[geos-commits] [SCM] GEOS branch 3.13 updated. c6efac893a74f71b9d4fcc112e78def153f22e0b
    git at osgeo.org
    git at osgeo.org
    Fri Oct 11 14:55:12 PDT 2024
the project "GEOS".
The branch, 3.13 has been updated
       via  c6efac893a74f71b9d4fcc112e78def153f22e0b (commit)
       via  2d2802d7f7acd7919599b94f3d1530e8cd987aee (commit)
      from  c80bdc7d3afd7b20ee178a9be256038658ba9d20 (commit)
revisions in full, below.
commit c6efac893a74f71b9d4fcc112e78def153f22e0b
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Oct 11 14:54:48 2024 -0700
    Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 0f267b12d..b605e1a62 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -3,7 +3,7 @@
 - Fixes/Improvements:
   - Fix ConcaveHullOfPolygons nested shell handling (GH-1169, Martin Davis)
+  - Fix RelateNG for computing IM for empty-nonempty cases (Martin Davis)
 ## Changes in 3.13.0
 2024-09-06
commit 2d2802d7f7acd7919599b94f3d1530e8cd987aee
Date:   Fri Oct 11 14:00:07 2024 -0700
    Fix RelateNG IM for empty-nonempty cases
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 1e1c64683..1c164d635 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -302,10 +302,16 @@ TopologyComputer::addPointOnPointExterior(bool isGeomA, const CoordinateXY* pt)
 /* public */
 void
-TopologyComputer::addPointOnGeometry(bool isA, Location locTarget, int dimTarget, const CoordinateXY* pt)
+TopologyComputer::addPointOnGeometry(bool isPointA, Location locTarget, int dimTarget, const CoordinateXY* pt)
     (void)pt;
-    updateDim(isA, Location::INTERIOR, locTarget, Dimension::P);
+    //-- update entry for Point interior
+    updateDim(isPointA, Location::INTERIOR, locTarget, Dimension::P);
+    //-- an empty geometry has no points to infer entries from
+    if (getGeometry(! isPointA).isEmpty())
+      return;
     switch (dimTarget) {
     case Dimension::P:
         return;
@@ -323,8 +329,8 @@ TopologyComputer::addPointOnGeometry(bool isA, Location locTarget, int dimTarget
          * If a point intersects an area target, then the area interior and boundary
          * must extend beyond the point and thus interact with its exterior.
-        updateDim(isA, Location::EXTERIOR, Location::INTERIOR, Dimension::A);
-        updateDim(isA, Location::EXTERIOR, Location::BOUNDARY, Dimension::L);
+        updateDim(isPointA, Location::EXTERIOR, Location::INTERIOR, Dimension::A);
+        updateDim(isPointA, Location::EXTERIOR, Location::BOUNDARY, Dimension::L);
         return;
     throw IllegalStateException("Unknown target dimension: " + std::to_string(dimTarget));
@@ -339,6 +345,10 @@ TopologyComputer::addLineEndOnGeometry(bool isLineA, Location locLineEnd, Locati
     //-- record topology at line end point
     updateDim(isLineA, locLineEnd, locTarget, Dimension::P);
+    if (getGeometry(! isLineA).isEmpty())
+      return;
     //-- Line and Area targets may have additional topology
     case Dimension::P:
diff --git a/tests/unit/operation/relateng/RelateNGTest.cpp b/tests/unit/operation/relateng/RelateNGTest.cpp
