.h b/include/geos/algorithm/MinimumAreaRectangle.h
index 0e340a981..434f4c7f7 100644
--- a/include/geos/algorithm/MinimumAreaRectangle.h
+++ b/include/geos/algorithm/MinimumAreaRectangle.h
@@ -32,15 +32,6 @@ namespace geos {
-using geos::geom::CoordinateSequence;
-using geos::geom::CoordinateXY;
-using geos::geom::Geometry;
-using geos::geom::GeometryFactory;
-using geos::geom::LineSegment;
-using geos::geom::LineString;
-using geos::geom::Polygon;
 namespace geos {
@@ -65,6 +56,13 @@ namespace algorithm { // geos::algorithm
 class GEOS_DLL MinimumAreaRectangle {
+    using CoordinateSequence = geos::geom::CoordinateSequence;
+    using CoordinateXY = geos::geom::CoordinateXY;
+    using Geometry = geos::geom::Geometry;
+    using GeometryFactory = geos::geom::GeometryFactory;
+    using LineSegment = geos::geom::LineSegment;
+    using LineString = geos::geom::LineString;
+    using Polygon = geos::geom::Polygon;
 private:
diff --git a/include/geos/algorithm/PolygonNodeTopology.h b/include/geos/algorithm/PolygonNodeTopology.h
index ca3de04f2..8a4eb76e1 100644
--- a/include/geos/algorithm/PolygonNodeTopology.h
+++ b/include/geos/algorithm/PolygonNodeTopology.h
@@ -25,9 +25,6 @@ class CoordinateXY;
 namespace geos {
@@ -39,6 +36,7 @@ namespace algorithm { // geos::algorithm
 class GEOS_DLL PolygonNodeTopology {
 public:
diff --git a/include/geos/algorithm/Rectangle.h b/include/geos/algorithm/Rectangle.h
index ef073ee47..c1786534c 100644
--- a/include/geos/algorithm/Rectangle.h
+++ b/include/geos/algorithm/Rectangle.h
@@ -26,15 +26,14 @@ class Polygon;
 namespace geos {
 class GEOS_DLL Rectangle {
 public:
diff --git a/include/geos/algorithm/construct/IndexedDistanceToPoint.h b/include/geos/algorithm/construct/IndexedDistanceToPoint.h
index 68d845245..7509973cf 100644
--- a/include/geos/algorithm/construct/IndexedDistanceToPoint.h
+++ b/include/geos/algorithm/construct/IndexedDistanceToPoint.h
@@ -25,10 +25,6 @@
 #include <geos/algorithm/construct/IndexedPointInPolygonsLocator.h>
 #include <geos/operation/distance/IndexedFacetDistance.h>
-using geos::geom::Point;
-using geos::operation::distance::IndexedFacetDistance;
 namespace geos {
 namespace construct { // geos::algorithm::construct
@@ -43,6 +39,9 @@ namespace construct { // geos::algorithm::construct
  * \author Martin Davis
 class GEOS_DLL IndexedDistanceToPoint {
+    using Point = geos::geom::Point;
+    using IndexedFacetDistance = geos::operation::distance::IndexedFacetDistance;
 public:
diff --git a/include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h b/include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h
index dd82d55a4..59325daf9 100644
--- a/include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h
+++ b/include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h
@@ -25,12 +25,6 @@
 #include <geos/index/strtree/TemplateSTRtree.h>
 #include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
-using geos::geom::Location;
-using geos::index::strtree::TemplateSTRtree;
-using geos::algorithm::locate::IndexedPointInAreaLocator;
 namespace geos {
@@ -43,6 +37,12 @@ namespace construct { // geos::algorithm::construct
 class GEOS_DLL IndexedPointInPolygonsLocator {
+    using Location = geos::geom::Location;
+    template<typename ItemType>
+    using TemplateSTRtree = geos::index::strtree::TemplateSTRtree<ItemType>;
+    using IndexedPointInAreaLocator = geos::algorithm::locate::IndexedPointInAreaLocator;
 public:
diff --git a/include/geos/algorithm/construct/LargestEmptyCircle.h b/include/geos/algorithm/construct/LargestEmptyCircle.h
index f19931488..0f4b6d08c 100644
--- a/include/geos/algorithm/construct/LargestEmptyCircle.h
+++ b/include/geos/algorithm/construct/LargestEmptyCircle.h
@@ -40,8 +40,6 @@ class Point;
 namespace geos {
@@ -75,6 +73,7 @@ namespace construct { // geos::algorithm::construct
 class GEOS_DLL LargestEmptyCircle {
 public:
diff --git a/include/geos/algorithm/construct/MaximumInscribedCircle.h b/include/geos/algorithm/construct/MaximumInscribedCircle.h
index 1da12c038..3e6ba54ce 100644
--- a/include/geos/algorithm/construct/MaximumInscribedCircle.h
+++ b/include/geos/algorithm/construct/MaximumInscribedCircle.h
@@ -41,9 +41,6 @@ class Point;
 namespace geos {
@@ -54,6 +51,8 @@ namespace construct { // geos::algorithm::construct
  * Also computes two points which are separated by the distance.
 class GEOS_DLL MaximumInscribedCircle {
 public:
diff --git a/include/geos/algorithm/hull/ConcaveHull.h b/include/geos/algorithm/hull/ConcaveHull.h
index 6201e21b5..ce9de47d3 100644
--- a/include/geos/algorithm/hull/ConcaveHull.h
+++ b/include/geos/algorithm/hull/ConcaveHull.h
@@ -37,16 +37,6 @@ class QuadEdgeSubdivision;
-using geos::geom::Coordinate;
-using geos::geom::Triangle;
-using geos::triangulate::quadedge::QuadEdge;
-using geos::triangulate::quadedge::QuadEdgeSubdivision;
-using geos::triangulate::quadedge::TriangleVisitor;
-using geos::triangulate::tri::Tri;
-using geos::triangulate::tri::TriList;
 namespace geos {
 namespace hull {      // geos::algorithm::hull
@@ -93,6 +83,15 @@ typedef std::priority_queue<HullTri*, std::vector<HullTri*>, HullTri::HullTriCom
 * @author mdavis
 class GEOS_DLL ConcaveHull {
+    using Coordinate = geos::geom::Coordinate;
+    using Triangle = geos::geom::Triangle;
+    using QuadEdge = geos::triangulate::quadedge::QuadEdge;
+    using QuadEdgeSubdivision = geos::triangulate::quadedge::QuadEdgeSubdivision;
+    using Tri = geos::triangulate::tri::Tri;
+    template<typename TriType>
+    using TriList = geos::triangulate::tri::TriList<TriType>;
 public:
diff --git a/include/geos/algorithm/hull/ConcaveHullOfPolygons.h b/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
index 1c99ab9ed..f13dd0327 100644
--- a/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
+++ b/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
@@ -15,6 +15,7 @@
 #pragma once
 #include <geos/triangulate/tri/TriList.h>
+#include <geos/triangulate/tri/Tri.h>
 #include <set>
 #include <deque>
@@ -38,21 +39,6 @@ class Tri;
-#include <geos/triangulate/tri/Tri.h>
-using geos::geom::Envelope;
-using geos::geom::GeometryCollection;
-using geos::geom::LinearRing;
 namespace geos {
@@ -95,6 +81,17 @@ namespace hull {      // geos::algorithm::hull
 class GEOS_DLL ConcaveHullOfPolygons {
+    using Envelope = geos::geom::Envelope;
+    using GeometryCollection = geos::geom::GeometryCollection;
+    using LinearRing = geos::geom::LinearRing;
 private:
diff --git a/include/geos/algorithm/hull/HullTri.h b/include/geos/algorithm/hull/HullTri.h
index 4fbc587ae..0e04dbe16 100644
--- a/include/geos/algorithm/hull/HullTri.h
+++ b/include/geos/algorithm/hull/HullTri.h
@@ -33,20 +33,20 @@ namespace quadedge {
 namespace geos {
-class HullTri : public Tri
-    private:
+class HullTri : public geos::triangulate::tri::Tri {
+private:
         double m_size;
         bool m_isMarked = false;
diff --git a/include/geos/algorithm/hull/HullTriangulation.h b/include/geos/algorithm/hull/HullTriangulation.h
index 05808c842..5a921dd2b 100644
--- a/include/geos/algorithm/hull/HullTriangulation.h
+++ b/include/geos/algorithm/hull/HullTriangulation.h
@@ -15,7 +15,6 @@
 #pragma once
 #include <geos/algorithm/hull/HullTri.h>
 #include <geos/triangulate/quadedge/TriangleVisitor.h>
@@ -34,16 +33,6 @@ class QuadEdgeSubdivision;
 namespace geos {
@@ -51,6 +40,14 @@ namespace hull {      // geos::algorithm::hull
 class HullTriangulation
+    using TriangleVisitor = geos::triangulate::quadedge::TriangleVisitor;
 private:
diff --git a/include/geos/algorithm/hull/OuterShellsExtracter.h b/include/geos/algorithm/hull/OuterShellsExtracter.h
index ad0a054b0..3c09267c1 100644
--- a/include/geos/algorithm/hull/OuterShellsExtracter.h
+++ b/include/geos/algorithm/hull/OuterShellsExtracter.h
@@ -18,20 +18,11 @@
 namespace geos {
 namespace geom {
-class Coordinate;
-class CoordinateSequence;
-class Envelope;
 class Geometry;
-class GeometryCollection;
-class GeometryFactory;
 class LinearRing;
-class Polygon;
 namespace geos {
@@ -44,6 +35,9 @@ namespace hull {      // geos::algorithm::hull
 class OuterShellsExtracter {
 private:
     OuterShellsExtracter(const Geometry& g);
diff --git a/include/geos/coverage/Corner.h b/include/geos/coverage/Corner.h
index 5cada2413..373ee04f7 100644
--- a/include/geos/coverage/Corner.h
+++ b/include/geos/coverage/Corner.h
@@ -32,19 +32,16 @@ class LineString;
-using geos::simplify::LinkedLine;
 namespace geos {
 namespace coverage { // geos::coverage
 class Corner
+    using LinkedLine = geos::simplify::LinkedLine;
 public:
diff --git a/include/geos/coverage/CoverageBoundarySegmentFinder.h b/include/geos/coverage/CoverageBoundarySegmentFinder.h
index cc23093ba..359ea7aec 100644
--- a/include/geos/coverage/CoverageBoundarySegmentFinder.h
+++ b/include/geos/coverage/CoverageBoundarySegmentFinder.h
@@ -28,18 +28,16 @@ class Geometry;
-using geos::geom::CoordinateSequenceFilter;
 namespace geos {
-class CoverageBoundarySegmentFinder : public CoordinateSequenceFilter
+class CoverageBoundarySegmentFinder : public geos::geom::CoordinateSequenceFilter
+    using CoordinateSequenceFilter = geos::geom::CoordinateSequenceFilter;
 public:
diff --git a/include/geos/coverage/CoverageEdge.h b/include/geos/coverage/CoverageEdge.h
index 6404b653f..60afd1c7c 100644
--- a/include/geos/coverage/CoverageEdge.h
+++ b/include/geos/coverage/CoverageEdge.h
@@ -32,14 +32,6 @@ class GeometryFactory;
-using geos::geom::MultiLineString;
 namespace geos {      // geos.
