[geos-commits] [SCM] GEOS branch main updated. face0894c3a82268d4e551f65fa1c620b48cbf20
git at osgeo.org
git at osgeo.org
Fri Oct 11 14:00:30 PDT 2024
the project "GEOS".
The branch, main has been updated
via face0894c3a82268d4e551f65fa1c620b48cbf20 (commit)
from 29a4c7ea895da8bb721f1d9342b0a8ef3ad89b2f (commit)
revisions in full, below.
commit face0894c3a82268d4e551f65fa1c620b48cbf20
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Oct 11 14:00:07 2024 -0700
Fix RelateNG IM for empty-nonempty cases
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 1e1c64683..1c164d635 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -302,10 +302,16 @@ TopologyComputer::addPointOnPointExterior(bool isGeomA, const CoordinateXY* pt)
/* public */
void
-TopologyComputer::addPointOnGeometry(bool isA, Location locTarget, int dimTarget, const CoordinateXY* pt)
+TopologyComputer::addPointOnGeometry(bool isPointA, Location locTarget, int dimTarget, const CoordinateXY* pt)
(void)pt;
- updateDim(isA, Location::INTERIOR, locTarget, Dimension::P);
+ //-- update entry for Point interior
+ updateDim(isPointA, Location::INTERIOR, locTarget, Dimension::P);
+ //-- an empty geometry has no points to infer entries from
+ if (getGeometry(! isPointA).isEmpty())
+ return;
switch (dimTarget) {
case Dimension::P:
return;
@@ -323,8 +329,8 @@ TopologyComputer::addPointOnGeometry(bool isA, Location locTarget, int dimTarget
* If a point intersects an area target, then the area interior and boundary
* must extend beyond the point and thus interact with its exterior.
- updateDim(isA, Location::EXTERIOR, Location::INTERIOR, Dimension::A);
- updateDim(isA, Location::EXTERIOR, Location::BOUNDARY, Dimension::L);
+ updateDim(isPointA, Location::EXTERIOR, Location::INTERIOR, Dimension::A);
+ updateDim(isPointA, Location::EXTERIOR, Location::BOUNDARY, Dimension::L);
return;
throw IllegalStateException("Unknown target dimension: " + std::to_string(dimTarget));
@@ -339,6 +345,10 @@ TopologyComputer::addLineEndOnGeometry(bool isLineA, Location locLineEnd, Locati
//-- record topology at line end point
updateDim(isLineA, locLineEnd, locTarget, Dimension::P);
+ if (getGeometry(! isLineA).isEmpty())
+ return;
//-- Line and Area targets may have additional topology
case Dimension::P:
diff --git a/tests/unit/operation/relateng/RelateNGTest.cpp b/tests/unit/operation/relateng/RelateNGTest.cpp
index 7e54c71c9..2a4a53156 100644
--- a/tests/unit/operation/relateng/RelateNGTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGTest.cpp
@@ -839,20 +839,21 @@ void object::test<60> ()
//================ Empty Geometries ==============
+std::string empties[] = {
+ "POINT EMPTY",
+ "LINESTRING EMPTY",
+ "POLYGON EMPTY",
+ "MULTIPOINT EMPTY",
+ "MULTILINESTRING EMPTY",
+ "MULTIPOLYGON EMPTY",
+ "GEOMETRYCOLLECTION EMPTY"
//-- test equals against all combinations of empty geometries
template<>
template<>
void object::test<61> ()
- std::string empties[] = {
- "POINT EMPTY",
- "LINESTRING EMPTY",
- "POLYGON EMPTY",
- "MULTIPOINT EMPTY",
- "MULTILINESTRING EMPTY",
- "MULTIPOLYGON EMPTY",
- "GEOMETRYCOLLECTION EMPTY"
int nempty = 7;
for (int i = 0; i < nempty; i++) {
for (int j = 0; j < nempty; j++) {
@@ -862,13 +863,51 @@ void object::test<61> ()
checkEquals(a, b, true);
+// testEmptyNonEmpty
+template<>
+template<>
+void object::test<62> ()
+ std::string nonEmptyPoint = "POINT (1 1)";
+ std::string nonEmptyLine = "LINESTRING (1 1, 2 2)";
+ std::string nonEmptyPolygon = "POLYGON ((1 1, 1 2, 2 1, 1 1))";
+ for (int i = 0; i < 7; i++) {
+ std::string empty = empties[i];
+ checkRelate(empty, nonEmptyPoint, "FFFFFF0F2");
+ checkRelate(nonEmptyPoint, empty, "FF0FFFFF2");
+ checkRelate(empty, nonEmptyLine, "FFFFFF102");
+ checkRelate(nonEmptyLine, empty, "FF1FF0FF2");
+ checkRelate(empty, nonEmptyPolygon, "FFFFFF212");
+ checkRelate(nonEmptyPolygon, empty, "FF2FF1FF2");
+ checkEquals(empty, nonEmptyPoint, false);
+ checkEquals(empty, nonEmptyLine, false);
+ checkEquals(empty, nonEmptyPolygon, false);
+ checkIntersectsDisjoint(empty, nonEmptyPoint, false);
+ checkIntersectsDisjoint(empty, nonEmptyLine, false);
+ checkIntersectsDisjoint(empty, nonEmptyPolygon, false);
+ checkContainsWithin(empty, nonEmptyPoint, false);
+ checkContainsWithin(empty, nonEmptyLine, false);
+ checkContainsWithin(empty, nonEmptyPolygon, false);
+ checkContainsWithin(nonEmptyPoint, empty, false);
+ checkContainsWithin(nonEmptyLine, empty, false);
+ checkContainsWithin(nonEmptyPolygon, empty, false);
// Prepared test
template<>
template<>
-void object::test<62> ()
+void object::test<63> ()
std::string a = "POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))";
std::string b = "POLYGON((0.5 0.5, 1.5 0.5, 1.5 1.5, 0.5 1.5, 0.5 0.5))";
diff --git a/tests/xmltester/tests/general/TestRelateEmpty.xml b/tests/xmltester/tests/general/TestRelateEmpty.xml
new file mode 100644
index 000000000..6ed612820
--- /dev/null
+++ b/tests/xmltester/tests/general/TestRelateEmpty.xml
@@ -0,0 +1,1114 @@
+<run>
+ <desc>
+ Test relate predicates against cases containing EMPTY geometries.
