[geos-commits] [SCM] GEOS branch 3.13 updated. 23c7c2e96e32933701b81f536c8762a36f8d3379
Wed Nov 20 16:56:00 PST 2024
the project "GEOS".
The branch, 3.13 has been updated
       via  23c7c2e96e32933701b81f536c8762a36f8d3379 (commit)
      from  a5f51f7c6c26cdd498bf4328568e54aca3f1ad6a (commit)
revisions in full, below.
commit 23c7c2e96e32933701b81f536c8762a36f8d3379
Author: Mike Taves <mwtoews at gmail.com>
Date:   Thu Nov 21 13:55:30 2024 +1300
    Fix typos, add CI job to help catch them (#1194)
diff --git a/.codespellrc b/.codespellrc
new file mode 100644
index 000000000..3dc9e184d
--- /dev/null
+++ b/.codespellrc
@@ -0,0 +1,3 @@
+[codespell]
+skip = ./tools/astyle,./src/deps,./web/themes,./util/geosop/cxxopts.hpp
+ignore-words = ./tools/codespell.ignore
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index d2e0c4faa..d98ec451b 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -528,6 +528,7 @@ jobs:
         set -e
         sudo -E apt-get update
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
+        python3 -m pip install --disable-pip-version-check --user codespell
     - name: 'Check Out'
       uses: actions/checkout at v4
@@ -535,6 +536,9 @@ jobs:
     - name: 'cppcheck'
       run: ./tools/cppcheck.sh
+    - name: codespell
+      run: codespell
+      # false-positives can be added to tools/codespell.ignore
   cmake-subproject:
     name: 'CMake Subproject'
diff --git a/NEWS.md b/NEWS.md
index 82a4eddfc..30877064d 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -29,7 +29,7 @@
 - Breaking Changes
   - Zero-length linestrings (eg LINESTRING(1 1, 1 1)) are now treated as equivalent to points (POINT(1 1)) in boolean predicates
-  - CMake 3.15 or later is requried (GH-1143, Mike Taves)
+  - CMake 3.15 or later is required (GH-1143, Mike Taves)
 - Fixes/Improvements:
   - WKTReader: Points with all-NaN coordinates are not considered empty anymore (GH-927, Casper van der Wel)
@@ -933,7 +933,7 @@ See 3.7.0 notes
 - Added Polygonizer and LineMerger classes.
 - python wrapper examples
 - General cleanup / warnings removal
-- cleaner win32 / older copilers builds
+- cleaner win32 / older compilers builds
 - Reduced heap allocations
 - debian package builder scripts
 - reduction of standard C lib headers dependency
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index c2378f4c1..a3344e6e7 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -720,7 +720,7 @@ public:
      *   and dissolving the linework.
      * - Unioning a set of [Polygons](@ref Polygon) will always
      *   return a polygonal geometry (unlike Geometry::Union(const Geometry* other) const),
-     *   which may return geometrys of lower dimension if a topology collapse
+     *   which may return geometries of lower dimension if a topology collapse
      *   occurred.
      * @return the union geometry
diff --git a/include/geos/geom/Surface.h b/include/geos/geom/Surface.h
index 7b1bb6ff3..d2dcb384e 100644
--- a/include/geos/geom/Surface.h
+++ b/include/geos/geom/Surface.h
@@ -100,7 +100,7 @@ protected:
     int
     compareToSameClass(const Geometry* g) const override;
-    // Helper method allowing PolygonImpl to use GeometryFactory without cirular imports
+    // Helper method allowing PolygonImpl to use GeometryFactory without circular imports
     static std::unique_ptr<Geometry> createEmptyRing(const GeometryFactory&);
     virtual Curve* getExteriorRing() = 0;
diff --git a/include/geos/io/WKTWriter.h b/include/geos/io/WKTWriter.h
index 105b63739..6acaac301 100644
--- a/include/geos/io/WKTWriter.h
+++ b/include/geos/io/WKTWriter.h
@@ -107,7 +107,7 @@ public:
      * Generates the WKT for a N-point <code>LineString</code>.
-     * @param seq the sequence to outpout
+     * @param seq the sequence to output
      * @return the WKT
diff --git a/include/geos/noding/IteratedNoder.h b/include/geos/noding/IteratedNoder.h
index 5f231fcc7..3e82c8aa1 100644
--- a/include/geos/noding/IteratedNoder.h
+++ b/include/geos/noding/IteratedNoder.h
@@ -104,7 +104,7 @@ public:
     /** \brief
-     * Fully nodes a list of {@link SegmentString}s, i.e. peforms noding iteratively
+     * Fully nodes a list of {@link SegmentString}s, i.e. performs noding iteratively
      * until no intersections are found between segments.