 namespace coverage { // geos.coverage
@@ -52,6 +44,14 @@ namespace coverage { // geos.coverage
 class GEOS_DLL CoverageEdge {
+    using MultiLineString = geos::geom::MultiLineString;
 private:
diff --git a/include/geos/coverage/CoverageGapFinder.h b/include/geos/coverage/CoverageGapFinder.h
index 3a9780f40..4be685f70 100644
--- a/include/geos/coverage/CoverageGapFinder.h
+++ b/include/geos/coverage/CoverageGapFinder.h
@@ -27,8 +27,6 @@ class LinearRing;
@@ -50,6 +48,8 @@ namespace coverage { // geos::coverage
 class GEOS_DLL CoverageGapFinder {
 private:
diff --git a/include/geos/coverage/CoveragePolygon.h b/include/geos/coverage/CoveragePolygon.h
index e56668c45..4363ea06e 100644
--- a/include/geos/coverage/CoveragePolygon.h
+++ b/include/geos/coverage/CoveragePolygon.h
@@ -25,15 +25,14 @@ class Polygon;
 class GEOS_DLL CoveragePolygon {
     // Members
     const Polygon* m_polygon;
diff --git a/include/geos/coverage/CoveragePolygonValidator.h b/include/geos/coverage/CoveragePolygonValidator.h
index 8f635de38..8c49bcc01 100644
--- a/include/geos/coverage/CoveragePolygonValidator.h
+++ b/include/geos/coverage/CoveragePolygonValidator.h
@@ -33,12 +33,6 @@ class GeometryFactory;
@@ -96,6 +90,15 @@ namespace coverage { // geos::coverage
 class GEOS_DLL CoveragePolygonValidator {
 private:
diff --git a/include/geos/coverage/CoverageRing.h b/include/geos/coverage/CoverageRing.h
index 76bd44aaf..f9a78f730 100644
--- a/include/geos/coverage/CoverageRing.h
+++ b/include/geos/coverage/CoverageRing.h
@@ -31,18 +31,17 @@ class Polygon;
 class GEOS_DLL CoverageRing : public noding::BasicSegmentString {
 private:
diff --git a/include/geos/coverage/CoverageRingEdges.h b/include/geos/coverage/CoverageRingEdges.h
index ec2809852..5a0f4ac1b 100644
--- a/include/geos/coverage/CoverageRingEdges.h
+++ b/include/geos/coverage/CoverageRingEdges.h
@@ -36,14 +36,6 @@ class CoverageEdge;
-using geos::geom::MultiPolygon;
@@ -58,6 +50,13 @@ namespace coverage { // geos.coverage
  * @author Martin Davis
 class GEOS_DLL CoverageRingEdges {
+    using MultiPolygon = geos::geom::MultiPolygon;
 private:
diff --git a/include/geos/coverage/CoverageSimplifier.h b/include/geos/coverage/CoverageSimplifier.h
index 5e23028d3..74df234dd 100644
--- a/include/geos/coverage/CoverageSimplifier.h
+++ b/include/geos/coverage/CoverageSimplifier.h
@@ -32,13 +32,6 @@ class CoverageEdge;
-using geos::coverage::CoverageEdge;
 namespace geos {
@@ -74,7 +67,10 @@ namespace coverage { // geos::coverage
 class GEOS_DLL CoverageSimplifier {
+    using CoverageEdge = geos::coverage::CoverageEdge;
 public:
diff --git a/include/geos/coverage/CoverageUnion.h b/include/geos/coverage/CoverageUnion.h
index 8983c19c0..2749488e5 100644
--- a/include/geos/coverage/CoverageUnion.h
+++ b/include/geos/coverage/CoverageUnion.h
@@ -25,8 +25,6 @@ class Geometry;
@@ -39,6 +37,7 @@ namespace coverage { // geos::coverage
 class GEOS_DLL CoverageUnion {
 private:
diff --git a/include/geos/coverage/CoverageValidator.h b/include/geos/coverage/CoverageValidator.h
index 86a53e68d..2185d23cb 100644
--- a/include/geos/coverage/CoverageValidator.h
+++ b/include/geos/coverage/CoverageValidator.h
@@ -24,9 +24,6 @@ class Geometry;
@@ -63,6 +60,9 @@ namespace coverage { // geos::coverage
 class GEOS_DLL CoverageValidator {
+    template <typename ItemType>
 private:
diff --git a/include/geos/coverage/InvalidSegmentDetector.h b/include/geos/coverage/InvalidSegmentDetector.h
index 66f978340..a1f085001 100644
--- a/include/geos/coverage/InvalidSegmentDetector.h
+++ b/include/geos/coverage/InvalidSegmentDetector.h
@@ -30,12 +30,6 @@ class CoverageRing;
-using geos::noding::SegmentIntersector;
-using geos::noding::SegmentString;
@@ -52,7 +46,9 @@ namespace coverage { // geos.coverage
-class GEOS_DLL InvalidSegmentDetector : public SegmentIntersector {
+class GEOS_DLL InvalidSegmentDetector : public geos::noding::SegmentIntersector {
+    using SegmentString = geos::noding::SegmentString;
 private:
diff --git a/include/geos/coverage/TPVWSimplifier.h b/include/geos/coverage/TPVWSimplifier.h
index 657616e87..0b904c8a8 100644
--- a/include/geos/coverage/TPVWSimplifier.h
+++ b/include/geos/coverage/TPVWSimplifier.h
@@ -35,20 +35,6 @@ class MultiLineString;
-using geos::coverage::Corner;
-using geos::index::VertexSequencePackedRtree;
 namespace geos {
@@ -73,6 +59,18 @@ namespace coverage { // geos::coverage
 class GEOS_DLL TPVWSimplifier
+    using Corner = geos::coverage::Corner;
+    using VertexSequencePackedRtree = geos::index::VertexSequencePackedRtree;
 public:
diff --git a/include/geos/coverage/VertexRingCounter.h b/include/geos/coverage/VertexRingCounter.h
index a8899ae91..c0982ad2b 100644
--- a/include/geos/coverage/VertexRingCounter.h
+++ b/include/geos/coverage/VertexRingCounter.h
@@ -27,17 +27,14 @@ class Geometry;
 namespace geos {
-class VertexRingCounter : public CoordinateSequenceFilter
+class VertexRingCounter : public geos::geom::CoordinateSequenceFilter
 public:
diff --git a/include/geos/geom/prep/BasicPreparedGeometry.h b/include/geos/geom/prep/BasicPreparedGeometry.h
index f061de451..5e7323be5 100644
--- a/include/geos/geom/prep/BasicPreparedGeometry.h
+++ b/include/geos/geom/prep/BasicPreparedGeometry.h
@@ -38,8 +38,6 @@ namespace geos {
 namespace geom { // geos::geom
 namespace prep { // geos::geom::prep
-using geos::operation::relateng::RelateNG;
 // * \class BasicPreparedGeometry
@@ -56,6 +54,8 @@ using geos::operation::relateng::RelateNG;
 class BasicPreparedGeometry: public PreparedGeometry {
+    using RelateNG = geos::operation::relateng::RelateNG;
 private:
     const geom::Geometry* baseGeom;
     std::vector<const CoordinateXY*> representativePts;
diff --git a/include/geos/geomgraph/Label.h b/include/geos/geomgraph/Label.h
index 773b822ad..b0966db12 100644
--- a/include/geos/geomgraph/Label.h
+++ b/include/geos/geomgraph/Label.h
@@ -55,6 +55,7 @@ namespace geomgraph { // geos.geomgraph
 class GEOS_DLL Label final {
+    using Position = geos::geom::Position;
 public:
diff --git a/include/geos/geomgraph/TopologyLocation.h b/include/geos/geomgraph/TopologyLocation.h
index 7c37159ed..0c831ef93 100644
--- a/include/geos/geomgraph/TopologyLocation.h
+++ b/include/geos/geomgraph/TopologyLocation.h
@@ -34,9 +34,6 @@
 #pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
 #endif
-using geos::geom::Position;
 namespace geos {
@@ -61,6 +58,8 @@ namespace geomgraph { // geos.geomgraph
  * where j has the values ON, LEFT, RIGHT
 class GEOS_DLL TopologyLocation {
 public:
diff --git a/include/geos/index/VertexSequencePackedRtree.h b/include/geos/index/VertexSequencePackedRtree.h
index cab7eeeed..8cf08364e 100644
--- a/include/geos/index/VertexSequencePackedRtree.h
+++ b/include/geos/index/VertexSequencePackedRtree.h
@@ -26,11 +26,6 @@ class Envelope;
 namespace geos {
 namespace index {
@@ -52,6 +47,9 @@ namespace index {
 class GEOS_DLL VertexSequencePackedRtree {
 private:
diff --git a/include/geos/noding/BoundaryChainNoder.h b/include/geos/noding/BoundaryChainNoder.h
index 890f400bc..dc6bd0be2 100644
--- a/include/geos/noding/BoundaryChainNoder.h
+++ b/include/geos/noding/BoundaryChainNoder.h
@@ -31,8 +31,6 @@ class NodedSegmentString;
 namespace noding { // geos::noding
@@ -55,6 +53,7 @@ namespace noding { // geos::noding
 class GEOS_DLL BoundaryChainNoder : public Noder {
 private:
diff --git a/include/geos/operation/buffer/BufferCurveSetBuilder.h b/include/geos/operation/buffer/BufferCurveSetBuilder.h
index e731840bf..ca5fc64dd 100644
--- a/include/geos/operation/buffer/BufferCurveSetBuilder.h
+++ b/include/geos/operation/buffer/BufferCurveSetBuilder.h
@@ -70,6 +70,7 @@ namespace buffer { // geos.operation.buffer
 class GEOS_DLL BufferCurveSetBuilder {
 private:
diff --git a/include/geos/operation/buffer/OffsetCurve.h b/include/geos/operation/buffer/OffsetCurve.h
index 403ca98b7..3b218aa4a 100644
--- a/include/geos/operation/buffer/OffsetCurve.h
+++ b/include/geos/operation/buffer/OffsetCurve.h
@@ -37,13 +37,6 @@ class SegmentMCIndex;
 namespace geos {
 namespace operation {
 namespace buffer {
@@ -88,7 +81,12 @@ namespace buffer {
 class GEOS_DLL OffsetCurve {
 private:
diff --git a/include/geos/operation/buffer/OffsetCurveBuilder.h b/include/geos/operation/buffer/OffsetCurveBuilder.h
index f73672b1c..1f6cddf74 100644
--- a/include/geos/operation/buffer/OffsetCurveBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveBuilder.h
@@ -40,9 +40,6 @@ class PrecisionModel;
-using geos::geom::PrecisionModel;
 namespace geos {
 namespace operation { // geos.operation
@@ -66,6 +63,9 @@ namespace buffer { // geos.operation.buffer
  * See removeRepeatedAndInvalidPoints.