+ </desc>
+<!-- ================ POINT ============== -->
+<case>
+ <desc>P/P - empty point VS empty point </desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ POINT EMPTY
+ </b>
+ <test><op name="relate" arg3="FFFFFFFF2" arg1="A" arg2="B"> true </op></test>
+ <test><op name="contains" arg1="A" arg2="B"> false </op></test>
+ <test><op name="coveredBy" arg1="A" arg2="B"> false </op></test>
+ <test><op name="covers" arg1="A" arg2="B"> false </op></test>
+ <test><op name="crosses" arg1="A" arg2="B"> false </op></test>
+ <test><op name="disjoint" arg1="A" arg2="B"> true </op></test>
+ <test><op name="equalsTopo" arg1="A" arg2="B"> true </op></test>
+ <test><op name="intersects" arg1="A" arg2="B"> false </op></test>
+ <test><op name="overlaps" arg1="A" arg2="B"> false </op></test>
+ <test><op name="touches" arg1="A" arg2="B"> false </op></test>
+ <test><op name="within" arg1="A" arg2="B"> false </op></test>
+</case>
+<case>
+ <desc>P/L - empty point VS empty line</desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ LINESTRING EMPTY
+ </b>
+</case>
+<case>
+ <desc>P/A - empty point VS empty polygon</desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ POLYGON EMPTY
+ </b>
+</case>
+<case>
+ <desc>P/mP - empty Point VS empty MultiPoint </desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ MULTIPOINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>P/mL - empty Point VS empty MultiLineString</desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ MULTILINESTRING EMPTY
+ </b>
+</case>
+<case>
+ <desc>P/mA - empty Point VS empty MultiPolygon</desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ MULTIPOLYGON EMPTY
+ </b>
+</case>
+<case>
+ <desc>P/GC - empty Point VS empty GC </desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ GEOMETRYCOLLECTION EMPTY
+ </b>
+</case>
+<!-- ================ LINESTRING ============== -->
+<case>
+ <desc>L/P - empty line VS empty point </desc>
+ <a>
+ LINESTRING EMPTY
+ </a>
+ <b>
+ POINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>L/L - empty line VS empty line</desc>
+ <a>
+ LINESTRING EMPTY
+ </a>
+ <b>
+ LINESTRING EMPTY
+ </b>
+</case>
+<case>
+ <desc>L/A - empty line VS empty polygon</desc>
+ <a>
+ LINESTRING EMPTY
+ </a>
+ <b>
+ POLYGON EMPTY
+ </b>
+</case>
+<case>
+ <desc>L/mP - empty line VS empty MultiPoint </desc>
+ <a>
+ LINESTRING EMPTY
+ </a>
+ <b>
+ MULTIPOINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>L/mL - empty line VS empty MultiLineString</desc>
+ <a>
+ LINESTRING EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>L/mA - empty line VS empty MultiPolygon</desc>
+ <a>
+ LINESTRING EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>L/GC - empty line VS empty GC </desc>
+ <a>
+ LINESTRING EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<!-- ================ POLYGON ============== -->
+<case>
+ <desc>A/P - empty polygon VS empty line</desc>
+ <a>
+ POLYGON EMPTY
+ </a>
+ <b>
+ POINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>A/L - empty polygon VS empty line</desc>
+ <a>
+ POLYGON EMPTY
+ </a>
+ <b>
+ LINESTRING EMPTY
+ </b>
+</case>
+<case>
+ <desc>A/A - empty polygon VS empty polygon</desc>
+ <a>
+ POLYGON EMPTY
+ </a>
+ <b>
+ POLYGON EMPTY
+ </b>
+</case>
+<case>
+ <desc>A/mP - empty polygon VS empty MultiPoint </desc>
+ <a>
+ POLYGON EMPTY
+ </a>
+ <b>
+ MULTIPOINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>A/mP - empty polygon VS empty MultiLineString</desc>
+ <a>
+ POLYGON EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>A/mP - empty polygon VS empty MultiPolygon</desc>
+ <a>
+ POLYGON EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>A/mP - empty polygon VS empty GC </desc>
+ <a>
+ POLYGON EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<!-- ================ MULTIPOINT ============== -->
+<case>
+ <desc>mP/P - empty MultiPoint VS empty point </desc>
+ <a>
+ MULTIPOINT EMPTY
+ </a>
+ <b>
+ POINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>mP/L - empty MultiPoint VS empty line</desc>
+ <a>
+ MULTIPOINT EMPTY
+ </a>
+ <b>
+ LINESTRING EMPTY
+ </b>
+</case>
+<case>
+ <desc>mP/A - empty MultiPoint VS empty polygon</desc>
+ <a>
+ MULTIPOINT EMPTY