index 7e54c71c9..2a4a53156 100644
--- a/tests/unit/operation/relateng/RelateNGTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGTest.cpp
@@ -839,20 +839,21 @@ void object::test<60> ()
 //================  Empty Geometries  ==============
+std::string empties[] = {
+    "POINT EMPTY",
+    "LINESTRING EMPTY",
+    "POLYGON EMPTY",
+    "MULTIPOINT EMPTY",
+    "MULTILINESTRING EMPTY",
+    "MULTIPOLYGON EMPTY",
+    "GEOMETRYCOLLECTION EMPTY"
 //-- test equals against all combinations of empty geometries
 template<>
 template<>
 void object::test<61> ()
-    std::string empties[] = {
-        "POINT EMPTY",
-        "LINESTRING EMPTY",
-        "POLYGON EMPTY",
-        "MULTIPOINT EMPTY",
-        "MULTILINESTRING EMPTY",
-        "MULTIPOLYGON EMPTY",
-        "GEOMETRYCOLLECTION EMPTY"
     int nempty = 7;
     for (int i = 0; i < nempty; i++) {
         for (int j = 0; j < nempty; j++) {
@@ -862,13 +863,51 @@ void object::test<61> ()
             checkEquals(a, b, true);
+// testEmptyNonEmpty
+template<>
+template<>
+void object::test<62> ()
+    std::string nonEmptyPoint = "POINT (1 1)";
+    std::string nonEmptyLine = "LINESTRING (1 1, 2 2)";
+    std::string nonEmptyPolygon = "POLYGON ((1 1, 1 2, 2 1, 1 1))";
+    for (int i = 0; i < 7; i++) {
+        std::string empty = empties[i];
+        checkRelate(empty, nonEmptyPoint, "FFFFFF0F2");
+        checkRelate(nonEmptyPoint, empty, "FF0FFFFF2");
+        checkRelate(empty, nonEmptyLine, "FFFFFF102");
+        checkRelate(nonEmptyLine, empty, "FF1FF0FF2");
+        checkRelate(empty, nonEmptyPolygon, "FFFFFF212");
+        checkRelate(nonEmptyPolygon, empty, "FF2FF1FF2");
+        checkEquals(empty, nonEmptyPoint, false);
+        checkEquals(empty, nonEmptyLine, false);
+        checkEquals(empty, nonEmptyPolygon, false);
+        checkIntersectsDisjoint(empty, nonEmptyPoint, false);
+        checkIntersectsDisjoint(empty, nonEmptyLine, false);
+        checkIntersectsDisjoint(empty, nonEmptyPolygon, false);
+        checkContainsWithin(empty, nonEmptyPoint, false);
+        checkContainsWithin(empty, nonEmptyLine, false);
+        checkContainsWithin(empty, nonEmptyPolygon, false);
+        checkContainsWithin(nonEmptyPoint, empty, false);
+        checkContainsWithin(nonEmptyLine, empty, false);
+        checkContainsWithin(nonEmptyPolygon, empty, false);
 // Prepared test
 template<>
 template<>
-void object::test<62> ()
+void object::test<63> ()
     std::string a = "POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))";
     std::string b = "POLYGON((0.5 0.5, 1.5 0.5, 1.5 1.5, 0.5 1.5, 0.5 0.5))";
diff --git a/tests/xmltester/tests/general/TestRelateEmpty.xml b/tests/xmltester/tests/general/TestRelateEmpty.xml
new file mode 100644
index 000000000..6ed612820
--- /dev/null
+++ b/tests/xmltester/tests/general/TestRelateEmpty.xml
@@ -0,0 +1,1114 @@
+<run>
+  <desc>
+    Test relate predicates against cases containing EMPTY geometries.