 class GEOS_DLL OffsetCurveBuilder {
+    using PrecisionModel = geos::geom::PrecisionModel;
 public:
diff --git a/include/geos/operation/buffer/OffsetCurveSection.h b/include/geos/operation/buffer/OffsetCurveSection.h
index e73d759ce..2f953b87e 100644
--- a/include/geos/operation/buffer/OffsetCurveSection.h
+++ b/include/geos/operation/buffer/OffsetCurveSection.h
@@ -31,12 +31,6 @@ class LineString;
@@ -53,6 +47,11 @@ namespace buffer {    // geos.operation.buffer
  * @author mdavis
 class GEOS_DLL OffsetCurveSection {
 private:
diff --git a/include/geos/operation/buffer/SegmentMCIndex.h b/include/geos/operation/buffer/SegmentMCIndex.h
index a6ba27a79..1e23aeba6 100644
--- a/include/geos/operation/buffer/SegmentMCIndex.h
+++ b/include/geos/operation/buffer/SegmentMCIndex.h
@@ -26,20 +26,22 @@ class Envelope;
-using namespace geos::index;
 namespace geos {
 namespace buffer {
 class GEOS_DLL SegmentMCIndex {
+    using MonotoneChain = geos::index::chain::MonotoneChain;
+    using MonotoneChainSelectAction = geos::index::chain::MonotoneChainSelectAction;
 private:
-    strtree::TemplateSTRtree<const index::chain::MonotoneChain*> index;
-    std::vector<chain::MonotoneChain> segChains;
+    TemplateSTRtree<const MonotoneChain*> index;
+    std::vector<MonotoneChain> segChains;
     void buildIndex(const CoordinateSequence* segs);
@@ -47,7 +49,7 @@ public:
     SegmentMCIndex(const CoordinateSequence* segs);
-    void query(const Envelope* env, chain::MonotoneChainSelectAction& action);
+    void query(const Envelope* env, MonotoneChainSelectAction& action);
diff --git a/include/geos/operation/overlayng/CoverageUnion.h b/include/geos/operation/overlayng/CoverageUnion.h
index 6c7a8be84..3bfb38e4b 100644
--- a/include/geos/operation/overlayng/CoverageUnion.h
+++ b/include/geos/operation/overlayng/CoverageUnion.h
@@ -24,8 +24,6 @@ class Geometry;
 namespace overlayng { // geos.operation.overlayng
@@ -67,6 +65,7 @@ namespace overlayng { // geos.operation.overlayng
 private:
diff --git a/include/geos/operation/overlayng/Edge.h b/include/geos/operation/overlayng/Edge.h
index 9db3362ad..b0f670b7b 100644
--- a/include/geos/operation/overlayng/Edge.h
+++ b/include/geos/operation/overlayng/Edge.h
@@ -53,6 +53,7 @@ namespace overlayng { // geos.operation.overlayng
  * @author mdavis
 class GEOS_DLL Edge {
 private:
diff --git a/include/geos/operation/overlayng/EdgeKey.h b/include/geos/operation/overlayng/EdgeKey.h
index 3014bc30f..ef66e4653 100644
--- a/include/geos/operation/overlayng/EdgeKey.h
+++ b/include/geos/operation/overlayng/EdgeKey.h
@@ -26,9 +26,6 @@ namespace geos {      // geos.
  * A key for sorting and comparing edges in a noded arrangement.
  * Relies on the fact that in a correctly noded arrangement
@@ -39,6 +36,7 @@ using geos::geom::Coordinate;
 class GEOS_DLL EdgeKey {
 private:
diff --git a/include/geos/operation/overlayng/EdgeNodingBuilder.h b/include/geos/operation/overlayng/EdgeNodingBuilder.h
index f84657150..9d2195b35 100644
--- a/include/geos/operation/overlayng/EdgeNodingBuilder.h
+++ b/include/geos/operation/overlayng/EdgeNodingBuilder.h
@@ -62,6 +62,14 @@ namespace overlayng { // geos.operation.overlayng
  * @author mdavis
 class GEOS_DLL EdgeNodingBuilder {
 private:
diff --git a/include/geos/operation/overlayng/InputGeometry.h b/include/geos/operation/overlayng/InputGeometry.h
index 862ac9f0f..a1ecff0e4 100644
--- a/include/geos/operation/overlayng/InputGeometry.h
+++ b/include/geos/operation/overlayng/InputGeometry.h
@@ -38,10 +38,12 @@ namespace overlayng { // geos.operation.overlayng
-using namespace geos::algorithm::locate;
-using namespace geos::geom;
 class GEOS_DLL InputGeometry {
+    using PointOnGeometryLocator = geos::algorithm::locate::PointOnGeometryLocator;
 private:
diff --git a/include/geos/operation/overlayng/LineLimiter.h b/include/geos/operation/overlayng/LineLimiter.h
index f4ec5fb08..8a9b27f49 100644
--- a/include/geos/operation/overlayng/LineLimiter.h
+++ b/include/geos/operation/overlayng/LineLimiter.h
@@ -30,8 +30,6 @@ class CoordinateSequence;
@@ -54,6 +52,9 @@ namespace overlayng { // geos.operation.overlayng
 class GEOS_DLL LineLimiter {
 private:
diff --git a/include/geos/operation/overlayng/MaximalEdgeRing.h b/include/geos/operation/overlayng/MaximalEdgeRing.h
index 359753eb8..489625ef9 100644
--- a/include/geos/operation/overlayng/MaximalEdgeRing.h
+++ b/include/geos/operation/overlayng/MaximalEdgeRing.h
@@ -24,7 +24,6 @@
 namespace geos {
 namespace geom {
 class Coordinate;
-class CoordinateArray;
@@ -39,9 +38,9 @@ namespace geos {      // geos.
 class GEOS_DLL MaximalEdgeRing {
 private:
diff --git a/include/geos/operation/overlayng/OverlayEdge.h b/include/geos/operation/overlayng/OverlayEdge.h
index 7cb6d41ee..42d3632cd 100644
--- a/include/geos/operation/overlayng/OverlayEdge.h
+++ b/include/geos/operation/overlayng/OverlayEdge.h
@@ -37,11 +37,6 @@ class MaximalEdgeRing;
-using geos::geom::CoordinateXYZM;
@@ -50,6 +45,10 @@ namespace overlayng { // geos.operation.overlayng
 * Creates a single OverlayEdge.
 class GEOS_DLL OverlayEdge : public edgegraph::HalfEdge {
+    using CoordinateXYZM = geos::geom::CoordinateXYZM;
 private:
diff --git a/include/geos/operation/overlayng/OverlayEdgeRing.h b/include/geos/operation/overlayng/OverlayEdgeRing.h
index a5c3237bf..b2509f02c 100644
--- a/include/geos/operation/overlayng/OverlayEdgeRing.h
+++ b/include/geos/operation/overlayng/OverlayEdgeRing.h
@@ -44,11 +44,14 @@ namespace geos {      // geos.
-using algorithm::locate::PointOnGeometryLocator;
-using algorithm::locate::IndexedPointInAreaLocator;
 class GEOS_DLL OverlayEdgeRing {
+    using PointOnGeometryLocator = algorithm::locate::PointOnGeometryLocator;
+    using IndexedPointInAreaLocator = algorithm::locate::IndexedPointInAreaLocator;
 private:
diff --git a/include/geos/operation/overlayng/OverlayGraph.h b/include/geos/operation/overlayng/OverlayGraph.h
index 718390fcd..e44c46b2e 100644
--- a/include/geos/operation/overlayng/OverlayGraph.h
+++ b/include/geos/operation/overlayng/OverlayGraph.h
@@ -39,8 +39,6 @@ namespace geos {      // geos.
  * A planar graph of {@link OverlayEdge}, representing
  * the topology resulting from an overlay operation.
@@ -52,6 +50,8 @@ using namespace geos::geom;
 class GEOS_DLL OverlayGraph {
 private:
diff --git a/include/geos/operation/overlayng/OverlayLabel.h b/include/geos/operation/overlayng/OverlayLabel.h
index 59dab3684..d0c004077 100644
--- a/include/geos/operation/overlayng/OverlayLabel.h
+++ b/include/geos/operation/overlayng/OverlayLabel.h
@@ -20,9 +20,6 @@
 #include <geos/geom/Position.h>
 #include <geos/export.h>
@@ -87,6 +84,8 @@ namespace overlayng { // geos.operation.overlayng
 class GEOS_DLL OverlayLabel {
 private:
diff --git a/include/geos/operation/overlayng/OverlayMixedPoints.h b/include/geos/operation/overlayng/OverlayMixedPoints.h
index b83b8802d..c7b681228 100644
--- a/include/geos/operation/overlayng/OverlayMixedPoints.h
+++ b/include/geos/operation/overlayng/OverlayMixedPoints.h
@@ -46,9 +46,6 @@ namespace geos {      // geos.
  * Computes an overlay where one input is Point(s) and one is not.
  * This class supports overlay being used as an efficient way
@@ -77,6 +74,16 @@ using algorithm::locate::PointOnGeometryLocator;
 class GEOS_DLL OverlayMixedPoints {
 private:
diff --git a/include/geos/operation/overlayng/OverlayNG.h b/include/geos/operation/overlayng/OverlayNG.h
index 12b10ea09..9a3ad2805 100644
--- a/include/geos/operation/overlayng/OverlayNG.h
+++ b/include/geos/operation/overlayng/OverlayNG.h
@@ -118,6 +118,9 @@ namespace overlayng { // geos.operation.overlayng
 class GEOS_DLL OverlayNG {
 private:
diff --git a/include/geos/operation/overlayng/OverlayNGRobust.h b/include/geos/operation/overlayng/OverlayNGRobust.h
index 0f1829ec8..c63d7d3b5 100644
--- a/include/geos/operation/overlayng/OverlayNGRobust.h
+++ b/include/geos/operation/overlayng/OverlayNGRobust.h
@@ -62,6 +62,7 @@ namespace overlayng { // geos.operation.overlayng
 class GEOS_DLL OverlayNGRobust {
 private:
diff --git a/include/geos/operation/overlayng/OverlayPoints.h b/include/geos/operation/overlayng/OverlayPoints.h
index e357dcdca..0130c3069 100644
--- a/include/geos/operation/overlayng/OverlayPoints.h
+++ b/include/geos/operation/overlayng/OverlayPoints.h
@@ -37,8 +37,6 @@ namespace geos {      // geos.
  * Performs an overlay operation on inputs which are both point geometries.
@@ -53,6 +51,13 @@ using namespace geos::geom;
 class GEOS_DLL OverlayPoints {
 private:
diff --git a/include/geos/operation/overlayng/OverlayUtil.h b/include/geos/operation/overlayng/OverlayUtil.h
index 9d30dca34..bc0dbadfb 100644
--- a/include/geos/operation/overlayng/OverlayUtil.h
+++ b/include/geos/operation/overlayng/OverlayUtil.h
@@ -41,13 +41,10 @@ class OverlayGraph;
  * Utility methods for overlay processing.
@@ -55,6 +52,15 @@ using namespace geos::geom;
 class GEOS_DLL OverlayUtil {
 private:
diff --git a/include/geos/operation/overlayng/PrecisionReducer.h b/include/geos/operation/overlayng/PrecisionReducer.h
index c01bb6e7f..50f34299e 100644
--- a/include/geos/operation/overlayng/PrecisionReducer.h
+++ b/include/geos/operation/overlayng/PrecisionReducer.h
@@ -35,8 +35,6 @@ namespace geos {      // geos.
 * Reduces the precision of a geometry by rounding it to the
 * supplied {@link geom::PrecisionModel}.
@@ -50,6 +48,8 @@ using namespace geos::geom;
 * This provides an effective way to node / snap-round a collection of {@link geom::LineString}s.
 class GEOS_DLL PrecisionReducer {
 private:
diff --git a/include/geos/operation/overlayng/PrecisionUtil.h b/include/geos/operation/overlayng/PrecisionUtil.h
index 71def5647..b515a19de 100644
--- a/include/geos/operation/overlayng/PrecisionUtil.h
+++ b/include/geos/operation/overlayng/PrecisionUtil.h
@@ -38,8 +38,6 @@ namespace geos {      // geos.
