[geos-commits] [SCM] GEOS branch main updated. 1765c1222357af9c9d255ff536572f8e387470c6
git at osgeo.org
git at osgeo.org
Mon Sep 9 09:29:48 PDT 2024
the project "GEOS".
The branch, main has been updated
via 1765c1222357af9c9d255ff536572f8e387470c6 (commit)
from 1c0840a47ac3c189baff87ca46b105d108363e31 (commit)
revisions in full, below.
commit 1765c1222357af9c9d255ff536572f8e387470c6
Author: Oreille <33065839+Oreilles at users.noreply.github.com>
Date: Mon Sep 9 18:29:27 2024 +0200
Add GEOSGeom_transformXYZ (#1157)
* Add GEOSGeom_transformXYZ
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 834f3ef51..39d34ff5e 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -663,6 +663,12 @@ extern "C" {
+ Geometry*
+ GEOSGeom_transformXYZ(const GEOSGeometry* g, GEOSTransformXYZCallback callback, void* userdata) {
+ return GEOSGeom_transformXYZ_r(handle, g, callback, userdata);
// memory management functions
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 19f0dcb27..2dab4135a 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -284,7 +284,7 @@ typedef int (*GEOSDistanceCallback)(
* Callback function for use in GEOSGeom_transformXY.
* Allows custom function to be applied to x and y values for each coordinate
-* in a geometry. Z values are unchanged by this function.
+* in a geometry. Z and M values are unchanged by this function.
* Extra data for the calculation can be passed via the userdata.
* \param x coordinate value to be updated
@@ -299,6 +299,26 @@ typedef int (*GEOSTransformXYCallback)(
void* userdata);
+* Callback function for use in GEOSGeom_transformXYZ.
+* Allows custom function to be applied to x, y and z values for each coordinate
+* in a geometry. M values are unchanged by this function.
+* Extra data for the calculation can be passed via the userdata.
+* \param x coordinate value to be updated
+* \param y coordinate value to be updated
+* \param z coordinate value to be updated
+* \param userdata extra data for the calculation
+* \return 1 if calculation succeeded, 0 on failure
+typedef int (*GEOSTransformXYZCallback)(
+ double* x,
+ double* y,
+ double* z,
+ void* userdata);
/* ========== Interruption ========== */
@@ -1821,6 +1841,13 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_transformXY_r(
GEOSTransformXYCallback callback,
void* userdata);
+/** \see GEOSGeom_transformXYZ */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_transformXYZ_r(
+ GEOSContextHandle_t handle,
+ const GEOSGeometry* g,
+ GEOSTransformXYZCallback callback,
+ void* userdata);
/* ========= Algorithms ========= */
/** \see GEOSOrientationIndex */
@@ -4696,7 +4723,7 @@ extern int GEOS_DLL GEOSHilbertCode(
* Apply XY coordinate transform callback to all coordinates in a copy of
* input geometry. If the callback returns an error, returned geometry will be
-* NULL. Z values, if present, are not modified by this function.
+* NULL. Z and M values, if present, are not modified by this function.
* \param[in] g Input geometry
* \param[in] callback a function to be executed for each coordinate in the
geometry. The callback takes 3 parameters: x and y coordinate
@@ -4712,6 +4739,25 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_transformXY(
void* userdata);
+* Apply XYZ coordinate transform callback to all coordinates in a copy of
+* input geometry. If the callback returns an error, returned geometry will be
+* NULL. M values, if present, are not modified by this function.
+* \param[in] g Input geometry
+* \param[in] callback a function to be executed for each coordinate in the
+ geometry. The callback takes 4 parameters: x, y and z coordinate
+ values to be updated and a void userdata pointer.
+* \param userdata an optional pointer to pe passed to 'callback' as an argument
+* \return a copy of the input geometry with transformed coordinates.
+* Caller must free with GEOSGeom_destroy().
