[geos-commits] [SCM] GEOS branch main updated. 793e19a7d997e05ff817e9741a40f17371ed9276
git at osgeo.org
git at osgeo.org
Fri Oct 25 11:29:06 PDT 2024
the project "GEOS".
The branch, main has been updated
via 793e19a7d997e05ff817e9741a40f17371ed9276 (commit)
from d7c51c401213d11f5dafd56596295274433379b6 (commit)
revisions in full, below.
commit 793e19a7d997e05ff817e9741a40f17371ed9276
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 25 11:28:42 2024 -0700
Warn when Google benchmarks are not found but benchmarks are requested.
diff --git a/benchmarks/algorithm/CMakeLists.txt b/benchmarks/algorithm/CMakeLists.txt
index 8b829c21e..cf89a52e5 100644
--- a/benchmarks/algorithm/CMakeLists.txt
+++ b/benchmarks/algorithm/CMakeLists.txt
@@ -16,6 +16,8 @@ target_link_libraries(perf_interiorpoint_area geos)
add_executable(perf_unaryunion_segments UnaryUnionSegmentsPerfTest.cpp)
target_link_libraries(perf_unaryunion_segments geos)
+if (BUILD_BENCHMARKS)
if (benchmark_FOUND)
add_executable(perf_orientation OrientationIndexPerfTest.cpp
${PROJECT_SOURCE_DIR}/src/algorithm/CGAlgorithmsDD.cpp
@@ -41,6 +43,12 @@ if (benchmark_FOUND)
$<BUILD_INTERFACE:${PROJECT_BINARY_DIR}/include>)
target_link_libraries(perf_voronoi PRIVATE
benchmark::benchmark geos)
+else()
+ MESSAGE(WARNING "Unable to find google benchmarks library!")
+ MESSAGE(WARNING " Some benchmarks will not be built!")
+ MESSAGE(WARNING " See https://github.com/google/benchmark")
+endif()
endif()
add_subdirectory(locate)
diff --git a/benchmarks/algorithm/LineIntersectorPerfTest.cpp b/benchmarks/algorithm/LineIntersectorPerfTest.cpp
index eaa1d7762..151fe5a52 100644
--- a/benchmarks/algorithm/LineIntersectorPerfTest.cpp
+++ b/benchmarks/algorithm/LineIntersectorPerfTest.cpp
@@ -32,8 +32,8 @@ using geos::algorithm::LineIntersector;
template<typename CoordType>
static void BM_PointIntersection(benchmark::State& state) {
- std::size_t n = 1000;
- std::size_t seed = 12345;
+ unsigned int n = 1000;
+ unsigned int seed = 12345;
std::default_random_engine e(seed);
Summary of changes:
benchmarks/algorithm/CMakeLists.txt | 8 ++++++++
benchmarks/algorithm/LineIntersectorPerfTest.cpp | 4 ++--
2 files changed, 10 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