  * Unions a collection of geometries in an
  * efficient way, using {@link OverlayNG}
@@ -47,6 +45,10 @@ using namespace geos::geom;
 class GEOS_DLL PrecisionUtil {
+    using CoordinateFilter = geos::geom::CoordinateFilter;
 private:
diff --git a/include/geos/operation/overlayng/RingClipper.h b/include/geos/operation/overlayng/RingClipper.h
index dffd1fd99..d8f6a186e 100644
--- a/include/geos/operation/overlayng/RingClipper.h
+++ b/include/geos/operation/overlayng/RingClipper.h
@@ -27,8 +27,6 @@ class CoordinateSequence;
@@ -62,6 +60,9 @@ namespace overlayng { // geos.operation.overlayng
 class GEOS_DLL RingClipper {
 private:
diff --git a/include/geos/operation/overlayng/RobustClipEnvelopeComputer.h b/include/geos/operation/overlayng/RobustClipEnvelopeComputer.h
index c75c05633..4c43ed706 100644
--- a/include/geos/operation/overlayng/RobustClipEnvelopeComputer.h
+++ b/include/geos/operation/overlayng/RobustClipEnvelopeComputer.h
  * Computes a robust clipping envelope for a pair of polygonal geometries.
  * The envelope is computed to be large enough to include the full
@@ -50,6 +48,12 @@ using namespace geos::geom;
  * @author mdavis
 class GEOS_DLL RobustClipEnvelopeComputer {
 private:
diff --git a/include/geos/operation/overlayng/UnaryUnionNG.h b/include/geos/operation/overlayng/UnaryUnionNG.h
index dd7a251d9..ebc7d75a6 100644
--- a/include/geos/operation/overlayng/UnaryUnionNG.h
+++ b/include/geos/operation/overlayng/UnaryUnionNG.h
@@ -42,6 +42,8 @@ namespace overlayng { // geos.operation.overlayng
 class GEOS_DLL UnaryUnionNG {
 private:
diff --git a/include/geos/operation/relateng/AdjacentEdgeLocator.h b/include/geos/operation/relateng/AdjacentEdgeLocator.h
index d6e576985..3a84a79c6 100644
--- a/include/geos/operation/relateng/AdjacentEdgeLocator.h
+++ b/include/geos/operation/relateng/AdjacentEdgeLocator.h
@@ -36,16 +36,6 @@ namespace geom {
 namespace relateng {  // geos.operation.relateng
@@ -65,6 +55,12 @@ namespace relateng {  // geos.operation.relateng
 class GEOS_DLL AdjacentEdgeLocator {
 public:
diff --git a/include/geos/operation/relateng/BasicPredicate.h b/include/geos/operation/relateng/BasicPredicate.h
index 2ed3f0539..083973e7c 100644
--- a/include/geos/operation/relateng/BasicPredicate.h
+++ b/include/geos/operation/relateng/BasicPredicate.h
@@ -29,17 +29,15 @@ namespace geom {
 namespace operation { // geos.operation.
 class GEOS_DLL BasicPredicate : public TopologyPredicate {
+protected:
 private:
diff --git a/include/geos/operation/relateng/DimensionLocation.h b/include/geos/operation/relateng/DimensionLocation.h
index 6d3d87050..22c327aa1 100644
--- a/include/geos/operation/relateng/DimensionLocation.h
+++ b/include/geos/operation/relateng/DimensionLocation.h
@@ -18,16 +18,13 @@
 #include <geos/geom/Location.h>
 class GEOS_DLL DimensionLocation {
 public:
diff --git a/include/geos/operation/relateng/EdgeSegmentIntersector.h b/include/geos/operation/relateng/EdgeSegmentIntersector.h
index 1b05b6f13..29714863b 100644
--- a/include/geos/operation/relateng/EdgeSegmentIntersector.h
+++ b/include/geos/operation/relateng/EdgeSegmentIntersector.h
@@ -34,17 +34,13 @@ namespace relateng {
-using geos::algorithm::LineIntersector;
-class GEOS_DLL EdgeSegmentIntersector : public SegmentIntersector {
+class GEOS_DLL EdgeSegmentIntersector : public geos::noding::SegmentIntersector {
+    using LineIntersector = geos::algorithm::LineIntersector;
 private:
diff --git a/include/geos/operation/relateng/EdgeSegmentOverlapAction.h b/include/geos/operation/relateng/EdgeSegmentOverlapAction.h
index 7f84ec797..3364a4d41 100644
--- a/include/geos/operation/relateng/EdgeSegmentOverlapAction.h
+++ b/include/geos/operation/relateng/EdgeSegmentOverlapAction.h
@@ -35,12 +35,6 @@ namespace noding {
-using geos::index::chain::MonotoneChain;
-using geos::index::chain::MonotoneChainOverlapAction;
 namespace geos {
 namespace operation { // geos::operation
 namespace relateng {  // geos::operation::relateng
@@ -49,7 +43,9 @@ namespace relateng {  // geos::operation::relateng
  * The action for the internal iterator for performing
  * overlap queries on a MonotoneChain.
-class GEOS_DLL EdgeSegmentOverlapAction : public MonotoneChainOverlapAction {
+class GEOS_DLL EdgeSegmentOverlapAction : public geos::index::chain::MonotoneChainOverlapAction {
+    using SegmentIntersector = geos::noding::SegmentIntersector;
 private:
diff --git a/include/geos/operation/relateng/EdgeSetIntersector.h b/include/geos/operation/relateng/EdgeSetIntersector.h
index 0b59eabc9..302a397a5 100644
--- a/include/geos/operation/relateng/EdgeSetIntersector.h
+++ b/include/geos/operation/relateng/EdgeSetIntersector.h
@@ -38,20 +38,18 @@ namespace relateng {
-using geos::operation::relateng::EdgeSegmentIntersector;
 class GEOS_DLL EdgeSetIntersector {
+    using EdgeSegmentIntersector = geos::operation::relateng::EdgeSegmentIntersector;
 private:
diff --git a/include/geos/operation/relateng/IMPatternMatcher.h b/include/geos/operation/relateng/IMPatternMatcher.h
index be8486c57..21fc02883 100644
--- a/include/geos/operation/relateng/IMPatternMatcher.h
+++ b/include/geos/operation/relateng/IMPatternMatcher.h
@@ -31,20 +31,16 @@ namespace geom {
-using geos::geom::Dimension;
-using geos::geom::IntersectionMatrix;
 class GEOS_DLL IMPatternMatcher : public IMPredicate {
+    using Dimension = geos::geom::Dimension;
+    using IntersectionMatrix = geos::geom::IntersectionMatrix;
 private:
diff --git a/include/geos/operation/relateng/IMPredicate.h b/include/geos/operation/relateng/IMPredicate.h
index 6cf9f9b10..afd6543a7 100644
--- a/include/geos/operation/relateng/IMPredicate.h
+++ b/include/geos/operation/relateng/IMPredicate.h
@@ -31,19 +31,17 @@ namespace geom {
 class GEOS_DLL IMPredicate : public BasicPredicate {
+protected:
 private:
diff --git a/include/geos/operation/relateng/LineStringExtracter.h b/include/geos/operation/relateng/LineStringExtracter.h
index fc7298f88..993f78319 100644
--- a/include/geos/operation/relateng/LineStringExtracter.h
+++ b/include/geos/operation/relateng/LineStringExtracter.h
@@ -29,18 +29,14 @@ namespace geom {
-using geos::geom::GeometryFilter;
-class GEOS_DLL LineStringExtracter : public GeometryFilter {
+class GEOS_DLL LineStringExtracter : public geos::geom::GeometryFilter {
 private:
diff --git a/include/geos/operation/relateng/LinearBoundary.h b/include/geos/operation/relateng/LinearBoundary.h
index 18032663b..9cd8fe6d8 100644
--- a/include/geos/operation/relateng/LinearBoundary.h
+++ b/include/geos/operation/relateng/LinearBoundary.h
@@ -32,18 +32,15 @@ namespace geom {
-using geos::algorithm::BoundaryNodeRule;
 class GEOS_DLL LinearBoundary {
+    using BoundaryNodeRule = geos::algorithm::BoundaryNodeRule;
 private:
diff --git a/include/geos/operation/relateng/NodeSection.h b/include/geos/operation/relateng/NodeSection.h
index 8fe00870e..16b85e949 100644
--- a/include/geos/operation/relateng/NodeSection.h
+++ b/include/geos/operation/relateng/NodeSection.h
@@ -28,11 +28,6 @@ namespace geom {
@@ -53,6 +48,8 @@ namespace relateng { // geos.operation.relateng
 class GEOS_DLL NodeSection {
 private:
diff --git a/include/geos/operation/relateng/NodeSections.h b/include/geos/operation/relateng/NodeSections.h
index d7d08b342..ceafa1240 100644
--- a/include/geos/operation/relateng/NodeSections.h
+++ b/include/geos/operation/relateng/NodeSections.h
@@ -35,17 +35,14 @@ namespace geom {
 class GEOS_DLL NodeSections {
 private:
diff --git a/include/geos/operation/relateng/PolygonNodeConverter.h b/include/geos/operation/relateng/PolygonNodeConverter.h
index 0b1ddce35..60d0fac43 100644
--- a/include/geos/operation/relateng/PolygonNodeConverter.h
+++ b/include/geos/operation/relateng/PolygonNodeConverter.h
@@ -64,6 +64,7 @@ namespace relateng {  // geos.operation.relateng
  * @see RelateNode
 class GEOS_DLL PolygonNodeConverter {
 public:
diff --git a/include/geos/operation/relateng/RelateEdge.h b/include/geos/operation/relateng/RelateEdge.h
index 96afc244c..176a93978 100644
--- a/include/geos/operation/relateng/RelateEdge.h
+++ b/include/geos/operation/relateng/RelateEdge.h
@@ -34,18 +34,15 @@ namespace geom {
 class GEOS_DLL RelateEdge {
 private:
diff --git a/include/geos/operation/relateng/RelateGeometry.h b/include/geos/operation/relateng/RelateGeometry.h
index 53adf01b1..09753b682 100644
--- a/include/geos/operation/relateng/RelateGeometry.h
+++ b/include/geos/operation/relateng/RelateGeometry.h
@@ -48,12 +48,20 @@ namespace geos {      // geos.
 class GEOS_DLL RelateGeometry {
 private:
diff --git a/include/geos/operation/relateng/RelateMatrixPredicate.h b/include/geos/operation/relateng/RelateMatrixPredicate.h
index b54ec2c3b..0acc8e322 100644
--- a/include/geos/operation/relateng/RelateMatrixPredicate.h
+++ b/include/geos/operation/relateng/RelateMatrixPredicate.h
@@ -31,19 +31,16 @@ namespace geom {
 class GEOS_DLL RelateMatrixPredicate : public IMPredicate {
 public:
diff --git a/include/geos/operation/relateng/RelateNG.h b/include/geos/operation/relateng/RelateNG.h
index b55f2ddfc..66f38395d 100644
--- a/include/geos/operation/relateng/RelateNG.h
+++ b/include/geos/operation/relateng/RelateNG.h
@@ -48,13 +48,6 @@ namespace geos {      // geos.
