[geos-commits] [SCM] GEOS branch 3.12 updated. a8474e59b99e763e11ec2b1a16f37d1f744a8151
git at osgeo.org
git at osgeo.org
Tue Sep 3 10:08:06 PDT 2024
the project "GEOS".
The branch, 3.12 has been updated
via a8474e59b99e763e11ec2b1a16f37d1f744a8151 (commit)
from 8fa289cf0146780a0be01e97501589b5a29224c4 (commit)
revisions in full, below.
commit a8474e59b99e763e11ec2b1a16f37d1f744a8151
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Sep 3 10:07:37 2024 -0700
Remove HTML markup to see if deb build gets happier
diff --git a/include/geos/math/DD.h b/include/geos/math/DD.h
index 9f2ea979c..f35ff4a7b 100644
--- a/include/geos/math/DD.h
+++ b/include/geos/math/DD.h
@@ -15,21 +15,21 @@
* Implements extended-precision floating-point numbers
* which maintain 106 bits (approximately 30 decimal digits) of precision.
- * <p>
* A DoubleDouble uses a representation containing two double-precision values.
* A number x is represented as a pair of doubles, x.hi and x.lo,
* such that the number represented by x is x.hi + x.lo, where
- * <pre>
* |x.lo| <= 0.5*ulp(x.hi)
- * </pre>
* and ulp(y) means "unit in the last place of y".
* The basic arithmetic operations are implemented using
* convenient properties of IEEE-754 floating-point arithmetic.
- * <p>
* The range of values which can be represented is the same as in IEEE-754.
* The precision of the representable numbers
* is twice as great as IEEE-754 double precision.
- * <p>
* The correctness of the arithmetic algorithms relies on operations
* being performed with standard IEEE-754 double precision and rounding.
* This is the Java standard arithmetic model, but for performance reasons
@@ -40,9 +40,9 @@
* A JVM implementation may choose to use the non-standard extended-precision
* as its default arithmetic mode.
* To prevent this from happening, this code uses the
- * Java <tt>strictfp</tt> modifier,
+ * Java strictfp modifier,
* which forces all operations to take place in the standard IEEE-754 rounding model.
- * <p>
* The API provides both a set of value-oriented operations
* and a set of mutating operations.
* Value-oriented operations treat DoubleDouble values as
@@ -54,37 +54,35 @@
* It provides optimum memory performance, but requires
* care to ensure that aliasing errors are not created
* and constant values are not changed.
- * <p>
* For example, the following code example constructs three DD instances:
* two to hold the input values and one to hold the result of the addition.
- * <pre>
* DD a = new DD(2.0);
* DD b = new DD(3.0);
* DD c = a.add(b);
- * </pre>
* In contrast, the following approach uses only one object:
- * <pre>
* a.selfAdd(3.0);
- * </pre>
- * <p>
* This implementation uses algorithms originally designed variously by
* Knuth, Kahan, Dekker, and Linnainmaa.
* Douglas Priest developed the first C implementation of these techniques.
* Other more recent C++ implementation are due to Keith M. Briggs and David Bailey et al.
- * <h3>References</h3>
- * <ul>
- * <li>Priest, D., <i>Algorithms for Arbitrary Precision Floating Point Arithmetic</i>,
- * in P. Kornerup and D. Matula, Eds., Proc. 10th Symposium on Computer Arithmetic,
- * IEEE Computer Society Press, Los Alamitos, Calif., 1991.
- * <li>Yozo Hida, Xiaoye S. Li and David H. Bailey,
- * <i>Quad-Double Arithmetic: Algorithms, Implementation, and Application</i>,
- * manuscript, Oct 2000; Lawrence Berkeley National Laboratory Report BNL-46996.
- * <li>David Bailey, <i>High Precision Software Directory</i>;
- * <tt>http://crd.lbl.gov/~dhbailey/mpdist/index.html</tt>
- * </ul>
+ * -- References --
+ * * Priest, D., Algorithms for Arbitrary Precision Floating Point Arithmetic,
+ * in P. Kornerup and D. Matula, Eds., Proc. 10th Symposium on Computer Arithmetic,
+ * IEEE Computer Society Press, Los Alamitos, Calif., 1991.
+ * * Yozo Hida, Xiaoye S. Li and David H. Bailey,
+ * Quad-Double Arithmetic: Algorithms, Implementation, and Application,
+ * manuscript, Oct 2000; Lawrence Berkeley National Laboratory Report BNL-46996.
+ * * David Bailey, High Precision Software Directory;
+ * http://crd.lbl.gov/~dhbailey/mpdist/index.html
* @author Martin Davis
Summary of changes:
include/geos/math/DD.h | 46 ++++++++++++++++++++++------------------------
1 file changed, 22 insertions(+), 24 deletions(-)
hooks/post-receive
More information about the geos-commits
