[geos-commits] [SCM] GEOS branch 3.13 updated. 4f293e17469fe4abf6a5dcf398713c9d914377f2
Sun Nov 24 17:59:34 PST 2024
the project "GEOS".
The branch, 3.13 has been updated
       via  4f293e17469fe4abf6a5dcf398713c9d914377f2 (commit)
       via  782bec075b3d0b9a2cf6df79e020356dc8eb62e6 (commit)
      from  25854d3f8053fa38fbccdc6fc09e022e98ab5432 (commit)
revisions in full, below.
commit 4f293e17469fe4abf6a5dcf398713c9d914377f2
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Sun Nov 24 17:59:12 2024 -0800
    Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 31d66733d..ee8ab3733 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -8,6 +8,7 @@
   - Fix TopologyPreservingSimplifier/TaggedLineString to avoid jumping components (JTS-1096, Martin Davis)
   - Fix WKTWriter for small precisions and with trim enabled (GH-1199, Mike Taves)
   - Fix BufferOp to increase length of segments removed by heuristic (GH-1200, Martin Davis)
+  - Improve RelateNG performance for A/L cases in prepared predicates (GH-1201, Martin Davis)
 ## Changes in 3.13.0
 2024-09-06
commit 782bec075b3d0b9a2cf6df79e020356dc8eb62e6
Date:   Sun Nov 24 17:55:11 2024 -0800
    Improve RelateNG performance for A/L cases in prepared predicates (#1201)
diff --git a/include/geos/operation/relateng/RelateGeometry.h b/include/geos/operation/relateng/RelateGeometry.h
index 53adf01b1..9cb43797c 100644
--- a/include/geos/operation/relateng/RelateGeometry.h
+++ b/include/geos/operation/relateng/RelateGeometry.h
@@ -171,6 +171,10 @@ public:
             case Dimension::A: return hasAreas;
         return false;
+    bool hasAreaAndLine() const {
+        return hasAreas && hasLines;
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 0b6782e42..e911bc6f8 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -132,11 +132,16 @@ TopologyComputer::getDimension(bool isA) const
 bool
 TopologyComputer::isSelfNodingRequired() const
-    if (predicate.requireSelfNoding()) {
-        if (geomA.isSelfNodingRequired() ||
-            geomB.isSelfNodingRequired())
-        return true;
+    if (! predicate.requireSelfNoding())
+      return false;
+    if (geomA.isSelfNodingRequired())
+      return true;
+    //-- if B is a mixed GC with A and L require full noding
+    if (geomB.hasAreaAndLine())
+      return true;
     return false;
diff --git a/tests/unit/operation/relateng/RelateNGGCTest.cpp b/tests/unit/operation/relateng/RelateNGGCTest.cpp
index c8405328a..7e78401c2 100644
--- a/tests/unit/operation/relateng/RelateNGGCTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGGCTest.cpp
@@ -320,6 +320,10 @@ void object::test<23> ()
     std::string a = "POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))";
     std::string b = "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0)), MULTIPOINT ((0 2), (0 5)))";
     checkEquals(a, b, true);
+    checkContainsWithin(a, b, true);
+    checkCoversCoveredBy(a, b, true);
+    checkContainsWithin(b, a, true);
+    checkCoversCoveredBy(b, a, true);
@@ -331,6 +335,10 @@ void object::test<24> ()
     std::string b = "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0)), LINESTRING (0 2, 0 5))";
@@ -341,7 +349,10 @@ void object::test<25> ()
     std::string b = "GEOMETRYCOLLECTION (POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)),LINESTRING(0 2, 0 5, 5 5))";
+    checkCoversCoveredBy(b, a, true);}
diff --git a/tests/xmltester/tests/general/TestRelateGC.xml b/tests/xmltester/tests/general/TestRelateGC.xml
index f67b789a0..a83444a01 100644
--- a/tests/xmltester/tests/general/TestRelateGC.xml
+++ b/tests/xmltester/tests/general/TestRelateGC.xml
@@ -574,6 +574,17 @@ GEOMETRYCOLLECTION (POLYGON ((1 9, 5 9, 6 6, 1 5, 1 9), (2 6, 4 8, 6 6, 2 6)), P
   <test><op name="overlaps"   arg1="A" arg2="B"> false </op></test>
   <test><op name="touches"    arg1="A" arg2="B"> false </op></test>
   <test><op name="within"     arg1="A" arg2="B"> true </op></test>
+  <test><op name="contains"   arg1="B" arg2="A"> true </op></test>
+  <test><op name="coveredBy"  arg1="B" arg2="A"> true </op></test>
+  <test><op name="covers"     arg1="B" arg2="A"> true </op></test>
+  <test><op name="crosses"    arg1="B" arg2="A"> false </op></test>
+  <test><op name="disjoint"   arg1="B" arg2="A"> false </op></test>
+  <test><op name="equalsTopo" arg1="B" arg2="A"> true </op></test>
+  <test><op name="intersects" arg1="B" arg2="A"> true </op></test>
+  <test><op name="overlaps"   arg1="B" arg2="A"> false </op></test>
+  <test><op name="touches"    arg1="B" arg2="A"> false </op></test>
+  <test><op name="within"     arg1="B" arg2="A"> true </op></test>
 </case>
 <case>
@@ -596,6 +607,17 @@ GEOMETRYCOLLECTION (POLYGON ((1 9, 5 9, 6 6, 1 5, 1 9), (2 6, 4 8, 6 6, 2 6)), P
 </case>
 </run>
Summary of changes:
 NEWS.md                                          |  1 +
 include/geos/operation/relateng/RelateGeometry.h |  4 ++++
 src/operation/relateng/TopologyComputer.cpp      | 15 ++++++++++-----
 tests/unit/operation/relateng/RelateNGGCTest.cpp | 13 ++++++++++++-
 tests/xmltester/tests/general/TestRelateGC.xml   | 22 ++++++++++++++++++++++
 5 files changed, 49 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