      * Maintains labelling of edges correctly through the noding.
diff --git a/include/geos/operation/overlayng/OverlayUtil.h b/include/geos/operation/overlayng/OverlayUtil.h
index 9d30dca34..a033c5a71 100644
--- a/include/geos/operation/overlayng/OverlayUtil.h
+++ b/include/geos/operation/overlayng/OverlayUtil.h
@@ -69,7 +69,7 @@ private:
     * are:
     * - INTERSECTION: result envelope is the intersection of the input envelopes
-    * - DIFERENCE: result envelope is the envelope of the A input geometry
+    * - DIFFERENCE: result envelope is the envelope of the A input geometry
     * Otherwise, <code>null</code> is returned to indicate full extent.
diff --git a/include/geos/planargraph/DirectedEdge.h b/include/geos/planargraph/DirectedEdge.h
index 38d096830..5d1d44358 100644
--- a/include/geos/planargraph/DirectedEdge.h
+++ b/include/geos/planargraph/DirectedEdge.h
@@ -84,7 +84,7 @@ public:
      * to the given parentEdges vector.
      * @note Parents are pushed to the parentEdges vector, make sure
-     * it is empty if index-based corrispondence is important.
+     * it is empty if index-based correspondence is important.
     static void toEdges(std::vector<DirectedEdge*>& dirEdges,
                         std::vector<Edge*>& parentEdges);
diff --git a/include/geos/vend/json.hpp b/include/geos/vend/json.hpp
index c81c5c510..315e0a35b 100644
--- a/include/geos/vend/json.hpp
+++ b/include/geos/vend/json.hpp
@@ -5091,7 +5091,7 @@ struct wide_string_input_helper<BaseInputAdapter, 2>
-// Wraps another input apdater to convert wide character types into individual bytes.
+// Wraps another input adapter to convert wide character types into individual bytes.
 template<typename BaseInputAdapter, typename WideCharType>
 class wide_string_input_adapter
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index 55fbfe6d5..026310d20 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -38,7 +38,7 @@ using namespace geos::geom;
 namespace geos {
 namespace algorithm { // geos.algorithm
-// file statics
+// file statistics
 namespace {
 double
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index f454a7ac7..3e634d6e9 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -45,7 +45,7 @@ namespace algorithm { // geos.algorithm
 MinimumBoundingCircle::getCircle()
-    //TODO: ensure the output circle contains the extermal points.
+    //TODO: ensure the output circle contains the extremal points.
     //TODO: or maybe even ensure that the returned geometry contains ALL the input points?
     compute();
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index b5c77570c..9b24f7929 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -318,4 +318,4 @@ Point::getCoordinatesRO() const
 } // namespace geos::geom
-} // namesapce geos
+} // namespace geos
diff --git a/src/geomgraph/Edge.cpp b/src/geomgraph/Edge.cpp
index 6212703a3..3b4ea5d51 100644
--- a/src/geomgraph/Edge.cpp
+++ b/src/geomgraph/Edge.cpp
@@ -55,7 +55,7 @@ using namespace geos::algorithm;
  * Updates an IM from the label for an edge.
- * Handles edges from both L and A geometrys.
+ * Handles edges from both L and A geometries.
 void
 Edge::updateIM(const Label& lbl, IntersectionMatrix& im)
diff --git a/src/index/bintree/NodeBase.cpp b/src/index/bintree/NodeBase.cpp
index c35296fb9..30331aa5c 100644
--- a/src/index/bintree/NodeBase.cpp
+++ b/src/index/bintree/NodeBase.cpp
@@ -26,7 +26,7 @@ namespace index { // geos.index
 namespace bintree { // geos.index.bintree
- * Returns the index of the subnode that wholely contains the given interval.
+ * Returns the index of the subnode that wholly contains the given interval.
  * If none does, returns -1.
 int
diff --git a/src/operation/buffer/BufferCurveSetBuilder.cpp b/src/operation/buffer/BufferCurveSetBuilder.cpp
index 41038d74e..4fc725f96 100644
--- a/src/operation/buffer/BufferCurveSetBuilder.cpp
+++ b/src/operation/buffer/BufferCurveSetBuilder.cpp
@@ -117,7 +117,7 @@ BufferCurveSetBuilder::addCurve(CoordinateSequence* coord,
     // coord ownership transferred to SegmentString
     SegmentString* e = new NodedSegmentString(coord, coord->hasZ(), coord->hasM(), newlabel);
-    // SegmentString doesnt own the sequence, so we need to delete in
+    // SegmentString doesn't own the sequence, so we need to delete in
     // the destructor
     newLabels.push_back(newlabel);
     curveList.push_back(e);
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index 90a18ed44..3971a7b99 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -181,7 +181,7 @@ RelateComputer::computeIM()
      * Now process improper intersections
-     * (eg where one or other of the geometrys has a vertex at the
+     * (eg where one or other of the geometries has a vertex at the
      * intersection point)
      * We need to compute the edge graph at all nodes to determine
      * the IM.