+* \since 3.13
+extern GEOSGeometry GEOS_DLL *GEOSGeom_transformXYZ(
+ void* userdata);
* Snaps the vertices and segments of the first geometry to vertices of the
* second geometry within the given tolerance.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index ef238229a..b77d872ba 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1655,6 +1655,35 @@ extern "C" {
+ Geometry*
+ GEOSGeom_transformXYZ_r(GEOSContextHandle_t handle, const GEOSGeometry* g, GEOSTransformXYZCallback callback, void* userdata) {
+ struct TransformFilter final: public geos::geom::CoordinateFilter {
+ TransformFilter(GEOSTransformXYZCallback p_callback,
+ void* p_userdata) :
+ m_callback(p_callback),
+ m_userdata(p_userdata) {}
+ void filter_rw(Coordinate* c) const override {
+ if (!m_callback(&(c->x), &(c->y), &(c->z), m_userdata)) {
+ throw std::runtime_error(std::string("Failed to transform coordinates."));
+ GEOSTransformXYZCallback m_callback;
+ void* m_userdata;
+ return execute(handle, [&]() {
+ TransformFilter filter(callback, userdata);
+ auto ret = g->clone();
+ ret->apply_rw(&filter);
+ ret->geometryChanged();
+ return ret.release();
diff --git a/tests/unit/capi/GEOSGeom_transformXYZTest.cpp b/tests/unit/capi/GEOSGeom_transformXYZTest.cpp
new file mode 100644
index 000000000..c696b4da5
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_transformXYZTest.cpp
@@ -0,0 +1,333 @@
+// Test Suite for C-API GEOSGeom_transformXYZ
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include "capi_test_utils.h"
+namespace tut {
+struct test_capi_geosgeom_transformxyz : public capitest::utility {};
+typedef test_group<test_capi_geosgeom_transformxyz> group;
+typedef group::object object;
+group test_capi_geosgeom_transformxyz_group("capi::GEOSGeom_transformXYZ");
+static int SCALE_2_3_4(double* x, double* y, double* z, void* userdata) {
+ (*x) *= 2;
+ (*y) *= 3;
+ (*z) *= 4;
+ (void)(userdata); // make unused parameter warning go away
+ return 1;
+// callback that doesn't update coordinates should return original values
+template <>
+template <>
+void object::test<1>() {
+ GEOSGeometry* geom = GEOSGeomFromWKT("POINT (1 1 1)");
+ GEOSGeometry* out = GEOSGeom_transformXYZ(
+ geom,
+ [](double* x, double* y, double* z, void* userdata) {
+ (void)(x); // make unused parameter warning go away
+ (void)(y); // make unused parameter warning go away
+ (void)(z); // make unused parameter warning go away
+ return 1;
+ nullptr);
+ ensure(out != nullptr);
+ ensure_equals(GEOSEqualsExact(out, geom, 0), 1);
+ GEOSGeom_destroy(geom);
+ GEOSGeom_destroy(out);
+// failed callback should return NULL
+template <>
+template <>
+void object::test<2>() {
+ geom,
+ return 0; // indicates error
+ nullptr);
+ ensure(out == nullptr);
+// callback should modify point coordinates
+template <>
+template <>
+void object::test<3>() {
+ GEOSGeometry* out = GEOSGeom_transformXYZ(geom, SCALE_2_3_4, nullptr);
+ ensure_geometry_equals(out, "POINT (2 3 4)");
+ double xmin, ymin, xmax, ymax;
+ GEOSGeom_getExtent(out, &xmin, &ymin, &xmax, &ymax);
+ ensure_equals(xmin, 2);
+ ensure_equals(ymin, 3);
+ ensure_equals(xmax, 2);
+ ensure_equals(ymax, 3);
+// callback should modify linestring coordinates
+template <>
+template <>
+void object::test<4>() {
+ GEOSGeometry* geom = GEOSGeomFromWKT("LINESTRING (1 1 1, 2 2 2)");
+ ensure_geometry_equals(out, "LINESTRING (2 3 4, 4 6 8)");
+ ensure_equals(xmax, 4);
+ ensure_equals(ymax, 6);
+// callback should modify polygon coordinates
+template <>
+template <>
+void object::test<5>() {
+ "POLYGON ((1 1 1, 1 10 100, 10 10 10, 10 1 .1, 1 1 1), (2 2 2, 2 4 8, 4 4 4, 4 2 1, 2 2 2))");
