[geos-commits] [SCM] GEOS branch 3.13 updated. 3ef3276d9515bed7667e0578a89029a7f2dab6b3
git at osgeo.org
git at osgeo.org
Mon Sep 30 13:10:24 PDT 2024
the project "GEOS".
The branch, 3.13 has been updated
via 3ef3276d9515bed7667e0578a89029a7f2dab6b3 (commit)
from 20b34be0528e5bcb72ffd21f23832c32d6c60c0a (commit)
revisions in full, below.
commit 3ef3276d9515bed7667e0578a89029a7f2dab6b3
Author: Martin Davis <mtnclimb at gmail.com>
Date: Sun Sep 29 18:46:17 2024 -0700
Fix ConcaveHullOfPolygons nested shell handling (#1169)
diff --git a/include/geos/algorithm/hull/ConcaveHullOfPolygons.h b/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
index 861e9a37d..1c99ab9ed 100644
--- a/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
+++ b/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
@@ -124,10 +124,6 @@ private:
std::unique_ptr<Geometry> createEmptyHull();
- static void extractShellRings(
- const Geometry* polygons,
- std::vector<const LinearRing*>& rings);
void buildHullTris();
diff --git a/include/geos/algorithm/hull/OuterShellsExtracter.h b/include/geos/algorithm/hull/OuterShellsExtracter.h
new file mode 100644
index 000000000..ad0a054b0
--- /dev/null
+++ b/include/geos/algorithm/hull/OuterShellsExtracter.h
@@ -0,0 +1,75 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2024 Martin Davis
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <vector>
+namespace geos {
+namespace geom {
+class Coordinate;
+class CoordinateSequence;
+class Envelope;
+class Geometry;
+class GeometryCollection;
+class GeometryFactory;
+class LinearRing;
+class Polygon;
+using geos::geom::Geometry;
+using geos::geom::LinearRing;
+namespace geos {
+namespace algorithm { // geos::algorithm
+namespace hull { // geos::algorithm::hull
+ * Extracts the rings of outer shells from a polygonal geometry.
+ * Outer shells are the shells of polygon elements which
+ * are not nested inside holes of other polygons.
+ * \author Martin Davis
+class OuterShellsExtracter {
+private:
+ OuterShellsExtracter(const Geometry& g);
+ void extractOuterShells(std::vector<const LinearRing*>& outerShells);
+ bool isOuter(const LinearRing& shell, std::vector<const LinearRing*>& outerShells);
+ bool covers(const LinearRing& shellA, const LinearRing& shellB);
+ bool isPointInRing(const LinearRing& shell, const LinearRing& shellRing);
+ static void extractShellRings(const Geometry& polygons, std::vector<const LinearRing*>& shells);
+ static bool envelopeAreaComparator(
+ const LinearRing* g1,
+ const LinearRing* g2);
+ const Geometry& geom;
+public:
+ static void extractShells(const Geometry* polygons, std::vector<const LinearRing*>& shells);
+} // geos::algorithm::hull
+} // geos
diff --git a/src/algorithm/hull/ConcaveHullOfPolygons.cpp b/src/algorithm/hull/ConcaveHullOfPolygons.cpp
index 6ed54fb0a..135ca5acf 100644
--- a/src/algorithm/hull/ConcaveHullOfPolygons.cpp
+++ b/src/algorithm/hull/ConcaveHullOfPolygons.cpp
@@ -13,6 +13,7 @@
#include <geos/algorithm/hull/ConcaveHullOfPolygons.h>
+#include <geos/algorithm/hull/OuterShellsExtracter.h>
#include <geos/geom/Coordinate.h>
#include <geos/geom/Envelope.h>
#include <geos/geom/Geometry.h>
@@ -182,26 +183,11 @@ ConcaveHullOfPolygons::createEmptyHull()
return geomFactory->createPolygon();
-/* private static */
-void
-ConcaveHullOfPolygons::extractShellRings(const Geometry* polygons, std::vector<const LinearRing*>& rings)
- rings.clear();
- for (std::size_t i = 0; i < polygons->getNumGeometries(); i++) {
- const Geometry* consGeom = polygons->getGeometryN(i);
- const Polygon* consPoly = static_cast<const Polygon*>(consGeom);
- const LinearRing* lr = consPoly->getExteriorRing();
- rings.push_back(lr);
- return;
/* private */
void
ConcaveHullOfPolygons::buildHullTris()
- extractShellRings(inputPolygons, polygonRings);
+ OuterShellsExtracter::extractShells(inputPolygons, polygonRings);
std::unique_ptr<Polygon> frame = createFrame(inputPolygons->getEnvelopeInternal());
ConstrainedDelaunayTriangulator::triangulatePolygon(frame.get(), triList);
//System.out.println(tris);
diff --git a/src/algorithm/hull/OuterShellsExtracter.cpp b/src/algorithm/hull/OuterShellsExtracter.cpp
index 000000000..d2152fe54
--- /dev/null
+++ b/src/algorithm/hull/OuterShellsExtracter.cpp
@@ -0,0 +1,123 @@
+ * Copyright (C) 2022 Paul Ramsey <pramsey at cleverelephant.ca>
+#include <geos/algorithm/PointLocation.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Coordinate.h>