diff --git a/src/operation/relateng/RelateNG.cpp b/src/operation/relateng/RelateNG.cpp
index 9338123ff..8342fe868 100644
--- a/src/operation/relateng/RelateNG.cpp
+++ b/src/operation/relateng/RelateNG.cpp
@@ -534,7 +534,7 @@ RelateNG::computeLineEnds(
                 continue;
             const LineString* line = static_cast<const LineString*>(elem);
-            //TODO: add optimzation to skip disjoint elements once exterior point found
+            //TODO: add optimization to skip disjoint elements once exterior point found
             const CoordinateXY& e0 = line->getCoordinatesRO()->getAt(0);
             hasExteriorIntersection |= computeLineEnd(geom, isA, &e0, geomTarget, topoComputer);
             if (topoComputer.isResultKnown()) {
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 1c164d635..0b6782e42 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -231,7 +231,7 @@ TopologyComputer::addIntersection(NodeSection* a, NodeSection* b)
     // we run this first (unlike JTS) in case the subsequent test throws
     // an exception and the NodeSection pointers are not correctly
     // saved in the memory managed store on the NodeSections, causing
-    // a small memeory leak
+    // a small memory leak
     addNodeSections(a, b);
     if (! a->isSameGeometry(b)) {
diff --git a/tests/unit/geom/util/GeometryFixerTest.cpp b/tests/unit/geom/util/GeometryFixerTest.cpp
index bc10f61d6..908552dc5 100644
--- a/tests/unit/geom/util/GeometryFixerTest.cpp
+++ b/tests/unit/geom/util/GeometryFixerTest.cpp
@@ -70,8 +70,8 @@ struct test_geometryfixer_data {
         std::unique_ptr<Geometry> expected = wktreader_.read(wktExpected);
-        // std::cout << "Reslt: " << wktwriter_.write(actual.get()) << std::endl;
-        // std::cout << "Expct: " << wktwriter_.write(expected.get()) << std::endl;
+        // std::cout << "Result: " << wktwriter_.write(actual.get()) << std::endl;
+        // std::cout << "Expect: " << wktwriter_.write(expected.get()) << std::endl;
         ensure("Result is invalid", actual->isValid());
         ensure_equals_geometry(expected.get(), actual.get());
diff --git a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
index b8a8cb474..d546a9d62 100644
--- a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
+++ b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
@@ -132,7 +132,7 @@
 <case>
   <desc>mA/L
   	A has 2 shells touching at one vertex and one non-vertex.
-  	B passes between the shells, but is wholely contained
+  	B passes between the shells, but is wholly contained
   </desc>
   <a>
     MULTIPOLYGON (((100 30, 30 110, 150 110, 100 30)),
@@ -204,7 +204,7 @@
 </case>
 <case>
-  <desc>A/L - wholely contained
+  <desc>A/L - wholly contained
   </desc>
   <a> POLYGON ((10 10, 60 100, 110 10, 10 10))
     </a>
diff --git a/tools/codespell.ignore b/tools/codespell.ignore
index 000000000..896a43d83
--- /dev/null
+++ b/tools/codespell.ignore
@@ -0,0 +1,17 @@
+parms
+Geometrys
+deques
+extracter
+implementors
+translater
+thirdparty
+crate
+eiter
+examplar
+nempty
+ba
+te
+seh
+bLoc
+aLo
+Wel
Summary of changes:
 .codespellrc                                            |  3 +++
 .github/workflows/ci.yml                                |  4 ++++
 NEWS.md                                                 |  4 ++--
 include/geos/geom/Geometry.h                            |  2 +-
 include/geos/geom/Surface.h                             |  2 +-
 include/geos/io/WKTWriter.h                             |  2 +-
 include/geos/noding/IteratedNoder.h                     |  2 +-
 include/geos/operation/overlayng/OverlayUtil.h          |  2 +-
 include/geos/planargraph/DirectedEdge.h                 |  2 +-
 include/geos/vend/json.hpp                              |  2 +-
 src/algorithm/InteriorPointArea.cpp                     |  2 +-
 src/algorithm/MinimumBoundingCircle.cpp                 |  2 +-
 src/geom/Point.cpp                                      |  2 +-
 src/geomgraph/Edge.cpp                                  |  2 +-
 src/index/bintree/NodeBase.cpp                          |  2 +-
 src/operation/buffer/BufferCurveSetBuilder.cpp          |  2 +-
 src/operation/relate/RelateComputer.cpp                 |  2 +-
 src/operation/relateng/RelateNG.cpp                     |  2 +-
 src/operation/relateng/TopologyComputer.cpp             |  2 +-
 tests/unit/geom/util/GeometryFixerTest.cpp              |  4 ++--
 .../tests/general/TestPreparedPolygonPredicate.xml      |  4 ++--
 tools/codespell.ignore                                  | 17 +++++++++++++++++
 22 files changed, 46 insertions(+), 22 deletions(-)
 create mode 100644 .codespellrc
 create mode 100644 tools/codespell.ignore
hooks/post-receive
More information about the geos-commits mailing list
