[geos-commits] [SCM] GEOS branch 3.13 updated. 06715295d1974cc0e19b5d519a52ee85cc1991af
Thu Nov 21 09:16:22 PST 2024
the project "GEOS".
The branch, 3.13 has been updated
       via  06715295d1974cc0e19b5d519a52ee85cc1991af (commit)
       via  b554b0a1ef10559b9495ac5575e470774c55bc49 (commit)
      from  29e3f0583318fa194d1b27fcf35497bb8c312b48 (commit)
revisions in full, below.
commit 06715295d1974cc0e19b5d519a52ee85cc1991af
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Nov 21 09:15:59 2024 -0800
    Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 6eb86f277..31d66733d 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -7,7 +7,7 @@
   - Fix LineString->getPoint(n) for M geometries (GH-1191, @hsieyuan)
   - Fix TopologyPreservingSimplifier/TaggedLineString to avoid jumping components (JTS-1096, Martin Davis)
   - Fix WKTWriter for small precisions and with trim enabled (GH-1199, Mike Taves)
+  - Fix BufferOp to increase length of segments removed by heuristic (GH-1200, Martin Davis)
 ## Changes in 3.13.0
 2024-09-06
commit b554b0a1ef10559b9495ac5575e470774c55bc49
Date:   Wed Nov 20 15:56:35 2024 -0800
    Increase length of segments removed by BufferOp short segment removal heuristic (#1200)
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 4537f9b3d..6c7c2c3b0 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -44,7 +44,7 @@ namespace operation { // geos.operation
 namespace buffer { // geos.operation.buffer
 /*private data*/
-const double OffsetSegmentGenerator::CURVE_VERTEX_SNAP_DISTANCE_FACTOR = 1.0E-6;
+const double OffsetSegmentGenerator::CURVE_VERTEX_SNAP_DISTANCE_FACTOR = 1.0E-4;
 const double OffsetSegmentGenerator::OFFSET_SEGMENT_SEPARATION_FACTOR = 1.0E-3;
 const double OffsetSegmentGenerator::INSIDE_TURN_VERTEX_SNAP_DISTANCE_FACTOR = 1.0E-3;
 const double OffsetSegmentGenerator::SIMPLIFY_FACTOR = 100.0;
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 478704424..f1894c4ef 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -59,6 +59,13 @@ struct test_bufferop_data {
         ensure_equals_geometry(expected.get(), actual.get(), tolerance);
+    void checkBufferValid(const Geometry& buffer)
+        ensure_not(buffer.isEmpty());
+        ensure(buffer.isValid());
+        ensure_equals(buffer.getGeometryTypeId(), geos::geom::GEOS_POLYGON);
 private:
     // noncopyable
     test_bufferop_data(test_bufferop_data const& other) = delete;
@@ -70,6 +77,9 @@ typedef group::object object;
 group test_bufferop_group("geos::operation::buffer::BufferOp");
+using geos::operation::buffer::BufferOp;
+using geos::operation::buffer::BufferParameters;
 // Test Cases
@@ -180,7 +190,7 @@ void object::test<4>
         ensure_not(gBuffer->isEmpty());
         ensure(gBuffer->isValid());
         ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
-        ensure(gBuffer->getNumPoints() >= std::size_t(243));
+        ensure(gBuffer->getNumPoints() >= std::size_t(240));
     // Buffer point with custom parameters: 32 quadrant segments
@@ -193,7 +203,7 @@ void object::test<4>
-        ensure(gBuffer->getNumPoints() >= std::size_t(317));
+        ensure(gBuffer->getNumPoints() >= std::size_t(310));
@@ -582,9 +592,6 @@ template<>
 void object::test<21>
-    using geos::operation::buffer::BufferOp;
-    using geos::operation::buffer::BufferParameters;
     std::string wkt("LINESTRING (50 50, 150 150, 150 100, 150 0)");
     GeomPtr geom(wktreader.read(wkt));
@@ -603,9 +610,6 @@ template<>
 void object::test<22>
     std::string wkt("MULTILINESTRING((0 0,10 0),(20 0,30 0))");
@@ -622,7 +626,7 @@ void object::test<22>
 // See https://github.com/libgeos/geos/issues/984
 template<>
 template<>
-void object::test<24>
+void object::test<23>
     std::string wkt("MULTIPOLYGON (((833454.7163917861 6312507.405413097, 833455.3726665961 6312510.208920742, 833456.301153878 6312514.207390314, 833492.2432584754 6312537.770332065, 833493.0901320165 6312536.098774815, 833502.6580673696 6312517.561360772, 833503.9404352929 6312515.0542803425, 833454.7163917861 6312507.405413097)))");
@@ -633,19 +637,26 @@ void object::test<24>
         "POLYGON ((833489.57 6312527.65, 833493.27 6312520.48, 833474.09 6312517.5, 833489.57 6312527.65))");
-// Checks a bug in the inverted-ring-removal heuristic.