+ </a>
+ <b>
+ POLYGON EMPTY
+ </b>
+</case>
+<case>
+ <desc>mP/mP - empty MultiPoint VS empty MultiPoint </desc>
+ <a>
+ MULTIPOINT EMPTY
+ </a>
+ <b>
+ MULTIPOINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>mP/mL - empty MultiPoint VS empty MultiLineString</desc>
+ <a>
+ MULTIPOINT EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>mP/mA - empty MultiPoint VS empty MultiPolygon</desc>
+ <a>
+ MULTIPOINT EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>mP/GC - empty MultiPoint VS empty GC </desc>
+ <a>
+ MULTIPOINT EMPTY
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>mL/P - empty Multiline VS empty point </desc>
+ <a>
+ </a>
+ <b>
+ POINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>mL/L - empty Multiline VS empty line</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING EMPTY
+ </b>
+</case>
+<case>
+ <desc>mL/A - empty Multiline VS empty polygon</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON EMPTY
+ </b>
+</case>
+<case>
+ <desc>mL/mP - empty Multiline VS empty MultiPoint </desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>mL/mL - empty Multiline VS empty MultiLineString</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>mL/mA - empty Multiline VS empty MultiPolygon</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>mL/GC - empty Multiline VS empty GC </desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>mA/P - empty Multipolygon VS empty line</desc>
+ <a>
+ </a>
+ <b>
+ POINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>mA/L - empty Multipolygon VS empty line</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING EMPTY
+ </b>
+</case>
+<case>
+ <desc>mA/A - empty Multipolygon VS empty polygon</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON EMPTY
+ </b>
+</case>
+<case>
+ <desc>mA/mP - empty Multipolygon VS empty MultiPoint </desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>mA/mL - empty Multipolygon VS empty MultiLineString</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>mA/mA - empty Multipolygon VS empty MultiPolygon</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>mA/GC - empty Multipolygon VS empty GC </desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>GC/P - empty GC VS empty line</desc>
+ <a>
+ </a>
+ <b>
+ POINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>GC/L - empty GC VS empty line</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING EMPTY
+ </b>
+</case>
+<case>
+ <desc>GC/A - empty GC VS empty polygon</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON EMPTY
+ </b>
+</case>
+<case>
+ <desc>GC/mP - empty GC VS empty MultiPoint </desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT EMPTY
+ </b>
+</case>
+<case>
+ <desc>GC/mL - empty GC VS empty MultiLineString</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>GC/mA - empty GC VS empty MultiPolygon</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>GC/GC - empty GC VS empty GC </desc>
+ <a>
+ </a>
+ <b>
+ </b>
+</case>
+<!-- ================ Mixed EMPTY and non-EMPTY ============== -->
+<case>
+ <desc>P/P - empty Point VS Point</desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ POINT (1 1)
+ </b>
+ <test><op name="relate" arg3="FFFFFF0F2" arg1="A" arg2="B"> true </op></test>
+ <test><op name="equalsTopo" arg1="A" arg2="B"> false </op></test>
+</case>
+<case>
+ <desc>P/L - empty Point VS LineString</desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ LINESTRING (1 1, 2 2)
+ </b>
+ <test><op name="relate" arg3="FFFFFF102" arg1="A" arg2="B"> true </op></test>
+</case>
+<case>
+ <desc>P/L - empty Point VS Polygon</desc>
+ <a>
+ POINT EMPTY
+ </a>
+ <b>
+ POLYGON ((1 1, 1 2, 2 1, 1 1))
+ </b>
+ <test><op name="relate" arg3="FFFFFF212" arg1="A" arg2="B"> true </op></test>
+</case>
+</run>
Summary of changes:
src/operation/relateng/TopologyComputer.cpp | 18 +-
tests/unit/operation/relateng/RelateNGTest.cpp | 59 +-
tests/xmltester/tests/general/TestRelateEmpty.xml | 1114 +++++++++++++++++++++
3 files changed, 1177 insertions(+), 14 deletions(-)
create mode 100644 tests/xmltester/tests/general/TestRelateEmpty.xml
hooks/post-receive
More information about the geos-commits
