[geos-commits] [SCM] GEOS branch main updated. feb4459969212ced293e4ead339dc95457631bcc
Fri Nov 8 14:56:32 PST 2024
the project "GEOS".
The branch, main has been updated
       via  feb4459969212ced293e4ead339dc95457631bcc (commit)
      from  52f36cb2819010b43deb182e2aa3a7bb3e0a6bbc (commit)
revisions in full, below.
commit feb4459969212ced293e4ead339dc95457631bcc
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Nov 8 14:56:11 2024 -0800
    Update developer notes
diff --git a/DEVELOPER-NOTES.md b/DEVELOPER-NOTES.md
index b81594b60..bfa94f66f 100644
--- a/DEVELOPER-NOTES.md
+++ b/DEVELOPER-NOTES.md
@@ -109,3 +109,25 @@ rather than:
 ### Use `pragma once` to limit header inclusion
 Use `#pragma once` to limit header inclusion.  It is simpler and faster.
+### Use `using` to reduce namespace qualifiers
+GEOS is organized into many nested namespaces to reflect the JTS package structure.
+Namespace qualification of class references can be shortened
+with the `using` keyword in two different ways:
+In **header files**, `using` [type aliases](https://en.cppreference.com/w/cpp/language/type_alias) can be defined **inside class definitions**:
+class OffsetCurve {
+  using Geometry = geom::Geometry;
+In **implementation files**, `using` [declarations](https://en.cppreference.com/w/cpp/language/using_declaration) can be defined for classes or entire namespaces:
+using geos::algorithm::Distance;
+using namespace geos::geom;
\ No newline at end of file
Summary of changes:
 DEVELOPER-NOTES.md | 22 ++++++++++++++++++++++
 1 file changed, 22 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
