[geos-commits] [SCM] GEOS branch main updated. 7852bc6c5e59d97daa0bf3ec8961a77010d26961
Fri Nov 22 13:47:48 PST 2024
the project "GEOS".
The branch, main has been updated
       via  7852bc6c5e59d97daa0bf3ec8961a77010d26961 (commit)
      from  ef84de66451723471d59cb22fac634fa861f939a (commit)
revisions in full, below.
commit 7852bc6c5e59d97daa0bf3ec8961a77010d26961
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Nov 22 13:47:25 2024 -0800
    Improve geosop help doc
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index 025e905c4..d55d7b88f 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -734,28 +734,28 @@ std::vector<GeometryOpCreator> opRegistry {
 { "containsPrep", [](std::string name) { return GeometryOp::create(name,
-    catRel, "test if geometry A contains geometry B, using PreparedGeometry",
+    catRel, "test if geometry A contains geometry B, with A prepared",
     Result::typeBool,
     [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB) {
         return new Result( prepGeomCache.get(geom.get())->contains( geomB.get() ) );
 { "containsProperlyPrep", [](std::string name) { return GeometryOp::create(name,
-    catRel, "test if geometry A properly contains geometry B, using PreparedGeometry",
+    catRel, "test if geometry A properly contains geometry B, with A prepared",
     Result::typeBool,
         return new Result( prepGeomCache.get(geom.get())->containsProperly( geomB.get() ) );
 { "coversPrep", [](std::string name) { return GeometryOp::create(name,
-    catRel, "test if geometry A covers geometry B, using PreparedGeometry",
+    catRel, "test if geometry A covers geometry B, with A prepared",
     Result::typeBool,
         return new Result( prepGeomCache.get(geom.get())->covers( geomB.get() ) );
 { "intersectsPrep", [](std::string name) { return GeometryOp::create(name,
-    catRel, "test if geometry A intersects geometry B, using PreparedGeometry",
+    catRel, "test if geometry A intersects geometry B, with A prepared",
     Result::typeBool,
         return new Result( prepGeomCache.get(geom.get())->intersects( geomB.get() ) );
Summary of changes:
 util/geosop/GeometryOp.cpp | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
