[geos-commits] [SCM] GEOS branch main updated. 1ee3b0be4e860b0b76e857075b4f51de01be581b
git at osgeo.org
git at osgeo.org
Fri Nov 15 14:36:21 PST 2024
the project "GEOS".
The branch, main has been updated
via 1ee3b0be4e860b0b76e857075b4f51de01be581b (commit)
from 286f189e2b3d07d8dc76cca8dd39465550b69bad (commit)
revisions in full, below.
commit 1ee3b0be4e860b0b76e857075b4f51de01be581b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 15 14:35:25 2024 -0800
Fix line->getPoint(n) error with m coordinates GH-1191
diff --git a/src/geom/SimpleCurve.cpp b/src/geom/SimpleCurve.cpp
index be9b50b44..6bb589257 100644
--- a/src/geom/SimpleCurve.cpp
+++ b/src/geom/SimpleCurve.cpp
@@ -251,7 +251,18 @@ SimpleCurve::getPointN(std::size_t n) const
assert(getFactory());
assert(points.get());
- return std::unique_ptr<Point>(getFactory()->createPoint(points->getAt(n)));
+ std::unique_ptr<Point> point;
+ if (hasM() || hasZ()) {
+ CoordinateXYZM c;
+ points->getAt(n, c);
+ return getFactory()->createPoint(c);
+ else {
+ CoordinateXY c;
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index 26a8756bf..06e1dfa0c 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -35,6 +35,7 @@ struct test_linestring_data {
geos::geom::PrecisionModel pm_;
geos::geom::GeometryFactory::Ptr factory_;
geos::io::WKTReader reader_;
+ geos::io::WKTWriter writer_;
std::unique_ptr<geos::geom::LineString> empty_line_;
std::unique_ptr<geos::geom::LineString> line_;
@@ -588,5 +589,50 @@ void object::test<32>
ensure(!line_->hasDimension(geos::geom::Dimension::A));
+// https://github.com/libgeos/geos/issues/1191
+// line->getPoint(n) loses M dimension
+template<>
+template<>
+void object::test<33>
+ auto geom = reader_.read("LINESTRING M (0 1 2, 10 11 12, 20 21 22)");
+ ensure(geom != nullptr);
+ geos::geom::LineString *line = static_cast<LineString*>(geom.get());
+ ensure_equals(line->getCoordinateDimension(), 3);
+ auto pt = line->getPointN(2);
+ auto out = writer_.write(*pt);
+ ensure_equals(out, "POINT M (20 21 22)");
+template<>
+template<>
+void object::test<34>
+ auto geom = reader_.read("LINESTRING Z (0 1 2, 10 11 12, 20 21 22)");
+ ensure_equals(out, "POINT Z (20 21 22)");
+template<>
+template<>
+void object::test<35>
+ auto geom = reader_.read("LINESTRING ZM (0 1 2 3, 10 11 12 13, 20 21 22 23)");
+ ensure_equals(line->getCoordinateDimension(), 4);
+ ensure_equals(out, "POINT ZM (20 21 22 23)");
} // namespace tut
Summary of changes:
src/geom/SimpleCurve.cpp | 13 ++++++++++-
tests/unit/geom/LineStringTest.cpp | 46 ++++++++++++++++++++++++++++++++++++++
2 files changed, 58 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