-// See https://github.com/libgeos/geos/issues/984
+// Test that hole is not removed
+// See https://github.com/libgeos/geos/issues/1125
 template<>
 template<>
-void object::test<23>
+void object::test<24>
-    std::string wkt("POLYGON ((182719.04521570954238996 224897.14115349075291306, 182807.02887436276068911 224880.64421749324537814, 182808.47314301913138479 224877.25002362736267969, 182718.38701137207681313 224740.00115247094072402, 182711.82697281913715415 224742.08599378637154587, 182717.1393717635946814 224895.61432328051887453, 182719.04521570954238996 224897.14115349075291306))");
+    std::string wkt("POLYGON ((-148960.4047102984 6579513.659170938, -148960.40472686838 6579513.659178669, -148928.03967482893 6581180.350337844, -148928.03966852615 6581180.350346942, -148245.02969243884 6581451.972863571, -147792.69963135064 6581746.752366657, -147792.6996281087 6581746.75236803, -147401.9935951374 6581835.620705241, -147401.99358759282 6581835.620703953, -147210.88713389705 6581715.340857458, -147165.89526002048 6581718.457445952, -147051.42048342412 6581994.82400416, -147051.42047801215 6581994.824009572, -146383.20456979086 6582271.608101351, -146383.2045621372 6582271.608101351, -145714.9886539159 6581994.824009572, -145714.98864850393 6581994.82400416, -145614.3328321268 6581751.81936713, -145289.9656757827 6581774.313793615, -145289.96567191236 6581774.313793121, -145251.8481577967 6581761.535459794, -144930.85554023445 6582023.4300059695, -144930.8555367881 6582023.430007799, -144801.3009401439 6582062.324496457, -144649.32384133 6582200.989150884, -144370
 .3984315592 6582625.9565866, -144433.62831761822 6582865.175298614, -144433.62831293597 6582865.175309839, -144433.62830087988 6582865.1753082415, -144245.21925235502 6582676.803615549, -144190.80928433637 6582650.465391226, -143612.84111918643 6583156.44930699, -143612.84111246275 6583156.449309465, -142975.83638491016 6583147.740068783, -141662.4868993248 6583201.722187021, -141223.96080949655 6583368.877976318, -141223.9608054673 6583368.877976963, -140134.4210790951 6583317.8899636455, -140134.42107909513 6583317.889963645, -137814.40233039632 6583217.2880082, -136584.74750083112 6583197.764297265, -135440.77723332949 6583205.617226817, -135255.13230017386 6583263.689926113, -135255.1322874622 6583263.689918893, -135023.5892295815 6582294.773116073, -135023.58923119382 6582294.773107903, -135333.80239165394 6581864.15594604, -135352.36463803763 6581737.195077398, -134265.49708795475 6581601.806141964, -134265.49708081497 6581601.806137504, -134171.3523981878 6581457.46162037, -1
 34171.35240780914 6581457.4616049845, -135439.245418129 6581616.60978835, -135680.42426776656 6581646.652416545, -136232.90414847215 6581417.807757019, -136232.90415612582 6581417.807757019, -136858.6936574759 6581677.018255669, -136858.69366288788 6581677.018261081, -136920.3618271267 6581825.898379553, -138060.72504339425 6581967.9663254, -138065.18111364308 6581962.887381392, -138068.72527594457 6581957.509990996, -137927.47673027252 6581707.240836958, -137927.47673406618 6581707.240823334, -137979.72909077935 6581677.750295738, -137979.72910440317 6581677.750299531, -138121.13853298384 6581928.304511579, -138125.10691371575 6581928.045277543, -138155.67609864438 6581921.76382738, -138155.67610616024 6581921.763828826, -138161.59059580622 6581925.661985681, -138170.61370458457 6581926.915141124, -138241.97873011595 6581930.376670242, -138796.47362546774 6581702.31578339, -138796.4736332052 6581702.315783444, -138854.7945810144 6581727.268948418, -138854.7945866605 6581727.2689547
