[geos-commits] [SCM] GEOS branch main updated. 1db7c04d6c0ceafb591f039c0b0b3aead450301c
git at osgeo.org
git at osgeo.org
Wed Oct 30 05:00:25 PDT 2024
the project "GEOS".
The branch, main has been updated
via 1db7c04d6c0ceafb591f039c0b0b3aead450301c (commit)
via 1847c69e750a2b039e0213d19e0cfda75d52e58b (commit)
from 46972ad89a143d01ed3ec9a6c2d91d904a87ab0a (commit)
revisions in full, below.
commit 1db7c04d6c0ceafb591f039c0b0b3aead450301c
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Oct 30 12:19:30 2024 +0100
Fix removal of include directories by `make uninstall`
Closes GH-1189
diff --git a/cmake/cmake_uninstall.cmake.in b/cmake/cmake_uninstall.cmake.in
index 7eab12b3f..ece9ae0a6 100644
--- a/cmake/cmake_uninstall.cmake.in
+++ b/cmake/cmake_uninstall.cmake.in
@@ -43,7 +43,7 @@ endforeach()
message(STATUS "Deleting ${GEOS_INCLUDE_DIR} directory")
execute_process(
- COMMAND "@CMAKE_COMMAND@" -E remove_directory \"${GEOS_INCLUDE_DIR}\"
+ COMMAND "@CMAKE_COMMAND@" -E remove_directory "${GEOS_INCLUDE_DIR}"
OUTPUT_VARIABLE rm_out
RESULT_VARIABLE rm_retval)
commit 1847c69e750a2b039e0213d19e0cfda75d52e58b
Date: Wed Oct 30 08:25:07 2024 +0100
Fix uninstall Makefile rule
Syntax confirmed by
https://gitlab.kitware.com/cmake/community/-/wikis/FAQ#can-i-do-make-uninstall-with-cmake
Closes GH-1187
References GH-1102 when it probably broke
index 749221415..7eab12b3f 100644
@@ -31,7 +31,7 @@ foreach(file ${files})
endif()
execute_process(
- COMMAND "@CMAKE_COMMAND@" -E remove \"$ENV{DESTDIR}${file}\"
+ COMMAND "@CMAKE_COMMAND@" -E remove "$ENV{DESTDIR}${file}"
Summary of changes:
cmake/cmake_uninstall.cmake.in | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