-using geos::noding::MCIndexSegmentSetMutualIntersector;
  * Computes the value of topological predicates between two geometries based on the
  * Dimensionally-Extended 9-Intersection Model <https://en.wikipedia.org/wiki/DE-9IM> (DE-9IM).
@@ -91,6 +84,14 @@ using geos::noding::MCIndexSegmentSetMutualIntersector;
  * @see PreparedGeometry
 class GEOS_DLL RelateNG {
+    using MCIndexSegmentSetMutualIntersector = geos::noding::MCIndexSegmentSetMutualIntersector;
 private:
diff --git a/include/geos/operation/relateng/RelateNode.h b/include/geos/operation/relateng/RelateNode.h
index 581eec359..7c4390324 100644
--- a/include/geos/operation/relateng/RelateNode.h
+++ b/include/geos/operation/relateng/RelateNode.h
@@ -37,17 +37,14 @@ namespace geom {
 class GEOS_DLL RelateNode {
 private:
diff --git a/include/geos/operation/relateng/RelatePointLocator.h b/include/geos/operation/relateng/RelatePointLocator.h
index 3ac03da64..a2cb3cfe3 100644
--- a/include/geos/operation/relateng/RelatePointLocator.h
+++ b/include/geos/operation/relateng/RelatePointLocator.h
@@ -47,17 +47,6 @@ namespace geom {
-using geos::algorithm::locate::PointOnGeometryLocator;
@@ -84,6 +73,14 @@ namespace relateng { // geos.operation.relateng
 class GEOS_DLL RelatePointLocator {
 private:
diff --git a/include/geos/operation/relateng/RelatePredicate.h b/include/geos/operation/relateng/RelatePredicate.h
index ca1db412f..c7950d3a8 100644
--- a/include/geos/operation/relateng/RelatePredicate.h
+++ b/include/geos/operation/relateng/RelatePredicate.h
@@ -23,17 +23,14 @@
 #include <geos/geom/Envelope.h>
 class GEOS_DLL RelatePredicate {
 public:
diff --git a/include/geos/operation/relateng/RelateSegmentString.h b/include/geos/operation/relateng/RelateSegmentString.h
index f2e6caff4..dcd486a76 100644
--- a/include/geos/operation/relateng/RelateSegmentString.h
+++ b/include/geos/operation/relateng/RelateSegmentString.h
@@ -38,20 +38,17 @@ namespace relateng {
-using geos::noding::BasicSegmentString;
-class GEOS_DLL RelateSegmentString : public BasicSegmentString {
+class GEOS_DLL RelateSegmentString : public geos::noding::BasicSegmentString {
+    using BasicSegmentString = geos::noding::BasicSegmentString;
 private:
diff --git a/include/geos/operation/relateng/TopologyComputer.h b/include/geos/operation/relateng/TopologyComputer.h
index 4b52598b3..e016d8e6e 100644
--- a/include/geos/operation/relateng/TopologyComputer.h
+++ b/include/geos/operation/relateng/TopologyComputer.h
@@ -32,22 +32,19 @@ namespace relateng {
-using geos::operation::relateng::NodeSection;
-using geos::operation::relateng::NodeSections;
-using geos::operation::relateng::RelateGeometry;
-using geos::operation::relateng::RelateNode;
-using geos::operation::relateng::TopologyPredicate;
 class GEOS_DLL TopologyComputer {
+    using NodeSection = geos::operation::relateng::NodeSection;
+    using NodeSections = geos::operation::relateng::NodeSections;
+    using RelateGeometry = geos::operation::relateng::RelateGeometry;
+    using RelateNode = geos::operation::relateng::RelateNode;
+    using TopologyPredicate = geos::operation::relateng::TopologyPredicate;
 private:
diff --git a/include/geos/operation/relateng/TopologyPredicate.h b/include/geos/operation/relateng/TopologyPredicate.h
index 52ec524d8..b944d6b14 100644
--- a/include/geos/operation/relateng/TopologyPredicate.h
+++ b/include/geos/operation/relateng/TopologyPredicate.h
@@ -28,17 +28,14 @@ namespace geom {
 class GEOS_DLL TopologyPredicate {
 public:
diff --git a/include/geos/operation/union/CoverageUnion.h b/include/geos/operation/union/CoverageUnion.h
index 4b29b8e22..9579b4b2c 100644
--- a/include/geos/operation/union/CoverageUnion.h
+++ b/include/geos/operation/union/CoverageUnion.h
@@ -28,19 +28,19 @@ namespace geos {
 namespace geos {
 namespace geounion {
     public:
         static std::unique_ptr<Geometry> Union(const Geometry* geom);
diff --git a/include/geos/operation/valid/IndexedNestedHoleTester.h b/include/geos/operation/valid/IndexedNestedHoleTester.h
index 8786c56d9..c52e977a0 100644
--- a/include/geos/operation/valid/IndexedNestedHoleTester.h
+++ b/include/geos/operation/valid/IndexedNestedHoleTester.h
@@ -34,12 +34,10 @@ namespace geos {      // geos.
 namespace valid {     // geos.operation.valid
 class GEOS_DLL IndexedNestedHoleTester {
 private:
diff --git a/include/geos/operation/valid/IndexedNestedPolygonTester.h b/include/geos/operation/valid/IndexedNestedPolygonTester.h
index 9ae9dd020..22650be44 100644
--- a/include/geos/operation/valid/IndexedNestedPolygonTester.h
+++ b/include/geos/operation/valid/IndexedNestedPolygonTester.h
@@ -37,14 +37,14 @@ namespace geos {      // geos.
-using index::strtree::TemplateSTRtree;
 class GEOS_DLL IndexedNestedPolygonTester {
+    using TemplateSTRtree = index::strtree::TemplateSTRtree<ItemType>;
 private:
diff --git a/include/geos/operation/valid/IsValidOp.h b/include/geos/operation/valid/IsValidOp.h
index d669ddfd9..27c6fe4c4 100644
--- a/include/geos/operation/valid/IsValidOp.h
+++ b/include/geos/operation/valid/IsValidOp.h
@@ -55,6 +55,7 @@ namespace valid {     // geos.operation.valid
  * @version 1.7
 class GEOS_DLL IsValidOp {
 private:
diff --git a/include/geos/operation/valid/PolygonIntersectionAnalyzer.h b/include/geos/operation/valid/PolygonIntersectionAnalyzer.h
index 40542e18e..4a2eed919 100644
--- a/include/geos/operation/valid/PolygonIntersectionAnalyzer.h
+++ b/include/geos/operation/valid/PolygonIntersectionAnalyzer.h
@@ -36,10 +36,9 @@ namespace geos {      // geos.
 class GEOS_DLL PolygonIntersectionAnalyzer : public noding::SegmentIntersector {
 private:
diff --git a/include/geos/operation/valid/PolygonRing.h b/include/geos/operation/valid/PolygonRing.h
index fc32e9d2f..b1447c18a 100644
--- a/include/geos/operation/valid/PolygonRing.h
+++ b/include/geos/operation/valid/PolygonRing.h
@@ -35,11 +35,9 @@ namespace geos {      // geos.
 class GEOS_DLL PolygonRing {
 private:
diff --git a/include/geos/operation/valid/PolygonRingSelfNode.h b/include/geos/operation/valid/PolygonRingSelfNode.h
index d9cd8b760..2b95eebdb 100644
--- a/include/geos/operation/valid/PolygonRingSelfNode.h
+++ b/include/geos/operation/valid/PolygonRingSelfNode.h
@@ -26,9 +26,8 @@ namespace geos {      // geos.
 class GEOS_DLL PolygonRingSelfNode {
 private:
diff --git a/include/geos/operation/valid/PolygonRingTouch.h b/include/geos/operation/valid/PolygonRingTouch.h
index c8aea3df9..b59e64bbe 100644
--- a/include/geos/operation/valid/PolygonRingTouch.h
+++ b/include/geos/operation/valid/PolygonRingTouch.h
@@ -34,9 +34,8 @@ namespace geos {      // geos.
 class GEOS_DLL PolygonRingTouch {
 private:
diff --git a/include/geos/operation/valid/PolygonTopologyAnalyzer.h b/include/geos/operation/valid/PolygonTopologyAnalyzer.h
index bfb2ed430..8d7238112 100644
--- a/include/geos/operation/valid/PolygonTopologyAnalyzer.h
+++ b/include/geos/operation/valid/PolygonTopologyAnalyzer.h
@@ -35,12 +35,12 @@ namespace geos {      // geos.
 class GEOS_DLL PolygonTopologyAnalyzer {
 private:
diff --git a/include/geos/simplify/ComponentJumpChecker.h b/include/geos/simplify/ComponentJumpChecker.h
index 59fdd2ecb..d25cde550 100644
--- a/include/geos/simplify/ComponentJumpChecker.h
+++ b/include/geos/simplify/ComponentJumpChecker.h
@@ -34,15 +34,14 @@ class TaggedLineString;
 namespace geos {
 namespace simplify { // geos::simplify
 class GEOS_DLL ComponentJumpChecker {
 private:
diff --git a/include/geos/simplify/LinkedLine.h b/include/geos/simplify/LinkedLine.h
index 7d78d59fe..606bb7c8e 100644
--- a/include/geos/simplify/LinkedLine.h
+++ b/include/geos/simplify/LinkedLine.h
@@ -29,15 +29,13 @@ class CoordinateSequence;
 namespace geos {
 class LinkedLine
 public:
diff --git a/include/geos/simplify/LinkedRing.h b/include/geos/simplify/LinkedRing.h
index 5df7eb98c..85ea607f5 100644
--- a/include/geos/simplify/LinkedRing.h
+++ b/include/geos/simplify/LinkedRing.h
@@ -20,9 +20,6 @@
 #include <geos/geom/CoordinateSequence.h>
 #include <geos/constants.h>
 namespace geos {
@@ -30,6 +27,9 @@ namespace simplify { // geos::simplify
 class LinkedRing
     private:
         const CoordinateSequence& m_coord;
diff --git a/include/geos/simplify/PolygonHullSimplifier.h b/include/geos/simplify/PolygonHullSimplifier.h
index db2a4b6b6..ac603f261 100644
--- a/include/geos/simplify/PolygonHullSimplifier.h
+++ b/include/geos/simplify/PolygonHullSimplifier.h
@@ -33,15 +33,6 @@ class RingHullIndex;
 namespace geos {
@@ -84,6 +75,12 @@ namespace simplify { // geos::simplify
 class GEOS_DLL PolygonHullSimplifier
 public:
diff --git a/include/geos/simplify/RingHull.h b/include/geos/simplify/RingHull.h
index fd8a0443b..d22bb911f 100644
--- a/include/geos/simplify/RingHull.h
+++ b/include/geos/simplify/RingHull.h
@@ -32,21 +32,20 @@ class RingHullIndex;
 namespace geos {
 class RingHull
 public:
diff --git a/include/geos/simplify/TaggedLineString.h b/include/geos/simplify/TaggedLineString.h
index b23f3a400..a3f962b21 100644
--- a/include/geos/simplify/TaggedLineString.h
+++ b/include/geos/simplify/TaggedLineString.h
@@ -47,9 +47,6 @@ class TaggedLineSegment;
 namespace geos {
@@ -58,6 +55,8 @@ namespace simplify { // geos::simplify
  * Contains and owns a list of TaggedLineSegments.
