[geos-commits] [SCM] GEOS branch 3.13 updated. a5f51f7c6c26cdd498bf4328568e54aca3f1ad6a
git at osgeo.org
git at osgeo.org
Fri Nov 15 14:48:27 PST 2024
the project "GEOS".
The branch, 3.13 has been updated
via a5f51f7c6c26cdd498bf4328568e54aca3f1ad6a (commit)
via fa087153f3e6cc8dce1e55e9f3301ba2f8565896 (commit)
from 3c648f216b961e9b86cca48d368f32e918d573ce (commit)
revisions in full, below.
commit a5f51f7c6c26cdd498bf4328568e54aca3f1ad6a
Merge: fa087153f 3c648f216
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 15 14:47:47 2024 -0800
Fix LineString->getPoint(n) for M geometries (closes GH-1191)
diff --cc NEWS.md
index 1f555c9cb,eef6897a2..82a4eddfc
--- a/NEWS.md
+++ b/NEWS.md
@@@ -4,7 -4,7 +4,9 @@@
- Fixes/Improvements:
- Fix ConcaveHullOfPolygons nested shell handling (GH-1169, Martin Davis)
- Fix RelateNG for computing IM for empty-nonempty cases (Martin Davis)
- - Fix TopologyPreservingSimplifier/TaggedLineString to avoid jumping components (JTS-1096, Martin Davis)
+ - Fix LineString->getPoint(n) for M geometries (GH-1191, @hsieyuan)
++ - Fix TopologyPreservingSimplifier/TaggedLineString to avoid jumping components (JTS-1096, Martin Davis)
## Changes in 3.13.0
2024-09-06
commit fa087153f3e6cc8dce1e55e9f3301ba2f8565896
Date: Fri Nov 15 14:46:31 2024 -0800
diff --git a/NEWS.md b/NEWS.md
index b605e1a62..1f555c9cb 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -4,6 +4,7 @@
2024-09-06
diff --git a/src/geom/SimpleCurve.cpp b/src/geom/SimpleCurve.cpp
index be9b50b44..dcbaf7114 100644
--- a/src/geom/SimpleCurve.cpp
+++ b/src/geom/SimpleCurve.cpp
@@ -251,7 +251,16 @@ SimpleCurve::getPointN(std::size_t n) const
assert(getFactory());
assert(points.get());
- return std::unique_ptr<Point>(getFactory()->createPoint(points->getAt(n)));
+ if (hasM() || hasZ()) {
+ CoordinateXYZM c;
+ points->getAt(n, c);
+ return getFactory()->createPoint(c);
+ else {
+ CoordinateXY c;
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index 26a8756bf..1e1136fce 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -13,6 +13,7 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
#include <geos/util/GEOSException.h>
#include <geos/util/IllegalArgumentException.h>
#include <geos/constants.h>
@@ -35,6 +36,7 @@ struct test_linestring_data {
geos::geom::PrecisionModel pm_;
geos::geom::GeometryFactory::Ptr factory_;
geos::io::WKTReader reader_;
+ geos::io::WKTWriter writer_;
std::unique_ptr<geos::geom::LineString> empty_line_;
std::unique_ptr<geos::geom::LineString> line_;
@@ -588,5 +590,23 @@ void object::test<32>
ensure(!line_->hasDimension(geos::geom::Dimension::A));
+// https://github.com/libgeos/geos/issues/1191
+// line->getPoint(n) loses M dimension
+template<>
+template<>
+void object::test<33>
+ auto geom = reader_.read("LINESTRING M (0 1 2, 10 11 12, 20 21 22)");
+ ensure(geom != nullptr);
+ geos::geom::LineString *line = static_cast<LineString*>(geom.get());
+ ensure_equals(line->getCoordinateDimension(), 3);
+ auto pt = line->getPointN(2);
+ auto out = writer_.write(*pt);
+ ensure_equals(out, "POINT M (20 21 22)");
} // namespace tut
Summary of changes:
NEWS.md | 4 +++-
src/geom/SimpleCurve.cpp | 11 ++++++++++-
tests/unit/geom/LineStringTest.cpp | 20 ++++++++++++++++++++
3 files changed, 33 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
