[geos-commits] [SCM] GEOS branch main updated. b14bac3ba8151bab07823e05c533c6c0de1ec3b3
Tue Sep 24 09:06:57 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  b14bac3ba8151bab07823e05c533c6c0de1ec3b3 (commit)
      from  b3b94d4a5365cddc08372cc45e62a9fb500bfce5 (commit)
revisions in full, below.
commit b14bac3ba8151bab07823e05c533c6c0de1ec3b3
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Sep 24 09:06:39 2024 -0700
    Update README.md
diff --git a/util/geosop/README.md b/util/geosop/README.md
index 3ba3b8e3a..684cdce69 100644
--- a/util/geosop/README.md
+++ b/util/geosop/README.md
@@ -18,7 +18,6 @@ It can be used to:
 * Apply a limit and offset (TBD) to the input geometries
 * collect input geometries into a GeometryCollection (for aggregate operations)
 * Execute a GEOS operation on each geometry
-* TBD: Execute a GEOS operation on each geometry for a list of different arguments
 * Explode result collections into individual geometries
 * Output result as text, WKT or WKB
 * Time the overall and individual performance of each operation
@@ -40,6 +39,8 @@ It can be used to:
   -p, --precision arg  Set number of decimal places in output coordinates
   -q, --quiet          Disable result output
   -r, --repeat arg     Repeat operation N times
+      --select         Select geometries where op result is true
+      --selectNot      Select geometries where op result is false
   -t, --time           Print execution time
   -v, --verbose        Verbose output
   -h, --help           Print help
@@ -59,7 +60,7 @@ It can be used to:
     `geosop -a geoms.wkt -f wkb`
-* Compute the area of geometries in a WKT file and output them as text
+* Compute the areas of geometries in a WKT file and output them as text
     `geosop -a geoms.wkt area`
@@ -77,11 +78,12 @@ It can be used to:
 * Compute the buffer with distance 10 of WKB geometries and output as WKT
-    `geosop -a geoms.wkb -f wkt buffer 10`
+    `geosop -a geoms.wkb buffer 10`
-* To get around cmdline parset limitation for parsing negative numbers, you must replace '-' by 'N'. Same as previous, but compute the buffer with distance -10
+* To get around cmdline parset limitation for parsing negative numbers, you must replace '-' by 'N'.
+  Same as previous, but compute the buffer with distance -10
-    `geosop -a geoms.wkb -f wkt buffer N10`
+    `geosop -a geoms.wkb buffer N10`
 * Compute the unary union of a set of WKT geometries and output as WKB
   * `unaryUnion` is an aggregate operation, so automatically collects all input geometries
@@ -112,14 +114,6 @@ It can be used to:
     `geosop -a some-geom.wkt -b some-other-geom.wkb union`
-* TBD: Compute the buffer of a WKT literal for multiple distances
-    `geosop -a "MULTIPOINT ( (0 0), (10 10) )" buffer 1,2,3,4`
-* TBD: Compute the buffer of a WKT literal and output as WKB, with SRID set to 4326
-    `geosop -a "POINT (10 10)" --srid=4326 -f wkb buffer 10`
 ## Future Ideas
@@ -128,3 +122,12 @@ It can be used to:
 * `--where [eq | gt |ge | lt | le ]:val` filters result geometries by value of operation
 * `--limit N` applies limit to output (used with sorting)
 * `--srid s` sets SRID to s, for WKB output
+* Execute a GEOS operation on each geometry for a list of different arguments
+* Compute the buffer of a WKT literal for multiple distances
+    `geosop -a "MULTIPOINT ( (0 0), (10 10) )" buffer 1,2,3,4`
+* Compute the buffer of a WKT literal and output as WKB, with SRID set to 4326
+    `geosop -a "POINT (10 10)" --srid=4326 -f wkb buffer 10`
Summary of changes:
 util/geosop/README.md | 29 ++++++++++++++++-------------
 1 file changed, 16 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
