[geos-commits] [SCM] GEOS branch main updated. df6780c9064909f7a6825e3a798ce56da7394762
Fri Aug 8 17:32:24 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  df6780c9064909f7a6825e3a798ce56da7394762 (commit)
      from  a721f7d4bdf82f00aea13137cac1796d8338dfde (commit)
revisions in full, below.
commit df6780c9064909f7a6825e3a798ce56da7394762
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Aug 8 17:31:50 2025 -0700
    Return a more descriptive error in the exception for CoverageUnion
diff --git a/src/operation/overlayng/CoverageUnion.cpp b/src/operation/overlayng/CoverageUnion.cpp
index 3d860c92a..05cd4d0b3 100644
--- a/src/operation/overlayng/CoverageUnion.cpp
+++ b/src/operation/overlayng/CoverageUnion.cpp
@@ -43,7 +43,14 @@ CoverageUnion::geomunion(const Geometry* coverage)
     else {
         BoundaryChainNoder bcn;
-        result = OverlayNG::geomunion(coverage, nullptr, &bcn);
+        // https://github.com/libgeos/geos/pull/1279#discussion_r2256157484
+        // return a more descriptive exception error
+        try {
+            result = OverlayNG::geomunion(coverage, nullptr, &bcn);
+        catch (const geos::util::TopologyException& te) {
+            throw geos::util::TopologyException("CoverageUnion cannot process incorrectly noded inputs");
     double area_in = coverage->getArea();
diff --git a/tests/unit/capi/GEOSCoverageUnionTest.cpp b/tests/unit/capi/GEOSCoverageUnionTest.cpp
index 59fe3357a..1e0d7d67d 100644
--- a/tests/unit/capi/GEOSCoverageUnionTest.cpp
+++ b/tests/unit/capi/GEOSCoverageUnionTest.cpp
@@ -69,18 +69,8 @@ void object::test<2>
     auto input = GEOSWKTReader_read(m_reader,
         "GEOMETRYCOLLECTION(POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0)), POLYGON ((1 0, 0.9 1, 2 1, 2 0, 1 0)))");
-    // auto input = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION, geoms, 2);
-    // Temporary, wrap in a try/catch block until JTS upstream issue is fixed.
-    try {
-        auto result = GEOSCoverageUnion(input);
-        ensure( result != nullptr );
-        ensure( GEOSEquals(input, result) );
-        GEOSGeom_destroy(result);
-    catch(std::exception& e) {
-        (void)0;
+    auto result = GEOSCoverageUnion(input);
+    ensure( result == nullptr );
     GEOSGeom_destroy(input);
Summary of changes:
 src/operation/overlayng/CoverageUnion.cpp |  9 ++++++++-
 tests/unit/capi/GEOSCoverageUnionTest.cpp | 14 ++------------
 2 files changed, 10 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