 class GEOS_DLL TaggedLineString {
 public:
diff --git a/include/geos/simplify/TaggedLineStringSimplifier.h b/include/geos/simplify/TaggedLineStringSimplifier.h
index 3fba7e0d5..495a12628 100644
--- a/include/geos/simplify/TaggedLineStringSimplifier.h
+++ b/include/geos/simplify/TaggedLineStringSimplifier.h
@@ -51,11 +51,6 @@ class ComponentJumpChecker;
 namespace geos {
@@ -67,6 +62,9 @@ namespace simplify { // geos::simplify
 class GEOS_DLL TaggedLineStringSimplifier {
 public:
diff --git a/include/geos/triangulate/polygon/ConstrainedDelaunayTriangulator.h b/include/geos/triangulate/polygon/ConstrainedDelaunayTriangulator.h
index 23c385d21..f03c97cff 100644
--- a/include/geos/triangulate/polygon/ConstrainedDelaunayTriangulator.h
+++ b/include/geos/triangulate/polygon/ConstrainedDelaunayTriangulator.h
@@ -26,13 +26,6 @@ class Polygon;
 namespace geos {
 namespace triangulate {
 namespace polygon {
@@ -48,6 +41,12 @@ namespace polygon {
  * Holes are supported.
 class GEOS_DLL ConstrainedDelaunayTriangulator {
 private:
diff --git a/include/geos/triangulate/polygon/PolygonEarClipper.h b/include/geos/triangulate/polygon/PolygonEarClipper.h
index 561621661..1eacca8bd 100644
--- a/include/geos/triangulate/polygon/PolygonEarClipper.h
+++ b/include/geos/triangulate/polygon/PolygonEarClipper.h
@@ -32,13 +32,6 @@ class Envelope;
 namespace geos {
 namespace polygon {
@@ -65,6 +58,14 @@ namespace polygon {
 class GEOS_DLL PolygonEarClipper {
 private:
diff --git a/include/geos/triangulate/polygon/PolygonHoleJoiner.h b/include/geos/triangulate/polygon/PolygonHoleJoiner.h
index b65c0c0a0..870282f7d 100644
--- a/include/geos/triangulate/polygon/PolygonHoleJoiner.h
+++ b/include/geos/triangulate/polygon/PolygonHoleJoiner.h
@@ -37,14 +37,6 @@ namespace noding {
-using geos::noding::SegmentSetMutualIntersector;
 namespace geos {
 namespace polygon {
@@ -68,6 +60,12 @@ namespace polygon {
  * The output ring is always CW.
 class GEOS_DLL PolygonHoleJoiner {
+    using SegmentSetMutualIntersector = geos::noding::SegmentSetMutualIntersector;
 private:
diff --git a/include/geos/triangulate/polygon/PolygonNoder.h b/include/geos/triangulate/polygon/PolygonNoder.h
index 94c355641..fde921356 100644
--- a/include/geos/triangulate/polygon/PolygonNoder.h
+++ b/include/geos/triangulate/polygon/PolygonNoder.h
@@ -19,6 +19,7 @@
 //#include <geos/geom/CoordinateSequence.h>
 #include <map>
 #include <memory>
@@ -38,12 +39,6 @@ class LineIntersector;
-using geos::noding::NodedSegmentString;
 namespace geos {
 namespace polygon {
@@ -60,6 +55,13 @@ namespace polygon {
  * and does not trigger an error.
 class GEOS_DLL PolygonNoder {
+    using NodedSegmentString = geos::noding::NodedSegmentString;
 public:
diff --git a/include/geos/triangulate/polygon/PolygonTriangulator.h b/include/geos/triangulate/polygon/PolygonTriangulator.h
index 4df9cfe54..8c6cd2b54 100644
--- a/include/geos/triangulate/polygon/PolygonTriangulator.h
+++ b/include/geos/triangulate/polygon/PolygonTriangulator.h
 namespace geos {
 namespace polygon {
@@ -57,6 +50,12 @@ namespace polygon {
 class GEOS_DLL PolygonTriangulator {
 private:
diff --git a/include/geos/triangulate/polygon/TriDelaunayImprover.h b/include/geos/triangulate/polygon/TriDelaunayImprover.h
index 3d1758d67..956c4d879 100644
--- a/include/geos/triangulate/polygon/TriDelaunayImprover.h
+++ b/include/geos/triangulate/polygon/TriDelaunayImprover.h
@@ -26,11 +26,6 @@ class Coordinate;
 namespace geos {
 namespace polygon {
@@ -46,6 +41,10 @@ namespace polygon {
 class GEOS_DLL TriDelaunayImprover {
 private:
diff --git a/include/geos/triangulate/tri/Tri.h b/include/geos/triangulate/tri/Tri.h
index 786e250d3..06fecedc4 100644
--- a/include/geos/triangulate/tri/Tri.h
+++ b/include/geos/triangulate/tri/Tri.h
@@ -28,10 +28,6 @@ class Polygon;
 namespace triangulate { // geos.triangulate
 namespace tri {         // geos.triangulate.tri
@@ -47,6 +43,10 @@ namespace tri {         // geos.triangulate.tri
 class GEOS_DLL Tri {
 protected:
diff --git a/include/geos/triangulate/tri/TriEdge.h b/include/geos/triangulate/tri/TriEdge.h
index 208006449..14199b93d 100644
--- a/include/geos/triangulate/tri/TriEdge.h
+++ b/include/geos/triangulate/tri/TriEdge.h
@@ -18,8 +18,6 @@
 #include <geos/geom/Coordinate.h>
 #include <iostream>
@@ -35,6 +33,7 @@ namespace tri {         // geos.triangulate.tri
  * @author mdavis
 class GEOS_DLL TriEdge {
 private:
diff --git a/include/geos/triangulate/tri/TriList.h b/include/geos/triangulate/tri/TriList.h
index a71deb211..78a622af3 100644
--- a/include/geos/triangulate/tri/TriList.h
+++ b/include/geos/triangulate/tri/TriList.h
@@ -31,10 +31,6 @@ class Geometry;
 typedef int TriIndex;
@@ -52,6 +48,9 @@ namespace tri {         // geos.triangulate.tri
 class TriList {
 private:
diff --git a/include/geos/triangulate/tri/TriangulationBuilder.h b/include/geos/triangulate/tri/TriangulationBuilder.h
index 1faa2ca11..09f5a5e0c 100644
--- a/include/geos/triangulate/tri/TriangulationBuilder.h
+++ b/include/geos/triangulate/tri/TriangulationBuilder.h
@@ -32,8 +32,6 @@ class Tri;
@@ -47,6 +45,7 @@ namespace tri {         // geos.triangulate.tri
 class GEOS_DLL TriangulationBuilder {
 private:
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index ccfef602e..0d61b335e 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -20,11 +20,11 @@
 #include <geos/algorithm/CGAlgorithmsDD.h>
 #include <geos/util/IllegalArgumentException.h>
-#include <sstream>
 #include <cmath>
 using namespace geos::algorithm;
+using geos::math::DD;
 namespace {
diff --git a/src/algorithm/construct/IndexedPointInPolygonsLocator.cpp b/src/algorithm/construct/IndexedPointInPolygonsLocator.cpp
index bb9e51abe..1832ef3ca 100644
--- a/src/algorithm/construct/IndexedPointInPolygonsLocator.cpp
+++ b/src/algorithm/construct/IndexedPointInPolygonsLocator.cpp
@@ -24,6 +24,7 @@
+using geos::geom::Location;
 using geos::geom::util::PolygonalExtracter;
 namespace geos {
diff --git a/src/algorithm/hull/HullTriangulation.cpp b/src/algorithm/hull/HullTriangulation.cpp
index ea8e0d4eb..b9b77f835 100644
--- a/src/algorithm/hull/HullTriangulation.cpp
+++ b/src/algorithm/hull/HullTriangulation.cpp
@@ -39,6 +39,7 @@ using geos::geom::Polygon;
 using geos::triangulate::DelaunayTriangulationBuilder;
 using geos::triangulate::tri::TriangulationBuilder;
+using geos::triangulate::tri::Tri;
 using geos::operation::overlayng::CoverageUnion;
 namespace geos {
diff --git a/src/coverage/Corner.cpp b/src/coverage/Corner.cpp
index 743681e7b..9aeb033ae 100644
--- a/src/coverage/Corner.cpp
+++ b/src/coverage/Corner.cpp
@@ -25,9 +25,11 @@
+using geos::geom::CoordinateSequence;
+using geos::geom::LineString;
 using geos::io::WKTWriter;
 namespace geos {
diff --git a/src/coverage/CoverageBoundarySegmentFinder.cpp b/src/coverage/CoverageBoundarySegmentFinder.cpp
index 22740acfe..d5759be7d 100644
--- a/src/coverage/CoverageBoundarySegmentFinder.cpp
+++ b/src/coverage/CoverageBoundarySegmentFinder.cpp
@@ -19,6 +19,7 @@
+using geos::geom::LineSegment;
diff --git a/src/coverage/CoverageEdge.cpp b/src/coverage/CoverageEdge.cpp
index a2114b992..65971fc3a 100644
--- a/src/coverage/CoverageEdge.cpp
+++ b/src/coverage/CoverageEdge.cpp
@@ -26,6 +26,9 @@ using geos::geom::Coordinate;
+using geos::geom::MultiLineString;
diff --git a/src/coverage/CoveragePolygonValidator.cpp b/src/coverage/CoveragePolygonValidator.cpp
index d0161c097..16b252e00 100644
--- a/src/coverage/CoveragePolygonValidator.cpp
+++ b/src/coverage/CoveragePolygonValidator.cpp
@@ -43,6 +43,7 @@ using geos::geom::Location;
 using geos::geom::util::PolygonExtracter;
+using geos::noding::SegmentString;
 using geos::operation::valid::RepeatedPointRemover;
diff --git a/src/coverage/TPVWSimplifier.cpp b/src/coverage/TPVWSimplifier.cpp
index 7d395cdf3..0bf36ac30 100644
--- a/src/coverage/TPVWSimplifier.cpp
+++ b/src/coverage/TPVWSimplifier.cpp
@@ -26,6 +26,7 @@
 #include <geos/simplify/LinkedLine.h>
diff --git a/src/index/VertexSequencePackedRtree.cpp b/src/index/VertexSequencePackedRtree.cpp
index de75836a4..7f11ec95e 100644
--- a/src/index/VertexSequencePackedRtree.cpp
+++ b/src/index/VertexSequencePackedRtree.cpp
@@ -21,6 +21,8 @@
 #include <algorithm>
+using geos::geom::Envelope;
 namespace geos {
 namespace index {
diff --git a/src/operation/overlayng/EdgeNodingBuilder.cpp b/src/operation/overlayng/EdgeNodingBuilder.cpp
index d617ca4f0..569633462 100644
--- a/src/operation/overlayng/EdgeNodingBuilder.cpp
+++ b/src/operation/overlayng/EdgeNodingBuilder.cpp
@@ -32,6 +32,7 @@ namespace geos {      // geos
+using namespace geos::geom;
 using geos::noding::snapround::SnapRoundingNoder;
 using geos::noding::Noder;
diff --git a/src/operation/overlayng/InputGeometry.cpp b/src/operation/overlayng/InputGeometry.cpp
index 794971887..95580ce7a 100644
--- a/src/operation/overlayng/InputGeometry.cpp
+++ b/src/operation/overlayng/InputGeometry.cpp
@@ -18,6 +18,11 @@ namespace geos {      // geos
+using geos::geom::Geometry;
