[geos-commits] [SCM] GEOS branch main updated. e308bf7a0dddb6842dc2ac73b5fd5c8a5c599263
git at osgeo.org
git at osgeo.org
Tue Aug 12 16:11:47 PDT 2025
the project "GEOS".
The branch, main has been updated
via e308bf7a0dddb6842dc2ac73b5fd5c8a5c599263 (commit)
from b142156227e2c484f80c62b8cf28b02ada859518 (commit)
revisions in full, below.
commit e308bf7a0dddb6842dc2ac73b5fd5c8a5c599263
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Aug 12 19:11:20 2025 -0400
Add GEOSisSimpleDetail (#1296)
diff --git a/NEWS.md b/NEWS.md
index 78d2c7c24..da909eb34 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -13,6 +13,7 @@
- Add GEOSCoordSeq_createWithDimensions, GEOSCoordSeq_setM, GEOSCoordSeq_getM (GH-1246, Dan Baston)
- Add GEOSGeoJSONWriter_setOutputDimension (GH-1260, Aurele Ferotin)
- Add GEOSGeom_transformXYZ (GH-1157, Aurele Ferotin)
+ - Add GEOSisSimpleDetail (GH-1296, Dan Baston)
- Breaking Changes:
- C++17 is now required (GH-1144)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index e4af7acc9..35d14fd18 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -459,6 +459,12 @@ extern "C" {
return GEOSisSimple_r(handle, g);
+ char
+ GEOSisSimpleDetail(const Geometry* g, int returnAllPoints, Geometry** result)
+ return GEOSisSimpleDetail_r(handle, g, returnAllPoints, result);
char
GEOSisRing(const Geometry* g)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index ee30bb461..e52e2cac4 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1638,6 +1638,13 @@ extern char GEOS_DLL *GEOSisValidReason_r(
GEOSContextHandle_t handle,
const GEOSGeometry* g);
+/** \see GEOSisSimpleDetail */
+extern char GEOS_DLL GEOSisSimpleDetail_r(
+ GEOSContextHandle_t handle,
+ const GEOSGeometry* g,
+ int findAllLocations,
+ GEOSGeometry** location);
/** \see GEOSisValidDetail */
extern char GEOS_DLL GEOSisValidDetail_r(
@@ -3367,6 +3374,25 @@ and geometric quality.
extern char GEOS_DLL GEOSisSimple(const GEOSGeometry* g);
+* In one step, calculate and return whether a geometry is simple
+* and one more more points at which the geometry self-intersects
+* at interior points.
+* Caller has the responsibility to destroy 'location' with
+* GEOSGeom_destroy()
+* \param g The geometry to test
+* \param findAllLocations Whether to return all self-intersection locations, or just one
+* \param locations A pointer in which the location GEOSGeometry will be placed
+* \return 1 when simple, 0 when non-simple, 2 on exception
+* \since 3.14
+extern char GEOS_DLL GEOSisSimpleDetail(
+ GEOSGeometry** locations);
* Check the validity of the provided geometry.