+  </desc>
+<!-- ================  POINT ============== -->
+<case>
+  <desc>P/P - empty point VS empty point </desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    POINT EMPTY
+  </b>
+  <test><op name="relate" arg3="FFFFFFFF2" arg1="A" arg2="B"> true </op></test>
+  <test><op name="contains"   arg1="A" arg2="B"> false </op></test>
+  <test><op name="coveredBy"  arg1="A" arg2="B"> false </op></test>
+  <test><op name="covers"     arg1="A" arg2="B"> false </op></test>
+  <test><op name="crosses"    arg1="A" arg2="B"> false </op></test>
+  <test><op name="disjoint"   arg1="A" arg2="B"> true </op></test>
+  <test><op name="equalsTopo" arg1="A" arg2="B"> true </op></test>
+  <test><op name="intersects" arg1="A" arg2="B"> false </op></test>
+  <test><op name="overlaps"   arg1="A" arg2="B"> false </op></test>
+  <test><op name="touches"    arg1="A" arg2="B"> false </op></test>
+  <test><op name="within"     arg1="A" arg2="B"> false </op></test>
+</case>
+<case>
+  <desc>P/L - empty point VS empty line</desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    LINESTRING EMPTY
+  </b>
+</case>
+<case>
+  <desc>P/A - empty point VS empty polygon</desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    POLYGON EMPTY
+  </b>
+</case>
+<case>
+  <desc>P/mP - empty Point VS empty MultiPoint </desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    MULTIPOINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>P/mL - empty Point VS empty MultiLineString</desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    MULTILINESTRING EMPTY
+  </b>
+</case>
+<case>
+  <desc>P/mA - empty Point VS empty MultiPolygon</desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    MULTIPOLYGON EMPTY
+  </b>
+</case>
+<case>
+  <desc>P/GC - empty Point VS empty GC </desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    GEOMETRYCOLLECTION EMPTY
+  </b>
+</case>
+<!-- ================  LINESTRING ============== -->
+<case>
+  <desc>L/P - empty line VS empty point </desc>
+  <a>
+    LINESTRING EMPTY
+  </a>
+  <b>
+    POINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>L/L - empty line VS empty line</desc>
+  <a>
+    LINESTRING EMPTY
+  </a>
+  <b>
+    LINESTRING EMPTY
+  </b>
+</case>
+<case>
+  <desc>L/A - empty line VS empty polygon</desc>
+  <a>
+    LINESTRING EMPTY
+  </a>
+  <b>
+    POLYGON EMPTY
+  </b>
+</case>
+<case>
+  <desc>L/mP - empty line VS empty MultiPoint </desc>
+  <a>
+    LINESTRING EMPTY
+  </a>
+  <b>
+    MULTIPOINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>L/mL - empty line VS empty MultiLineString</desc>
+  <a>
+    LINESTRING EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>L/mA - empty line VS empty MultiPolygon</desc>
+  <a>
+    LINESTRING EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>L/GC - empty line VS empty GC </desc>
+  <a>
+    LINESTRING EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<!-- ================  POLYGON ============== -->
+<case>
+  <desc>A/P - empty polygon VS empty line</desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+  <b>
+    POINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>A/L - empty polygon VS empty line</desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+  <b>
+    LINESTRING EMPTY
+  </b>
+</case>
+<case>
+  <desc>A/A - empty polygon VS empty polygon</desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+  <b>
+    POLYGON EMPTY
+  </b>
+</case>
+<case>
+  <desc>A/mP - empty polygon VS empty MultiPoint </desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+  <b>
+    MULTIPOINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>A/mP - empty polygon VS empty MultiLineString</desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>A/mP - empty polygon VS empty MultiPolygon</desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>A/mP - empty polygon VS empty GC </desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<!-- ================  MULTIPOINT ============== -->
+<case>
+  <desc>mP/P - empty MultiPoint VS empty point </desc>
+  <a>
+    MULTIPOINT EMPTY
+  </a>
+  <b>
+    POINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>mP/L - empty MultiPoint VS empty line</desc>
+  <a>
+    MULTIPOINT EMPTY
+  </a>
+  <b>
+    LINESTRING EMPTY
+  </b>
+</case>
+<case>
+  <desc>mP/A - empty MultiPoint VS empty polygon</desc>
+  <a>