+using geos::algorithm::locate::IndexedPointInAreaLocator;
+using geos::algorithm::locate::PointOnGeometryLocator;
 /*public*/
 InputGeometry::InputGeometry(const Geometry* geomA, const Geometry* geomB)
diff --git a/src/operation/overlayng/IntersectionPointBuilder.cpp b/src/operation/overlayng/IntersectionPointBuilder.cpp
index dc41e4400..9289ad430 100644
--- a/src/operation/overlayng/IntersectionPointBuilder.cpp
+++ b/src/operation/overlayng/IntersectionPointBuilder.cpp
@@ -19,7 +19,7 @@
 #include <geos/operation/overlayng/OverlayLabel.h>
 #include <geos/geom/GeometryFactory.h>
diff --git a/src/operation/overlayng/LineLimiter.cpp b/src/operation/overlayng/LineLimiter.cpp
index 1c8106c35..57036e248 100644
--- a/src/operation/overlayng/LineLimiter.cpp
+++ b/src/operation/overlayng/LineLimiter.cpp
@@ -20,6 +20,8 @@
diff --git a/src/operation/overlayng/OverlayEdgeRing.cpp b/src/operation/overlayng/OverlayEdgeRing.cpp
index a1b3d1bdd..f45d46418 100644
--- a/src/operation/overlayng/OverlayEdgeRing.cpp
+++ b/src/operation/overlayng/OverlayEdgeRing.cpp
@@ -31,6 +31,7 @@ namespace overlayng { // geos.operation.overlayng
 using geos::operation::polygonize::EdgeRing;
diff --git a/src/operation/overlayng/OverlayLabel.cpp b/src/operation/overlayng/OverlayLabel.cpp
index bcdc810c7..0570878f1 100644
--- a/src/operation/overlayng/OverlayLabel.cpp
+++ b/src/operation/overlayng/OverlayLabel.cpp
@@ -14,6 +14,7 @@
diff --git a/src/operation/overlayng/OverlayMixedPoints.cpp b/src/operation/overlayng/OverlayMixedPoints.cpp
index 1285186a2..62492d6b7 100644
--- a/src/operation/overlayng/OverlayMixedPoints.cpp
+++ b/src/operation/overlayng/OverlayMixedPoints.cpp
@@ -36,6 +36,8 @@ namespace operation { // geos.operation
  * @brief Extracts and rounds coordinates from a geometry
diff --git a/src/operation/overlayng/OverlayPoints.cpp b/src/operation/overlayng/OverlayPoints.cpp
index 6afe7a211..66fbfbb74 100644
--- a/src/operation/overlayng/OverlayPoints.cpp
+++ b/src/operation/overlayng/OverlayPoints.cpp
@@ -21,7 +21,7 @@
 #include <geos/operation/overlayng/OverlayNG.h>
 #include <geos/operation/overlayng/OverlayUtil.h>
diff --git a/src/operation/overlayng/PolygonBuilder.cpp b/src/operation/overlayng/PolygonBuilder.cpp
index 80b8f5bc0..abdb4a0fb 100644
--- a/src/operation/overlayng/PolygonBuilder.cpp
+++ b/src/operation/overlayng/PolygonBuilder.cpp
@@ -20,6 +20,7 @@
 #include <geos/util/TopologyException.h>
+using geos::geom::Polygon;
diff --git a/src/operation/overlayng/PrecisionReducer.cpp b/src/operation/overlayng/PrecisionReducer.cpp
index 85dbebdf0..96a0a7a4f 100644
--- a/src/operation/overlayng/PrecisionReducer.cpp
+++ b/src/operation/overlayng/PrecisionReducer.cpp
@@ -22,6 +22,9 @@ namespace geos {      // geos
+using geos::geom::GeometryFactory;
 /*public static*/
 PrecisionReducer::reducePrecision(const Geometry* geom, const PrecisionModel* pm, bool replacePrecisionModel)
diff --git a/src/operation/overlayng/RingClipper.cpp b/src/operation/overlayng/RingClipper.cpp
index 6a87d5f3e..cf108dd1e 100644
--- a/src/operation/overlayng/RingClipper.cpp
+++ b/src/operation/overlayng/RingClipper.cpp
@@ -14,6 +14,7 @@
 #include <geos/operation/overlayng/RingClipper.h>
diff --git a/src/operation/overlayng/RobustClipEnvelopeComputer.cpp b/src/operation/overlayng/RobustClipEnvelopeComputer.cpp
index 2786701d6..a2275bc8d 100644
--- a/src/operation/overlayng/RobustClipEnvelopeComputer.cpp
+++ b/src/operation/overlayng/RobustClipEnvelopeComputer.cpp
@@ -25,6 +25,7 @@ namespace geos {      // geos
 RobustClipEnvelopeComputer::RobustClipEnvelopeComputer(const Envelope* p_targetEnv)
     : targetEnv(p_targetEnv)
diff --git a/src/operation/relateng/RelateEdge.cpp b/src/operation/relateng/RelateEdge.cpp
index 4670b058b..821cd9905 100644
--- a/src/operation/relateng/RelateEdge.cpp
+++ b/src/operation/relateng/RelateEdge.cpp
@@ -28,6 +28,7 @@ using geos::algorithm::PolygonNodeTopology;
diff --git a/src/operation/relateng/RelateGeometry.cpp b/src/operation/relateng/RelateGeometry.cpp
index 668968eff..df00ad594 100644
--- a/src/operation/relateng/RelateGeometry.cpp
+++ b/src/operation/relateng/RelateGeometry.cpp
@@ -43,6 +43,7 @@ using geos::geom::util::ComponentCoordinateExtracter;
 using geos::geom::util::GeometryLister;
 using geos::geom::util::PointExtracter;
diff --git a/src/operation/relateng/RelateNode.cpp b/src/operation/relateng/RelateNode.cpp
index 0ec3045a6..626b97122 100644
--- a/src/operation/relateng/RelateNode.cpp
+++ b/src/operation/relateng/RelateNode.cpp
@@ -29,6 +29,7 @@ using geos::geom::Geometry;
diff --git a/src/operation/valid/IndexedNestedPolygonTester.cpp b/src/operation/valid/IndexedNestedPolygonTester.cpp
index 3dbaa3f26..65f452f2e 100644
--- a/src/operation/valid/IndexedNestedPolygonTester.cpp
+++ b/src/operation/valid/IndexedNestedPolygonTester.cpp
@@ -32,6 +32,7 @@ namespace operation { // geos.operation
 /* public */
diff --git a/src/operation/valid/PolygonIntersectionAnalyzer.cpp b/src/operation/valid/PolygonIntersectionAnalyzer.cpp
index d64a37c08..7f71f0f08 100644
--- a/src/operation/valid/PolygonIntersectionAnalyzer.cpp
+++ b/src/operation/valid/PolygonIntersectionAnalyzer.cpp
@@ -21,14 +21,15 @@
 #include <geos/operation/valid/TopologyValidationError.h>
 #include <geos/util/IllegalStateException.h>
+using geos::geom::Coordinate;
+using geos::geom::CoordinateXY;
 /* public */
 void
 PolygonIntersectionAnalyzer::processIntersections(
diff --git a/src/simplify/LinkedRing.cpp b/src/simplify/LinkedRing.cpp
index 51bc28e39..4a3212ce5 100644
--- a/src/simplify/LinkedRing.cpp
+++ b/src/simplify/LinkedRing.cpp
@@ -19,6 +19,7 @@
 namespace geos {
diff --git a/src/triangulate/polygon/ConstrainedDelaunayTriangulator.cpp b/src/triangulate/polygon/ConstrainedDelaunayTriangulator.cpp
index 5f56b12c2..7baca31f3 100644
--- a/src/triangulate/polygon/ConstrainedDelaunayTriangulator.cpp
+++ b/src/triangulate/polygon/ConstrainedDelaunayTriangulator.cpp
@@ -22,6 +22,7 @@
 #include <geos/triangulate/polygon/PolygonEarClipper.h>
 #include <geos/triangulate/polygon/TriDelaunayImprover.h>
 namespace geos {
diff --git a/src/triangulate/polygon/PolygonEarClipper.cpp b/src/triangulate/polygon/PolygonEarClipper.cpp
index 3bb54069c..c493353ef 100644
--- a/src/triangulate/polygon/PolygonEarClipper.cpp
+++ b/src/triangulate/polygon/PolygonEarClipper.cpp
@@ -24,6 +24,8 @@
 using geos::algorithm::Orientation;
 using geos::algorithm::Angle;
diff --git a/src/triangulate/polygon/PolygonHoleJoiner.cpp b/src/triangulate/polygon/PolygonHoleJoiner.cpp
index 8b4c0e908..239491672 100644
--- a/src/triangulate/polygon/PolygonHoleJoiner.cpp
+++ b/src/triangulate/polygon/PolygonHoleJoiner.cpp
@@ -38,6 +38,8 @@ using geos::algorithm::Orientation;
+using geos::geom::LinearRing;
diff --git a/src/triangulate/polygon/PolygonNoder.cpp b/src/triangulate/polygon/PolygonNoder.cpp
index b949bd5ce..8e6a70ad9 100644
--- a/src/triangulate/polygon/PolygonNoder.cpp
+++ b/src/triangulate/polygon/PolygonNoder.cpp
@@ -24,6 +24,7 @@
diff --git a/src/triangulate/polygon/PolygonTriangulator.cpp b/src/triangulate/polygon/PolygonTriangulator.cpp
index ad490ed0a..1e1381f56 100644
--- a/src/triangulate/polygon/PolygonTriangulator.cpp
+++ b/src/triangulate/polygon/PolygonTriangulator.cpp
@@ -20,7 +20,7 @@
 #include <geos/triangulate/polygon/PolygonHoleJoiner.h>
 namespace geos {
diff --git a/src/triangulate/tri/Tri.cpp b/src/triangulate/tri/Tri.cpp
index 55dce9217..ecf82ab8d 100644
--- a/src/triangulate/tri/Tri.cpp
+++ b/src/triangulate/tri/Tri.cpp
@@ -25,7 +25,7 @@
 #include <geos/util.h>
 using geos::util::IllegalArgumentException;
diff --git a/tests/unit/coverage/TPVWSimplifierTest.cpp b/tests/unit/coverage/TPVWSimplifierTest.cpp
index 3c1143a6c..de8d0beac 100644
--- a/tests/unit/coverage/TPVWSimplifierTest.cpp
+++ b/tests/unit/coverage/TPVWSimplifierTest.cpp
@@ -7,6 +7,7 @@
 // geos
 #include <geos/coverage/TPVWSimplifier.h>
 using geos::coverage::TPVWSimplifier;
 namespace tut {
diff --git a/tests/unit/index/VertexSequencePackedRtreeTest.cpp b/tests/unit/index/VertexSequencePackedRtreeTest.cpp
index 554187f70..877666e8d 100644
--- a/tests/unit/index/VertexSequencePackedRtreeTest.cpp
+++ b/tests/unit/index/VertexSequencePackedRtreeTest.cpp
@@ -15,8 +15,8 @@
 // std
 #include <stdio.h>
-using geos::geom::Point;
 namespace tut {
diff --git a/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp b/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
index 603b9e1e2..2c3d3ca14 100644
--- a/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
@@ -18,6 +18,7 @@
 using namespace geos::operation::relateng;
+using geos::algorithm::BoundaryNodeRule;
 using geos::io::WKTReader;
Summary of changes:
 include/geos/algorithm/CGAlgorithmsDD.h            |  3 +--
 include/geos/algorithm/MinimumAreaRectangle.h      | 16 ++++++-------
 include/geos/algorithm/PolygonNodeTopology.h       |  4 +---
 include/geos/algorithm/Rectangle.h                 |  9 ++++----
 .../algorithm/construct/IndexedDistanceToPoint.h   |  7 +++---