 44, -138922.92405045434 6581954.795890863, -138946.81598659043 6581964.415299832, -139938.37021206832 6581949.812276196, -139938.37021590595 6581949.8122769, -139952.45944601868 6581955.406602237, -140868.02751450587 6581942.0008049095, -140881.4916733481 6581925.799231012, -140881.49167358445 6581925.799230739, -141370.63531269276 6581378.759410803, -140611.15578010492 6581049.475868011, -139690.6039796629 6580651.269214067, -139690.6039740706 6580651.269201963, -139690.6039854776 6580651.26919506, -140701.38102713643 6580840.959071666, -140701.38102925656 6580840.959072313, -141466.34649523295 6581171.308880125, -141779.4716785676 6581271.496083775, -141779.47168395555 6581271.496087928, -142011.00982111954 6581635.151647786, -142357.03529463548 6581674.463073463, -142838.53214036624 6581404.193867828, -142879.22309585733 6581262.508441415, -142930.87215587177 6580987.212409333, -142930.8721639988 6580987.212401323, -143534.53311040023 6580882.981192067, -143534.5331217403 6580882
 .981204585, -143430.70804648325 6581258.626694803, -143473.24119568476 6581352.886713272, -143473.2411965649 6581352.886717073, -143492.189997855 6581960.431913559, -144142.7852635694 6582035.092757561, -144146.60337361123 6581637.42813556, -144146.60337730165 6581637.428127897, -144191.08019920863 6581601.260212262, -144191.08020840262 6581601.260210446, -144537.4404387965 6581705.616846219, -144590.7462798729 6581606.573062022, -144590.74628235682 6581606.573059013, -144763.58672583086 6581465.554334507, -144954.4193364253 6580944.824930562, -144954.4193514073 6580944.824925713, -145151.23516818596 6581077.603406857, -145568.85454308268 6581011.191119298, -145714.98864850393 6580658.392180065, -145714.9886539159 6580658.392174653, -146383.2045621372 6580381.608082874, -146383.20457111226 6580381.60808354, -147120.06182640104 6580824.10705606, -148440.15106589507 6579967.272987214, -148960.4047102984 6579513.659170938), (-136955.57204480894 6581910.9033646155, -137006.19393013295 6
 582033.115406717, -137716.57054709445 6582951.997026325, -138024.97011972597 6582044.130380035, -136955.57204480894 6581910.9033646155), (-141937.5472958841 6582399.340443012, -141701.90518838447 6583118.585420219, -142423.0688508369 6583134.765513478, -142134.02124709485 6582436.3483778415, -141937.5472958841 6582399.340443012), (-143109.90838714276 6582619.958906428, -142984.15380482498 6583123.4834393775, -143587.23570536837 6583134.1575379195, -143327.76121576456 6582574.317213843, -143109.90838714276 6582619.958906428))");
+    GeomPtr geom(wktreader.read(wkt));
-    checkBuffer(wkt, -5, 0.1,
-        "POLYGON ((182722 224891.5, 182802 224876.5, 182717 224747, 182722 224891.5))");
-    checkBuffer(wkt, -30, 0.1,
-        "POLYGON ((182745.98 224861.57, 182760.51 224858.84, 182745.07 224835.33, 182745.98 224861.57))");
+    geos::operation::buffer::BufferParameters bp;
+    bp.setQuadrantSegments(1);
+    geos::operation::buffer::BufferOp op(geom.get(), bp);
+    std::unique_ptr<Geometry> result = op.getResultGeometry(0.00001);
+    checkBufferValid(*result);
+    ensure_equals(result->getNumGeometries(), 1u);
+    const Polygon* poly = dynamic_cast<const Polygon*>( result.get() );
+    ensure_equals(poly->getNumInteriorRing(), 3u);
 } // namespace tut
Summary of changes:
 NEWS.md                                         |  2 +-
 src/operation/buffer/OffsetSegmentGenerator.cpp |  2 +-
 tests/unit/operation/buffer/BufferOpTest.cpp    | 45 +++++++++++++++----------
 3 files changed, 30 insertions(+), 19 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