* - All points are valid.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index c00f0aa8f..f4690f04f 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -97,6 +97,7 @@
#include <geos/operation/sharedpaths/SharedPathsOp.h>
#include <geos/operation/union/CascadedPolygonUnion.h>
#include <geos/operation/union/DisjointSubsetUnion.h>
+#include <geos/operation/valid/IsSimpleOp.h>
#include <geos/operation/valid/IsValidOp.h>
#include <geos/operation/valid/MakeValid.h>
#include <geos/operation/valid/RepeatedPointRemover.h>
@@ -1242,6 +1243,29 @@ extern "C" {
+ char
+ GEOSisSimpleDetail_r(GEOSContextHandle_t extHandle, const Geometry* g1, int returnAllPoints, Geometry** result)
+ return execute(extHandle, 2, [&]() {
+ geos::operation::valid::IsSimpleOp iso(g1);
+ iso.setFindAllLocations(returnAllPoints);
+ *result = nullptr;
+ bool simple = iso.isSimple();
+ if (!simple) {
+ auto locations = iso.getNonSimpleLocations();
+ if (locations.size() == 1 || !returnAllPoints) {
+ *result = extHandle->geomFactory->createPoint(locations.front()).release();
+ } else {
+ *result = extHandle->geomFactory->createMultiPoint(locations).release();
+ return simple;
char
GEOSisRing_r(GEOSContextHandle_t extHandle, const Geometry* g)
diff --git a/tests/unit/capi/GEOSisSimpleDetailTest.cpp b/tests/unit/capi/GEOSisSimpleDetailTest.cpp
new file mode 100644
index 000000000..95ce75675
--- /dev/null
+++ b/tests/unit/capi/GEOSisSimpleDetailTest.cpp
@@ -0,0 +1,105 @@
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+struct test_geosissimpledetail_data : public capitest::utility {};
+typedef test_group<test_geosissimpledetail_data> group;
+typedef group::object object;
+group test_geosissimpledetail("capi::GEOSisSimpleDetail");
+template<>
+template<>
+void object::test<1>()
+ set_test_name("simple LineString");
+ input_ = GEOSGeomFromWKT("LINESTRING (0 0, 1 1)");
+ ensure_equals(1, GEOSisSimpleDetail(input_, 0, &result_));
+ ensure(result_ == nullptr);
+template<>
+template<>
+void object::test<2>()
+ set_test_name("LineString with single self-intersection");
+ input_ = GEOSGeomFromWKT("LINESTRING (0 0, 2 2, 1 2, 1 0)");
+ ensure_equals(0, GEOSisSimpleDetail(input_, 0, &result_));
+ ensure_geometry_equals(result_, "POINT (1 1)");
+template<>
+template<>
+void object::test<3>()
+ set_test_name("LineString with multiple self-intersections");
+ input_ = GEOSGeomFromWKT("LINESTRING (2 1, 0 0, 2 2, 1 2, 1 0)");
+ expected_ = GEOSGeomFromWKT("MULTIPOINT (1 1, 1 0.5)");
+ ensure(result_ != nullptr);
+ ensure(GEOSEquals(result_, GEOSGetGeometryN(expected_, 0)) || GEOSEquals(result_, GEOSGetGeometryN(expected_, 1)));
+ GEOSGeom_destroy(result_);
+ ensure_equals(0, GEOSisSimpleDetail(input_, 1, &result_));
+ ensure_geometry_equals(result_, expected_);
+template<>
+template<>
+void object::test<4>()
+ set_test_name("error raised on curved geometry");
+ input_ = fromWKT("CIRCULARSTRING (0 0, 1 1, 2 0)");
+ ensure(input_ != nullptr);
+ ensure_equals(GEOSisSimpleDetail(input_, 0, &result_), 2);
+template<>
+template<>
+void object::test<5>()
+ set_test_name("points are always simple");
+ input_ = GEOSGeomFromWKT("POINT (3 2)");
+template<>
+template<>
+void object::test<6>()
+ set_test_name("empty LineString is simple");
+ input_ = GEOSGeomFromWKT("LINESTRING EMPTY");
+template<>
+template<>
+void object::test<7>()
+ set_test_name("Polygon is non-simple if ring is non-simple");
+ input_ = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 0 1, 1 1, 0 0))");
+ ensure_geometry_equals(result_, "POINT (0.5 0.5)");
+} // namespace tut
Summary of changes:
NEWS.md | 1 +
capi/geos_c.cpp | 6 ++
capi/geos_c.h.in | 26 +++++++
capi/geos_ts_c.cpp | 24 +++++++
tests/unit/capi/GEOSisSimpleDetailTest.cpp | 105 +++++++++++++++++++++++++++++
5 files changed, 162 insertions(+)
create mode 100644 tests/unit/capi/GEOSisSimpleDetailTest.cpp
hooks/post-receive
More information about the geos-commits