 .../construct/IndexedPointInPolygonsLocator.h      | 12 +++++-----
 .../geos/algorithm/construct/LargestEmptyCircle.h  |  3 +--
 .../algorithm/construct/MaximumInscribedCircle.h   |  5 ++--
 include/geos/algorithm/hull/ConcaveHull.h          | 19 ++++++++-------
 .../geos/algorithm/hull/ConcaveHullOfPolygons.h    | 27 ++++++++++------------
 include/geos/algorithm/hull/HullTri.h              | 16 ++++++-------
 include/geos/algorithm/hull/HullTriangulation.h    | 19 +++++++--------
 include/geos/algorithm/hull/OuterShellsExtracter.h | 12 +++-------
 include/geos/coverage/Corner.h                     | 11 ++++-----
 .../geos/coverage/CoverageBoundarySegmentFinder.h  | 14 +++++------
 include/geos/coverage/CoverageEdge.h               | 16 ++++++-------
 include/geos/coverage/CoverageGapFinder.h          |  4 ++--
 include/geos/coverage/CoveragePolygon.h            |  9 ++++----
 include/geos/coverage/CoveragePolygonValidator.h   | 15 +++++++-----
 include/geos/coverage/CoverageRing.h               | 15 ++++++------
 include/geos/coverage/CoverageRingEdges.h          | 15 ++++++------
 include/geos/coverage/CoverageSimplifier.h         | 12 ++++------
 include/geos/coverage/CoverageUnion.h              |  3 +--
 include/geos/coverage/CoverageValidator.h          |  6 ++---
 include/geos/coverage/InvalidSegmentDetector.h     | 10 +++-----
 include/geos/coverage/TPVWSimplifier.h             | 26 ++++++++++-----------
 include/geos/coverage/VertexRingCounter.h          | 11 ++++-----
 include/geos/geom/prep/BasicPreparedGeometry.h     |  4 ++--
 include/geos/geomgraph/Label.h                     |  1 +
 include/geos/geomgraph/TopologyLocation.h          |  5 ++--
 include/geos/index/VertexSequencePackedRtree.h     |  8 +++----
 include/geos/noding/BoundaryChainNoder.h           |  3 +--
 .../geos/operation/buffer/BufferCurveSetBuilder.h  |  1 +
 include/geos/operation/buffer/OffsetCurve.h        | 14 +++++------
 include/geos/operation/buffer/OffsetCurveBuilder.h |  6 ++---
 include/geos/operation/buffer/OffsetCurveSection.h | 11 ++++-----
 include/geos/operation/buffer/SegmentMCIndex.h     | 16 +++++++------
 include/geos/operation/overlayng/CoverageUnion.h   |  3 +--
 include/geos/operation/overlayng/Edge.h            |  1 +
 include/geos/operation/overlayng/EdgeKey.h         |  4 +---
 .../geos/operation/overlayng/EdgeNodingBuilder.h   |  8 +++++++
 include/geos/operation/overlayng/InputGeometry.h   |  8 ++++---
 include/geos/operation/overlayng/LineLimiter.h     |  5 ++--
 include/geos/operation/overlayng/MaximalEdgeRing.h |  5 ++--
 include/geos/operation/overlayng/OverlayEdge.h     |  9 ++++----
 include/geos/operation/overlayng/OverlayEdgeRing.h | 11 +++++----
 include/geos/operation/overlayng/OverlayGraph.h    |  4 ++--
 include/geos/operation/overlayng/OverlayLabel.h    |  5 ++--
 .../geos/operation/overlayng/OverlayMixedPoints.h  | 13 ++++++++---
 include/geos/operation/overlayng/OverlayNG.h       |  3 +++
 include/geos/operation/overlayng/OverlayNGRobust.h |  1 +
 include/geos/operation/overlayng/OverlayPoints.h   |  9 ++++++--
 include/geos/operation/overlayng/OverlayUtil.h     | 12 +++++++---
 .../geos/operation/overlayng/PrecisionReducer.h    |  4 ++--
 include/geos/operation/overlayng/PrecisionUtil.h   |  6 +++--
 include/geos/operation/overlayng/RingClipper.h     |  5 ++--
 .../overlayng/RobustClipEnvelopeComputer.h         |  8 +++++--
 include/geos/operation/overlayng/UnaryUnionNG.h    |  2 ++
 .../geos/operation/relateng/AdjacentEdgeLocator.h  | 16 +++++--------
 include/geos/operation/relateng/BasicPredicate.h   |  8 +++----
 .../geos/operation/relateng/DimensionLocation.h    |  5 +---
 .../operation/relateng/EdgeSegmentIntersector.h    | 10 +++-----
 .../operation/relateng/EdgeSegmentOverlapAction.h  | 10 +++-----
 .../geos/operation/relateng/EdgeSetIntersector.h   | 16 ++++++-------
 include/geos/operation/relateng/IMPatternMatcher.h | 12 ++++------
 include/geos/operation/relateng/IMPredicate.h      | 12 ++++------
 .../geos/operation/relateng/LineStringExtracter.h  | 10 +++-----
 include/geos/operation/relateng/LinearBoundary.h   | 11 ++++-----
 include/geos/operation/relateng/NodeSection.h      |  7 ++----
 include/geos/operation/relateng/NodeSections.h     |  7 ++----
 .../geos/operation/relateng/PolygonNodeConverter.h |  1 +
 include/geos/operation/relateng/RelateEdge.h       |  9 +++-----
 include/geos/operation/relateng/RelateGeometry.h   | 18 +++++++++++----
 .../operation/relateng/RelateMatrixPredicate.h     | 11 ++++-----
 include/geos/operation/relateng/RelateNG.h         | 15 ++++++------
 include/geos/operation/relateng/RelateNode.h       |  7 ++----
 .../geos/operation/relateng/RelatePointLocator.h   | 19 +++++++--------
 include/geos/operation/relateng/RelatePredicate.h  |  7 ++----
 .../geos/operation/relateng/RelateSegmentString.h  | 13 ++++-------
 include/geos/operation/relateng/TopologyComputer.h | 17 ++++++--------
 .../geos/operation/relateng/TopologyPredicate.h    |  7 ++----
 include/geos/operation/union/CoverageUnion.h       | 16 ++++++-------
 .../geos/operation/valid/IndexedNestedHoleTester.h |  8 +++----
 .../operation/valid/IndexedNestedPolygonTester.h   | 14 +++++------
 include/geos/operation/valid/IsValidOp.h           |  1 +
 .../operation/valid/PolygonIntersectionAnalyzer.h  |  5 ++--
 include/geos/operation/valid/PolygonRing.h         |  6 ++---
 include/geos/operation/valid/PolygonRingSelfNode.h |  3 +--
 include/geos/operation/valid/PolygonRingTouch.h    |  3 +--
 .../geos/operation/valid/PolygonTopologyAnalyzer.h | 10 ++++----
 include/geos/simplify/ComponentJumpChecker.h       |  7 +++---
 include/geos/simplify/LinkedLine.h                 |  6 ++---
 include/geos/simplify/LinkedRing.h                 |  6 ++---
 include/geos/simplify/PolygonHullSimplifier.h      | 15 +++++-------
 include/geos/simplify/RingHull.h                   | 17 +++++++-------
 include/geos/simplify/TaggedLineString.h           |  5 ++--
 include/geos/simplify/TaggedLineStringSimplifier.h |  8 +++----
 .../polygon/ConstrainedDelaunayTriangulator.h      | 13 +++++------
 .../geos/triangulate/polygon/PolygonEarClipper.h   | 15 ++++++------
 .../geos/triangulate/polygon/PolygonHoleJoiner.h   | 14 +++++------
 include/geos/triangulate/polygon/PolygonNoder.h    | 14 ++++++-----
 .../geos/triangulate/polygon/PolygonTriangulator.h | 13 +++++------
 .../geos/triangulate/polygon/TriDelaunayImprover.h |  9 ++++----
 include/geos/triangulate/tri/Tri.h                 |  8 +++----
 include/geos/triangulate/tri/TriEdge.h             |  3 +--
 include/geos/triangulate/tri/TriList.h             |  7 +++---
 .../geos/triangulate/tri/TriangulationBuilder.h    |  3 +--
 src/algorithm/CGAlgorithmsDD.cpp                   |  2 +-
 .../construct/IndexedPointInPolygonsLocator.cpp    |  1 +
 src/algorithm/hull/HullTriangulation.cpp           |  1 +
 src/coverage/Corner.cpp                            |  2 ++
 src/coverage/CoverageBoundarySegmentFinder.cpp     |  1 +
 src/coverage/CoverageEdge.cpp                      |  3 +++
 src/coverage/CoveragePolygonValidator.cpp          |  1 +
 src/coverage/TPVWSimplifier.cpp                    |  1 +
 src/index/VertexSequencePackedRtree.cpp            |  2 ++
 src/operation/overlayng/EdgeNodingBuilder.cpp      |  1 +
 src/operation/overlayng/InputGeometry.cpp          |  5 ++++
 .../overlayng/IntersectionPointBuilder.cpp         |  2 +-
 src/operation/overlayng/LineLimiter.cpp            |  2 ++
 src/operation/overlayng/OverlayEdgeRing.cpp        |  1 +
 src/operation/overlayng/OverlayLabel.cpp           |  1 +
 src/operation/overlayng/OverlayMixedPoints.cpp     |  2 ++
 src/operation/overlayng/OverlayPoints.cpp          |  2 +-
 src/operation/overlayng/PolygonBuilder.cpp         |  1 +
 src/operation/overlayng/PrecisionReducer.cpp       |  3 +++
 src/operation/overlayng/RingClipper.cpp            |  1 +
 .../overlayng/RobustClipEnvelopeComputer.cpp       |  1 +
 src/operation/relateng/RelateEdge.cpp              |  1 +
 src/operation/relateng/RelateGeometry.cpp          |  1 +
 src/operation/relateng/RelateNode.cpp              |  1 +
 src/operation/valid/IndexedNestedPolygonTester.cpp |  1 +
 .../valid/PolygonIntersectionAnalyzer.cpp          |  7 +++---
 src/simplify/LinkedRing.cpp                        |  1 +
 .../polygon/ConstrainedDelaunayTriangulator.cpp    |  1 +
 src/triangulate/polygon/PolygonEarClipper.cpp      |  2 ++
 src/triangulate/polygon/PolygonHoleJoiner.cpp      |  2 ++
 src/triangulate/polygon/PolygonNoder.cpp           |  1 +
 src/triangulate/polygon/PolygonTriangulator.cpp    |  2 +-
 src/triangulate/tri/Tri.cpp                        |  2 +-
 tests/unit/coverage/TPVWSimplifierTest.cpp         |  1 +
 tests/unit/index/VertexSequencePackedRtreeTest.cpp |  2 +-
 .../relateng/RelateNGBoundaryNodeRuleTest.cpp      |  1 +
 143 files changed, 510 insertions(+), 543 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
