[geos-commits] [SCM] GEOS branch main updated. 3bb7596c313ea69b9c20f1e8e6d860da3da4fc23
Wed Nov 20 14:28:40 PST 2024
the project "GEOS".
The branch, main has been updated
       via  3bb7596c313ea69b9c20f1e8e6d860da3da4fc23 (commit)
      from  f94b91384411bf21bd44b8d0947e5a16ba1a3e13 (commit)
revisions in full, below.
commit 3bb7596c313ea69b9c20f1e8e6d860da3da4fc23
Author: Mike Taves <mwtoews at gmail.com>
Date:   Thu Nov 21 11:28:16 2024 +1300
    Fix WKTWriter for small precisions and with trim enabled (#1199)
diff --git a/NEWS.md b/NEWS.md
index 56cfc634b..2d3f1e158 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -9,6 +9,7 @@
   - Fix ConcaveHullOfPolygons nested shell handling (GH-1169, Martin Davis)
   - Fix RelateNG for computing IM for empty-nonempty cases (Martin Davis)
   - Fix TopologyPreservingSimplifier/TaggedLineString to avoid jumping components (JTS-1096, Martin Davis)
+  - Fix WKTWriter for small precisions and with trim enabled (GH-1199, Mike Taves)
 ## Changes in 3.13.0
 2024-09-06
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 53fa14269..7c8f04bdc 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -460,7 +460,10 @@ WKTWriter::writeTrimmedNumber(double d, uint32_t precision, char* buf)
         // most real-world coordinates, use positional notation
         if ( (precision < 4) && (da < 1.0) ) {
             // adjust precision to avoid rounding to zero
-            precision = static_cast<std::uint32_t>(-floor(log10(da)));
+            const auto higher_prec = static_cast<std::uint32_t>(-floor(log10(da)));
+            if (higher_prec > precision) {
+                precision = higher_prec;
         return geos_d2sfixed_buffered_n(d, precision, buf);
diff --git a/tests/unit/capi/GEOS_printDoubleTest.cpp b/tests/unit/capi/GEOS_printDoubleTest.cpp
index 69cd61562..0bcf62427 100644
--- a/tests/unit/capi/GEOS_printDoubleTest.cpp
+++ b/tests/unit/capi/GEOS_printDoubleTest.cpp
@@ -69,6 +69,21 @@ void object::test<1>()
         TESTCASE(12, 1.2345678901234e+17, "1.234567890123e+17"),
         TESTCASE(13, 1.2345678901234e+17, "1.2345678901234e+17"),
         TESTCASE(14, 1.2345678901234e+17, "1.2345678901234e+17"),
+        TESTCASE(0, 0.0123456789, "0.01"),
+        TESTCASE(1, 0.0123456789, "0.01"),
+        TESTCASE(2, 0.0123456789, "0.01"),
+        TESTCASE(3, 0.0123456789, "0.012"),
+        TESTCASE(4, 0.0123456789, "0.0123"),
+        TESTCASE(0, 0.123456789, "0.1"),
+        TESTCASE(1, 0.123456789, "0.1"),
+        TESTCASE(2, 0.123456789, "0.12"),
+        TESTCASE(3, 0.123456789, "0.123"),
+        TESTCASE(4, 0.123456789, "0.1235"),
+        TESTCASE(0, 1.23456789, "1"),
+        TESTCASE(1, 1.23456789, "1.2"),
+        TESTCASE(2, 1.23456789, "1.23"),
+        TESTCASE(3, 1.23456789, "1.235"),
+        TESTCASE(4, 1.23456789, "1.2346"),
     for (const auto& testcase : testcase_l) {
         char buf[28];
Summary of changes:
 NEWS.md                                  |  1 +
 src/io/WKTWriter.cpp                     |  5 ++++-
 tests/unit/capi/GEOS_printDoubleTest.cpp | 15 +++++++++++++++
 3 files changed, 20 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