+ "POLYGON ((2 3 4, 2 30 400, 20 30 40, 20 3 0.4, 2 3 4), (4 6 8, 4 12 32, 8 12 16, 8 6 4, 4 6 8))");
+ ensure_equals(xmax, 20);
+ ensure_equals(ymax, 30);
+// callback should modify multi point coordinates
+template <>
+template <>
+void object::test<6>() {
+ "MULTIPOINT ((1 1 1), (2 2 2))");
+ "MULTIPOINT ((2 3 4), (4 6 8))");
+// callback should modify multi linestring coordinates
+template <>
+template <>
+void object::test<7>() {
+ "MULTILINESTRING ((1 1 1, 2 2 2), (3 3 3, 4 4 4))");
+ "MULTILINESTRING ((2 3 4, 4 6 8), (6 9 12, 8 12 16))");
+// callback should modify multi polygon coordinates
+template <>
+template <>
+void object::test<8>() {
+ "MULTIPOLYGON (((1 1 1, 1 10 100, 10 10 100, 10 1 0.1, 1 1 1), (2 2 2, 2 4 8, 4 4 4, 4 2 1, 2 2 2)), ((0 0 0, 0 100 1000, 100 100 100, 100 0 -100, 0 0 0)))");
+ "MULTIPOLYGON (((2 3 4, 2 30 400, 20 30 40, 20 3 0.4, 2 3 4), (4 6 8, 4 12 16, 8 12 16, 8 6 4, 4 6 8)), ((0 0 0, 0 300 4000, 200 300 400, 200 0 -400, 0 0 0)))");
+// callback should modify geometry collection coordinates
+template <>
+template <>
+void object::test<9>() {
+ "GEOMETRYCOLLECTION (POINT (1 1 1), LINESTRING (1 1 1, 2 2 2), POLYGON ((1 1 1, 1 2 3, 2 2 2, 4 2 1, 1 1 1)))");
+ ensure_geometry_equals(out, "GEOMETRYCOLLECTION (POINT (2 3 4), LINESTRING (2 3 4, 4 6 8), POLYGON ((2 3 4, 2 6 12, 4 6 8, 8 6 4, 2 3 4)))");
+// should not fail for empty geometry
+template <>
+template <>
+void object::test<10>() {
+ GEOSGeometry* geom = GEOSGeomFromWKT("POINT EMPTY");
+ ensure_geometry_equals(out, "POINT EMPTY");
+// should retain original coords even if they collapse to same coordinate
+template <>
+template <>
+void object::test<11>() {
+ geom,
+ *x = 0;
+ *y = 0;
+ *z = 0;
+ return 1;
+ nullptr);
+ ensure_equals(GEOSGetNumCoordinates(out), 2);
+ // Cannot construct WKT for this case, must test coords directly
+ const GEOSCoordSequence* seq = GEOSGeom_getCoordSeq(out);
+ double x, y, z;
+ GEOSCoordSeq_getXYZ(seq, 0, &x, &y, &z);
+ ensure_equals(x, 0);
+ ensure_equals(y, 0);
+ ensure_equals(z, 0);
+ GEOSCoordSeq_getXYZ(seq, 1, &x, &y, &z);
+// should pass through userdata
+template <>
+template <>
+void object::test<12>() {
+ double userdata_scale = 5.0;
+ geom,
+ double scale = *(double *)(userdata);
+ (*x) *= scale;
+ (*y) *= scale;
+ (*z) *= scale;
+ return 1;
+ (void *)(&userdata_scale));
+ ensure_geometry_equals(out, "LINESTRING (5 5 5, 10 10 10)");
+// transform should preserve existing M coordinate values
+template <>
+template <>
+void object::test<13>() {
+ GEOSGeometry* geom = GEOSGeomFromWKT("POINT ZM (1 1 1 5)");
+ ensure_geometry_equals(out, "POINT ZM (2 3 4 5)");
+template <>
+template <>
+void object::test<14>() {
+ input_ = GEOSGeomFromWKT("CIRCULARSTRING Z (0 0 0, 1 1 1, 2 1 0)");
+ ensure(input_);
+ result_ = GEOSGeom_transformXYZ(input_, SCALE_2_3_4, nullptr);
+ ensure_equals(toWKT(result_), "CIRCULARSTRING Z (0 0 0, 2 3 4, 4 3 0)");
+// callback should succed on 2D geometry
+template <>
+template <>
+void object::test<15>() {
+ GEOSGeometry* geom = GEOSGeomFromWKT("POINT (1 1)");
+ ensure_geometry_equals(out, "POINT (2 3)");
+ int dims = GEOSGeom_getCoordinateDimension(geom);
+ ensure_equals(dims, 2);
+} // namespace tut
Summary of changes:
capi/geos_c.cpp | 6 +
capi/geos_c.h.in | 50 ++++++++-
capi/geos_ts_c.cpp | 29 +++++
...ormXYTest.cpp => GEOSGeom_transformXYZTest.cpp} | 125 ++++++++++++---------
4 files changed, 158 insertions(+), 52 deletions(-)
copy tests/unit/capi/{GEOSGeom_transformXYTest.cpp => GEOSGeom_transformXYZTest.cpp} (56%)
hooks/post-receive
More information about the geos-commits
