[geos-commits] [SCM] GEOS branch main updated. d2dcb92e76294ab802bd3d2c26ad5d33d47c06fd
git at osgeo.org
git at osgeo.org
Mon Sep 16 09:31:07 PDT 2024
the project "GEOS".
The branch, main has been updated
via d2dcb92e76294ab802bd3d2c26ad5d33d47c06fd (commit)
from 701c868fa9ad8e82a3aa43f0bd19ec2003722f45 (commit)
revisions in full, below.
commit d2dcb92e76294ab802bd3d2c26ad5d33d47c06fd
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Sep 16 09:30:34 2024 -0700
Fix C API spatial predicate documentation
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 2dab4135a..bd3b3e36c 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4827,7 +4827,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_setPrecision(
-* True if no point of either geometry touchess or is within the other.
+* Tests if two geometries have no point in common.
* \param g1 Input geometry
* \param g2 Input geometry
* \returns 1 on true, 0 on false, 2 on exception
@@ -4837,8 +4837,8 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_setPrecision(
extern char GEOS_DLL GEOSDisjoint(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometries share boundaries at one or more points, but do
-* not have interior overlaps.
+* Tests if two geometries share boundaries at one or more points, but do
+* not have interior points in common.
@@ -4848,7 +4848,7 @@ extern char GEOS_DLL GEOSDisjoint(const GEOSGeometry* g1, const GEOSGeometry* g2
extern char GEOS_DLL GEOSTouches(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometries are not disjoint.
+* Tests if two geometries intersect.
@@ -4858,7 +4858,7 @@ extern char GEOS_DLL GEOSTouches(const GEOSGeometry* g1, const GEOSGeometry* g2)
extern char GEOS_DLL GEOSIntersects(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometries interiors interact but their boundaries do not.
+* Tests if two geometries interiors intersect but their boundaries do not.
* Most useful for finding line crosses cases.
@@ -4869,8 +4869,8 @@ extern char GEOS_DLL GEOSIntersects(const GEOSGeometry* g1, const GEOSGeometry*
extern char GEOS_DLL GEOSCrosses(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometry g1 is completely within g2, and not
-* touching the boundary of g2.
+* Tests if geometry g1 is completely within g2,
+* but not wholly contained in the boundary of g2.
@@ -4880,7 +4880,8 @@ extern char GEOS_DLL GEOSCrosses(const GEOSGeometry* g1, const GEOSGeometry* g2)
extern char GEOS_DLL GEOSWithin(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometry g2 is completely within g1.
+* Tests if geometry g2 is completely within g1,
+* but not wholly contained in the boundary of g1.
@@ -4890,7 +4891,7 @@ extern char GEOS_DLL GEOSWithin(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSContains(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometries share interiors but are neither
+* Tests if two geometries share interiors but are neither
* within nor contained.
@@ -4901,7 +4902,7 @@ extern char GEOS_DLL GEOSContains(const GEOSGeometry* g1, const GEOSGeometry* g2
extern char GEOS_DLL GEOSOverlaps(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometries cover the same space on the plane.
+* Tests if two geometries contain the same set of points in the plane.
@@ -4911,8 +4912,8 @@ extern char GEOS_DLL GEOSOverlaps(const GEOSGeometry* g1, const GEOSGeometry* g2
extern char GEOS_DLL GEOSEquals(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometry g1 is completely within g2, including possibly
+* Tests if geometry g1 covers g2, which is the case
+* if every point of g2 lies in g1.
@@ -4923,8 +4924,8 @@ extern char GEOS_DLL GEOSEquals(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSCovers(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* True if geometry g2 is completely within g1, including possibly
-* touching the boundary of g1.
+* Tests if geometry g1 is covered by g2,
+* which is the case if every point of g1 lies in g2.
@@ -4935,7 +4936,7 @@ extern char GEOS_DLL GEOSCovers(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSCoveredBy(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* Determine pointwise equivalence of two geometries, by
+* Determine pointwise equality of two geometries, by
* checking that they have identical structure
* and that each vertex of g2 is
* within the distance tolerance of the corresponding vertex in g1.
@@ -4957,7 +4958,7 @@ extern char GEOS_DLL GEOSEqualsExact(
double tolerance);
- * Determine pointwise equivalence of two geometries by checking
+ * Determine pointwise equality of two geometries by checking
* that the structure, ordering, and values of all vertices are
* identical in all dimensions. NaN values are considered to be
* equal to other NaN values.
@@ -4974,9 +4975,8 @@ extern char GEOS_DLL GEOSEqualsIdentical(
* Calculate the [DE9IM](https://en.wikipedia.org/wiki/DE-9IM) string for a geometry pair
-* and compare against a DE9IM pattern to check for
-* consistency.
-* If the result matches the pattern return true.
+* and compare against a DE9IM pattern.
+* Returns true if the computed matrix matches the pattern.
* The pattern is a 9-character string
* containing symbols in the set "012TF*".
* "012F" match the corresponding dimension symbol;
Summary of changes:
capi/geos_c.h.in | 38 +++++++++++++++++++-------------------
1 file changed, 19 insertions(+), 19 deletions(-)
hooks/post-receive
More information about the geos-commits