+    MULTIPOINT EMPTY
+  </a>
+  <b>
+    POLYGON EMPTY
+  </b>
+</case>
+<case>
+  <desc>mP/mP - empty MultiPoint VS empty MultiPoint </desc>
+  <a>
+    MULTIPOINT EMPTY
+  </a>
+  <b>
+    MULTIPOINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>mP/mL - empty MultiPoint VS empty MultiLineString</desc>
+  <a>
+    MULTIPOINT EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>mP/mA - empty MultiPoint VS empty MultiPolygon</desc>
+  <a>
+    MULTIPOINT EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>mP/GC - empty MultiPoint VS empty GC </desc>
+  <a>
+    MULTIPOINT EMPTY
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>mL/P - empty Multiline VS empty point </desc>
+  <a>
+  </a>
+  <b>
+    POINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>mL/L - empty Multiline VS empty line</desc>
+  <a>
+  </a>
+  <b>
+    LINESTRING EMPTY
+  </b>
+</case>
+<case>
+  <desc>mL/A - empty Multiline VS empty polygon</desc>
+  <a>
+  </a>
+  <b>
+    POLYGON EMPTY
+  </b>
+</case>
+<case>
+  <desc>mL/mP - empty Multiline VS empty MultiPoint </desc>
+  <a>
+  </a>
+  <b>
+    MULTIPOINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>mL/mL - empty Multiline VS empty MultiLineString</desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>mL/mA - empty Multiline VS empty MultiPolygon</desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>mL/GC - empty Multiline VS empty GC </desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>mA/P - empty Multipolygon VS empty line</desc>
+  <a>
+  </a>
+  <b>
+    POINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>mA/L - empty Multipolygon VS empty line</desc>
+  <a>
+  </a>
+  <b>
+    LINESTRING EMPTY
+  </b>
+</case>
+<case>
+  <desc>mA/A - empty Multipolygon VS empty polygon</desc>
+  <a>
+  </a>
+  <b>
+    POLYGON EMPTY
+  </b>
+</case>
+<case>
+  <desc>mA/mP - empty Multipolygon VS empty MultiPoint </desc>
+  <a>
+  </a>
+  <b>
+    MULTIPOINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>mA/mL - empty Multipolygon VS empty MultiLineString</desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>mA/mA - empty Multipolygon VS empty MultiPolygon</desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>mA/GC - empty Multipolygon VS empty GC </desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>GC/P - empty GC VS empty line</desc>
+  <a>
+  </a>
+  <b>
+    POINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>GC/L - empty GC VS empty line</desc>
+  <a>
+  </a>
+  <b>
+    LINESTRING EMPTY
+  </b>
+</case>
+<case>
+  <desc>GC/A - empty GC VS empty polygon</desc>
+  <a>
+  </a>
+  <b>
+    POLYGON EMPTY
+  </b>
+</case>
+<case>
+  <desc>GC/mP - empty GC VS empty MultiPoint </desc>
+  <a>
+  </a>
+  <b>
+    MULTIPOINT EMPTY
+  </b>
+</case>
+<case>
+  <desc>GC/mL - empty GC VS empty MultiLineString</desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>GC/mA - empty GC VS empty MultiPolygon</desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<case>
+  <desc>GC/GC - empty GC VS empty GC </desc>
+  <a>
+  </a>
+  <b>
+  </b>
+</case>
+<!-- ================  Mixed EMPTY and non-EMPTY ============== -->
+<case>
+  <desc>P/P - empty Point VS Point</desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    POINT (1 1)
+  </b>
+  <test><op name="relate" arg3="FFFFFF0F2" arg1="A" arg2="B"> true </op></test>
+  <test><op name="equalsTopo" arg1="A" arg2="B"> false </op></test>
+</case>
+<case>
+  <desc>P/L - empty Point VS LineString</desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    LINESTRING (1 1, 2 2)
+  </b>
+  <test><op name="relate" arg3="FFFFFF102" arg1="A" arg2="B"> true </op></test>
+</case>
+<case>
+  <desc>P/L - empty Point VS Polygon</desc>
+  <a>
+    POINT EMPTY
+  </a>
+  <b>
+    POLYGON ((1 1, 1 2, 2 1, 1 1))
+  </b>
+  <test><op name="relate" arg3="FFFFFF212" arg1="A" arg2="B"> true </op></test>
+</case>
+</run>
Summary of changes:
 NEWS.md                                           |    2 +-
 src/operation/relateng/TopologyComputer.cpp       |   18 +-
 tests/unit/operation/relateng/RelateNGTest.cpp    |   59 +-
 tests/xmltester/tests/general/TestRelateEmpty.xml | 1114 +++++++++++++++++++++
 4 files changed, 1178 insertions(+), 15 deletions(-)
 create mode 100644 tests/xmltester/tests/general/TestRelateEmpty.xml
hooks/post-receive
More information about the geos-commits