+using geos::algorithm::PointLocation;
+using geos::geom::Polygon;
+using geos::geom::CoordinateXY;
+namespace geos {
+namespace hull {
+/* public static */
+void
+OuterShellsExtracter::extractShells(const Geometry* polygons, std::vector<const LinearRing*>& shells)
+ OuterShellsExtracter extracter(*polygons);
+ extracter.extractOuterShells(shells);
+/* private */
+OuterShellsExtracter::OuterShellsExtracter(const geom::Geometry& g)
+ : geom(g)
+/* private */
+void
+OuterShellsExtracter::extractOuterShells(std::vector<const LinearRing*>& outerShells)
+ std::vector<const LinearRing*> shells;
+ extractShellRings(geom, shells);
+ //-- sort shells in order of increasing envelope area
+ std::sort(shells.begin(), shells.end(), envelopeAreaComparator);
+ //-- Scan shells by decreasing area to ensure that shells are added before any nested shells
+ for (auto i = shells.rbegin(); i != shells.rend(); ++i) {
+ const LinearRing* shell = *i;
+ if (outerShells.size() == 0
+ || isOuter(*shell, outerShells)) {
+ outerShells.push_back(shell);
+bool
+OuterShellsExtracter::envelopeAreaComparator(
+ double area1 = g1->getEnvelopeInternal()->getArea();
+ double area2 = g2->getEnvelopeInternal()->getArea();
+ if (area1 < area2)
+ return true;
+ else
+ return false;
+/* private */
+bool
+OuterShellsExtracter::isOuter(const LinearRing& shell, std::vector<const LinearRing*>& outerShells)
+ for (const LinearRing* outShell : outerShells) {
+ if (covers(*outShell, shell)) {
+ return false;
+ return true;
+/* private */
+bool
+OuterShellsExtracter::covers(const LinearRing& shellA, const LinearRing& shellB)
+ //-- if shellB envelope is not covered then shell is not covered
+ if (! shellA.getEnvelopeInternal()->covers(shellB.getEnvelopeInternal()))
+ return false;
+ //-- if a shellB point lies inside shellA, shell is covered (since shells do not overlap)
+ if (isPointInRing(shellB, shellA))
+ return true;
+ return false;
+bool
+OuterShellsExtracter::isPointInRing(const LinearRing& shell, const LinearRing& shellRing)
+ //TODO: optimize this with cached index
+ const CoordinateXY* pt = shell.getCoordinate();
+ return PointLocation::isInRing(*pt, shellRing.getCoordinatesRO());
+void
+OuterShellsExtracter::extractShellRings(const Geometry& polygons, std::vector<const LinearRing*>& shells)
+ shells.clear();
+ for (std::size_t i = 0; i < polygons.getNumGeometries(); i++) {
+ const Geometry* consGeom = polygons.getGeometryN(i);
+ const Polygon* consPoly = static_cast<const Polygon*>(consGeom);
+ const LinearRing* lr = consPoly->getExteriorRing();
+ shells.push_back(lr);
+} // geos
\ No newline at end of file
diff --git a/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp b/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
index 574e2da38..83505123e 100644
--- a/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
+++ b/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
@@ -191,5 +191,27 @@ void object::test<7>()
"POLYGON ((6 9, 8 9, 9 5, 8 0, 6 0, 5 0, 1 0, 1 4, 1 5, 1 9, 5 9, 6 9))");
+// testPolygonHole
+template<>
+template<>
+void object::test<8>()
+ checkHullByLenRatio(
+ "MULTIPOLYGON (((1 1, 10 3, 19 1, 16 8, 19 7, 19 19, 10 20, 8 17, 1 19, 1 1), (3 4, 5 10, 3 16, 9 14, 14 15, 15 9, 13 5, 3 4)))",
+ 0.9,
+ "POLYGON ((10 20, 19 19, 19 7, 19 1, 10 3, 1 1, 1 19, 10 20), (13 5, 15 9, 14 15, 9 14, 3 16, 5 10, 3 4, 13 5))" );
+// testPolygonNestedPoly
+template<>
+template<>
+void object::test<9>()
+ "MULTIPOLYGON (((1 1, 10 3, 19 1, 16 8, 19 7, 19 19, 10 20, 8 17, 1 19, 1 1), (3 4, 5 10, 3 16, 9 14, 14 15, 15 9, 13 5, 3 4)), ((6 10, 7 13, 10 12, 12 13, 13 11, 11 9, 13 8, 9 6, 6 6, 7 8, 6 10)))",
+ 0.9,
+ "MULTIPOLYGON (((10 20, 19 19, 19 7, 19 1, 10 3, 1 1, 1 19, 10 20), (13 5, 15 9, 14 15, 9 14, 3 16, 5 10, 3 4, 13 5)), ((7 13, 10 12, 12 13, 13 11, 11 9, 13 8, 9 6, 6 6, 7 8, 6 10, 7 13)))" );
} // namespace tut
Summary of changes:
.../geos/algorithm/hull/ConcaveHullOfPolygons.h | 4 -
include/geos/algorithm/hull/OuterShellsExtracter.h | 75 +++++++++++++
src/algorithm/hull/ConcaveHullOfPolygons.cpp | 18 +--
src/algorithm/hull/OuterShellsExtracter.cpp | 123 +++++++++++++++++++++
.../algorithm/hull/ConcaveHullOfPolygonsTest.cpp | 22 ++++
5 files changed, 222 insertions(+), 20 deletions(-)
create mode 100644 include/geos/algorithm/hull/OuterShellsExtracter.h
create mode 100644 src/algorithm/hull/OuterShellsExtracter.cpp
hooks/post-receive
More information about the geos-commits
